//LED8*8滾動(dòng)顯示
//列掃描,低電平有效
//包含頭文件
#include <reg52.h>
#include "74HC595.H"
#include<intrins.h> //包含_nop_()函數(shù)定義的頭文件
//全局變量定義
unsigned char i,flag,t,w,t;
unsigned int m,n;
unsigned char t1,t2,t3,t4;
//代碼庫(kù)
#define num sizeof(buff) //代碼長(zhǎng)度
unsigned char code aa[]={0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
unsigned char code table2[]={
0x60,0x60,0x00,0x3E,0x7F,0x41,0x7F,0x3E,/*"0",0*/
0x60,0x60,0x00,0x42,0x7F,0x7F,0x40,0x00,/*"1",1*/
0x60,0x60,0x00,0x62,0x73,0x59,0x4F,0x46,/*"2",2*/
0x60,0x60,0x00,0x22,0x6B,0x49,0x7F,0x36,/*"3",3*/
0x60,0x60,0x00,0x38,0x3E,0x7F,0x7F,0x20,/*"4",4*/
0x60,0x60,0x00,0x4F,0x4F,0x49,0x79,0x31,/*"5",5*/
0x60,0x60,0x00,0x3E,0x7F,0x49,0x7B,0x32,/*"6",6*/
0x60,0x60,0x00,0x03,0x73,0x79,0x0F,0x07,/*"7",7*/
0x60,0x60,0x00,0x36,0x7F,0x49,0x7F,0x36,/*"8",8*/
0x60,0x60,0x00,0x26,0x6F,0x49,0x7F,0x3E,/*"9",9*/
unsigned char code table1[]= {
//取模方式 陰碼 列掃描 逆向
0x00,0x3E,0x7F,0x41,0x7F,0x3E,0x00,0x00,/*"0",0*/
0x00,0x42,0x7F,0x7F,0x40,0x00,0x00,0x00,/*"1",1*/
0x00,0x62,0x73,0x59,0x4F,0x46,0x00,0x00,/*"2",2*/
0x00,0x22,0x6B,0x49,0x7F,0x36,0x00,0x00,/*"3",3*/
0x00,0x38,0x3E,0x7F,0x7F,0x20,0x00,0x00,/*"4",4*/
0x00,0x4F,0x4F,0x49,0x79,0x31,0x00,0x00,/*"5",5*/
0x00,0x3E,0x7F,0x49,0x7B,0x32,0x00,0x00,/*"6",6*/
0x00,0x03,0x73,0x79,0x0F,0x07,0x00,0x00,/*"7",7*/
0x00,0x36,0x7F,0x49,0x7F,0x36,0x00,0x00,/*"8",8*/
0x00,0x26,0x6F,0x49,0x7F,0x3E,0x00,0x00,/*"9",9*/
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",10*/
unsigned char buff[]={
0x00,0x03,0x03,0x3E,0x7F,0x41,0x63,0x22,/*"C",0*/
以下是DS18B20的操作程序
sbit DQ=P3^3;
unsigned char time; //設(shè)置全局變量,專(zhuān)門(mén)用于嚴(yán)格延時(shí)
函數(shù)功能:將DS18B20傳感器初始化,讀取應(yīng)答信號(hào)
出口參數(shù):flag
bit Init_DS18B20(void)
bit flag; //儲(chǔ)存DS18B20是否存在的標(biāo)志,flag=0,表示存在;flag=1,表示不存在
DQ = 1; //先將數(shù)據(jù)線拉高
for(time=0;time<2;time++) //略微延時(shí)約6微秒
DQ = 0; //再將數(shù)據(jù)線從高拉低,要求保持480~960us
for(time=0;time<200;time++) //略微延時(shí)約600微秒
; //以向DS18B20發(fā)出一持續(xù)480~960us的低電平復(fù)位脈沖
DQ = 1; //釋放數(shù)據(jù)線(將數(shù)據(jù)線拉高)
for(time=0;time<10;time++)
; //延時(shí)約30us(釋放總線后需等待15~60us讓DS18B20輸出存在脈沖)
flag=DQ; //讓單片機(jī)檢測(cè)是否輸出了存在脈沖(DQ=0表示存在)
for(time=0;time<200;time++) //延時(shí)足夠長(zhǎng)時(shí)間,等待存在脈沖輸出完畢
return (flag); //返回檢測(cè)成功標(biāo)志
函數(shù)功能:從DS18B20讀取一個(gè)字節(jié)數(shù)據(jù)
出口參數(shù):dat
unsigned char ReadOneChar(void)
unsigned char i=0;
unsigned char dat; //儲(chǔ)存讀出的一個(gè)字節(jié)數(shù)據(jù)
for (i=0;i<8;i++)
DQ =1; // 先將數(shù)據(jù)線拉高
_nop_(); //等待一個(gè)機(jī)器周期
