印字 器件 廠商 類型 封裝 器件用途及參數(shù)
-28 PDTA114WU Phi N SOT323 pnp dtr
-24 PDTC114TU Phi N SOT323 npn dtr R1 10k
-23 PDTA114TU Phi N SOT323 pnp dtr R1 10k
-20 PDTC114WU Phi N SOT323 npn dtr
-6 PMSS3906 Phi N SOT323 2N3906
-4 PMSS3904 Phi N SOT323 2N3904
0 2SC3603 Nec CX SOT173 Npn RF fT 7GHz
1 Gali-1 MC AZ SOT89 DC-8GHz MMIC amp 12dB gain
1 2SC3587 Nec CX - npn RF fT10GHz
1 BA277 Phi I SOD523 VHF Tuner band switch diode
2 BST82 Phi M - n-ch mosfet 80V 175mA
2 MRF5711L Mot X SOT143 npn RF MRF571
2 DTCC114T Roh N - 50V 100mA npn sw + 10k base res
2 Gali-2 MC AZ SOT89 DC-8GHz MMIC amp 16dB gain
2 BAT62-02W Sie I SCD80 BAT16 schottky diode
2 2SC3604 Nec CX - npn RF fT8GHz 12dB@2GHz
3 Gali-3 MC AZ SOT89 DC-3GHz MMIC amp 22dB gain
3 DTC143TE Roh N EMT3 npn dtr R1 4k7 50V 100mA
3 DTC143TUA Roh N SC70 npn dtr R1 4k7 50V 100mA
3 DTC143TKA Roh N SC59 npn dtr R1 4k7 50V 100mA
3 BAT60A Sie I SOD323 10V 3A sw schottky
3 BAT62-02W Sie I SCD80 -
4 DTC114TCA Roh N SOT23 npn dtr R1 10k 50V 100mA
4 DTC114TE Roh N EMT3 npn dtr R1 10k 50V 100mA
4 DTC114TUA Roh N SC70 npn dtr R1 10k 50V 100mA
4 DTC114TKA Roh N SC59 npn dtr R1 10k 50V 100mA
4 MRF5211L Mot X SOT143 pnp RF MRF521
4 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 17.5 dBm
4 BB664 Sie I SCD80 Varicap 42-2.5pF
5 SSTPAD5 Sil J - PAD-5 5pA leakage diode
5 Gali-4 MC AZ SOT89 DC-4GHz MMIC amp 18 dBm o/p
5 DTC124TE Roh N EMT3 npn dtr R1 22k 50V 100mA
5 DTC124TUA Roh N SC70 npn dtr R1 22k 50V 100mA
5 DTC124TKA Roh N SC59 npn dtr R1 22k 50V 100mA
6 Gali-6 MC AZ SOT89 DC-4GHz MMIC amp 115 dBm o/p
6 DTC144TE Roh N EMT3 npn dtr R1 47k 50V 100mA
6 DTC144TUA Roh N SC70 npn dtr R1 47k 50V 100mA
6 DTC144TKA Roh N SC59 npn dtr R1 47k 50V 100mA
9 DTC115TUA Roh N SC70 npn dtr R2 100k 50V 100mA
9 DTC115TKA Roh N SC59 npn dtr R2 100k 50V 100mA
9 BC849 Mot N SOT23 BC 549B
10 SSTPAD10 Sil J - PAD-10 10pA leakage diode
10 MRF9411L Mot X SOT143 npn Rf 8GHz MRF941
11 SO2369R SGS R SOT23R 2N2369
11 MRF9511L Mot X SOT143 npn RF 8GHz MRF951
11 MUN5311DW1 Mot DP SOT363 npn/pnp dtr 10k+10k
11 PDTA114EU Phi N SOT416 pnp dtr
12 MUN5312DW1 Mot DP SOT363 npn/pnp dtr 22k+22k
12 DTA123EUA Rho N SC70 pnp dtr 2k2+2k2 50V 100ma
12 DTA123EKA Rho N SC59 pnp dtr 2k2+2k2 res 50V 100ma
13 DTA143EUA Rho N SC70 pnp dtr 4k7+4k7 50V 100ma
13 DTA143EKA Rho N SC59 pnp dtr 4k7+4k7 50V 100ma
13 DTA143ECA Rho N SOT23 pnp dtr 4k7+4k7 50V 100ma
13 MA4CS103A M/A C SOT23 Schottky RF 20V 100mA
13 MUN5313DW1 Mot DP SOT363 npn/pnp dtr 47k+47k
14 BAT114-099R Sie DQ - Quad Schottky crossover ring
14 DTA114EUA Roh N SC70 pnp dtr 10k + 10k
14 DTA114EKA Roh N SC59 pnp dtr 10k + 10k
14 MUN5314DW1 Mot DP SOT363 npn/pnp dtr 10k R1
14 DTA114ECA Roh N SOT23 pnp dtr 10k + 10k
15 DTA124EUA Roh N SC70 pnp dtr 30V 50mA 22k+22k
15 DTA124EKA Roh N SC59 pnp dtr 30V 50mA 22k+22k
15 DTA124ECA Roh N SOT23 pnp dtr 30V 50mA 22k+22k
15 MUN5315DW1 Mot DP SOT363 npn/pnp dtr 10k R1
15 MMBT3960 Mot N - 2N3960
16 MUN5316DW1 Mot DP SOT363 npn/pnp dtr 4k7 R1
16 DTA144EUA Roh N SC70 pnp dtr 30V 50mA 47k+47k
16 DTA144EKA Roh N SC59 pnp dtr 30V 50mA 47k+47k
18 BFP181T Tfk X - npn Rf fT 7.8GHz 10V 20mA
18 PDTC143ZK Phi N SOT346 npn dtr 4k7+47k
19 PDTA143ZK Phi N SOT346 pnp dtr 4k7+47k
19 DTA115EUA Rho N SC70 pnp dtr 100k+100k 50V 100ma
19 DTA115EKA Rho N SC59 pnp dtr 100k+100k 50V 100ma
20 SSTPAD20 Sil J - PAD-20 20pA leakage diode
20 MRF5811 Mot X SOT143 npn Rf fT 5GHz 0.2A
21 Gali-21 MC AZ SOT89 DC-8GHz MMIC amp 14 dB gain
22 MMBT4209 Nat N SOT23 pnp sw 850MHz 2N4209
22 DTC123EUA Rho N SC70 npn dtr 2k2+2k2 50V 100ma
22 DTC123EKA Rho N SC59 npn dtr 2k2+2k2 50V 100ma
23 MMBT3646 Nat N SOT23 npn sw 350MHz 2N3646
23 DTC143EUA Roh N SC70 pnp dtr 50V 100mA 4k7+ 4k7
23 DTC143EKA Roh N SC59 pnp dtr 50V 100mA 4k7+ 4k7
24 MMBD2101 Nat C SOT23 Si diode 100V 200mA
24 DTC114ECA Roh N SOT23 npn dtr 50V 100mA 10k + 10k
24 DTC114EUA Roh N SC70 npn dtr 50V 100mA 10k + 10k
24 DTC114EKA Roh N SC59 npn dtr 50V 100mA 10k + 10k
24 2SC5006 Nec N - npn RF fT 4.5GHz @3V 7mA
25 MMBD2102 Nat K SOT23 Si diode 100V 200mA
25 DTC124ECA Roh N SOT23 npn dtr 50V 100mA 22k + 22k
25 DTC124EKA Roh N SC59 npn dtr 50V 100mA 22k + 22k
25 DTC124EUA Roh N SC70 npn dtr 50V 100mA 22k + 22k
26 MMBD2103 Nat D SOT23 dual MMBD1201
26 DTC144EKA Roh N SC59 npn dtr 50V 30mA 47k + 47k
26 DTC144EUA Roh N SC70 npn dtr 50V 30mA 47k + 47k
27 MMBD2104 Nat B SOT23 dual cc MMBD1201
28 BFP280T Tfk W - npn RF fT 7GHz 8V 10mA
28 MMBD2105 Nat A SOT23 dual ca MMBD1201
29 MMBD1401 Nat C SOT23 Si diode 200V 100mA
29 DTC115EE Roh N EMT3 npn dtr 100k +100k 50V 20mA
29 DTC115EUA Roh N SC70 npn dtr 100k +100k 50V 20mA
29 DTC115EKA Roh N SC59 npn dtr 100k +100k 50V 20mA
30 MUN5330DW1 Mot DP SOT363 npn/pnp dtr 1k0+1k0
31 MUN5331DW1 Mot DP SOT363 npn/pnp dtr 2k2+2k2
31 MMBD1402 Nat K SOT23 Si diode 200V 100mA
32 MUN5332DW1 Mot DP SOT363 npn/pnp dtr 4k7+4k7
32 MMBD1403 Nat D SOT23 dual Si diode 200V 100mA
32 BAT32 Sie CS - 18GHz zero-bias schottky
33 MUN5333DW1 Mot DP SOT363 npn/pnp dtr 4k7+47k
33 DTA143XE Roh N EMT3 pnp dtr 4k7+10k 50V 100mA
33 DTA143XUA Roh N SC70 pnp sw 4k7+10k bias res 50V 100mA
33 DTA143XKA Roh N SC59 pnp sw 4k7+10k bias res 50V 100mA
33 MMBD1404 Nat B SOT23 dual cc Si diode 200V 100mA
33 Gali-33 MC AZ SOT89 DC-4GHz MMIC amp 19dB gain
34 MUN5334DW1 Mot DP SOT363 npn/pnp dtr 22k+47k
34 MMBD1405 Nat A SOT23 dual ca Si diode 200V 100mA
34 2SC5007 Nec N - npn RF fT 7GHz @3V 7mA
35 MUN5335DW1 Mot DP SOT363 npn/pnp dtr 2k2+47k
35 DTA124XE Roh N EMT3 pnp dtr 22k+47k 50V 50mA
35 DTA124XUA Roh N SC70 pnp dtr 22k+47k 50V 50mA
35 DTA124XKA Roh N SC59 pnp dtr 22k+47k 50V 50mA
41 BAT14-115S Sie CS SOT173 40GHz schottky diode
41 BAT14-115R Sie CZ SOT173 40GHz schottky ring quad
42 BAT14-025S Sie CS SOT173 4GHz schottky diode
42 BAT14-025R Sie CZ SOT173 4GHz schottky ring quad
43 BAS40 Sie C SOT23 schottky diode 40V 100mA
43 DTA143EE Mot N SOT416 pnp dtr 4k7 + 4k7
43 DTC143XE Roh N EMT3 npn dtr 4k7+10k 50V 100mA
43 DTC143XUA Roh N SC70 npn dtr 4k7+10k 50V 100mA
43 DTC143XKA Roh N SC59 npn dtr 4k7+10k 50V 100mA
44 BAS40-04 Sie D SOT23 dual series BAS40
44 BAS40-04W Sie D SOT323 dual series BAS40
44 2SC5009 Nec N - npn RF fT 12GHz @3V 5mA
45 BAS40-05 Sie A SOT23 dual ca BAS40
45 BAS40-05W Sie A SOT323 dual ca BAS40
45 BAT14-055S Sie CS SOT173 8GHz schottky diode
45 BAT14-055R Sie CZ SOT173 8GHz schottky ring quad
45 DTC124XE Roh N EMT3 npn dtr 22k+47k 50V 50mA
45 DTC124XUA Roh N SC70 npn dtr 22k+47k 50V 50mA
45 DTC124XKA Roh N SC59 npn dtr 22k+47k 50V 50mA
46 BAS40-06 Sie B SOT23 dual cc BAS40
46 BAS40-06W Sie B SOT323 dual cc BAS40
46 MBT3946DW Mot DP - 2N3904/2N3906 pair
47 BAS40-07 Sie S SOT143 dual BAS40
47 BAS40-07W Sie S SOT343 dual BAS40
49 BAT14-095S Sie CS SOT173 18GHz shottky diode
49 BAT14-095R Sie CZ SOT173 18GHz schottky ring quad
50 SSTPAD50 Sil J - PAD-50 50pA leakage diode
51 BAT15-115S Sie CS SOT173 40GHz schottky diode
51 BAT15-115R Sie CZ SOT173 40GHz schottky ring quad
52 BAT15-025S Sie CS SOT173 4GHz schottky diode
52 BAT15-025R Sie CZ SOT173 4GHz schottky ring quad
52 Gali-52 MC AZ SOT89 DC-2GHz MMIC amp 23 dB gain
52 BAS52-02V Inf I SC79 Schottky diode 45V 750mA
52 DTA123YE Roh N EMT3 pnp dtr 2k2 +10k 50V 100mA
52 DTA123YUA Roh N SC70 pnp dtr 2k2 +10k 50V 100mA
52 DTA123YKA Roh N SC59 pnp dtr 2k2 +10k 50V 100mA
54 DTA114YE Roh N EMT3 pnp dtr 10k + 47k 50V 100mA
54 DTA114YUA Roh N SC70 pnp dtr 10k + 47k 50V 100mA
54 DTA114YKA Roh N SC59 pnp dtr 10k + 47k 50V 100mA
55 BAT15-055S Sie CS SOT173 8GHz schottky diode
55 BAT15-055R Sie CZ SOT173 8GHz schottky ring quad
55 Gali-55 MC AZ SOT89 DC-4GHz MMIC amp 21 dB gain
57 BFQ57 Sie CX SOT173 npn 6.5GHz 16V/35mA
58 BFQ58 Sie CX SOT173 npn 6.5GHz 16V/30mA
59 BAT15-095S Sie CS SOT173 18GHz schottky diode
59 BAT15-095R Sie CZ SOT173 18GHz schottky ring quad
62 DTC123YE Roh N EMT3 npn dtr 2k2 +10k 50V 100mA
62 DTC123YUA Roh N SC70 npn dtr 2k2 +10k 50V 100mA
62 DTC123YKA Roh N SC59 npn dtr 2k2 +10k 50V 100mA
64 DTC114YE Roh N EMT3 npn dtr 10k + 47k 50V 100mA
64 DTC114YUA Roh N SC70 npn dtr 10k + 47k 50V 100mA
64 DTC114YKA Roh N SC59 npn dtr 10k + 47k 50V 100mA
67 BFP67 Tfk X - npn Rf fT 7.5GHz 10V 50mA
69 DTA114YE Mot N SOT416 pnp dtr 10k +47k
69 DTC115EE Roh N EMT3 npn dtr 100k+100k 50V 20mA
69 DTC115EUA Roh N SC70 npn dtr 100k+100k 50V 20mA
69 DTC115EKA Roh N SC59 npn dtr 100k+100k 50V 20mA
70 BFQ70 Sie CX SOT173 npn fT 5.2GHz 15V 35mA
71 BFQ71 Sie CX SOT173 npn fT 5.2GHz 15V 30mA
72 BFQ72 Sie CX SOT173 npn fT 5.1GHz 15V 50mA
72 2N7002 Sil M SOT23 n-ch mosfet 60V 170mA
73 MA4CS101A M/A C SOT23 schottky diode 70V 50mA
73 BFQ73 Sie CX SOT173 npn fT 4.9GHz 15V 75mA
73 2SC5004 Nec N - npn RF 5GHz @5V 5mA
74 BFQ74 Sie CX SOT173 npn fT 6GHz 16V 35mA
74 MA4CS101B M/A D SOT23 dual series MA4CS101A (73)
74 DTA114WE Rho N EMT3 pnp dtr 10k + 4k7 50V 100mA
74 DTA114WUA Rho N SC70 pnp dtr 10k + 4k7 50V 100mA
74 DTA114WKA Rho N SC59 pnp dtr 10k + 4k7 50V 100mA
74 2SC5005 Nec N - npn RF 5.5GHz @5V 5mA
75 BFQ75 Sie CX SOT173 pnp fT 5GHz 12V 50mA
76 BFQ76 Sie CX SOT173 pnp fT 5GHz 15V 30mA
76 DTA144WE Rho N EMT3 pnp dtr 47k + 22k 50V 30mA
76 DTA144WUA Rho N SC70 pnp dtr 47k + 22k 50V 30mA
76 DTA144WKA Rho N SC59 pnp dtr 47k + 22k 50V 30mA
77 MA4CS101E M/A S SOT143 dual MA4CS101A (73)
77 BFQ77 Sie CX SOT173 npn fT 7GHz 15V 20mA
78 MMBT4258 Nat N SOT23 pnp sw fT 700MHz
81 SO2369AR SGS R SOT23R 2N2369A
81 ZMV831BV2 Zet I SOD523 28V hyperabrupt varicap 15pF @2V
82 2SC5009 Nec N - npn RF fT 12GHz @ 3V 5mA
82 ZMV832BV2 Zet I SOD523 28V hyperabrupt varicap 22pF @2V
83 MMBT4400 Nat N - npn 2N4400
83 2SC5010 Nec N - npn RF fT 12GHz 3V 10mA
83 MA4CS102A M/A C SOT23 schottky diode 8V 30mA
84 MA4CS102B M/A D SOT23 dual ser schottky diode 8V 30mA
84 DTC114WE Rho N EMT3 npn dtr 10k + 4k7 50V 100mA
84 DTC114WUA Rho N SC70 npn dtr 10k + 4k7 50V 100mA
84 DTC114WKA Rho N SC59 npn dtr 10k + 4k7 50V 100mA
85 MMBD1701 Nat C - Fast Si diode 30V 50mA
85 MA4CS102A M/A B SOT23 dual cc schottky diode 8V 30mA
86 MMBD1702 Nat K - Fast Si diode 30V 50mA
86 DTC144WE Rho N EMT3 npn dtr 47k + 22k 50V 30mA
86 DTC144WUA Rho N SC70 npn dtr 47k + 22k 50V 30mA
86 DTC144WKA Rho N SC59 npn dtr 47k + 22k 50V 30mA
87 MMBD1703 Nat D - dual ser MMBD1701
87 MA4CS102A M/A S SOT143 dual schottky diode 8V 30mA
88 MMBD1704 Nat B - dual cc MMBD1701
89 MMBD1705 Nat A - dual ca MMBD1701
91 ZV931V2 Zet I SOD523 4-13.5pF hyperabrupt varicap
91 DTA113TKA Roh N SC59 pnp dtr R11k0 50V 100mA
92 ZV932V2 Zet I SOD523 5.5-17pF hyperabrupt varicap
93 ZV933V2 Zet I SOD523 12-42pF hyperabrupt varicap
93 DTA143TE Roh N EMT3 pnp dtr R1 4k7 50V 100mA
93 DTA143TUA Roh N SC70 pnp dtr R1 4k7 50V 100mA
93 DTA143TKA Roh N SC59 pnp dtr R1 4k7 50V 100mA
94 DTA114TE Roh N EMT3 pnp dtr R1 10k 50V 100mA
94 DTA114TUA Roh N SC70 pnp dtr R1 10k 50V 100mA
94 DTA114TKA Roh N SC59 pnp dtr R1 10k 50V 100mA
95 DTA124TE Roh N EMT3 pnp dtr R1 22k 50V 100mA
95 DTA124TCA Roh N SOT23 pnp dtr R1 22k 50V 100mA
95 DTA124TKA Roh N SC59 pnp dtr R1 22k 50V 100mA
96 DTA144TE Roh N EMT3 pnp dtr R1 47k 50V 100mA
96 DTA144TUA Roh N SC70 pnp dtr R1 47k 50V 100mA
96 DTA144TKA Roh N SC59 pnp dtr R1 47k 50V 100mA
99 DTA115TE Roh N EMT3 pnp dtr R1 100k 50V 100mA
99 DTA115TUA Roh N SC70 pnp dtr R1 100k 50V 100mA
99 DTA115TKA Roh N SC59 pnp dtr R1 100k 50V 100mA
100 SSTPAD100 Sil J SOT23 PAD-100 100pA leakage diode
101 PZM10NB1 Phi C SOT346 10V 0.3W zener
102 PZM10NB2 Phi C SOT346 10V 0.3W zener
103 PZM10NB3 Phi C SOT346 10V 0.3W zener
111 PZM11NB1 Phi C SOT346 11V 0.3W zener
111 DTA113ZUA Roh N SC70 pnp dtr 1k+10k 50V 100mA
112 PZM11NB2 Phi C SOT346 11V 0.3W zener
113 PZM11NB3 Phi C SOT346 11V 0.3W zener
113 DTA143ZUA Roh N SC70 pnp dtr 4k7+47k 50V 100mA
121 PZM12NB1 Phi C SOT346 12V 0.3W zener
121 DTC113ZUA Roh N SC70 npn dtr 1k+10k 50V 100mA
122 PZM12NB2 Phi C SOT346 12V 0.3W zener
123 PZM12NB3 Phi C SOT346 12V 0.3W zener
123 DTC143ZUA Roh N SC70 npn dtr 4k7+47k 50V 100mA
131 PZM13NB1 Phi C SOT346 13V 0.3W zener
132 PZM13NB2 Phi C SOT346 13V 0.3W zener
132 DTA123JUA Roh N SC70 pnp dtr 2k2+47k 50V 100mA
133 PZM13NB3 Phi C SOT346 13V 0.3W zener
142 DTA123JUA Roh N SC70 npn dtr 2k2+47k 50V 100mA
151 PZM15NB1 Phi C SOT346 15V 0.3W zener
152 PZM15NB2 Phi C SOT346 15V 0.3W zener
153 PZM15NB3 Phi C SOT346 15V 0.3W zener
