查看: 3056|回復(fù): 0
關(guān)于USART1的調(diào)試
ID:99624 發(fā)表于 2015-12-27 04:15 | 顯示全部樓層 |閱讀模式
2,關(guān)于波特率的設(shè)置
在設(shè)置波特率的時候,通過寫寄存器USART_BRR來實現(xiàn)。USART_BRR1148位為USARTDIV的整數(shù)部分,USART_BRR304位為USARTDIV的小數(shù)部分。如:
設(shè)置USART_BRR=0x01BC,則有,USARTDIV的整數(shù)部分為0x1B=27,USARTDIV的小數(shù)部分為0x0C=12,轉(zhuǎn)換成十進(jìn)制為12/16=0.75。綜上,USARTDIV=27.75。
同理,如果要設(shè)置USARTDIV=25.7,則USART_BRR1140x19,其300.7*16=11.2,取11,即為0x0B。綜上,若要設(shè)置USART_DIV=25.7,則只需設(shè)置USART_BRR=0x19B即可。
在初始化USART之后,發(fā)現(xiàn)串口并沒有數(shù)據(jù)輸出。初始化代碼如下:
#include"stm32f10x.h"
#include"io_control.h"
void GPIO_Config(void);
void USART_Config(void);
int main()
GPIO_Config();
USART_Config();
USART_SendData(USART1,0x41);
  LED4_OFF();
delay(800000);
LED4_ON();
delay(800000);
GPIO_InitTypeDef GPIO_Structure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC,ENABLE);
//LED-->>PC6   U1_TX-->PA9  U1_RX-->>PA10  U2_TX-->>PA2  U2_RX-->>PA3
GPIO_Structure.GPIO_Pin= GPIO_Pin_2|GPIO_Pin_9;
GPIO_Structure.GPIO_Speed= GPIO_Speed_2MHz;
GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_PP;
GPIO_Init(GPIOA,&GPIO_Structure);  //USART_AFIO_Config
GPIO_Structure.GPIO_Pin= GPIO_Pin_3|GPIO_Pin_10;
GPIO_Structure.GPIO_Mode= GPIO_Mode_AF_OD;
GPIO_Structure.GPIO_Pin= GPIO_Pin_6;
GPIO_Structure.GPIO_Mode= GPIO_Mode_Out_PP;
GPIO_Init(GPIOC,&GPIO_Structure); //LED4 Config
USART_InitTypeDef USART_Structure;
RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1,ENABLE);
USART_Structure.USART_BaudRate=115200;
USART_Structure.USART_WordLength=USART_WordLength_8b;
USART_Structure.USART_StopBits=USART_StopBits_1;
USART_Structure.USART_Parity=USART_Parity_No;
USART_Structure.USART_Mode=USART_Mode_Rx|USART_Mode_Tx;
USART_Structure.USART_HardwareFlowControl=USART_HardwareFlowControl_None;
USART_Init(USART1,&USART_Structure);
USART_Cmd(USART1,ENABLE);
對比官方代碼,并沒有大的區(qū)別。因此,推斷是否需要配置時鐘。
問題出現(xiàn)在void USART_Config(void)里面的時鐘使能函數(shù):RCC_APB2PeriphResetCmd(RCC_APB2Periph_USART1,ENABLE);應(yīng)該更改為
RCC_APB2periphClockCmd(RCC_APB2Periph_USART1,ENABLE);
在使用USART_SendData()發(fā)送數(shù)組時,
void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen)
  // Check the parameters
  uint16_t i;
  // Transmit Data
  for(i=0;i<strlen;i++)
  USART_SendData(USARTx, (*point));
//USART_ClearFlag(USARTx,USART_FLAG_TC);
point++;