DQ = 0; //單片機(jī)從DS18B20讀書(shū)據(jù)時(shí),將數(shù)據(jù)線從高拉低即啟動(dòng)讀時(shí)序
dat>>=1;
DQ = 1; //將數(shù)據(jù)線"人為"拉高,為單片機(jī)檢測(cè)DS18B20的輸出電平作準(zhǔn)備
; //延時(shí)約6us,使主機(jī)在15us內(nèi)采樣
if(DQ==1)
dat|=0x80; //如果讀到的數(shù)據(jù)是1,則將1存入dat
dat|=0x00;//如果讀到的數(shù)據(jù)是0,則將0存入dat
//將單片機(jī)檢測(cè)到的電平信號(hào)DQ存入r[i]
for(time=0;time<8;time++)
; //延時(shí)3us,兩個(gè)讀時(shí)序之間必須有大于1us的恢復(fù)期
return(dat); //返回讀出的十進(jìn)制數(shù)據(jù)
函數(shù)功能:向DS18B20寫(xiě)入一個(gè)字節(jié)數(shù)據(jù)
入口參數(shù):dat
WriteOneChar(unsigned char dat)
unsigned char i=0;
for (i=0; i<8; i++)
DQ=0; //將數(shù)據(jù)線從高拉低時(shí)即啟動(dòng)寫(xiě)時(shí)序
DQ=dat&0x01; //利用與運(yùn)算取出要寫(xiě)的某位二進(jìn)制數(shù)據(jù),
//并將其送到數(shù)據(jù)線上等待DS18B20采樣
;//延時(shí)約30us,DS18B20在拉低后的約15~60us期間從數(shù)據(jù)線上采樣
DQ=1; //釋放數(shù)據(jù)線
for(time=0;time<1;time++)
;//延時(shí)3us,兩個(gè)寫(xiě)時(shí)序間至少需要1us的恢復(fù)期
dat>>=1; //將dat中的各二進(jìn)制位數(shù)據(jù)右移1位
for(time=0;time<4;time++)
; //稍作延時(shí),給硬件一點(diǎn)反應(yīng)時(shí)間
void ReadyReadTemp(void)
Init_DS18B20(); //將DS18B20初始化
WriteOneChar(0xCC); // 跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
for(time=0;time<100;time++)
; //溫度轉(zhuǎn)換需要一點(diǎn)時(shí)間
WriteOneChar(0xCC); //跳過(guò)讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器,前兩個(gè)分別是溫度的低位和高位
//顯示函數(shù)
void Display(void)
if(flag==2){
Ser_IN((aa[i])); //列掃描數(shù)據(jù)
Ser_IN(buff[i + n]); //查表取出行掃描數(shù)據(jù)
Par_OUT(); //輸出顯示
i++; if(i == 8) i = 0; //循環(huán)掃描
m++; if(m == 100) {m = 0; n++;} //滾動(dòng)速度控制
if(n == num-7)
n = 0; //循環(huán)顯示
flag=1;
//定時(shí)器初始化
void T_init(void)
TMOD = 0x11;
TH0 = 0xfc; //1MS
TL0 = 0x66;
EA = 1; //允許CPU中斷
ET0 = 1; //定時(shí)器0中斷打開(kāi)
TR0 = 1;
//定時(shí)器中斷服務(wù)
void T0_intservice(void) interrupt 1 using 0
TH0 = 0xfc;
TL0 = 0x66;
Display();
//主函數(shù)
void main (void)
unsigned char TL; //儲(chǔ)存暫存器的溫度低位
unsigned char TH; //儲(chǔ)存暫存器的溫度高位
unsigned char TN; //儲(chǔ)存溫度的整數(shù)部分
unsigned char TD; //儲(chǔ)存溫度的小數(shù)部分
flag=1;
T_init();
while(1){
if(flag==1){
ReadyReadTemp(); //讀溫度準(zhǔn)備
TL=ReadOneChar(); //先讀的是溫度值低位
TH=ReadOneChar(); //接著讀的是溫度值高位
TN=TH*16+TL/16; //實(shí)際溫度值=(TH*256+TL)/16,即:TH*16+TL/16
//這樣得出的是溫度的整數(shù)部分,小數(shù)部分被丟棄了
TD=(TL%16)*10/16; //計(jì)算溫度的小數(shù)部分,將余數(shù)乘以10再除以16取整,
t1=TN/100; //取百位
t2=(TN%100)/10; //取十位
t3=TN%10; //取個(gè)位
t4=TD;
flag=0;
if(flag==0){
for(w=1;w<6;w++){
if(w==5){
flag=2;
for(t=0;t<8;t++){
switch(w){
case 1:
buff[t+(8*w)]=table1[(8*t1)+t];
break;
case 2:
buff[t+(8*w)]=table1[(8*t2)+t];
break;
case 3:
buff[t+(8*w)]=table1[(8*t3)+t];
break;
case 4:
buff[t+(8*w)]=table2[(8*t4)+t];
break;