156 DTA144VUA Roh N SC70 pnp dtr 47k+10k 50V 100mA
161 PZM16NB1 Phi C SOT346 16V 0.3W zener
162 PZM16NB2 Phi C SOT346 16V 0.3W zener
163 PZM16NB3 Phi C SOT346 16V 0.3W zener
166 DTC144VUA Roh N SC70 npn dtr 47k+10k 50V 100mA
179 FMMT5179 Zet N - 2N5179
181 PZM18NB1 Phi C SOT346 18V 0.3W zener
182 PZM18NB2 Phi C SOT346 18V 0.3W zener
183 PZM18NB3 Phi C SOT346 18V 0.3W zener
200 SSTPAD200 Sil J - PAD-200 200pA leakage diode
201 PZM20NB1 Phi C SOT346 20V 300mW Zener
202 PZM20NB2 Phi C SOT346 20V 300mW Zener
203 PZM20NB3 Phi C SOT346 20V 300mW Zener
221 PZM22NB1 Phi C SOT346 22V 300mW Zener
222 PZM22NB2 Phi C SOT346 22V 300mW Zener
223 PZM22NB3 Phi C SOT346 22V 300mW Zener
241 PZM24NB Phi C SOT346 24V 300mW Zener
242 PZM24NB Phi C SOT346 24V 300mW Zener
243 PZM20NB Phi C SOT346 24V 300mW Zener
271 PZM2.7NB1 Phi C SOT346 2.7V 300mW Zener
272 PZM2.7NB2 Phi C SOT346 2.7V 300mW Zener
301 FDV301N Fch M SOT23 n-ch 'digital' fet 25V 0.22A
302 FDV302P Fch M SOT23 p-ch 'digital' fet 25V 0.13A
303 FDV303N Fch M SOT23 n-ch 'digital' fet 25V 0.68A
304 FDV304P Fch M SOT23 p-ch 'digital' fet 25V 0.46A
331 NDS331N Fch M SOT23 n-ch mosfet 1.3A 20V
331 PZM3.3NB1 Phi C SOT346 3.3V 300mW zener
332 PZM3.3NB2 Phi C SOT346 3.3V 300mW zener
332 NDS332N Fch M SOT23 "p-ch mosfet 0.4A, 1A pk, 20V"
335 NDS335N Fch M SOT23 "n-ch mosfet 70 mA, 1.7A pk, 20V"
336 NDS336N Fch M SOT23 "p-ch mosfet 0.27A, 1.2A pk, 20V"
337 NDS337N Fch M SOT23 "n-ch mosfet 50 mA, 2.5A pk 20V"
338 NDS338N Fch M SOT23 "p-ch mosfet 0.13A, 1.6Apk 20V"
340 FDV340P Fch M SOT23 p-ch mosfet 20V 70 mA
351 NDS351N Fch M SOT23 n-ch mosfet 1.1A 30V
352 NDS352N Fch M SOT23 p-ch mosfet 0.5A 20V
355 NDS355N Fch M SOT23 "n-ch mosfet 0.1A, 1.6A pk 30V"
356 NDS356N Fch M SOT23 "p-ch mosfet 0.3A, 1.1A pk 20V"
357 NDS357N Fch M SOT23 n-ch mosfet 2.5Apk 30V
358 NDS358N Fch M SOT23 "p-ch mosfet 0.2A, 1.6A pk 30V"
358 FDN358N Fch M SOT23 p-ch mosfet 0.2A 1.6A pk 30V
360 FDN360P Fch M SOT23 "p-ch mosfet 80mA, 2a PK, 30V"
361 PZM3.6NB1 Phi C SOT346 3.6V 300mW Zener
362 PZM3.3NB2 Phi C SOT346 3.6V 300mW Zener
391 PZM3.9NB1 Phi C SOT346 3.9V 300mW Zener
392 PZM3.9NB2 Phi C SOT346 3.9V 300mW Zener
413 FMMT413 Zet N SOT23 npn avalanche 150v 0.1A
415 FMMT415 Zet N SOT23 npn avalanche 260v 0.1A
417 FMMT417 Zet N SOT23 npn avalanche 320v 0.1A
431 PZM4.3NB1 Phi C SOT346 4.3V 0.3W zener
432 PZM4.3NB2 Phi C SOT346 4.3V 0.3W zener
433 PZM4.3NB3 Phi C SOT346 4.3V 0.3W zener
449 FMMT449 Zet N SOT23 npn 50V 1A low Vce sat
451 FMMT451 Zet N SOT23 npn 60V 1A
455 FMMT455 Zet N SOT23 NPN 140V 1A
458 FMMT458 Zet N SOT23 npn 400V 0.4A
471 PZM4.7NB1 Phi C SOT346 4.7V 0.3W zener
472 PZM4.7NB2 Phi C SOT346 4.7V 0.3W zener
473 PZM4.7NB3 Phi C SOT346 4.7V 0.3W zener
491 FMMT491 Zet N SOT23 ZTX 450/451
493 FMMT493 Zet N SOT23 ZTX 453
494 FMMT494 Zet N SOT23 npn 120V 1A
495 FMMT495 Zet N SOT23 npn 170V 1A
497 FMMT497 Zet N SOT23 npn 300V 0.5A
500 SSTPAD500 Sil J PAD-500 500pA leakage diode
511 PZM5.1NB1 Phi C SOT346 5.1V 0.3W zener
512 PZM5.1NB2 Phi C SOT346 5.1V 0.3W zener
513 PZM5.1NB3 Phi C SOT346 5.1V 0.3W zener
558 FMMT558 Zet N SOT23 pnp 400V 0.15A
561 PZM5.1NB1 Phi C SOT346 5.6V 0.3W zener
562 PZM5.1NB2 Phi C SOT346 5.6V 0.3W zener
563 PZM5.1NB3 Phi C SOT346 5.6V 0.3W zener
589 FMMT589 Zet N SOT23 pnp 30V 1A
593 FMMT593 Zet N SOT23 ZTX 553
605 NDS0605 Fch M SOT23 P-ch mosfet 60V 180mA
605 NDS0605 Fch M - p-ch sw mosfet 60V
610 NDS0610 Fch M - p-ch sw mosfet 60V
614 FMMT614 Zet N SOT23 sw
617 FMMT617 Zet N SOT23 npn sw 15V 3A
618 FMMT618 Zet N SOT23 npn sw 20V 2.5A
619 FMMT619 Zet N SOT23 npn sw 50V 2A
621 PZM6.2NB1 Phi C SOT346 6.2V 0.3W zener
622 PZM6.2NB2 Phi C SOT346 6.2V 0.3W zener
623 PZM6.2NB3 Phi C SOT346 6.2V 0.3W zener
624 FMMT624 Zet N SOT23 -
625 FMMT625 Zet N SOT23 -
634 FMMT634 Zet N SOT23 100V 0.9A darlington npn
651 PZT651 Mot N SOT223 npn 60V 1A
681 PZM6.8NB1 Phi C SOT346 6.8V 0.3W zener
682 PZM6.8NB2 Phi C SOT346 6.8V 0.3W zener
683 PZM6.8NB1 Phi C SOT346 6.8V 0.3W zener
701 2N7001 Mot M SOT23 n-ch mosfet
702 2N7002 Mot M SOT23 n-ch mosfet 60V 0.11A
703 2N7003 Mot M SOT23 n-ch mosfet
712 NDS7002A Nat M SOT23 n-ch mosfet 60V 0.28A
717 FMMT717 Zet N SOT23 pnp sw 0.625W 2.5A 12V
718 FMMT718 Zet N SOT23 pnp sw 0.625W 1.5A 20V
720 FMMT720 Zet N SOT23 pnp sw 0.625W 1.5A
722 FMMT722 Zet N SOT23 pnp sw
723 FMMT723 Zet N SOT23 pnp sw
730 FMMT730 Zet N SOT23 ZTX550/551
751 PZM7.5NB1 Phi C SOT346 7.5V 0.3W zener
752 PZM7.5NB2 Phi C SOT346 7.5V 0.3W zener
753 PZM7.5NB3 Phi C SOT346 7.5V 0.3W zener
821 PZM8.2NB1 Phi C SOT23 8.2V 0.3W zener
822 PZM8.2NB2 Phi C SOT23 8.2V 0.3W zener
822 S822T Tfk X - npn RF fT 5.2GHz 6V 8mA
823 PZM8.2NB3 Phi C SOT23 8.2V 0.3W zener
852 S852T Tfk N SOT23 npn RF fT 5.2GHz 6V 8mA
887 S887T Tfk W SOT143 n-ch dg uhf mosfet
888 S888T Tfk W SOT142 n-ch dg uhf mosfet
911 PZM9.1NB1 Phi C SOT346 9.1V 0.3W zener
912 PZM9.1NB2 Phi C SOT346 9.1V 0.3W zener
913 PZM9.1NB3 Phi C SOT346 9.1V 0.3W zener
05F TSDF1205R Tfk WQ - fT12GHz npn 4V 5mA
0A MUN5111DW1 Mot DO SOT363 dual pnp dtr 10k+10k
0A DTC125TUA Roh N SC70 npn dtr R2 100k 50V 100mA
0A DTC125TKA Roh N SC59 npn dtr R2 100k 50V 100mA
0B MUN5112DW1 Mot DO SOT363 dual pnp dtr 22k+22k
0C MUN5113DW1 Mot DO SOT363 dual pnp dtr 47k+47k
0D MUN5114DW1 Mot DO SOT363 dual pnp dtr 10k+47k
0E MUN5115DW1 Mot DO SOT363 dual pnp dtr R1 10k
0F MUN5116DW1 Mot DO SOT363 dual pnp dtr R1 4k7
0G MUN5130DW1 Mot DO SOT363 dual pnp dtr 1k0+1k0
0H MUN5131DW1 Mot DO SOT363 dual pnp dtr 2k2+2k2
0J MUN5132DW1 Mot DO SOT363 dual pnp dtr 4k7+4k7
0K MUN5133DW1 Mot DO SOT363 dual pnp dtr 4k7+47k
0L MUN5134DW1 Mot DO SOT363 dual pnp dtr 22k+47k
0M MUN5135DW1 Mot DO SOT363 dual pnp dtr 2k2+47k
1 (red) BB669 Sie I SOD323 56-2.7 pF varicap
10A PZM10NB2A Phi A SOT346 dual ca 10V 0.3W zener
10V PZM10NB Phi C SOT346 10V 0.3W zener
10Y BZV49-C10 Phi O SOT89 10V 1W zener
11A PZM11NB2A Phi A SOT346 dual ca 11V 0.3W zener
11A MMBD1501A Nat C SOT23 Si diode 200V 100mA
11V PZM11NB Phi C SOT346 11V 0.3W zener
11Y BZV49-C11 Phi O SOT89 11V 1W zener
12A MMBD1502A Nat K SOT23 Si diode 200V 100mA
12A PZM12NB2A Phi A SOT346 dual ca 12V 0.3W zener
12E ZC2812E Zet D SOT23 dual series RF schottky15V 20mA
12V PZM12NB Phi C SOT346 12V 0.3W zener
12Y BZV49-C12 Phi O SOT89 12V 1W zener
13A MMBD1503A Nat D SOT23 dual Si diode 200V 100mA
13A PZM13NB2A Phi A SOT346 dual ca 13V 0.3W zener
13E ZC2813E Zet A SOT23 dual ca RF schottky15V 20mA
13s BAS125 Sie C SOT23 Schottky sw 24V 100mA
13s BAS125W Sie C SOT323 Schottky sw 24V 100mA
13t BC846BPN Phi N SOT363 BC546B
13V PZM13NB Phi C SOT346 13V 0.3W zener
13Y BZV49-C13 Phi O SOT89 13V 1W zener
14A MMBD1504A Nat B - dual cc Si diode 200V 100mA
14s BAS125-04 Sie D SOT23 Dual series Schottky 25V 100mA
14s BAS125-04W Sie D SOT323 Dual series Schottky 25V 100mA
15A MMBD1505A Nat A - dual ca Si diode 200V 100mA
15A PZM15NB2A Phi A SOT346 dual ca 15V 0.3W zener
15s BAS125-05 Sie B SOT23 dual cc Schottky 25V 100mA
15s BAS125-05W Sie B SOT323 dual cc Schottky 25V 100mA
15V PZM15NB Phi C SOT346 15V 0.3W zener
15Y BZV49-C15 Phi O SOT89 15V 1W zener
16s BAS125-06 Sie A SOT23 dual ca Schottky 25V 100mA
16s BAS125-06W Sie A SOT323 dual ca Schottky 25V 100mA
16V PZM16NB Phi C SOT346 16V 0.3W zener
16Y BZV49-C16 Phi O SOT89 16V 1W zener
17s BAS125-07 Sie S SOT143 dual Schottky 25V 100mA
17s BAS125-07W Sie S SOT343 dual Schottky 25V 100mA
18V PZM18NB Phi C SOT346 18V 0.3W zener
18Y BZV49-C18 Phi O SOT89 18V 1W zener
1A BC846A Phi N SOT23 BC546A
1A BC846AT Phi N SOT416 BC546A
1A FMMT3904 Zet N SOT23 2N3904
1A MMBT3904 Mot N SOT23 2N3904
1A IRLML2402 IR F SOT23 n-ch mosfet 20V 0.9A
-1A PMST3904 Phi N SOT323 2N3904
1A- BC846AW Phi N SOT323 BC546A
1AM MMBT3904L Mot N SOT23 2N3904
1Ap BC846A Phi N SOT23 BC546A
1At BC846A Phi N SOT23 BC546A
1At BC846AW Phi N SOT323 BC546A
1B BC846B Phi N SOT23 BC546B
1B BC846BT Phi N SOT416 BC546B
1B FMMT2222 Zet N SOT23 2N2222
1B MMBT2222 Mot N SOT23 2N2222
1B IRLML2803 IR F SOT23 n-ch mosfet 30V 0.9A
-1B PMST2222 Phi N SOT323 2N2222
1B- BC846BW Phi N SOT323 BC546B
1Bp BC846B Phi N SOT23 BC546B
1Bs BC817UPN Sie N SC74 -
1Bt BC846B Phi N SOT23 BC546B
1Bt BC846BW Phi N SOT323 BC546B
1C FMMT-A20 Zet N SOT23 MPSA20
1C MMBTA20L Mot N SOT23 MPS3904
1C IRLML6302 IR F SOT23 p-ch mosfet 20V 0.6A
1Cp BAP50-05 Phi B SOT23 dual cc GP RF pin diode
1Cs BC847S Sie - SOT363 BC457
1D MMBTA42 Mot N SOT23 MPSA42 300V npn
1D IRLML5103 IR F SOT23 p-ch mosfet 30V 0.6A
1D- BC846W Phi N SOT323 BC456
1DN 2SC4083 Roh N - npn 11V 3.2GHz TV tuners
1Dp BC846 Phi N SOT23 BC456
1DR MSD1328R Mot N SOT346 npn gp 25V 500mA
1Ds BC846U Sie N SC74 BC456
1Ds BC846U Sie - SOT363 BC456
1Dt BC846 Phi N SOT23 BC456
1Dt BC846W Phi N SOT323 BC456
1E BC847A Phi N SOT23 BC547A
1E BC847AT Phi N SOT416 BC547A
1E FMMT-A43 Zet N - MPSA43
1E MMBTA43 Mot N SOT23 MPSA43 200V npn
1E- BC847A Phi N SOT323 BC547A
1EN 2SC4084 Roh N - npn 20V 2.0GHz TV tuners
1Ep BC847A Phi N SOT23 BC547A
1ER BC847AR Phi R SOT23R BC547A
1Es BC847A Sie N SOT23 BC457
1Es BC847AW Sie N SOT323 BC457
1Et BC847A Phi N SOT23 BC547A
1Et BC847A Phi N SOT323 BC547A
1F BC847B Phi N SOT23 BC547B
1F BC847BT Phi N SOT416 BC547B
1F MMBT5550 Mot N SOT23 2N5550 140V npn
1F- BC847BW Phi N SOT323 BC547B
1Fp BC847B Phi N SOT23 BC547B
1FR BC847BR Phi R SOT23R BC547B
1Fs BC847B Sie N SOT23 BC547B
1Fs BC847BT Sie N SC75 BC547B
1Fs BC847BW Sie N SOT323 BC547B
1Ft BC847B Phi N SOT23 BC547B
1Ft BC847BW Phi N SOT323 BC547B
1FZ FMBT5550 Zet N SOT23 2N5550 140V npn
1G BC847C Phi N SOT23 BC547C
1G BC847CT Phi N SOT416 BC547C
1G FMMT-A06 Zet N SOT23 MPSA06
1G MMBTA06 Mot N SOT23 MPSA06
1G- BC847CW Phi N SOT323 BC547C
1GM MMBTA06 Mot N SOT23 MPSA06
1Gp BC847C Phi N SOT23 BC547C
1GR BC847CR Phi R SOT23R BC547C
1Gs BC847C Sie N SOT23 BC547C
1Gs BC847CW Sie N SOT323 BC547C
1Gt BC847CW Phi N SOT323 BC547C
1GT SOA06 SGS N SOT23 MPSA06
1H FMMT-A05 Zet N - MPSA05
1H MMBTA05 Mot N SOT23 MPSA05
1H- BC847W Phi N SOT323 BC547
1Hp BC847 Phi N SOT23 BC547
1Ht BC847 Phi N SOT23 BC547
1Ht BC847W Phi N SOT323 BC547
1HT SOA05 SGS N SOT23 MPSA05
1J BC848A Phi N SOT23 BC548A
1J FMMT2369 Zet N SOT23 2N2369
1J MMBT2369 Mot N SOT23 MPS2369
1JA MMBT2369A Mot N SOT23 MPS2369A
1Jp BCV61A Phi VQ SOT143 npn current mirror hFe 180
1JR BC848AR Phi R SOT23R BC548A
1Js BC848A Sie N SOT23 BC548A
1Js BC848AW Sie N SOT323 BC548A
1Js BCV61A Sie VQ SOT143 npn current mirror hFe 180
1JZ BC848A Zet N SOT23 BC548A
1K BC848B ITT N SOT23 BC548B
1K MMBT6428 Mot N SOT23 MPSA18 50V
1K FMMT4400 Zet N SOT23 2N4400
1KM MMBT6428L Mot N SOT23 MPSA18 50V
1Kp BC848B Phi N SOT23 BC548B
1Kp BCV61B Phi VQ SOT143B npn current mirror hFe 290
1KR BC848BR Phi R SOT23R BC548B
1Ks BC848B Sie N SOT23 BC548B
1Ks BC848BW Sie N SOT323 BC548B
1Ks BCV61B Sie VQ SOT143B npn current mirror hFe 290
1KZ FMMT4400 Zet N SOT23 2N4400
1L BC848C ITT N SOT23 BC548C
1L MMBT6429 Mot N - MPSA18 45V
1L FMMT4401 Zet N - 2N4401
1L BCV61C Sie VQ SOT143B npn current mirror hFe 520
1Lp BC848C Phi N SOT23 BC548C
1Lp BCV61C Phi VQ SOT143B npn current mirror hFe 520
1LR BC848CR Phi R SOT23R BC548C
1Ls BC848C Sie N SOT23 BC548C
1Ls BC848CW Sie N SOT323 BC548C
1M MMBTA13 Mot N SOT23 MPSA13 darlington
1M FMMT-A13 Zet N SOT23 MPSA13
1Mp BC848 Phi N SOT23 BC548
1Mp BCV61 Phi VQ SOT143B npn current mirror
1N FMMT-A14 Zet N SOT23 MPSA14
1N MMBTA14 Mot N SOT23 MPSA14 darlington
1N5 ZTX11N15DF Zet N SOT23 npn 15V 3A low saturation V
1P FMMT2222A Zet N - 2N2222A
1P MMBT2222A Mot N SOT23 2N2222A
1P BC847PN Sie DI - pnp/npn separate pair gp AF
1Q MMBT5088 Mot N SOT23 MPSA18 Vce 30V
1R MMBT5089 Mot N SOT23 MPSA18 Vce 25V
1S MMBT2369A Nat N SOT23 2N2369A 500MHz sw npn
1S MSC3130 Mot H SOT346 npn RF fT 1.4GHz 10V
1T MMBT3960A Mot N - 2N3960A
1U MMBT2484L Mot N SOT23 MPSA18
1V MMBT6427 Mot H SOT23 2N6426/7 darlington npn
1V- BF820W Phi N SOT323 npn 300V 50mA BF420
1Vp BF820 Phi N SOT23 npn 300V 50mA BF420
1Vt BF820 Phi N SOT23 npn 300V 50mA BF420
1Vt BF820W Phi N SOT323 npn 300V 50mA BF420
1W FMMT3903 Zet N SOT23 2N3903
1W - BF822W Phi N SOT323 pnp 300V 50mA BF421
1W t BF822W Phi N SOT323 pnp 300V 50mA BF421
1Wp BF821 Phi N SOT23 pnp 300V 50mA BF421
1Wt BF821 Phi N SOT23 pnp 300V 50mA BF421
1X MMBT930L Mot N SOT23 MPS3904
1Xp BF822 Phi N SOT23 npn 250V 50mA BF422