當(dāng)USART_DR數(shù)據(jù)發(fā)送完成時,TC被置位。此時,需要讀一次USART_SR狀態(tài)寄存器后,再次寫入USART_DR數(shù)據(jù)時,TC被自動清零。在上面的數(shù)組發(fā)送函數(shù)里面,由于沒有讀USART_SR的操作,所以,如果發(fā)送數(shù)組數(shù)據(jù)時,有可能因為發(fā)送時間過快,而TC沒有被清零,所以,導(dǎo)致數(shù)組數(shù)據(jù)發(fā)送不正確。
對其修正后如下:
  uint16_t i;
  // Transmit Data
while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==0);
point++;
事實上,因為讀一次USART_SR然后再寫USART_DR時,TC會自動清零,所以,USART_ClearFlag(USARTx,USART_FLAG_TC)
該語句可以不要。
由于在FW3.5的固件庫里,USART_SendData()函數(shù)里面沒有讀USART_SR的函數(shù):while(USART_GetFlagStatus(USARTx,USART_FLAG_TC)==0);
所以,在連續(xù)調(diào)用USART_SENDDATA(USART1,'A')發(fā)送字符A時,同樣會出現(xiàn)數(shù)據(jù)丟失。如:
USART_SendData(USART1,'A');
delay(1000);
USART_SendData(USART1,'B');
delay(1000);
USART_SendData(USART1,'C');
delay(1000);
加入delay1000)是為了證明數(shù)據(jù)丟失并非因為沒有延時而引起的。當(dāng)連續(xù)調(diào)用發(fā)送單個字符函數(shù)改成:
while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0);
數(shù)據(jù)沒有丟失。因此可以推斷,如果使用USART_SENDDATA()時,必須讀一次USART_SR狀態(tài)寄存器。這里,不適合用USART_ClearFlag(USARTx,USART_FLAG_TC)人為清零。
存在一個問題:
USART_SendData(USART1,'D');
USART_SendData(USART1,'E');
   i=sizeof(tab);
for(k=0;k<i;k++)
  USART_SendData(USART1, tab[k]);
//USART_SendString(USART1,tab,sizeof(tab));
//delay(2000000);
USART_SendData(USART1,'F');
USART_SendData(USART1,'G');
USART_SendData(USART1,'H');
  LED4_OFF();
delay(2000000);
LED4_ON();
delay(2000000);
在發(fā)送完數(shù)組里面的數(shù)據(jù)后,后面的單個發(fā)送不能正確發(fā)送。必須在發(fā)送完數(shù)組后加入一個足夠大的延時,后面的數(shù)據(jù)才能正常發(fā)送。
201251218:26:40
經(jīng)反復(fù)查詢,問題出在sizeof()這個語句中。例如:uchar tab[]="nihao",正常定義是5個字符,但是,在使用sizeof的時候,需要加上一個結(jié)束符,相當(dāng)于sizeoftab)返回的不是5,而是6.所以,在實際運(yùn)行的時候,由于發(fā)送字符串多發(fā)了一個空字符0x00,這個與后面的字符一起發(fā)送的時候,會被認(rèn)為是漢字組合,結(jié)果就導(dǎo)致后面發(fā)送的FGH不能正常發(fā)送。
修改后如下:(將while(USART_GetFlagStatus(USART1,USART_FLAG_TC)==0);放到USART_SENDDATA()函數(shù)里面,從而在USART_SENDSTRING()里面可以不要;另外,將sizeof返回的數(shù)值減1.
uint8_t tab[]="你現(xiàn)在還好嗎?是否過著你想要的生活?周華健";
void USART_SendString(USART_TypeDef* USARTx,uint8_t *point, uint16_t strlen);
int main()
//uint16_t i,k;
GPIO_Config();
USART_Config();
USART_SendString(USART1,tab,sizeof(tab)-1);
  LED4_OFF();
delay(2000000);
LED4_ON();
delay(2000000);
  uint16_t i;
  // Transmit Data
  point++;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOC|RCC_APB2Periph_AFIO,ENABLE);
RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1,ENABLE);
RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART2,ENABLE);
USART_Init(USART2,&USART_Structure);
USART_Cmd(USART2,ENABLE);