1Xt BF822 Phi N SOT23 npn 250V 50mA BF422
1Y MMBT3903 Mot N SOT23 2N3903
1Yp BF823 Phi N SOT23 pnp 250V 50mA BF423
1Yt BF823 Phi N SOT23 pnp 250V 50mA BF423
1Z BAS70-06 Zet A SOT23 dual RF CA schottky diode
1Z MMBT6517 Mot N SOT23 2N6517 npn Vce 350V
2 (blue) BAR64-03W Sie I SOD323 pin diode
2 (white) BB439 Sie I SOD323 29-5 pF varicap
20F TSDF1220 Tfk X SOT143 fT 12GHz npn 6V 20mA
20V PZM20NB Phi C SOT346 20V 300mW zener
20Y BZV49-C20 Phi O SOT89 20V 1W zener
22V PZM22NB Phi C SOT346 22V 300mW zener
22Y BZV49-C22 Phi O SOT89 22V 1W zener
24V PZM24NB Phi C SOT346 24V 300mW Zener
24Y BZV49-C24 Phi O SOT89 24V 1W zener
27V PZM27NB Phi C SOT346 27V 300mW Zener
27Y BZV49-C27 Phi O SOT89 27V 1W zener
2A MMBT3906L Mot N SOT23 2N3906
2A MMBT3906W Mot N SOT323 2N3906
2A FMMT3906 Zet N SOT23 2N3906
2A4 PZM2.4NB2A Phi A SOT346 dual 2.4V cc Zener
2A7 PZM2.7NB2A Phi A SOT346 dual 2.7V cc Zener
2B BC849B ITT N SOT23 BC549B
2B FMMT2907 Zet N SOT23 2N2907
2B MMBT2907 Mot N SOT23 MPS2907
2B- BC849BW Phi N SOT323 BC549B
2Bp BC849B Phi N SOT23 BC549B
2BR BC849BR Phi R SOT23R BC549B
2Bs BC849B Sie N SOT23 BC549B
2Bs BC849BW Sie N SOT323 BC549B
2Bt BC849BW Phi N SOT323 BC549B
2BZ FMMT2907 Zet N SOT23 2N2907
2C BC849C ITT N SOT23 BC549C
2C MMBTA70 Mot N SOT23 MPSA70
2C- BC849CW Phi N SOT323 BC549C
2Cp BC849C Phi N SOT23 BC549C
2CR BC849CR Phi R SOT23R BC549C
2Cs BC849C Sie N SOT23 BC549C
2Cs BC849CW Sie N SOT323 BC549C
2Ct BC849C Phi N SOT23 BC549C
2Ct BC849CW Phi N SOT323 BC549C
2CZ FMMTA70 Zet N SOT23 MPSA70
2D MMBTA92 Mot N SOT23 MPSA92 pnp Vce 300V
2E MMBTA93 Mot N SOT23 MPSA93 pnp Vce 200V
2E FMMT-A93 Zet N SOT23 MPSA93
2F BC850B ITT N SOT23 BC550B
2F FMMT2907A Zet N SOT23 2N2907A
2F MMBT2907A Mot N SOT23 MPS2907A
2F MMBT2907AW Mot N SOT323 MPS2907A
2F- BC850BW Phi N SOT323 BC550B
2Fp BC850B Phi N SOT23 BC550B
2FR BC850BR Phi R SOT23R BC550B
2Fs BC850B Sie N SOT23 BC550B
2Fs BC850BW Sie N SOT323 BC550B
2Ft BC850B Phi N SOT23 BC550B
2Ft BC850BW Phi N SOT323 BC550B
2G BC850C ITT N SOT23 BC550C
2G FMMT-A56 Zet N SOT23 MPSA56
2G MMBTA56 Mot N SOT23 MPSA56
2G- BC850CW Phi N SOT323 BC550C
2GM MMBTA56 Mot N SOT23 MPSA56
2Gp BC850C Phi N SOT23 BC550C
2GR BC850CR Phi R SOT23R BC550C
2Gs BC850C Sie N SOT23 BC550C
2Gt BC850C Phi N SOT323 BC550C
2Gt BC850CW Phi N SOT323 BC550C
2GT SOA56 SGS N SOT23 MPSA56
2H FMMT-A55 Zet N SOT23 MPSA55
2H MMBTA55 Mot N SOT23 MPSA55
2HT SOA55 SGS N SOT23 MPSA55
2J MMBT3640 Mot N SOT23 MPS3640 pnp sw
2K FMMT4402 Zet N SOT23 2N4402
2K MMBT8598 Mot N - 2N4125 pnp 60V
2L MMBT5401 Mot N SOT23 2N5401 pnp 150V
2L FMMT4403 Zet N SOT23 2N4403
2M FMMT5087 Zet N SOT23 2N5087
2M MMBT404 Mot N SOT23 pnp-chopper 24V 150mA
2N MMBT404A Mot N SOT23 pnp-chopper 35V 150mA
2N0 ZXT11N20DF Zet N SOT23 npn 20V 2.5A low sat switch
2P FMMT2222R Zet R SOT23R 2N2222
2P MMBT5086 Mot N SOT23 2N5086
2Q MMBT5087 Mot N SOT23 2N5087
2R HSMS-8102 HP Z SOT23 10-14GHz schottky mixer pair
2T SO4403 SGS N SOT23 2N4403
2T MMBT4403 Mot N SOT23 2N4403
2T HT2 Zet N SOT23 pnp 80V 100mA
2U MMBTA63 Mot N SOT23 MPSA63 darlington
2V MMBTA64 Mot N SOT23 MPSA64 darlington
2V4 PZM2.4NB Phi C SOT346 2.4V 300mW Zener
2V7 PZM2.7NB Phi C SOT346 2.7V 300mW Zener
2W FMMT3905 Zet N SOT23 2N3905
2W MMBT8599 Mot N - 2N4125 Vce 80V pnp
2X SO4401 SGS N SOT23 2N4401
2X MMBT4401 Mot N SOT23 2N4401
2Y4 BZV49-C2V4 Phi O SOT89 2.4V 1W zener
2Y7 BZV49-C2V7 Phi O SOT89 2.7V 1W zener
2Z MMBT6520 Mot N SOT23 2N6520 pnp Vce 350V
2Z BAS70-04 Zet D SOT23 dual series RF schottky 70V 15mA
2Z5 BAS70-05 Zet B SOT23 dual cc RF Schottky 70V 15mA
30V PZM30NB1 Phi C SOT346 30V 300mW zener
30Y BZV49-C30 Phi O SOT89 30V 1W zener
33V PZM33NB1 Phi C SOT346 33 300mW zener
33Y BZV49-C33 Phi O SOT89 33V 1W zener
36V PZM36NB1 Phi C SOT346 36V 300mW Zener
36Y BZV49-C36 Phi O SOT89 36V 1W zener
39V PZM39NB1 Phi C SOT346 39V 300mW Zener
39Y BZV49-C39 Phi O SOT89 39V 1W zener
3A BC856A ITT N SOT23 BC556A
3A BC856AT Phi N SOT416 BC556A
3A MMBTH24 Mot N SOT23 VHF mixer npn fT 600MHz
3A- BC856AW Phi N SOT323 BC556A
3A0 PZM3.0NB2A Phi C SOT346 dual 3.0V Zener
3A3 PZM3.3NB2A Phi C SOT346 dual 3.3V Zener
3A6 PZM3.6NB2A Phi C SOT346 dual 3.6V Zener
3A9 PZM3.9NB2A Phi C SOT346 dual 3.9V Zener
3Ap BC856A Phi N SOT23 BC556A
3AR BC856AR Phi R SOT23R BC556A
3As BC856A Sie N SOT23 BC556A
3At BC856A Phi N SOT23 BC556A
3At BC856AW Phi N SOT323 BC556A
3B BC856B ITT N SOT23 BC556B
3B BC856BT Phi N SOT416 BC556B
3B FMMT918 Zet N SOT23 2N918
3B MMBT918 Mot N SOT23 2N918
3B- BC856BW Phi N SOT323 BC556B
3Bp BC856B Phi N SOT23 BC556B
3BR BC856BR Phi R SOT23 BC556B
3Bs BC856B Sie N SOT23 BC556B
3Bt BC856B Phi N SOT23 BC556B
3Bt BC856BW Phi N SOT323 BC556B
3C FMMTA20R Zet R SOT23R MPSA20
3C BC857 Sie DO - pnp separate pair gp AF
3D BC856 Phi N SOT23 BC556 hfe 75 min
3D MMBTH81L Mot N SOT23 UHF pnp fT 600MHz
3D BC856S Sie DO - pnp separate pair gp AF
3D- BC856W Phi N SOT323 BC556 hfe 75 min
3Dp BC856 Phi N SOT23 BC556 hfe 75 min
3Dt BC856 Phi N SOT23 BC556 hfe 75 min
3Dt BC856W Phi N SOT323 BC556 hfe 75 min
3E BC857A Phi N SOT23 BC557A
3E BC857AT Phi N SOT416 BC557A
3E MMBTH10 Mot N SOT23 MPSH10 fT 650MHz
3E FMMT-A42 Zet N SOT23 MPSA42
3E- BC857A Phi N SOT323 BC557A
3EM MMBTH10L Mot N SOT23 VHF amp 650MHz fT
3Ep BC857A Phi N SOT23 BC557A
3ER BC857AR Phi R SOT23R BC557A
3Et BC857A Phi N SOT23 BC557A
3Et BC857A Phi N SOT323 BC557A
3EZ FMMTH10 Zet N SOT23 npn fT 650MHz
3F BC857B Phi N SOT23 BC557B
3F BC857BT Phi N SOT416 BC557B
3F- BC857BW Phi N SOT323 BC557B
3Fp BC857B Phi N SOT23 BC557B
3FR BC857BR Phi R SOT23R BC557B
3Fs BC857B Sie N SOT23 BC557B
3Ft BC857B Phi N SOT23 BC557B
3Ft BC857BW Phi N SOT323 BC557B
3Ft BC857BS Phi N SOT363 BC557B
3G BC857C Phi N SOT23 BC557C
3G MMBTH11 NS N SOT23 -
3G MGSF3454X Mot DK TSOP6 n-ch enh tmosfet 1.75A
3G- BC857CW Phi N SOT323 BC557C
3Gp BC857C Phi N SOT23 BC557C
3GR BC857CR Phi R SOT23R BC557CR
3Gs BC857C Sie N SOT23 BC557C
3Gt BC857C Phi N SOT23 BC557C
3Gt BC857CW Phi N SOT323 BC557C
3H MMBTH30 NS N SOT23 -
3H- BC857CW Phi N SOT323 BC557
3Hp BC857C Phi N SOT23 BC557
3Ht BC857C Phi N SOT23 BC557
3Ht BC857CW Phi N SOT323 BC557
3J MMBTH69 Mot N SOT23 pnp UHF fT 2GHz
3J BC858A Phi N SOT23 BC558A
3Jp BCV62A Phi VQ SOT143 pnp current mirror hFe 180
3JR BC858AR Phi R SOT23R BC558A
3Js BC858A Sie N SOT23 BC558A
3Js BCV62A Sie VQ SOT143 pnp current mirror hFe 180
3K BC858B Phi N SOT23 BC558B
3Kp BCV62B Phi VQ SOT143 npn current mirror hFe 290
3KR BC858BR Phi R SOT23R BC558B
3Ks BCV62B Sie VQ SOT143 npn current mirror hFe 290
3L BC858C Phi N SOT23 BC558C
3Lp BCV62C Phi VQ SOT143 pnp current mirror hFe 520
3LR BC858CR Phi R SOT23R BC558C
3Ls BCV62C Sie VQ SOT143 pnp current mirror hFe 520
3M BC858 Phi N SOT23 BC558
3M FMMT5087R Zet R SOT23R 2N5087 BC322
3Mp BCV62 Phi VQ SOT143 pnp current mirror
3Ms BCV62 Sie VQ SOT143 pnp current mirror
3N MMBT4402 Nat N SOT23 2N4402 pnp
3P FMT2222AR Zet R SOT23R 2N2222A
3R MMBT5571 Nat N SOT23 pnp sw 850MHz
3S MMBT5551 Nat N SOT23 npn 160V
3T HT3 Zet N SOT23 npn 80V 100mA
3V0 PZM3.0NB Phi C SOT346 3.0V 300mW Zener
3V3 PZM3.3NB Phi C SOT346 3.3V 300mW Zener
3V6 PZM3.6NB Phi C SOT346 3.6V 300mW Zener
3V9 PZM3.9NB Phi C SOT346 3.9V 300mW Zener
3W FMMT-A12 Zet N - MPSA12
3Y3 BZV49-C3V3 Phi O SOT89 3.3V 1W zener
3Y6 BZV49-C3V6 Phi O SOT89 3.6V 1W zener
3Y9 BZV49-C3V9 Phi O SOT89 3.9V 1W zener
4 (red) BB57-03W Sie I SOD323 Varicap
4 (white) BAS140W Sie I SOD323 40V 120mA sw schottky
4 (yellow) BB644 Sie I SOD323 Varicap 42-2.5pF
41A FMMT491A Zet N SOT23 npn 40v 1A max
41D BAT14-115D Sie CY SOT173 40GHz schottky dual
42D BAT14-025D Sie CY SOT173 4GHz schottky dual
43V PZM43NB Phi C SOT346 43V 0.3W zener
43Y BZV49-C43 Phi O SOT89 43V 1W zener
45D BAT14-055D Sie CY SOT173 8GHz schottky dual
47V PZM47NB Phi C SOT346 47V 0.3W zener
47Y BZV49-C47 Phi O SOT89 47V 1W zener
49D BAT14-095D Sie CY SOT173 18GHz schottky dual
4A MMBV109 Mot C SOT23 MV209 varicap
4A FMMV109 Zet C SOT23 MV209 varicap
4A HD3A Zet C - 75V 100mA sw diode
4A BC859A ITT N SOT23 BC559A
4A3 PZM4.3NB2A Phi A SOT346 dual ca 4.3V Zener
4A7 PZM4.7NB2A Phi A SOT346 dual ca 4.7V Zener
4Ap BC859A Phi N SOT23 BC559A
4AR BC859AR Phi R SOT23R BC559A
4As BC859AW Sie N SOT323 BC559A
4As BC859A Sie N SOT23 BC559A
4B MMBV432 Mot B - dual cc varicap 1.5-45pF
4B BC859B ITT N SOT23 BC559B
4B- BC859BW Phi N SOT323 BC559B
4Bp BC859B Phi N SOT23 BC559B
4BR BC859BR Phi R SOT23R BC559B
4Bs BC859B Sie N SOT23 BC559B
4Bs BC859BW Sie N SOT323 BC559B
4Bt BC859B Phi N SOT23 BC559B
4Bt BC859BW Phi N SOT323 BC559B
4C BC859C ITT N SOT23 BC559C
4C MMVB3102 Mot C SOT23 varicap 6-35pF
4C BC859C Phi N SOT23 BC559C
4C- BC859CW Phi N SOT323 BC559C
4Cp BC859C Phi N SOT23 BC559C
4CR BC859CR Phi R SOT23R BC559C
4Cs BC859C Sie N SOT23 BC559C
4Cs BC859CW Sie N SOT323 BC559C
4Ct BC859C Phi N SOT23 BC559C
4Ct BC859CW Phi N SOT323 BC559C
4D BC859B Phi N SOT23 BC559B
4D MMBV3401 Mot C SOT23 VHF pin diode
4D HD3A Zet C SOT23 sw diode 75V 100mA
4D- BC859W Phi N SOT323 BC559B
4Dt BC859W Phi N SOT323 BC559B
4E BC860A Phi N SOT23 BC560A
4E FMMT-A92 Zet N SOT23 MPSA92
4E MMBV105G Mot C SOT23 MV105 varicap
4ER BC860AR Phi R SOT23R BC560A
4F MMBD353 Mot Z SOT23 dual MBD101
4F BC860B Phi N SOT23 BC560B
4F Gali-4F MC AZ SOT89 DC-4GHz MMIC amp 15 dBm o/p
4F- BC860BW Phi N SOT323 BC560B
4Fp BC860B Phi N SOT23 BC560B
4FR BC860BR Phi R SOT23 BC560B
4Fs BC860B Sie N SOT23 BC560B
4Fs BC860BW Sie N SOT323 BC560B
4Ft BC860B Phi N SOT23 BC560B
4Ft BC860BW Phi N SOT323 BC560B
4G MMBV2101 Mot C SOT23 MV2101 varicap
4G BC860C Phi N SOT23 BC560C
4G- BC860CW Phi N SOT323 BC560C
4Gp BC860C Phi N SOT23 BC560C
4GR BC860CR Phi R SOT23 BC560CR
4Gs BC860C Sie N SOT23 BC560C
4Gs BC860CW Sie N SOT323 BC560C
4Gt BC860C Phi N SOT23 BC560C
4Gt BC860CW Phi N SOT323 BC560C
4H MMBV2103 Mot C SOT23 MV2103 varicap
4H- BC860W Phi N SOT323 BC560
4Hp BC860 Phi N SOT23 BC560
4Ht BC860W Phi N SOT323 BC560
4J FMMT38A Zet N SOT23 BCX38A
4J MMBV2109 Mot C SOT23 MV2109 varicap
4K BAP64-04 Phi D - dual series 3GHz pin diode
4K MMSB3000 Mot I SOD123 Si diode 30V 0.2A
4L BAP50-04 Phi D - dual series GP RF pin diode
4M MMBD101 Mot C SOT23 MBD101 schottky diode
4Ms BAT240A Sie EQ SOT143 dual schottky 250V 0.4A
4R MMBV3700 Mot C SOT23 200V vhf pin diode
4S MMBD201 Mot C SOT23 MBD201
4T MMBD301 Mot C SOT23 MBD301 UHF schottky diode
4U MMBV2105 Mot C SOT23 MV2105 varicap
4V MMBV2106 Mot C SOT23 MV2106 varicap
4V BCW65AR Zet R SOT23R npn 32V 0.8A
4V3 PZM4.3NB Phi C SOT346 4.3V 0.3W zener
4V7 PZM4.7NB Phi C SOT346 4.7V 0.3W zener
4W MMBV2107 Mot C SOT23 MV2107 varicap
4W BCW67AR Zet R SOT23R pnp 32V 0.8A
4X MMBV2108 Mot C SOT23 MV2108 varicap
4Y MMBV2102 Mot C SOT23 MV2102 varicap
4Y3 BZV49-C4V3 Phi O SOT89 4.3V 1W zener
4Y7 BZV49-C4V7 Phi O SOT89 4.7V 1W zener
4Z MMBV2104 Mot C SOT23 MV2104 varicap
5 (red) BBY57-03W Sie I SOD323 varicap
5 (white) BAT60B Sie I 10V 3A sw Schottky
51D BAT15-115D Sie CY SOT173 40GHz schottky dual
51V PZM51NB Phi C SOT346 51V 0.3W zener
51Y BZV49-C51 Phi O SOT89 51V 1W zener
52D BAT15-025D Sie CY SOT173 4GHz schottky dual
53s BAT17 Sie C SOT23 schottky diode 4V 100mA
54s BAT17-04 Sie D SOT23 dual series BAT17
54s BAT17-04W Sie D SOT323 dual series BAT17
55D BAT15-055D Sie CY SOT173 8GHz schottky dual
55s BAT17-05 Sie A SOT23 dual ca BAT17
55s BAT17-05W Sie A SOT323 dual ca BAT17
56s BAT17-06 Sie B SOT23 dual cc BAT17
56s BAT17-06W Sie B SOT323 dual cc BAT17
56V PZM56NB Phi C SOT346 56V 0.3W zener
56Y BZV49-C56 Phi O SOT89 56V 1W zener
57s BAT17-07 Sie S SOT143 dual BAT17
59D BAT15-095D Sie CY SOT173 18GHz schottky dual
5A BC807-16 Phi N SOT23 BC327-16
5A BSS123 Mot M SOT23 n-ch tmosfet Vds 100V
5A MMBD6050 Mot C SOT23 sw diode 70V 0.2A
5A FMMD6050 Zet C SOT23 sw diode 70V 100mA
5A- BC807-16W Phi N SOT323 BC327-16
5A1 PZM5.1NB2A Phi A SOT346 dual ca 5.1V 0.3W zener
5A6 PZM5.6NB2A Phi A SOT346 dual ca 5.6V 0.3W zener
5Ap BC807-16 Phi N SOT23 BC327-16
5AR BC807-16R Phi R SOT23R BC327-16
5As BC807-16 Sie N SOT23 BC327-16
5As BC807-16W Sie N SOT323 BC327-16
5At BC807-16 Phi N SOT23 BC327-16
5At BC807-16W Phi N SOT323 BC327-16
5B MMBT4123 Mot N SOT23 2N4123
5B BC807-25 SGS N SOT23 BC327-25
5B MMBD6100 Mot B SOT23 cc dual diode 70V 0.2A
5B FMMD6100 Zet B SOT23 cc dual diode 70V 0.2A
5B- BC807-25W Phi N SOT323 BC327-25
5BM MMBD6100 Mot B SOT23 cc dual diode 70V 0.2A
5Bp BC807-25 Phi N SOT23 BC327-25
5BR BC807-25R Phi R SOT23R BC327-25
5Bs BC807-25 Sie N SOT23 BC327-25
5Bs BC807-25W Sie N SOT323 BC327-25
5Bs BC807-25U Sie N SC74 BC327-25
5Bt BC807-25 Phi N SOT23 BC327-25
5Bt BC807-25W Phi N SOT323 BC327-25
5C BC807-40 SGS N SOT23 BC327-40
5C MMBD7000 Mot D SOT23 2 ser diodes 100V 0.2A
5C FMMD7000 Zet D SOT23 2 ser diodes 70V 200mA
5C- BC807-40W Phi N SOT323 BC327-40
5Cp BC807-40 Phi N SOT23 BC327-40
5CR BC807-40R Phi R SOT23E BC327-40
5Cs BC807-40 Sie N SOT23 BC327-40
5Cs BC807-40W Sie N SOT323 BC327-40
5Ct BC807-40 Phi N SOT23 BC327-40
5Ct BC807-40W Phi N SOT323 BC327-40
5D FMMD914 Zet C SOT23 1N914
5D MMBD914 Mot C SOT23 1N914
5D MMSD914 Mot I SOD123 1N914
5D HD2A Zet B dual cc HD2 75V 100mA
5D- BC807W Phi N SOT323 BC327
5Dp BC807 Phi N SOT23 BC327
5Dt BC807 Phi N SOT23 BC327
5Dt BC807W Phi N SOT323 BC327
5E BC808-16 Phi N SOT23 BC328-16
5E FMMT-A43R Zet R SOT23R MPSA43
5ER BC808-16R Phi R SOT23R BC328-16
5Es BC808-16 Sie N SOT23 BC328-16
5Es BC808-16W Sie N SOT323 BC328-16
5F BC808-25 Phi N SOT23 BC328-25
5F MMBD501 Mot C SOT23 MBD501 hot carrier diode
5F Gali-5F MC AZ SOT89 DC-4GHz MMIC amp 20 dB gain
5FR BC808-25R Phi R SOT23R BC328-25
5Fs BC808-25 Sie N SOT23 BC328-25
5Fs BC808-25W Sie N SOT323 BC328-25
5G BC808-40 Phi N SOT23 BC328-40
5G MMBD353 Mot D dual series MBD101
5GR BC808-40R Phi R SOT23R BC328-40
5Gs BC808-40 Sie N SOT23 BC328-40
5Gs BC808-40W Sie N SOT323 BC328-40
5H MMBD701 Mot C SOT23 MBD701 UHF schottky diode
5H MMBD4148 Nat C SOT23 1N4148
5Hp BC808 Phi N SOT23 BC328
5HZ BC808 Zet N SOT23 BC328
5I MMSD4148 Mot C 1N4148
5J FMMT38B Zet N BCX38B
5K MMBV809 Mot C SOT23 Hyperabrupt varicap
5Kp BAP64-05 Phi B dual cc 3GHz RF pin diode
5L MMBV609 Mot B SOT23 dual cc Hyperabrupt varicap
5N MMBD452L Mot D SOT23 series UHF schottky diodes
5P FMMT2907AR Zet R SOT23R 2N2907A
5T BCW66GR Sie R SOT23R npn 45V 0.8A 350mW
5V BCW65BR Zet R SOT23R npn 32V 0.8A
5V1 PZM5.1NB Phi C SOT346 5.1V 0.3W zener
5V6 PZM5.6NB Phi C SOT346 5.6V 0.3W zener
5W BCW67BR Zet R SOT23R pnp 32V 0.8A
5Y1 BZV49-C5V1 Phi O SOT89 5.1V 1W zener
5Y6 BZV49-C5V6 Phi O SOT89 5.6V 1W zener
6 (red) BBY56-03W Sie I SOD323 varicap
60s BAR60 Sie QQ SOT143 3 pin diodes
61A MMBF4117 Nat F - n-ch jfet ultra low i/p Ig
61A MMBF4119 Nat F - n-ch jfet ultra low i/p Ig
61C MMBF4118 Nat F - n-ch jfet ultra low i/p Ig
61J MMBF4091 Nat F - n-ch jfet sw/chopper
61K MMBF4092 Nat F - n-ch jfet sw/chopper
61L MMBF4093 Nat F - n-ch jfet sw/chopper
61M MMBF4859 Nat F - n-ch jfet sw/chopper
61N MMBF5514 Nat F - p-ch jfet sw/chopper
61P MMBF5115 Nat F - p-ch jfet sw/chopper
61Q MMBF5516 Nat F - p-ch jfet sw/chopper
61s BAR61 Sie PQ SOT143 3 pin diodes pi atten
61S MMBF5458 Nat F - n-ch jfet gp 2N5458
61T MMBF5459 Nat F - n-ch jfet gp 2N5459
61U MMBF5461 Nat F - p-ch jfet gp 2N5461
61V MMBF5462 Nat F - p-ch jfet gp 2N5462
62P MMBFJ201 Nat F - n-ch jfet gp J201
62Q MMBFJ202 Nat F - n-ch jfet gp J202
62R MMBFJ203 Nat F - n-ch jfet gp J203
62S MMBFJ270 Nat F - p-ch jfet gp J270
62T MMBFJ271 Nat F - p-ch jfet gp J271
62V PZM62NB1 Phi C SOT346 62V 0.3W zener
62Y BZV49-C62 Phi O SOT89 62V 1W zener
63Q MMBFJ304 Nat F - n-ch jfet vhf J304
63s BAT64 Sie C SOT23 Schottky 40V 250mA gp
63s BAT64W Sie C SOT323 Schottky 40V 250mA gp
64s BAT64-04 Sie D SOT23 dual ser gp Schottky 40V 250mA
64s BAT64-04W Sie D SOT323 dual ser gp Schottky 40V 250mA
65s BAT64-05 Sie B SOT23 dual cc gp Schottky 40V 250mA
65s BAT64-05W Sie B SOT323 dual cc gp Schottky 40V 250mA
66s BAT64-06 Sie A SOT23 dual ca gp Schottky 40V 250mA
66s BAT64-06W Sie A SOT323 dual ca gp Schottky 40V 250mA
67R BFP67R Tfk WQ - npn Rf fT 7.5GHz 10V 50mA
67s BAT64-07 Sie S SOT143 dual gp Schottky 40V 250mA
67s BAT64-07W Sie S SOT343 dual gp Schottky 40V 250mA
68V PZM68NB1 Phi C SOT346 68V 0.3W zener
68Y BZV49-C68 Phi O SOT89 68V 1W zener
6A MMBF4416 Mot F SOT23 2N4416 n-ch vhf jfet
6A MUN2111 Mot N SOT23 pnp dtr with 10k+10k
6A MUN5111 Mot N SOT323 pnp dtr with 10k+10k
6A BC817-16 Phi N SOT23 BC337-16
6A- BC817-16W Phi N SOT323 BC337-16
6A2 PZM6.2NB2A Phi A SOT346 dual ca 6.2V 0.3W zener
6A8 PZM6.8NB2A Phi A SOT346 dual ca 6.8V 0.3W zener
6Ap BC817-16W Phi N SOT23 BC337-16
6AR BC817-16R Phi R SOT23 BC337-16
6As BC817-16 Sie N SOT23 BC337-16
6As BC817-16 Sie N SOT323 BC337-16
6At BC817-16 Phi N SOT23 BC337-16
6At BC817-16W Phi N SOT323 BC337-16
6AZ BC817-16 Zet N SOT23 BC337-16
6B MMBF5484 Mot F SOT23 n-ch jfet 2N5484
6B BC817-25 Phi N SOT23 BC337-25
6B MUN2112 Mot N SOT23 pnp dtr 22k+22k
6B MUN5112 Mot N SOT323 MUN2112
6B- BC817-25W Phi N SOT323 BC337-25
6Bp BC817-25 Phi N SOT23 BC337-25
6BR BC817-25R Phi R SOT23R BC337-25
6Bs BC817-25 Sie N SOT23 BC337-25
6Bs BC817-25W Sie N SOT323 BC337-25
6Bt BC817-25 Phi N SOT23 BC337-25
6Bt BC817-25W Phi N SOT323 BC337-25
6BZ BC817-25 Zet N SOT23 BC337-25
6C BC817-40 Phi N SOT23 BC337-40
6C MMBFU310 Mot F SOT23 n-ch jfet U310
6C MUN2113 Mot N SOT23 pnp dtr 47k+47k
6C MUN5113 Mot N SOT323 MUN2113
6C- BC817-40W Phi N SOT323 BC337-40
6Cp BC817-40 Phi N SOT23 BC337-40
6CR BC817-40R Phi R SOT23R BC337-40
6Cs BC817-40 Sie N SOT23 BC337-40
6Cs BC817-40W Sie N SOT323 BC337-40
6Ct BC817-40 Phi N SOT23 BC337-40
6Ct BC817-40W Phi N SOT323 BC337-40
6CZ BC817-40 Zet N SOT23 BC337-40
6D MMBF5457 Mot F SOT23 2N5457 n-ch jfet
6D MUN2114 Mot N SOT23 pnp dtr 10k+47k
6D MUN5114 Mot N SOT323 MUN21141
6D- BC817W Phi N SOT323 BC337
6Dp BC817 Phi N SOT23 BC337
6Dt BC817 Phi N SOT23 BC337
6Dt BC817W Phi N SOT323 BC337
6DZ BC817 Zet N SOT23 BC337
6E FMMT-A93R Zet R SOT23R MPSA93
6E MMBF5460 Mot F SOT23 p-ch jfet 2N5460
6E BC818-16 Phi N SOT23 BC338-16
6E MUN2115 Mot N SOT23 pnp dtr R1 10k
6E MUN5115 Mot N SOT323 MUN2115
6ER BC818-16R Phi R SOT23 BC338-16
6Es BC818-16 Sie N SOT23 BC338-16
6Es BC818-16W Sie N SOT323 BC338-16
6EZ BC818-16 Zet N SOT23 BC338-16
6F MMBF4860 Mot F SOT23 2N4860 n-ch jfet
6F BC818-25 Phi N SOT23 BC338-25
6F MUN2116 Mot N SOT23 pnp dtr R1 4k7
6F MUN5116 Mot N SOT323 MUN2116
6F Gali-6F MC AZ SOT89 DC-4GHz MMIC amp 12 dB gain
6FR BC818-25R Phi R SOT23R BC338-25
6Fs BC818-25 Sie N SOT23 BC338-25
6Fs BC818-25W Sie N SOT323 BC338-25
6FZ BC818-25 Zet N SOT23 BC338-25
6G BC818-40 Phi N SOT23 BC338-40
6G MMBF4393 Mot F SOT23 n-ch jfet 2N4393
6G MUN2130 Mot N SOT23 pnp dtr 1k0+1k0
6G MUN5130 Mot N SOT323 "ial"">MUN2130 "
6GR BC818-40R Phi R SOT23 BC338-40
6Gs BC818-40 Sie N SOT23 BC338-40
6Gs BC818-40W Sie N SOT323 BC338-40
6GZ BC818-40 Zet N SOT23 BC338-40
6H MMBF5486 Mot F SOT23 n-ch jfet 2N5486
6H MUN2131 Mot N SOT23 pnp dtr 2k2 +2k2
6H MUN5131 Mot N SOT323 MUN2121
6Hp BC818 Phi N SOT23 BC338
6HZ BC818 Zet N SOT23 BC338
6J MMBF4391 Mot F SOT23 n-ch jfet 2N4391
6J MUN2132 Mot N SOT23 pnp dtr 4k7+ 4k7
6J MUN5132 Mot N SOT323 MUN2132
6K MMBF4932 Mot F SOT23 n-ch jfet 2N4932
6K MUN2133 Mot N SOT23 pnp dtr 4k7+ 47k
6K MUN5133 Mot N SOT323 MUN2133
6L MMBF5459 Mot F SOT23 n-ch jfet 2N5459
6L MUN2134 Mot N SOT23 pnp dtr 22k+47k
6L MUN5134 Mot N SOT323 MUN2134
6M MMBF5485 Nat F SOT23 n-ch jfet vhf 2N5485
6N MMBF4861 Nat F SOT23 n-ch jfet sw/chopper
6P MMBFJ111 Nat F - J111 n-ch jfet
6P BCX71HR Phi R SOT23R BCX79
6P MMBFJ113 Nat F - J113 n-ch jfet
6Q MMBFJ305 Nat F - n-chjfet vhf J305
6R MMBFJ112 Nat F - J112 n-chjfet
6S MMBFJ176 Nat F - J176 n-ch jfet
6S MMSD71 Mot C - gp Si diode
6T BCW68GR Sie R - pnp 45V 0.8A 350mW
6T MMBFJ310 Mot F SOT23 uhf n-ch jfet J310
6U MMBFJ309 Nat F SOT23 uhf n-ch jfet J309
6V BCW65CR Zet R SOT23R npn 32V 0.8A
6V MMBFJ174 Nat F - J174 p-ch jfet sw/chopper
6V2 PZM6.2NB Phi C SOT346 6.2V 0.3W zener
6V8 PZM6.8NB Phi C SOT346 6.8V 0.3W zener
6W BCW67CR Zet R SOT23R pnp32V 0.8A
6W MMBFJ175 Mot F SOT23 J175 p-ch jfet
6X MMBFJ174 Nat F - J174 p-ch jfet sw/chopper
6Y MMBFJ177 Mot F SOT23 J177 p-ch jfet
6Y2 BZV49-C6V2 Phi O SOT89 6.2V 1W zener
6Y8 BZV49-C6V8 Phi O SOT89 6.8V 1W zener
6Z MMBF170 Mot M SOT23 tmosfet n-ch Vds 60V
7 (white) BBY55-02W Sie I SCD80 UHF Varicap
73- BAS70W Phi C SOT323 schottky diode 70V 50mA
73p BAS70 Phi C SOT23 schottky diode 70V 50mA
73s BAS70 Sie C SOT23 schottky diode 70V 50mA
73S BFQ73S Sie CX SOT173 npn fT 5.3GHz 15V 100mA
73t BAS70 Phi C SOT23 schottky diode 70V 50mA
73t BAS70W Phi C SOT323 schottky diode 70V 50mA
74p BAS70-04 Phi D SOT23 dual series BAS70
74s BAS70-04 Sie D SOT23 dual series BAS70
74t BAS70-04 Phi D SOT23 dual series BAS70
74t BAS70-04W Phi D SOT323 dual series BAS70
75- BAS70-05W Phi B SOT323 dual cc BAS70
75p BAS70-05 Phi B SOT23 dual cc BAS70
75s BAS70-05 Sie B SOT23 dual cc BAS70
75s BAS70-05W Sie B SOT323 dual cc BAS70
75t BAS70-05W Phi B SOT323 dual cc BAS70
75t BAS70-05 Phi B SOT23 dual cc BAS70
75Y BZV49-C75 Phi O SOT89 75V 1W zener
76- BAS70-06W Phi A SOT323 dual ca BAS70
76p BAS70-06 Phi A SOT23 dual ca BAS70
76s BAS70-06 Sie A SOT23 dual ca BAS70
76t BAS70-06 Phi A SOT23 dual ca BAS70
76t BAS70-06W Phi A SOT323 dual ca BAS70
77s BAS70-07 Sie S SOT143 dual BAS70
77s BAS70-07 Sie S SOT343 dual BAS70
7A MMBR901 Mot N SOT23 npn RF MRF901
7A MUN5211DW1 Mot DN SOT363 dual npn dtr 10k+10k
7A5 PZM7.5NB2A Phi A SOT346 dual ca 7.5V 0.3W zener
7B MMBR920 Mot N SOT23 npn RF ?MRF920
7B MUN5212DW1 Mot DN SOT363 dual npn dtr 22k+22k
7C MMBR930 Mot N SOT23 npn RF ?MRF930
7C MUN5213DW1 Mot DN SOT363 dual npn dtr 47k+47k
7D MMBR931 Mot N SOT23 npn RF ?MRF931
7D HD4A Zet A - ca dual HD3A
7D MUN5214DW1 Mot DN SOT363 dual npn dtr 10k+47k
7E FMMT-A42R Zet R - MPSA42
7E MMBR2060 Mot N - npn RF fT 1GHz Vce 30V 50mA
7E MUN5215DW1 Mot DN SOT363 dual npn 10k base res
7F MMBR4957 Mot N - npn RF fT 1.2GHz 30V 30mA
7F MUN5211DW1 Mot DN SOT363 dual npn dtr R1 4k7
7G MMBR5031 Mot N SOT23 npn RF fT 1GHz 10V 20mA
7G MUN5230DW1 Mot DN SOT363 dual npn dtr 1k0+1k0
7H MMBR5179 Mot N SOT23 npn RF 2N5179/BFY90
7H MUN5231DW1 Mot DN SOT363 dual npn dtr 2k2+2k2
7J FMMT38C Zet N SOT23 BCX38C
7J MUN5232DW1 Mot DN SOT363 dual npn dtr 4k7+4k7
7K MMBR2857 Mot N - npn RF fT 1GHz Vce 15V 40mA
7K MUN5233DW1 Mot DN SOT363 dual npn dtr 4k7+47k bias
7L MUN5234DW1 Mot DN SOT3636 dual npn dtr 22k+47k bias
7M MUN5235DW1 Mot DN SOT363 dual npn dtr 2k2+47k bias
7M MMBR521L Mot N SOT23 pnp RF MRF521
7M BCW66HR Zet R SOT23R npn 45V 0.8A
7N MMBR941BL Mot N SOT23 npn RF fT 8GHx MRF941
7N BCW68HR Zet R SOT23 pnp 45V 0.8A
7P BCW66FR SGS R SOT23R npn 45V 0.8A 350mW
7P MMBR911L Mot N SOT23 npn RF fT 6GHz MRF911
7R MMBR536 Mot N - npn RF MRF536
7T BCW68FR Zet R SOT23R pnp 45V 0.8A
7V5 PZM7.5NB Phi C SOT346 7.5V 0.3W zener
7X MMBR571L Mot N SOT23 npn RF fT 8GHz MRF571
7Y MMBR941L Mot N SOT23 npn RF fT 8GHz MRF941
7Y5 BZV49-C7V5 Phi O SOT89 7.5V 1W zener
7Z MMBR951L Mot N SOT23 npn RF fT7.5GHz MRF951
8 (yellow) BBY58-03W Sie I SOD323 varicap
81A MMBZ5250B Mot C SOT23 20V zener 0.225W
81A PMBZ5250B Phi C SOT23 20V zener 0.225W
81B MMBZ5251B Mot C SOT23 22V zener 0.225W
81B PMBZ5251B Phi C SOT23 22V zener 0.225W
81C MMBZ5252B Mot C SOT23 24V zener 0.225W
81C PMBZ5252B Phi C SOT23 24V zener 0.225W
81D MMBZ5253B Mot C SOT23 25V zener 0.225W
81D PMBZ5253B Phi C SOT23 25V zener 0.225W
81E MMBZ5254B Mot C SOT23 27V zener 0.225W
81E PMBZ5254B Mot C SOT23 27V zener 0.225W
81F MMBZ5255B Mot C SOT23 28V zener 0.225W
81F PMBZ5255B Sie C SOT23 28V zener 0.225W
81G MMBZ5256B Mot C SOT23 30V zener 0.225W
81G PMBZ5256B Phi C SOT23 30V zener 0.225W
81H MMBZ5257B Mot C SOT23 33V zener 0.225W
81H PMBZ5257B Phi C SOT23 33V zener 0.225W
82P BFP182T Tfk X - npn RF fT 7.5GHz 10V 35mA
83P BFP183T Tfk X - npn RF fT 7.4GHz 10V 65mA
83s BAT68 Sie C SOT23 gp Schottky 8V 130mA
83s BAT68W Sie C SOT323 gp Schottky 8V 130mA
84s BAT68-04 Sie D SOT23 dual ser gp Schottky 8V 130mA
84s BAT68-04W Sie D SOT323 dual ser gp Schottky 8V 130mA
85s BAT68-05 Sie B SOT23 gp dual cc Schottky 8V 130mA
85s BAT68-05W Sie B SOT323 gp dual cc Schottky 8V 130mA
86s BAT68-06 Sie A SOT23 gp dual ca Schottky 8V 130mA
86s BAT68-06W Sie A SOT323 gp dual ca Schottky 8V 130mA
87s BAT68-07 Sie S SOT143 gp dual schottky 8V 130mA
8A NJM78L02A NJR KQ SOT89 78L 2.0V 0.1A regulator
8A MMBZ5226B Mot C SOT23 3.3V zener 0.225W
8A MUN2211 Mot N SOT23 npn dtr 10k +10k
8A MUN5211 Mot N SOT323 npn dtr 10k +10k
8A2 PZM8.2NB2A Phi C SOT23 dual ca 8.2V 0.3W zener
8B NJM78L03A NJR KQ SOT89 78L 3.0V 0.1A regulator
8B MMBZ5227B Mot C SOT23 3.6V zener 0.225W
8B MUN2212 Mot N SOT23 npn dtr 22k+22k
8B MUN5212 Mot N SOT323 npn dtr 22k+22k
8C NJM78L05A NJR KQ SOT89 78L 5.0V 0.1A regulator
8C MMBZ5228B Mot C SOT23 3.9V zener 0.225W
8C MUN2213 Mot N SOT23 npn dtr 47k + 47k
8C MUN5213 Mot N SOT323 npn dtr 47k + 47k
8D MUN2214 Mot N SOT23 npn dtr 10k + 47k
8D MUN5214 Mot N SOT323 MUN2214
8E NJM78L06A NJR KQ SOT89 78L 6.0V 0.1A regulator
8E FMMT-A92R Zet R SOT23R MPSA92
8E MMBZ5230B Mot C SOT23 4.7V zener 0.225W
8E MUN2215 Mot N SOT23 npn dtr R1 10k
8E MUN5215 Mot N SOT323 npn dtr R1 10k
8F NJM78L07A NJR KQ SOT89 78L 7.0V 0.1A regulator
8F MMBZ5231B Mot C SOT23 5.1V zener 0.225W
8F MUN2216 Mot N SOT23 npn dtr R1 4k7
8F MUN5216 Mot N SOT323 MUN2216
8G NJM78L08A NJR KQ SOT89 78L 8.0V 0.1A regulator
8G MMBZ5232B Mot C SOT23 5.6V zener 0.225W
8G MUN2230 Mot N SOT23 npn dtr 1k0+1k0
8G MUN5230 Mot N SOT323 npn dtr 1k0+1k0
8H NJM78L09A NJR KQ SOT89 78L 9.0V 0.1A regulator
8H MMBZ5233B Mot C SOT23 6.0V zener 0.225W
8H MUN2231 Mot N SOT23 npn dtr 2k2+2k2
8H MUN5231 Mot N SOT323 npn dtr 2k2+2k2
8J NJM78L10A NJR KQ SOT89 78L 10V 0.1A regulator
8J MMBZ5234B Mot C SOT23 6.2V zener 0.225W
8J MUN2232 Mot N SOT23 npn dtr 4k7+ 4k7
8J MUN5232 Mot N SOT323 npn dtr 4k7+ 4k7
8K NJM78L12A NJR KQ SOT89 78L 12V 0.1A regulator
8K MMBZ5235B Mot C SOT23 6.8V zener 0.225W
8K MUN2233 Mot N SOT23 npn dtr 4k7+ 47k
8K MUN5233 Mot N SOT323 npn dtr 4k7+ 47k
8L NJM78L15A NJR KQ SOT89 78L 15V 0.1A regulator
8L MMBZ5236B Mot C SOT23 7.5V zener 0.225W
8L MUN2234 Mot N SOT23 npn dtr 22k + 47k
8L MUN5234 Mot N SOT323 npn dtr 22k + 47k
8M NJM78L18A NJR KQ SOT89 78L 18V 0.1A regulator
8M MMBZ5237B Mot C SOT23 8.2V zener 0.225W
8N NJM78L20A NJR KQ SOT89 78L 20V 0.1A regulator
8N MMBZ5238B Mot C SOT23 8.7V zener 0.225W
8P NJM78L24A NJR KQ SOT89 78L 24V 0.1A regulator
8P MMBZ5239B Mot C SOT23 9.1V zener 0.225W
8Q MMBZ5240B Mot C SOT23 10V zener 0.225W
8R MMBZ5241B Mot C SOT23 11V zener 0.225W
8S MMBZ5242B Mot C SOT23 12V zener 0.225W
8T MMBZ5243B Mot C SOT23 13V zener 0.225W
8U MMBZ5244B Mot C SOT23 14V zener 0.225W
8V MMBZ5245B Mot C SOT23 15V zener 0.225W
8V2 PZM8.2NB Phi C SOT23 8.2V 0.3W zener
8W MMBZ5246B Mot C SOT23 16V zener 0.225W
8X MMBZ5247B Mot C SOT23 17V zener 0.225W
8Y MMBZ5248B Mot C SOT23 18V zener 0.225W
8Y2 BZV49-C8V2 Phi O SOT89 8.2V 1W zener
8Z NJM78L62A NJR KQ SOT89 78L 6.2V 0.1A regulator
8Z MMBZ5249B Mot C SOT23 19V zener 0.225W
91A FMMT730A Zet N SOT23 pnp 40V 1A 0.5W fT 150 MHz
92V BFP92A Tfk W - npn RF 6GHz 16V 30mA
9A FMMT2369AR Zet R SOT23 2N2369A
9A DTA125TUA Roh N SC70 pnp dtr R1 200k 50V 100mA
9A DTA125TKA Roh N SC59 pnp dtr R1 200k 50V 100mA
9A PLVA650A Phi C SOT23 5.0V avalanche reg diode
9A1 PZM9.1NB2A Phi A SOT346 dual ca 9.1V 0.3W zener
9B NJM79L03UA NJR KQR SOT89 79L reg 3.0V 0.1A
9B PLVA653A Phi C SOT23 5.3V avalanche reg diode
9C NJM79L05UA NJR KQR SOT89 79L reg 5.0V 0.1A
9C PLVA656A Phi C SOT23 5.6V avalanche reg diode
9D PLVA659A Phi C SOT23 5.9V avalanche reg diode
9E NJM79L06UA NJR KQR SOT89 79L reg 6.0V 0.1A
9E PLVA662A Phi C SOT23 6.2V avalanche reg diode
9F PLVA665A Phi C SOT23 6.5V avalanche reg diode
9G NJM79L08UA NJR KQR SOT89 79L reg 8.0V 0.1A
9G PLVA668A Phi C SOT23 6.8V avalanche reg diode
9H NJM79L09UA NJR KQR SOT89 79L reg 9.0V 0.1A
9J PLVA2650A Phi A SOT23 dual ca 5.0V reg diode
9K NJM79L12UA NJR KQR SOT89 79L reg 12V 0.1A
9K PLVA2653A Phi A SOT23 dual ca 5.3V reg diode
9L NJM79L15UA NJR KQR SOT89 79L reg 15V 0.1A
9L PLVA2656A Phi A SOT23 >dual 5.60V reg diode
9M NJM79L18UA NJR KQR SOT89 79L reg 18V 0.1A
9M PLVA2659A Phi A SOT23 dual ca 5.9V reg diode
9N PLVA2662A Phi A SOT23 dual ca 6.2V reg diode
9O PLVA2665A Phi A SOT23 dual ca 6.5V reg diode
9P NJM79L24UA NJR KQR SOT89 79L reg 24V 0.1A
9P PLVA2668A Phi A SOT23 dual ca 6.8V reg diode
9P BCX70HR Zet R SOT23 BCX70H
9R FMMT2369R Zet R SOT23 2N2369
9V1 PZM9.1NB Phi C SOT346 9.1V 0.3W zener
9Y1 BZV49-C9V1 Phi O SOT89 9.1V 1W zener
A MRF947 Mot N SOT323 npn RF 8 GHz
A BA892 Sie I SCD80 35V 100mA pin
A 1SS355 Roh I USM 100V 50mA sw
A0 HSMS-2800 HP C SOT23 HP2800 schottky
A0 HSMS-280B HP C SOT323 HP2800 schottky
A03 VAM-03 MC AQ - modamp MAR 3 Similar
A06 VAM-06 MC AQ - modamp MAR 6 Similar
A07 VAM-07 MC AQ - modamp MAR 7 Similar
A1 HSMS-2801 HP K - HP2800 schottky
A1 BAW56W Phi A SOT323 dual ca BAW62 (1N4148)
A1 BAW56 Phi A SOT23 dual ca BAW62 (1N4148)
A11 MMBD1501A Fch C SOT23 180V 200mA diode
A13 MMBD1503A Fch D SOT23 180V 200mA dual diode series
A14 MMBD1504A Fch B SOT23 180V 200mA dual diode cc
A15 MMBD1505A Fch A SOT23 180V 200mA dual diode ca
A16 ZC934A Zet C SOT23 25-95pF hyperabrupt varicap
A17 ZC933A Zet C SOT23 12-42pF hyperabrupt varicap
A1p BAW56 Phi A SOT23 dual ca BAW62 (1N4148)
A1s BAW56W Sie A SOT323 dual ca BAW62 (1N4148)
A1s BAW56 Sie A SOT23 dual ca BAW62 (1N4148)
A1s BAW56U Sie A SC74 dual ca BAW62 (1N4148)
A1t BAW56T Phi A SOT416 dual ca BAW62 (1N4148)
A1t BAW56S Phi SOT363 dual ca BAW62 (1N4148)
A1X MBAW56 Mot A - ditto
A2 HSMS-2802 HP D SOT23 dual HP2800
A2 HSMS-280C HP D SOT323 dual HP2800
A2 BAT18 Phi C SOT23 BA482
A2 MMBD2836 Mot A SOT23 dual ca sw diode 75V
A2 CFY30 Sie CQ SOT143 n-ch GaAsfet 6 GHz
A2 MBT3906DW1 Mot DO SOT363 dual 2N3906
A22 BAS21 Phi C SOD27 BAV21
A2s BAT18 Sie C SOT23 BA482
A2X MMBD2836 Mot A SOT23 dual ca sw 75V 100mA 15ns
A3 BAP64-03 Phi I SOD323 3 GHz pin diode
A3 HSMS-2803 HP D SOT23 HP2800 ser pair
A3 MMBD1005 Mot A SOT23 dual ca Si diode low leakage
A3 BAS16 Zet C - Si sw 75V 100mA
A3 BAT17 Phi C SOT23 BA481
A3 MBT3906DW Mot N SOT363 dual 2N3906
A3p BAT17 Phi C SOT23 BA481
A3t BAT17 Phi C SOT23 BA481
A3X MMBD2835 Mot A SOT23 dual ca sw 35V 100mA 15nS
A4 HSMS-2804 HP B SOT23 dual cc HP2800 schottky
A4 BAV70W Phi B SOT323 dual cc BAW62
A4p BAV70 Phi B SOT23 dual cc BAW62
A4s BAV70W Sie B SOT323 dual cc BAW62
A4s BAV70 Sie B SOT23 dual cc BAW62
A4s BAV70T Sie B SOT416 dual cc BAW62
A4s BAV70U Sie B SC74 dual cc BAW62
A4t BAV70 Phi B SOT23 dual cc BAW62
A4t BAV70 Phi B SOT363 dual cc BAW62
A4X MBAV70 Mot B - ditto
A5 BAP51-03 Phi I SOD323 GP RF pin diode
A5 HSMS-2805 HP S SOT143 dual HP2800 schottky
A5 MMBD1010 Mot B SOT23 dual cc Si diodes
A5 MMBD2837 Mot B SOT23 dual cc diodes 30V 150mA
A51 BRY62 Phi - SOT143 -
A5p BRY61 Phi - SOT143 -
A5t BRY61 Phi - SOT143 -
A6 BAS16W Phi C SOT323 BAW62 (1N4148)
A6 BAS16T Phi C SOT416 BAW62 (1N4148)
A6 BAS216 Phi I SOD110 BAW62 (1N4148)
A6 MMBD2836 Mot B SOT23 dual sw diode cc 75V
A6A MMUN2111 Mot N SOT23 pnp dtr 10k+10k
A6B MMUN2112 Mot N SOT23 pnp dtr 22k+22k
A6C MMUN2113 Mot N SOT23 pnp dtr 47k+47k
A6D MMUN2114 Mot N SOT23 pnp dtr 100k+100k
A6E MMUN2115 Mot N SOT23 pnp dtr R1 10k
A6F MMUN2116 Mot N SOT23 pnp dtr R1 4k7
A6G MMUN2130 Mot N SOT23 pnp dtr 1k0+1k0
A6H MMUN2131 Mot N SOT23 pnp dtr 2k2+2k2
A6J MMUN2132 Mot N SOT23 pnp dtr 4k7+4k7
A6K MMUN2133 Mot N SOT23 pnp dtr 4k7+47k
A6L MMUN2134 Mot N SOT23 pnp dtr 22k+47k
A6p BAS16 Phi C SOT23 BAW62 (1N4148)
A6p BAS316 Phi I SOD323 BAW62 (1N4148)
A6s BAS16W Sie C SOT323 BAW62 (1N4148)
A6s BAS16 Sie C SOT23 BAW62 (1N4148)
A6s BAS16U Sie C SC74 BAW62 (1N4148)
A6t BAS16 Phi C SOT23 BAW62 (1N4148)
A6X MMBD2838 Mot B SOT23 dual sw 50V 100mA
A7 BAV99W Phi D SOT323 dual ser BAW92
A7 BAV99 Phi D SOT23 dual ser BAW92
A7 HSMS-2807 HP RQ SOT143 HP2800 ring quad
A7s BAV99 Sie D SOT23 dual ser BAW92
A7s BAV99W Sie D SOT323 dual ser BAW92
A7s BAV99T Sie D SC75 dual ser BAW92
A7s BAV99U Sie D SC74 dual ser BAW92
A8 HSMS-2808 HP BQ SOT143 HP2800 bridge quad
A8 BAP50-03 Phi I SOD323 GP RF pin diode
A8 BAS19 Phi C SOT23 BAV19
A8 SI2308DS Sil M SOT23 "N-ch mosfet, 60V 0.1A"
A81 BAS20 Phi C SOT23 BAV20
A82 BAS21 Phi C SOT23 BAV21
A8A MMUN2211 Mot N SOT23 npn dtr 10k +10k
A8B MMUN2212 Mot N SOT23 npn dtr 22k +22k
A8C MMUN2213 Mot N SOT23 npn dtr 47k+47k
A8D MMUN2214 Mot N SOT23 npn dtr 100k+100k
A8E MMUN2215 Mot N SOT23 npn dtr R1 10k
A8F MMUN2216 Mot N SOT23 npn dtr R1 4k7
A8G MMUN2230 Mot N SOT23 npn dtr 1k0 +1k0
A8H MMUN2231 Mot N SOT23 npn dtr 2k2+2k2
A8J MMUN2232 Mot N SOT23 npn dtr 4k7+4k7
A8K MMUN2233 Mot N SOT23 npn dtr 4k7+47k
A8L MMUN2234 Mot N SOT23 npn dtr 22k+47k
A9 SI2309DS Sil M SOT23 "P-ch mosfet, 60V 0.1A"
A91 BAS17 Phi C SOT23 BA314
AA BCX51 Sie P SOT89 pnp 45V audio comp BCX54
AA BCW60A TT N SOT23 BCY58-vii
AA ZMV829A Zet I SOD323 varicap hyperabrupt 28V 8.2pF@2V
AAA MMBF4856 Mot F SOT23 2N4856 n-ch chopper jfet
AAAA MAX809LXR MAX ZB SOT23 microproc -ve reset gen 5.0V
AAAX MAX2470 MAX DT SOT23-6 VCO Buffer Amplifiers
AAAY MAX2471 MAX DT SOT23-6 VCO Buffer Amplifiers
AAG MMBR951AL Mot N SOT23 npn RF 8GHz
AAH MAX6326_R22-T Max ZB SC70 microproc -ve reset gen 2.200V
AAI MAX6327_R22-T Max ZB SC70 microproc +ve reset gen 2.200V
AAJ MAX6328_R22-T Max ZB SC70 microproc -ve reset gen 2.200V
AAK MAX6410BS33-T Max UC4 UCSP-4 "Volt. Detect. (3.300 V / Push-Pull,Active-High)"
AAL MAX6410BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V / Push-Pull,Active-High)"
AAM MAX6410BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V / Push-Pull,Active-High)"
AAN MAX6410BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V / Push-Pull,Active-High)"
AAN MAX809LXR Max ZB SC70 microproc -ve reset gen 5.0V
AAO MAX6410BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V / Push-Pull,Active-High)"
AAO MAX809MXR Max ZB SC70 microproc -ve reset gen 5.0V
AAP MAX6410BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V / Push-Pull,Active-High)"
AAP MAX809TXR Max ZB SC70 microproc -ve reset gen 3.3V
AAQ MAX6410BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V / Push-Pull,Active-High)"
AAQ MAX809SXR Max ZB SC70 microproc -ve reset gen 3.3V
AAR MAX6410BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V / Push-Pull,Active-High)"
AAR MAX809RXR Max ZB SC70 microproc -ve reset gen 3.0V
AAs BCW60A Sie N SOT23 BCY58-vii
AAS MAX6410BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V / Push-Pull,Active-High)"
AAS MAX803ZXR Max ZB SC70 microproc -ve reset gen 2.5V
AAT MAX6410BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V / Push-Pull,Active-High)"
AAT MAX810LXR Max ZB SC70 microproc +ve reset gen 5.0V
AAU MAX6410BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V / Push-Pull,Active-High)"
AAU MAX810MXR Max ZB SC70 microproc +-ve reset gen 5.0V
AAV MAX6410BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V / Push-Pull,Active-High)"
AAV MAX810TXR Max ZB SC70 microproc +ve reset gen 3.3V
AAW MAX6410BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V / Push-Pull,Active-High)"
AAW MAX810RXR Max ZB SC70 microproc +ve reset gen 3.0V
AAX MAX6410BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.630 V / Push-Pull,Active-High)"
AAX MAX810SXR Max ZB SC70 microproc +ve reset gen 3.3V
AAY MAX6411BS33-T Max UC4 UCSP-4 "Volt. Detect. (3.300 V/Open Drain,Active-Low)"
AAY MAX810ZXR Max ZB SC70 microproc +ve reset gen 2.5V
AAZ MAX6411BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V/Open Drain,Active-Low)"
AAZ MAX803LXR Max ZB SC70 microproc -ve reset gen 5.0V
AB BCW60B ITT N SOT23 BCY58-viii
AB ZMV830A Zet I SOD323 varicap hyperabrupt 28V 10pF@2V
ABA MAX6411BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V/Open Drain,Active-Low)"
ABA MAX803TXR Max ZB SC70 microproc -ve reset gen 5.0V
ABAA MAX809MXR Max ZB SOT23 microproc -ve reset gen 5.0V
ABB MAX6411BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V/Open Drain,Active-Low)"
ABB MAX803MXR Max ZB SC70 microproc -ve reset gen 3.3V
ABC MAX6411BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V/Open Drain,Active-Low)"
ABC MAX803SXR Max ZB SC70 microproc -ve reset gen 3.3V
ABD MAX6411BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V/Open Drain,Active-Low)"
ABD MAX803RXR Max ZB SC70 microproc -ve reset gen 3.0V
ABE MAX6411BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V/Open Drain,Active-Low)"
ABE MAX803ZXR Max ZB SC70 microproc -ve reset gen 2.5V
ABF MAX6411BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V/Open Drain,Active-Low)"
ABF LM4041AIX3-1.2 Max L SC70 1.225V 0.1% shunt V ref
ABG MAX6411BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V/Open Drain,Active-Low)"
ABG LM4041BIX3-1.2 Max L SC70 1.225V 0.2% shunt V ref
ABH MAX6411BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V/Open Drain,Active-Low)"
ABH LM4041DIX3-1.2 Max L SC70 1.225V 0.5% shunt V ref
ABI MAX6411BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V/Open Drain,Active-Low)"
ABI LM4041DIX3-1.2 Max L SC70 1.225V 1.5% shunt V ref
ABJ MAX6411BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V/Open Drain,Active-Low)"
ABJ LM4040AIX3-2.1 Max L SC70 2.048V 0.1% shunt V ref
ABK MAX6411BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V/Open Drain,Active-Low)"
ABK LM4040BIX3-2.1 Max L SC70 2.048V 0.2% shunt V ref
ABL MAX6411BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.640 V/Open Drain,Active-Low)"
ABL LM4040CIX3-2.1 Max L SC70 2.048V 0.5% shunt V ref
ABM LM4040DIX3-2.1 Max L SC70 2.048V 1% shunt V ref
ABN LM4040AIX3-2.5 Max L SC70 2.5001% shunt V ref
ABO LM4040BIX3-2.5 Max L SC70 2.500V 0.2% shunt V ref
ABp BCW60B Phi N SOT23 BCY58-viii
ABP LM4040CIX3-2.5 Max L SC70 2.500V 0.5% shunt V ref
ABQ LM4040DIX3-2.5 Max L SC70 2.500V 1% shunt V ref
ABR LM4040AIX3-3.0 Max L SC70 3.000V 0.1% shunt V ref
ABs BCW60B Sie N SOT23 BCY58-viii
ABS LM4040BIX3-3.0 Max L SC70 3.000V 0.2% shunt V ref
ABt BCW60B Phi N SOT23 BCY58-viii
ABT LM4040CIX3-3.0 Max L SC70 3.000V 0.5% shunt V ref
ABU LM4040DIX3-3.0 Max L SC70 3.000V 1% shunt V ref
ABV LM4040AIX3-4.1 Max L SC70 4.096V 0.1% shunt V ref
ABW LM4040BIX3-4.1 Max L SC70 4.096V 0.2% shunt V ref
ABX LM4040CIX3-4.1 Max L SC70 4.096V 0.5% shunt V ref
ABY LM4040DIX3-4.1 Max L SC70 4.096V 1% shunt V ref
ABZ LM4040AIX3-5.0 Max L SC70 5.000V 0.1% shunt V ref
AC BCX51-100 Sie P SOT89 45V pnp audio hfe 100
AC BCX51-10 Phi P SOT89 45V pnp audio hfe 100
AC BCW60C Phi N SOT23 BCY58-ix
AC ZMV831A Zet I SOD323 varicap hyperabrupt 28V 15pF@2V
ACA LM4040BIX3-5.0 Max L SC70 5.000V 0.2% shunt V ref
ACAA MAX809TXR Max ZB SOT23 microproc -ve reset gen 3.3V
ACB LM4040CIX3-5.0 Max L SC70 5.000V 0.5% shunt V ref
ACC LM4040DIX3-5.0 Max L SC70 5.000V 1% shunt V ref
ACE MAX6326_R31-T Max ZB SC70 microproc -ve reset gen 3.080V
ACF MAX6347_R46-T Max ZB SC70 microproc +ve reset gen 4.630V
ACH MAX6326_R23-T Max ZB SC70 microproc -ve reset gen 2.320V
ACI MAX6326_R26-T Max ZB SC70 microproc -ve reset gen 2.630V
ACJ MAX6328_R26-T Max ZB SC70 microproc -ve reset gen 2.630V
ACK MAX6346_R44-T Max ZB SC70 microproc -ve reset gen 4.380V
ACL MAX6347_R44-T Max ZB SC70 microproc +ve reset gen 4.380V
ACM MAX6348_R46-T Max ZB SC70 microproc -ve reset gen 4.630V
ACN MAX6348_R44-T Max ZB SC70 microproc -ve reset gen 4.380V
ACO MAX6346_R46-T Max ZB SC70 microproc -ve reset gen 4.630V
ACp BCW60C Phi N SOT23 BCY58-ix
ACP MAX6326_R29-T Max ZB SC70 microproc -ve reset gen 2.930V
ACQ MAX6327_R23-T Max ZB SC70 microproc +ve reset gen 2.320V
ACR MAX6327_R26-T Max ZB SC70 microproc +ve reset gen 2.630V
ACs BCW60C Sie N SOT23 BCY58-ix
ACS MAX6327_R29-T Max ZB SC70 microproc +ve reset gen 2.930V
ACt BCW60C Phi N SOT23 BCY58-ix
ACT MAX6327_R31-T Max ZB SC70 microproc +ve reset gen 3.080V
ACU MAX6328_R23-T Max ZB SC70 microproc -ve reset gen 2.320V
ACV MAX6328_R29-T Max ZB SC70 microproc -ve reset gen 2.930V
ACW MAX6326_R31-T Max ZB SC70 microproc -ve reset gen 3.080V
AD BCX51-160 Sie P SOT89 45V pnp audio hfe 160
AD BCX51-16 Phi P SOT89 45V pnp audio hfe 160
AD BCW60D Phi N SOT23 BCY58-x
AD ZMV832A Zet I SOD323 varicap hyperabrupt 28V 22pF@2V
ADAA MAX809SXR Max ZB SOT23 microproc -ve reset gen 3.3V
ADN 2SC3838K Roh N - npn 11V 3.2GHz TV tuners
ADp BCW60D Phi N SOT23 BCY58-x
ADs BCW60D Sie N SOT23 BCY58-x
ADt BCW60D Ph N SOT23 BCY58-x
ADW MAX6406BS22-T Max UC4 UCSP-4 "Volt. Detect. (2.200 V / Push-Pull, Active-Low)"
ADX MAX6406BS23-T Max UC4 UCSP-4 "Volt. Detect. (2.320 V / Push-Pull, Active-Low)"
ADY MAX6406BS24-T Max UC4 UCSP-4 "Volt. Detect. (2.400 V / Push-Pull, Active-Low)"
ADZ MAX6406BS25-T Max UC4 UCSP-4 "Volt. Detect. (2.500 V / Push-Pull, Active-Low)"
AE BCX52 Sie P SOT89 pnp 60V audio comp BCX55
AE ZMV833A Zet I SOD323 varicap hyperabrupt 28V 33pF@2V
AEA MAX6406BS26-T MAX UC4 UCSP-4 "Volt. Detect. (2.630 V / Push-Pull, Active-Low)"
AEB MAX6406BS27-T MAX UC4 UCSP-4 "Volt. Detect. (2.700 V / Push-Pull, Active-Low)"
AEC MAX6406BS28-T MAX UC4 UCSP-4 "Volt. Detect. (2.800 V / Push-Pull, Active-Low)"
AED MAX6406BS29-T MAX UC4 UCSP-4 "Volt. Detect. (2.930 V / Push-Pull, Active-Low)"
AEE MAX6406BS30-T MAX UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull, Active-Low)"
AEF MAX6406BS31-T MAX UC4 UCSP-4 "Volt. Detect. (3.080 V / Push-Pull, Active-Low)"
AEG MAX6407BS22-T MAX UC4 UCSP-4 "Volt. Detect. (2.200 V / Push-Pull, Active-High)"
AEH MAX6407BS23-T MAX UC4 UCSP-4 "Volt. Detect. (2.300 V / Push-Pull, Active-High)"
AEI MAX6407BS24-T MAX UC4 UCSP-4 "Volt. Detect. (2.400 V / Push-Pull, Active-High)"
AEJ MAX6407BS25-T MAX UC4 UCSP-4 "Volt. Detect. (2.500 V / Push-Pull, Active-High)"
AEK MAX6407BS26-T MAX UC4 UCSP-4 "Volt. Detect. (2.630 V / Push-Pull, Active-High)"
AEL MAX6407BS27-T MAX UC4 UCSP-4 "Volt. Detect. (2.700 V / Push-Pull, Active-High)"
AEM MAX6407BS28-T MAX UC4 UCSP-4 "Volt. Detect. (2.800 V / Push-Pull, Active-High)"
AEN MAX6407BS29-T MAX UC4 UCSP-4 "Volt. Detect. (2.930 V / Push-Pull, Active-High)"
AEN 2SC3839K Roh N - npn 20V 2.0GHz TV tuners
AEO MAX6407BS30-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull,Active-High)"
AEP MAX6407BS31-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V / Push-Pull,Active-High)"
AEQ MAX6408BS22-T Max UC4 UCSP-4 "Volt. Detect. (2.200 V/Open Drain,Active-Low)"
AER MAX6408BS23-T Max UC4 UCSP-4 "Volt. Detect. (2.320 V/Open Drain,Active-Low)"
AES MAX6408BS24-T Max UC4 UCSP-4 "Volt. Detect. (2.400 V/Open Drain,Active-Low)"
AET MAX6408BS25-T Max UC4 UCSP-4 "Volt. Detect. (2.500 V/Open Drain,Active-Low)"
AEU MAX6408BS26-T Max UC4 UCSP-4 "Volt. Detect. (2.630 V/Open Drain,Active-Low)"
AEV MAX6408BS27-T Max UC4 UCSP-4 "Volt. Detect. (2.700 V/Open Drain,Active-Low)"
AEW MAX6138AEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.1%)
AEW MAX6408BS28-T Max UC4 SC70-3 "Volt. Detect. (2.800 V/Open Drain,Active-Low)"
AEX MAX6138BEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.2%)
AEX MAX6408BS29-T Max UC4 UCSP-4 "Volt. Detect. (2.930 V/Open Drain,Active-Low)"
AEY MAX6138CEXR12-T Max L SC70-3 Shunt Voltage Ref. (output 1.2205 V / 0.5%)
AEY MAX6408BS30-T Max UC4 UCSP-4 "Volt. Detect. (3.000 V/Open Drain,Active-Low)"
AEZ MAX6408BS31-T Max UC4 UCSP-4 "Volt. Detect. (3.080 V/Open Drain,Active-Low)"
AF ZMV834A Zet I SOD323 varicap hyperabrupt 28V 47pF@2V
AFA MAX6138AEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.1%)
AFA MAX6409BS33-T Max - UCSP-4 "Volt. Detect. (3.300 V / Push-Pull, Active-Low)"
AFAA MAX809RXR Max ZB SOT23 microproc -ve reset gen 3.0V
AFB MAX6138BEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.2%)
AFB MAX6409BS34-T Max UC4 UCSP-4 "Volt. Detect. (3.400 V / Push-Pull, Active-Low)"
AFC MAX6138CEXR21-T Max L SC70-3 Shunt Voltage Ref. (output 2.0480 V / 0.5%)
AFC MAX6409BS35-T Max UC4 UCSP-4 "Volt. Detect. (3.500 V / Push-Pull, Active-Low)"
AFD MAX6409BS36-T Max UC4 UCSP-4 "Volt. Detect. (3.600 V / Push-Pull, Active-Low)"
AFE MAX6138AEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.1%)
AFE MAX6409BS37-T Max UC4 UCSP-4 "Volt. Detect. (3.700 V / Push-Pull, Active-Low)"
AFF MAX6138BEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.2%)
AFF MAX6409BS38-T Max UC4 UCSP-4 "Volt. Detect. (3.800 V / Push-Pull, Active-Low)"
AFG MAX6138CEXR25-T Max L SC70-3 Shunt Voltage Ref. (output 2.5000 V / 0.5%)
AFG MAX6409BS39-T Max UC4 UCSP-4 "Volt. Detect. (3.900 V / Push-Pull, Active-Low)"
AFH MAX6409BS40-T Max UC4 UCSP-4 "Volt. Detect. (4.000 V / Push-Pull, Active-Low)"
AFI MAX6138AEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.1%)
AFI MAX6409BS41-T Max UC4 UCSP-4 "Volt. Detect. (4.100 V / Push-Pull, Active-Low)"
AFJ MAX6138BEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.2%)
AFJ MAX6409BS42-T Max UC4 UCSP-4 "Volt. Detect. (4.200 V / Push-Pull, Active-Low)"
AFK MAX6138CEXR30-T Max L SC70-3 Shunt Voltage Ref. (output 3.0000 V / 0.5%)
AFK MAX6409BS43-T Max UC4 UCSP-4 "Volt. Detect. (4.300 V / Push-Pull, Active-Low)"
AFL MAX6409BS44-T Max UC4 UCSP-4 "Volt. Detect. (4.380 V / Push-Pull, Active-Low)"
AFM MAX6138AEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.1%)
AFM MAX6409BS45-T Max UC4 UCSP-4 "Volt. Detect. (4.500 V / Push-Pull, Active-Low)"
AFN MAX6138BEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.2%)
AFN MAX6409BS46-T Max UC4 UCSP-4 "Volt. Detect. (4.630 V / Push-Pull, Active-Low)"
AFO MAX6138CEXR41-T Max L SC70-3 Shunt Voltage Ref. (output 4.0960 V / 0.5%)
AFQ MAX6138AEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.1%)
AFR MAX6138BEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.2%)
AFs BCW60FF Sie N SOT23 BCY58
AFS MAX6138CEXR50-T Max L SC70-3 Shunt Voltage Ref. (output 5.0000 V / 0.5%)
AG ZMV835A Zet I SOD323 varicap hyperabrupt 28V 68pF@2V
AG BCX70G Phi N SOT23 BCY59-vii BC107
AG BCX52-10 Sie P SOT89 60V pnp BCX52 hfe 100
AGAA MAX810LXR Max ZB SOT23 microproc +ve reset gen 5.0V
AGp BCX70G Phi N SOT23 BCY59-vii BC107
AGs BCX70G Sie N SOT23 BCY59-vii BC107
AGt BCX70G Phi N SOT23 BCY59-vii BC107
AH BCX70H Phi N SOT23 BCY59-viii BC107B
AH BCP53 Mot P SOT223 pnp amp 80V 150mA
AH BCX53 Sie P SOT89 pnp 80V audio comp BCX56
AH ZMV930 Zet I SOD323 2.9-8.3pF hyperabrupt varicap
AHAA MAX810MXR Max ZB SOT23 microproc +-ve reset gen 5.0V
AHp BCX70H Phi N SOT23 BCY59-viii BC107B
AHs BCX70H Sie N SOT23 BCY59-viii BC107B
AHt BCX70H Phi N SOT23 BCY59-viii BC107B
AJ BCX70J Phi N SOT23 BCY59-ix BC107
AJ ZMV931 Zet I SOD323 4 -13.5pF hyperabrupt varicap
AJ s BCX70J Sie N SOT23 BCY59-ix BC107
AJAA MAX810TXR MAX ZB SOT23 microproc +ve reset gen 3.3V
AJp BCX70J Phi N SOT23 BCY59-ix BC107
AJt BCX70J Phi N SOT23 BCY59-ix BC107
AK BCX70K Phi N SOT23 BCY59-x BC107
AK ZMV932 Zet I SOD323 5.5-17pF hyperabrupt varicap
AK BCX53-10 Sie P SOT89 pnp 80V BCX53 hfe 100
AKAA MAX810SXR MAX ZB SOT23 microproc +ve reset gen 3.3V
AKp BCX70K Phi N SOT23 BCY59-x BC107
AKs BCX70K Sie N SOT23 BCY59-x BC107
AL BCX53-16 Sie P SOT89 80V pnp BCX53 hfe 100
AL MMBTA55L Mot N SOT23 pnp 25V (MPSA55)
AL ZMV933 Zet I SOD323 12-42pF hyperabrupt varicap
ALAA MAX810SXR MAX ZB SOT23 microproc +ve reset gen 3.0V
ALs BFP405 Sie MQ SOT343 -
AM MMBT3904W Mot N SOT323 2N3904
AM BCX52-16 Sie P SOT89 pnp 60V BCX52 hfe 160
AM BSS64 Mot N SOT23 npn 80V 0.1A fT 60MHz
AM ZMV933A Zet I SOD323 12-42pF hyperabrupt varicap
AMp BSS64 Phi N SOT23 npn 80V 0.1A fT 60MHz
AMs BFP420 Sie MQ SOT343 npn fT 25GHz 4.5V 35mA
AMs BSS64 Sie N SOT23 npn 80V 0.1A fT 60MHz
AMt BSS64 Phi N SOT23 npn 80V 0.1A fT 60MHz
AN BCW60FN Sie N SOT23 gp npn 35V 0.2A
AN ZMV934 Zet I SOD323 25-95pF hyperabrupt varicap
ANs BFP450 Sie MQ SOT343 npn fT 25GHz 4.5V 100mA
AO BCW60AR ITT R SOT23R BCY58-vii
AO ZMV934A Zet I SOD323 25-95pF hyperabrupt varicap
AP BCW60BR ITT R SOT23R BCY58-viii
APs BFP520 Sie MQ SOT343 npn fT 40GHz 2.5V 40mA
A-Q 2PD1820AQ Phi N SOT323 gp sw amp 50V npn hfe 85-170
A-Q 2PD1820AR Phi N SOT323 gp sw amp 50V npn hfe 120-240
AR BCW60CR ITT R SOT23R BCY58-ix
AR MSD709R Mot N - pnp gp 25V
AR1 BSR40 Phi P SOT89 npn 70V 1A 1.35W hfe 40-120
AR2 BSR41 Phi P SOT89 npn 70V 1A 1.35W hfe 100-300
AR3 BSR42 Phi P SOT89 npn 90V 1A 1.35W hfe 40-120
AR4 BSR43 Phi P SOT89 npn 90V 1A 1.35W hfe 100-300
AS BCW60DR ITT R SOT23R BCY58-x
AS MSD709S Mot N - pnp gp 25V
A-S 2PD1820AS Phi N SOT323 gp sw amp 50V npn hfe 170-340
AS1 BST50 Mot P SOT89 npn darlington 0.5A 60V
AS2 BST51 Mot P SOT89 npn darlington 0.5A 80V
AS3 BST52 Mot P SOT89 npn darlington 0.5A 90V
AS3 BSP52 Mot P SOT223 npn darlington 0.5A hfe 2000
ASs BAT18-05 Sie B SOT23 dual BAT18 RF pin
AtQ 2PD1820AQ Phi N SOT323 gp sw amp 50V npn hfe 85-170
AtQ 2PD1820AR Phi N SOT323 gp sw amp 50V npn hfe 120-240
AtS 2PD1820AS Phi N SOT323 gp sw amp 50V npn hfe 170-340
ATs BAT18-06 Sie A SOT23 dual ca BAT18 RF pin
ATs BFP540 Sie MQ SOT343 npn microwave
AU BCW60GR ITT R SOT23R BCY58
AUs BAT18-04 Sie D SOT23 dual BAT18 RF pin
AV DAN212K Roh C - 80V 100mA sw
AW BCW60HR ITT R SOT23R BCY58
AX BCX70JR ITT R SOT23R BCY59-ix
AY BCX70KR ITT R SOT23R BCY59-x
AY MMBD1000 Mot C SOT23 Si sw diode 30V 0.2A
B MRF957 Mot N SOT323 npn RF fT 9GHz
B BAS16-03W Sie I SOD323 Varicap 18pF 1V
B BB555 Sie I SCD80 Varicap 18pF 1V
B0 BZX399C4V3 Phi I SOD323 4.3V 0.3W zener
B0 HSMS-2810 HP C SOT23 HP2810 schottky
B0 HSMS-281B HP C SOT323 HP2810 schottky
B08 SST6908 Sil ZQ - 2N6908 prot n-ch jfet
B09 SST6909 Sil ZQ - 2N6909 prot n-ch jfet
B1 BZX399C1V8 Phi I SOD323 1.8V 0.3W zener
B1 HSMS-2811 HP K SOT23 HP2811 schottky
B1 BAS40 Mot C SOT23 schottky sw diode
B10 SST6910 Sil ZQ - 2N6910 prot n-ch jfet
B2 BZX399C2V0 Phi I SOD323 2.0V 0.3W zener
B2 BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw
B2 HSMS-2812 HP D SOT23 dual HP2810 schottky
B2 HSMS-281C HP D SOT323 dual HP2810 schottky
B26 BF570 Phi SOT23 -
B2p BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw
B2t BSV52 Phi N SOT23 BSX20 12V fT 400MHz sw
B3 BZX399C2V2 Phi I SOD323 2.2V 0.3W zener
B3 HSMS-2813 HP A SOT23 dual ca HP2810 schottky
B3 MMBD717L Mot A SOT323 dual ca schottky
B4 BZX399C2V4 Phi I SOD323 2.4V 0.3W zener
B4 BSV52R Phi R SOT23R BSX20
B4 HSMS-2814 HP B SOT23 dual cc HP2810 schottky
B5 BZX399C2V7 Phi I SOD323 2.7V 0.3W zener
B5 HSMS-2815 HP S SOT143 dual HP2810 schottky
B6 BZX399C3V0 Phi I SOD323 3.0V 0.3W zener
B6 BAT54A Mot A SOT23 dual ca 30V schottky
B7 BZX399C3V3 Phi I SOD323 3.3V 0.3W zener
B7 HSMS-2817 HP RQ SOT143 HP2810 ring quad
B8 BZX399C3V6 Phi I SOD323 3.6V 0.3W zener
B8 HSMS-2818 HP BQ SOT143 HP2810 bridge quad
B9 BZX399C3V9 Phi I SOD323 3.9V 0.3W zener
B9 2SC4617 Mot N SC90 npn gp
BA BCX54 Sie P SOT89 npn AF 45V comp BCX51
BA BCW61A Phi N SOT23 BCY78-vii
BA DAN217 Roh D - 80V 100mA dual
BA BZX399C4V7 Phi I SOD323 4.7V 0.3W zener
BAp BCW61A Phi N SOT23 BCY78-vii
BAt BCW61A Phi N SOT23 BCY78-vii
BB BCW61B Phi N SOT23 BCY78-viii
BB BAR81 Sie NQ SOT143 Dual pin shunt switch
BB BZX399C5V1 Phi I SOD323 5.1V 0.3W zener
BBp BCW61B Phi N SOT23 BCY78-viii
BBs BCW61B Sie N SOT23 BCY78-viii
BBs BAR81W Sie NQ SOT343 Dual pin shunt switch
BBt BCW61B Phi N SOT23 BCY78-viii
BC BCW61C Phi N SOT23 BCY78-ix
BC BCX54-10 Sie Phi P SOT89 npn hfe100
BC BZX399C5V6 Phi I SOD323 5.6V 0.3W zener
BCp BCW61C Phi N SOT23 BCY78-ix
BCs BCW61C Sie N SOT23 BCY78-ix
BCt BCW61C Phi N SOT23 BCY78-ix
BD BCW61D Phi N SOT23 BCY78-x
BD BCX54-16 Sie P SOT89 npn hfe160 comp BCX51-16
BD BZX399C6V2 Phi I SOD323 6.2V 0.3W zener
BD ZHCS400 Zet E SOT23 40V 0.4A schottky diode
BDp BCW61D Phi N SOT23 BCY78-x
BDs BCW61D Sie N SOT23 BCY78-x
BDt BCW61D Phi N SOT23 BCY78-x
BE BAS70 Mot C SOT23 schottky sw diode
BE BCX55 Sie P SOT89 npn AF 60V comp BCX52
BE BZX399C6V8 Phi I SOD323 6.8V 0.3W zener
BF BCW61FF Sie N SOT23 low noise BCW61
BF BZX399C7V5 Phi I SOD323 7.5V 0.3W zener
BG BCX71G Phi N SOT23 BCY79-vii
BG BCX55-10 Sie Phi P SOT89 npn hfe 100
BG BZX399C8V2 Phi I SOD323 8.2V 0.3W zener
BGp BCX71G Phi N SOT23 BCY79-vii
BGs BCX71G Sie N SOT23 BCY79-vii
BGt BCX71G Phi N SOT23 BCY79-vii
BH BCP56 Mot P SOT223 npn amp 80V 150mA
BH BCX56 Sie P SOT89 npn AF 80V
BH BZX399C9V1 Phi I SOD323 9.1V 0.3W zener i
BH BCX71H Phi N SOT23 BCY79-viii
BHp BCX71H Phi N SOT23 BCY79-viii
BHs BCX71H Sie N SOT23 BCY79-viii
BHt BCX71H Phi N SOT23 BCY79-viii
BJ BCX71J Phi N SOT23 BCY79-ix
BJ BZX399C10 Phi I SOD323 10V 0.3W zener
BJp BCX71J Phi N SOT23 BCY79-ix
BJs BCX71J Sie N SOT23 BCY79-ix
BJt BCX71J Phi N SOT23 BCY79-ix
BK BCP56-10 Mot P SOT223 npn amp 80V 150mA
BK BCX71K Phi N SOT23 BCY79
BK BCX56-10 Sie P SOT89 npn hfe 100
BK BZX399C11 Phi I SOD323 11V 0.3W zener
BKp BCX71K Phi N SOT23 BCY79
BKs BCX71K Sie N SOT23 BCY79
BKt BCX71K Phi N SOT23 BCY79
BL MBD54DW Mot DL SOT363 2x schottky detector diodes
BL BCP56-16 Mot P SOT223 npn amp 80V 150mA
BL BCX56-16 Sie P SOT89 npn hfe 160
BL BZX399C12 Phi I SOD323 12V 0.3W zener
BL BGA310 Sie GQ SOT143 MMIC amp 9dB @1GHz
BLs BGA420 Sie HQ SOT343 MMIC amp 13 dB @1.8GHz
BM BSS63L Mot N SOT23 100v pnp comp BSS64
BM BCX55-16 Sie P SOT89 npn hfe 160
BM BGA312 Sie GQ SOT143 MMIC amp 11dB @1GHz
BM BZX399C13 Phi I SOD323 13V 0.3W zener
BMp BSS63 Phi N SOT23 100v pnp comp BSS64
BMs BG427 Sie HQ SOT343 MMIC amp 18 dB @1.8GHz
BMt BSS63 Phi N SOT23 100v pnp comp BSS64
BN BZX399C15 Phi I SOD323 15V 0.3W zener
BN BGA318 Sie GQ SOT143 MMIC amp 16dB @1GHz
BNs BCW61FN Sie N SOT23 low noise BCW61
BO BCW61AR Phi N SOT23 "BCX78, BCY78-vii"
BP BCW61BR Phi N SOT23 BCY78-viii
BP BZX399C16 Phi I SOD323 16V 0.3W zener
BQ BZX399C18 Phi I SOD323 18V 0.3W zener in SOD323
BQ 2PB709AQ Phi N SC-59 PNP 45V 0.1A hfe 160-260
BR BCW61CR Phi N SOT23 BCY78-ix
BR 2SC2412K Roh N - npn 50V 150mA min hfe 180
BR 2SC4081 Roh N UMT 2SC2412K above
BR 2SC4617 Roh N EM3 2SC2412K above
BR MSB1218A Mot N SOT323 gp pnp 45V
BR BZX399C20 Phi I SOD323 20V 0.3W zener
BR 2PB709AR Phi N SC-59 pnp45V 0.1A hfe 210-340
BR1 BSR30 Phi P SOT89 pnp 70V 1A 1.35W hfe 40-120
BR2 BSR31 Phi P SOT89 pnp 70V 1A 1.35W hfe 100-300
BR4 BSR33 Phi P SOT89 pnp 90V 1A 1.35W hfe 100-300
BS BCW61DR Phi R SOT23 BCY78-x
BS BZX399C22 Phi I SOD323 22V 0.3W zener
BS 2PB709AS Phi N SC-59 pnp 45V 0.1A hfe 290-460
BS1 BST60 Mot P SOT89 pnp darlington 0.5A 60V
BS2 BST61 Mot P SOT89 pnp darlington 0.5A 80V
BS3 BST62 Mot P SOT89 pnp darlington 0.5A 90V
BS3 BSP62 Mot P SOT89 pnp darlington 0.5A hfe 2000
BT BZX399C24 Phi I SOD323 24V 0.3W zener
BT2 BSP16 Mot P SOT223 pnp –300V 1A
BT2 BST16 Phi P SOT89 pnp –300V 1A
BU BCX71GR Phi N SOT23 BCX79-vii
BU BZX399C27 Phi I SOD323 27V 0.3W zener
BV BZX399C30 Phi I SOD323 30V 0.3W zener
BW BCW71HR Phi N SOT23R BCX79-viii
BW BZX399C33 Phi I SOD323 33V 0.3W zener
BX BCW71JR Phi N SOT23R BCX79-ix
BX BZX399C36 Phi I SOD323 36V 0.3W zener
BY BCW71KR Phi N SOT23R BCX79-x
BY BZX399C39 Phi I SOD323 39V 0.3W zener
BZ BZX399C43 Phi I SOD323 43V 0.3W zener
C BB565 Sie I SCD80 uhf varicap 2-20pF
C KV1832E Tok I URD uhf varicap 4-17pf
C white BAT165 Sie I - 40V 750mA sw Schottky
C0 HSMS-2820 HP C SOT23 HP2835 schottky
C0 HSMS-282B HP C SOT323 HP2835 schottky
C1 HSMS-2821 HP K SOT23 HP2835 schottky
C1 BCW29 Phi N SOT23 BC178A
C1 BFQ51C Phi CX SOT173 pnp BFR90A complement
C11 SST111 Sil F SOT23 J111 n-ch fet
C12 SST112 Sil F SOT23 J112 n-ch fet
C13 SST113 Sil F SOT23 J113 n-ch fet
C1p BCW29 Phi N SOT23 BC178A
C1t BCW29 Phi N SOT23 BC178A
C2 BCW30 Phi N SOT23 BC178B
C2 BFQ32C Phi CX SOT173 pnp 4.5GHz 15V 100mA
C2 HSMS-2822 HP D SOT23 dual HP2835 schottky
C2 HSMS-282C HP D SOT323 dual HP2835 schottky
C2 SST112 Tem F SOT23 J112 analog sw n-ch jfet
C2A ZDC833A Zet B SOT23 dual cc 28V varicap 15pF @2V
C2p BCW30 Phi N SOT23 BC178B
C2t BCW30 Phi N SOT23 BC178B
C3 HSMS-2823 HP A SOT23 dual HP2835 schottky
C3 BFQ23C Phi CX SOT173 pnp complement BFP91A
C3 SMBT4126 Sie N - 2N4126
C3 SST113 Tem F SOT23 J113 analog sw jfet
C38 SST5638 Sil F SOT23 2N5638
C39 SST5639 Sil F SOT23 2N5639
C4 BCW29R Phi R SOT23R BC178A
C4 HSMS-2824 HP B SOT23 dual HP2835 schottky
C40 SST5640 Sil F SOT23 2N5640
C41 SST4091 Sil F SOT23 2N4091
C42 SST4092 Sil F SOT23 2N4092
C43 SST4093 Sil F SOT23 2N4093
C5 MMBA811C5 Mot N - 2N5086 pnp hfe 135-270
C5 BCW30R Phi R SOT23R BC178B
C5 HSMS-2825 HP S SOT143 dual HP2835 schottky
C56 SST4856 Sil F SOT23 2N4856
C57 SST4857 Sil F SOT23 2N4857
C58 SST4858 Sil F SOT23 2N4858
C59 SST4859 Sil F SOT23 2N4859
C5A ZDC834A Zet B SOT23 dual cc 28V varicap 47pF @2V
C6 MMBA811C6 Mot N - 2N5086 pnp hfe 200-400
C60 SST4860 Sil F SOT23 2N4860
C61 SST4861 Sil F SOT23 2N4861
C7 MMBA811C7 Mot N - 2N5086 pnp hfe 300-600
C7 HSMS-2827 HP RQ SOT143 HP2835 ring quad
C8 HSMS-2828 HP BQ SOT143 HP2835 bridge quad
C8 BCF30 SGS N SOT23 BC559B
C8 MMBA811C8 Mot N - 2N5086 pnp hfe 450-900
C91 SST4391 Sil F SOT23 2N4391
C92 SST4392 Sil F SOT23 2N4392
C93 SST4393 Sil F SOT23 2N4393
CA BCW61AR Phi R SOT23R BCY78-vii
CA BCP68 Mot P SOT223 20V 1A npn
CA ZMV829B Zet I SOD323 varicap hyperab 28V 8.2pF@2V
CB BCX68-10 Sie P SOT89 npn AF 20V 2A hfe 100
CB BCW61BR Phi R SOT23R BCY78-viii
CB ZMV830B Zet I SOD323 varicap hyperabrupt 28V 10pF@2V
CC BCW61CR Phi R SOT23R BCY78-ix
CC BCX68-16 Sie P SOT89 npn AF 20V 2A hfe 160
CC ZMV831B Zet I SOD323 varicap hyperabrupt 28V 15pF@2V
CC ZMDC831B Zet B SOT323 dual cc ZMV831B (above)
CD BCW61DR Phi R SOT23R BCY78-x
CD BCX68-25 Sie P SOT89 npn AF 20V 2A hfe 250
CD ZMV832B Zet I SOD323 varicap hyperabrupt 28V 22pF@2V
CD ZMDC832B Zet B SOT323 dual cc ZMV832B (above)
CDs BSS81B Sie N SOT23 npn sw 35V 0.8A
CE BCP69 Mot P SOT223 20V 1A pnp
CE ZMV833B Zet I SOD323 varicap hyperabrupt 28V 33pF@2V
CEs BSS79B Sie N SOT23 npn 40V 0.8A hfe 40-120
CF BSS79C Sie N SOT23 npn 40V 0.8A hfe 100 min
CF BCX69-10 Sie P SOT89 pnp AF 20V 2A hfe 100
CF ZMV834B Zet I SOD323 varicap hyperabrupt 28V 47pF@2V
CG BCX71GR Phi R SOT23R BCY79-vii
CG BCX69-16 Sie P SOT89 pnp AF 20V 2A hfe 160
CG ZMV835B Zet I SOD323 varicap hyperabrupt 28V 68pF@2V
CGs BSS81C Sie N SOT23 npn sw 35V 1A
CH BSS82BL Mot N SOT23 pnp 60V
CH BCX69-25 Sie N SOT89 pnp AF 20V 2A hfe 250
CHs BSS80B Sie N SOT23 pnp 40V 0.8A hfe 40-120
CJs BSS80C Sie N SOT23 pnp 40V 0.8A hfe 100 min
CK BCX71JR Phi R SOT23R BCY79-viii
CLs BSS82B Sie N SOT23 pnp 60V 0.8A hfe 40-120
CMs BSS82C Sie N SOT23 pnp 60V 0.8A hfe 100 min
CQ 2SC2411K Roh N - npn darlington
CQ MSD710Q Mot N SOT346 pnp gp 25V 150mA
CR MSD701R Mot N SOT346 pnp gp 25V 150mA
D BB659 Sie I SCD80 2-38p varicap
D BAS21-03W Sie I SOD323 -
D 1SS376 Roh I USM 300V 50mA sw
D MRF577 Mot N SOT323 npn RF fT 7GHz
D0 HSMP-3800 HP C SOT23 HP3800 pin atten diode
D1 BCW31 Phi N SOT23 BC108A
D1 HSMP-3801 HP K - HP3800 pin atten diode
D1 SST211 Tem XQ - n-ch mosfet 30V 1nS
D11 SST211 Sil XQ - n-ch mosfet sw
D11 SST215 Sil XQ - n-ch mosfet sw
D13 SST213 Sil XQ - n-ch mosfet sw
D1p BCW31 Phi N SOT23 BC108A
D1t BCW31 Phi N SOT23 BC108A
D2 BCW32 Phi N SOT23 BC108B
D2 HSMP-3802 HP D - dual HP3800 pin atten diode
D2p BCW32 Phi N SOT23 BC108B
D2t BCW32 Phi N SOT23 BC108B
D3 BCW33 Phi N SOT23 BC108C
D3B RB420D Roh C - 25V 100mA schottky
D3E RB411D Roh C SOT23 20V 500mA schottky
D3J RB420D Roh C - 25V 100mA schottky
D3L RB706D-40 Roh B - dual 45V 30mA schottky
D3p BCW33 Phi N SOT23 BC108C
D3t BCW33 Phi N SOT23 BC108C
D4 BCW31R Phi R SOT23R BC108A
D4 HSMP-3804 HP B SOT23 dual cc HP3800 pin atten diode
D5 SST215 Tem XQ - n-ch mosfet 20V 1nS
D5 BCW32R Phi R SOT23R BC108B
D58 FLLD261 Zet B SOT23 low leakage dual cc Si diode
D6 BCW33R Phi R SOT23R BC108C
D6 MMBC1622D6 Mot N - MPS3904 hfe 200-400
D63 FLLD263 Zet A SOT23 low leakage dual ca Si diode
D7 MMBC1622D7 Mot N - MPS3904 hfe 300-600
D76 BAR18J SGS I SOD232 schottky 70V 15mA
D76 BAR18 SGS C SOT23 schottky 70V 30mA
D7p BCF32 Phi N SOT23 -
D7t BCF32 Phi N SOT23 -
D85 BAT17DS SGS D - 2xBA481
D86 BAT54J ST I SOD232 schottky 30V 300mA
D86 BAT54 ST C SOT23 schottky 30V 300mA
D87 BAT54C ST B SOT23 dual cc schottky 30V 300mA
D88 BAT54S ST D SOT23 dual series schottky 30V 300mA
D8p BCF33 Phi N SOT23 BC146/03
D94 BAR42 SGS C SOT23 schottky 30V 100mA
D95 BAR43 SGS C SOT23 schottky 30V 100mA
D96 BAS70-04 SGS D SOT23 2xBAR18
D97 BAS70-05 SGS B SOT23 2xBAR18
D98 BAS70-06 SGS A SOT23 2xBAR18
DA BCW67A SGS N SOT23 pnp 32V 0.8A hfe 100 min
DA BF622 Sie P SOT89 npn 250V video o/p
DA5 BAR43S SGS D SOT23 2xBAR43
DB BCW67B SGS N SOT23 pnp 32V 0.8A hfe 160 min
DB BF623 Sie P SOT89 pnp 250V video o/p
DB1 BAR43A SGS A SOT23 2xBAR43
DB2 BAR43C SGS B SOT23 2xBAR43
DC BCW67C SGS N SOT23 pnp 32V 0.8A hfe 250 min
DC BF720 Mot P SOT223 npn 1.5W 300V
DC BFN20 Sie P SOT89 npn video o/p 300V comp BFN21
DD BFN16 Sie P SOT89 npn video o/p 250V comp BFN17
DE BFN18 Sie P SOT89 npn video o/p 300Vcomp BFN19
DF BCW68F SGS N SOT23 pnp 45V 0.8A hfe 100 min
DF BF721 Mot P SOT223 pnp 1.5W 300V
DF BFN21 Sie P SOT89 pnp 300V video o/p comp BFN20
DG BCW68G SGS N SOT23 pnp 45V 0.8A hfe 160 min
DG BFN17 Sie P SOT89 pnp video o/p 250V comp BFN16
DH BCW68H SGS N SOT23 pnp 45V 0.8A hfe 250 min
DH BCW68G Mot N SOT23 pnp 45V 0.8A hfe 160 min
DH MMBD2000 Mot C SOT323 Si sw diode 20V 0.2A SOT323
DH BFN19 Sie P SOT89 pnp video o/p 300V comp BFN18
DK BCX42 Sie N SOT23 gp audio pnp 125V comp BCX41
DP MMBD2010 Mot B SOT323 dual cc MMBD2000
DQ 2P710AQ Phi N SOT346 gp pnp hfe 85-170
DR 2P710AR Phi N SOT346 gp pnp hfe 120-240
DS 2P710AS Phi N SOT346 gp pnp hfe 170-340
DT BCW67AR SGS R SOT23R pnp 32V 0.8A hfe 100 min
DU BCW67BR SGS R SOT23R pnp 32V 0.8A hfe 160 min
DW BCW67CR SGS R SOT23R pnp 32V 0.8A hfe 250 min
DX BCW68FR SGS R SOT23R pnp 45V 0.8A hfe 100 min
DY BCW68GR SGS R SOT23R pnp 45V 0.8A hfe 160 min
DZ BCW68HR SGS R SOT23R pnp 45V 0.8A hfe 250 min
e BAT64-02W Sie I SCD80 -
E 1SS780 Roh I USM 40V 100mA lo leakage
E BB689 Sie I SCD80 2-55pF varicap
E0 HSMP-3810 HP C SOT23 HP3810 pin atten diode
E0 HSMP-381B HP C SOT323 HP3810 pin atten diode
E01 DTDG14EP Roh P SOT89 "npn dtr 60V 1A R2 10k, + c to b zener "
E02 DTDG23YP Roh P SOT89 "npn dtr 60V 1A 2k2+ 10k, + c to b zener "
E1 HSMP-3811 HP K SOT23 HP3810 pin atten diode
E11 DTA113ZE Roh N EMT3 pnp dtr 1k0 + 10k 50V 100mA
E11 DTA113ZKA Roh N SC59 pnp dtr 1k0 + 10k 50V 100mA
E13 DTA143ZE Roh N EMT3 pnp dtr 4k7 + 47k 50V 100mA
E13 DTA143ZKA Roh N SC59 pnp dtr 4k7 + 47k 50V 100mA
E1p BFS17 Phi N SOT23 BFY90 BFW92
E1p BFS17W Phi N SOT323 BFY90 BFW92
E2 BFS17A Phi N SOT23 npn RF 3GHz 25mA
E2 BAL99 Zet C - sw diode 75V 100mA
E2 HSMP-3812 HP D SOT23 dual series HP3810 pin atten diode
E23 DTC143ZCA Roh N SOT23 npn dtr 4k7 + 47k 50V 100mA
E23 DTC143ZE Roh N EMT3 npn dtr 4k7 + 47k 50V 100mA
E23 DTC143ZKA Roh N SC59 npn dtr 4k7 + 47k 50V 100mA
E3 BAR99 Zet C - sw diode 75V 100mA
E3 HSMP-3813 HP A SOT23 dual HP3810 pin atten diode
E32 DTA123JE Roh N EMT3 pnp dtr 2k2 + 47k 50V 100mA
E32 DTA123JKA Roh N SC59 pnp dtr 2k2 + 47k 50V 100mA
E4 BFS17R Phi R - BFY90 BFW92
E4 HSMP-3814 HP B SOT23 dual cc HP3810 pin atten diode
E42 DTC123JE Roh N EMT3 npn dtr 2k2 + 47k 50V 100mA
E42 DTC123JKA Roh N SC59 npn dtr 2k2 + 47k 50V 100mA
E5 BFS17AR Tfk R - npn rf 3 GHz 25mA
E56 DTA144VKA Roh N SC59 pnp dtr 47k + 10k 50V 100mA
E6 ZC2800E Zet C - HP2800
E66 DTC144VKA Roh N SC59 npn dtr 47k + 10k 50V 100mA
E8 ZC2811E Zet C - HP2811
E9 ZC5800E Zet C - HP5800
EAs BCW65A Sie N SOT23 npn 32V 800mA hfe 100 min
EB HSMP-4810 HP J SOT23 0.5-3GHz pin 2 cathode connections
EB MSC1022-B Mot H - pnp RF 150MHz fT 20V
EBs BCW65B Sie N SOT23 npn 32V 800mA hfe 160 min
EC MSC1022-C Mot H - pnp RF 150MHz fT 20V
ECs BCW65C Sie N SOT23 npn 32V 800mA hfe 250 min
ED BCV28 Sie P SOT89 pnp darlington 30V 0.8A comp BCV29
EE BCV48 Sie P SOT89 pnp darlington 60V 0.8A comp BCV49
EF BCV29 Sie P SOT89 npn darlington 30V 0.8A comp BCV28
EF BCW66F Sie N SOT23 npn 45V 800mA hfe 100 min
EG BCV49 Sie P SOT89 npn darlington 60V 0.8A comp BCV48
EGs BCW66G Sie N SOT23 npn 45V 800mA hfe 160 min
EHAA MAX6326_R22-T Max ZB SOT23 microproc -ve reset gen 2.200V
EHs BCW66H Sie N SOT23 npn 45V 800mA hfe 240 min
EIAA MAX6327_R22-T Max ZB SOT23 microproc +ve reset gen 2.200V
EJAA MAX6328_R22-T Max ZB SOT23 microproc -ve reset gen 2.200V
EKs BCX41 Sie N SOT23 gp npn 125V 1A comp BCX42
ET BCW65AR Sie R SOT23R npn 32V 800mA hfe 100 min
EU BCW65BR Sie R SOT23R npn 32V 800mA hfe 160 min
EW BCW65CR Sie R SOT23R npn 32V 800mA hfe 240 min
EWAA MAX6326_R23-T Max ZB SOT23 microproc -ve reset gen 2.320V
EX BCW65FR Sie R SOT23R npn 45V 800mA hfe 100 min
EXAA MAX6326_R24-T Max ZB SOT23 microproc -ve reset gen 2.400V
EY BCW65GR Sie R SOT23R npn 45V 800mA hfe 160 min
EYAA MAX6326_R25-T Max ZB SOT23 microproc -ve reset gen 2.500V
EZ BCW65HR Sie R SOT23R npn 45V 800mA hfe 240 min
EZAA MAX6326_R26-T Max ZB SOT23 microproc -ve reset gen 2.630V
f BAS20-02W Sie I SCD80 -
F KV1831E Tok I URD uhf varicap 2.5-22pf
F MRF927 Mot N SOT323 npn RF fT 8GHz
F0 HSMP-3820 HP C SOT23 35V RF pin sw diode
F02 DTD123TK Roh N SC59 npn dtr R1 2k2 40V 100mA
F03 DTD143TK Roh N SC59 npn dtr R1 4k7 40V 100mA
F05 TSDF1205 Tfk X - fT 12GHz npn RF 4V 12mA
F1 HSMP-3821 HP K SOT23 35V RF pin sw diode
F1 BFS18 Phi N SOT23 BF495
F1 MMBC1009F1 Mot N - RF npn fT 150MHz hfe30-60
F11 DTB113EK Roh N SC59 pnp dtr 1k + 1k 50V 500mA
F12 DTB123EK Roh N SC59 pnp dtr 2k2 + 2k2 50V 500mA
F13 DTB143EC Roh N SOT23 pnp dtr 4k7+ 4k7 50V 500mA
F13 DTB143EK Roh N SC59 pnp dtr 4k7+ 4k7 50V 500mA
F14 DTB114EK Roh N SC59 pnp dtr 10k + 10k 50V 500mA
F2 HSMP-3822 HP D SOT23 dual series HP3820 pin sw diode
F2 BFS19 SGS N SOT23 BF184 BF494
F20 TSDF1220 Tfk X - fT 12GHz npn 6V 20mA
F21 DTD113EK Roh N SC59 npn dtr 1k + 1k 50V 500mA
F22 DTD123EK Roh N SC59 npn dtr 2k2 + 2k2 50V 500mA
F23 DTD143EC Roh N SOT23 npn dtr 4k7 + 4k7 50V 500mA
F23 DTD143EK Roh N SC59 npn dtr 4k7 + 4k7 50V 500mA
F24 DTD114EK Roh N SC59 npn dtr 10k + 10k 50V 500mA
F2p BFS19 Phi N SOT23 BF184 BF494
F2t BFS19 Phi N SOT23 BF184 BF494
F3 MMBC1009F3 Mot N - RF npn fT150MHz hfe60-120
F4 BFS18R Phi N - BF495
F4 HSMP-3824 HP B SOT23 dual cc HP3820 pin sw diode
F5 BFS19R Phi N - BF184 BF494
F52 DTB123YC Roh N SOT23 pnp dtr 2k2 + 10k 50V 100mA
F52 DTB123YK Roh N SC59 pnp dtr 2k2 + 10k 50V 100mA
F62 DTD123YK Roh N SC59 npn dtr 2k2 + 10k 50V 100mA
F8p BF824 Phi N SOT23 -
F8t BF824 Phi N SOT23 -
F8t BF824W Phi N SOT323 -
F92 DTB123TK Roh N SC59 pnp dtr R1 2k2 40V 100mA
F93 DTB143TK Roh N SC59 pnp dtr R1 4k7 40V 100mA
F94 DTB114TK Roh N SC59 pnp dtr R110k 40V 100mA
FA HSMP-4820 HP B SOT23 0.5-3GHz cc pin dual anode
FA BFQ17 Phi P SOT89 npn RF 1.5GHz 300mA
FA BFP81 Sie X - BFQ69
FA BFQ19 Phi P SOT89 npn RF Ft 5.5GHz 100mA
FAAA MAX6326_R27-T Max ZB SOT23 microproc -ve reset gen 2.700V
FB BFP17 Sie X BFW92
FBAA MAX6328_R31-T Max ZB SOT23 microproc -ve reset gen 2.800V
FC BFQ64 Sie P - BFT98T
FC BFP29 Sie X - BFT97
FCAA MAX6326_R29-T Max ZB SOT23 microproc -ve reset gen 2.930V
FD BCV26 SGS N SOT23 pnp darlington
FD BFQ17P Sie P SOT89 BFW16A
FD BFP35A Sie X - BFR34A
FDAA MAX6326_R31-T Max ZB SOT23 microproc -ve reset gen 3.080V
FDp BCV26 Phi N SOT23 pnp darlington
FDt BCV26 Phi N SOT23 pnp darlington
FE BCV46 SGS N SOT23 pnp darlington
FE BFP93A Sie X SOT143 BFR91A
FEAA MAX6326_R30-T Max ZB SOT23 microproc -ve reset gen 3.000V
FEp BCV46 Phi N SOT23 pnp darlington
FEs BFQ19P Sie P SOT89 BFR96
FEt BCV46 Phi N SOT23 pnp darlington
FF BCV27 SGS N SOT23 npn darlington
FF BBY65-02V Inf I SC79 hyperabrupt varicap 2.7-30pF
FFAA MAX6327_R23-T Max ZB SOT23 microproc +ve reset gen 2.320V
FFMA MAX6327_R31-T Max ZB SOT23 microproc +ve reset gen 3.080V
FFNA MAX6327_R30-T Max ZB SOT23 microproc +ve reset gen 3.000V
FFp BCV27 Phi N SOT23 npn darlington
FFt BCV27 Phi N SOT23 npn darlington
FG BCV47 Phi N SOT23 npn darlington
FG BFQ19S Sie P SOT89 BFR96S
FGAA MAX6327_R24-T Max ZB SOT23 microproc +ve reset gen 2.400V
FGp BCV47 Phi N SOT23 npn darlington
FGt BCV47 Phi N SOT23 npn darlington
FHAA MAX6327_R25-T Max ZB SOT23 microproc +ve reset gen 2.500V
FHs BFN24 Sie N SOT23 npn 250V comp to BFN25
FIAA MAX6327_R26-T Max ZB SOT23 microproc +ve reset gen 2.630V
FJ BFN26 Sie N SOT23 npn 300V comp to BFN27
FJAA MAX6327_R27-T Max ZB SOT23 microproc +ve reset gen 2.700V
FK BFN25 Sie N SOT23 pnp 250V comp to BFN24
FKAA MAX6327_R28-T Max ZB SOT23 microproc +ve reset gen 2.800V
FL BFN27 Sie N SOT23 pnp 300V comp to BFN26
FLAA MAX6327_R29-T Max ZB SOT23 microproc +ve reset gen 2.930V
FOAA MAX6328_R23-T Max ZB SOT23 microproc -ve reset gen 2.320V
FPAA MAX6328_R24-T Max ZB SOT23 microproc -ve reset gen 2.400V
F-Q 2PA1576Q Phi N SOT323 gp pnp SC70 hfe 120-270
FQAA MAX6328_R25-T Max ZB SOT23 microproc -ve reset gen 2.500V
FR 2SA1037AK Roh N - hfe 150@1ma preamp pnp
FR 2SA1576A Roh N UMT see 2SA1037K above
FR 2SA1774 Roh N EM3 see 2SA1037K above
F-R 2PA1576R Phi N SOT323 gp pnp hfe 180-390
FRAA MAX6328_R26-T Max ZB SOT23 microproc -ve reset gen 2.630V
F-S 2PA1576S Phi N SOT323 gp pnp hfe 270-560
FSAA MAX6328_R27-T Max ZB SOT23 microproc -ve reset gen 2.700V
FTAA MAX6328_R28-T Max ZB SOT23 microproc -ve reset gen 2.800V
FtQ 2PA1576Q Phi N SOT323 gp pnp SC70 hfe 120-270
FtR 2PA1576R Phi N SOT323 gp pnp hfe 180-390
FtS 2PA1576S Phi N SOT323 gp pnp hfe 270-560
FUAA MAX6328_R29-T Max ZB SOT23 microproc -ve reset gen 2.930V
FVAA MAX6328_R31-T Max ZB SOT23 microproc -ve reset gen 3.080V
FWAA MAX6328_R30-T Max ZB SOT23 microproc -ve reset gen 3.000V
FZAP MAX6012A Max ZC SOT23 precision reference 1.247V
FZAQ MAX6025A Max ZC SOT23 precision reference 2.500V
FZAR MAX6041A Max ZC SOT23 precision reference 4.096V
FZAS MAX6045A Max ZC SOT23 precision reference 4.500V
FZAT MAX6050A Max ZC SOT23 precision reference 5.000V
FZAU MAX6021A Max ZC SOT23 precision reference 2.048V
FZAV MAX6346_R33-T Max ZB SOT23 micrproc -ve reset gen 3.300V
FZAW MAX6346_R34-T Max ZB SOT23 micrproc -ve reset gen 3.400V
FZAX MAX6346_R35-T Max ZB SOT23 micrproc -ve reset gen 3.500V
FZAY MAX6346_R36-T Max ZB SOT23 micrproc -ve reset gen 3.600V
FZAZ MAX6346_R37-T Max ZB SOT23 micrproc -ve reset gen 3.700V
FZBA MAX6346_R38-T Max ZB SOT23 micrproc -ve reset gen 3.800V
FZBB MAX6346_R39-T Max ZB SOT23 micrproc -ve reset gen 3.900V
FZBC MAX6346_R40-T Max ZB SOT23 micrproc -ve reset gen 4.0800V
FZBD MAX6346_R41-T Max ZB SOT23 micrproc -ve reset gen 4.100V
FZBE MAX6346_R42-T Max ZB SOT23 micrproc -ve reset gen 4.200V
FZBF MAX6346_R43-T Max ZB SOT23 micrproc -ve reset gen 4.300V
FZBG MAX6346_R44-T Max ZB SOT23 micrproc -ve reset gen 4.380V
FZBH MAX6346_R45-T Max ZB SOT23 micrproc -ve reset gen 4.500V
FZBI MAX6346_R46-T Max ZB SOT23 micrproc -ve reset gen 4.630V
FZBJ MAX6347_R33-T Max ZB SOT23 micrproc +ve reset gen 3.300V
FZBK MAX6347_R34-T Max ZB SOT23 micrproc +ve reset gen 3.400V
FZBL MAX6347_R35-T Max ZB SOT23 micrproc +ve reset gen 3.500V
FZBM MAX6347_R36-T Max ZB SOT23 micrproc +ve reset gen 3.600V
FZBN MAX6347_R37-T Max ZB SOT23 micrproc +-ve reset gen 3.700V
FZBO MAX6347_R38-T Max ZB SOT23 micrproc +ve reset gen 3.800V
FZBP MAX6347_R39-T Max ZB SOT23 micrproc +ve reset gen 3.900V
FZBQ MAX6347_R40-T Max ZB SOT23 micrproc +ve reset gen 4.0800V
FZBR MAX6347_R41-T Max ZB SOT23 micrproc +-ve reset gen 4.100V
FZBS MAX6347_R42-T Max ZB SOT23 micrproc +ve reset gen 4.200V
FZBT MAX6347_R43-T Max ZB SOT23 micrproc +ve reset gen 4.300V
FZBU MAX6347_R44-T Max ZB SOT23 micrproc +-ve reset gen 4.380V
FZBV MAX6347_R45-T Max ZB SOT23 micrproc +ve reset gen 4.500V
FZBW MAX6347_R46-T Max ZB SOT23 micrproc +-ve reset gen 4.630V
FZBX MAX6348_R33-T Max ZB SOT23 microproc -ve reset gen 3.300V
FZBY MAX6348_R34-T Max ZB SOT23 microproc -ve reset gen 3.400V
FZBZ MAX6348_R35-T Max ZB SOT23 microproc -ve reset gen 3.500V
FZCA MAX6348_R36-T Max ZB SOT23 microproc -ve reset gen 3.600V
FZCB MAX6348_R37-T Max ZB SOT23 microproc -ve reset gen 3.700V
FZCC MAX6348_R38T Max ZB SOT23 microproc -ve reset gen 3.800V
FZCD MAX6348_R39-T Max ZB SOT23 microproc -ve reset gen 3.900V
FZCE MAX6348_R40-T Max ZB SOT23 microproc -ve reset gen 4.000V
FZCF MAX6348_R41-T Max ZB SOT23 microproc -ve reset gen 4.100V
FZCG MAX6348_R42T Max ZB SOT23 microproc -ve reset gen 4.200V
FZCH MAX6348_R43-T Max ZB SOT23 microproc -ve reset gen 4.380V
FZCI MAX6348_R44-T Max ZB SOT23 microproc -ve reset gen 4.400V
FZCJ MAX6348_R45-T Max ZB SOT23 microproc -ve reset gen 4.500V
FZCK MAX6348_R46-T Max ZB SOT23 microproc -ve reset gen 4.600V
FZCW MAZ6001UR Max ZC SOT23 1.250V V reference
FZCX MAZ6002UR Max L SOT23 2.500V V reference
FZCY MAZ6004UR Max L SOT23 4.096V V reference
FZCZ MAZ6005UR Max L SOT23 5.000V V reference
FZDA MAX6012B Max ZC SOT23 precision reference 1.247V
FZDB MAX6025B Max ZC SOT23 precision reference 2.500V
FZDC MAX6041B Max ZC SOT23 precision reference 4.096V
FZDD MAX6045B Max ZC SOT23 precision reference 4.500V
FZdE MAX6050B Max ZC SOT23 precision reference 5.000V
FZDF MAX6021B Max ZC SOT23 precision reference 2.047V
FZDK MAZ6003UR Max L SOT23 3.000V V reference
FZDW MAX6030A Max ZC SOT23 precision reference 3.000V
FZDX MAX6012B Max ZC SOT23 precision reference 3.000V
FZEB LM4041AIM3-1.2 Max L SOT23 1.225V 0.1% shunt V ref
FZEC LM4041BIM3-1.2 Max L SOT23 1.225V 0.2% shunt V ref
FZED LM4041DIM3-1.2 Max L SOT23 1.225V 0.5% shunt V ref
FZEE LM4041DIM3-1.2 Max L SOT23 1.225V 1.5% shunt V ref
FZEF LM4040A IM3-2.1 Max L SOT23 2.048V shunt reference 0.1%
FZEG LM4040B IM3-2.1 Max L SOT23 2.048V shunt reference 0.2 %
FZEH LM4040C IM3-2.1 Max L SOT23 2.048V shunt reference 0.5%
FZEI LM4040D IM3-2.1 Max L SOT23 2.048V shunt reference 1.0%
FZEJ LM4040A IM3-2.5 Max L SOT23 2.500V shunt reference 0.1%
FZEK LM4040B IM3-2.5 Max L SOT23 2.500V shunt reference 0.2 %
FZEL LM4040C IM3-2.5 Max L SOT23 2.500V shunt reference 0.5%
FZEM LM4040D IM3-2.5 Max L SOT23 2.500V shunt reference 1.0%
FZEN LM4040A IM3-3.0 Max L SOT23 3.000V shunt reference 0.1%
FZEO LM4040B IM3-3.0 Max L SOT23 3.000V shunt reference 0.2 %
FZEP LM4040C IM3-3.0 Max L SOT23 3.000V shunt reference 0.5%
FZEQ LM4040D IM3-3.0 Max L SOT23 3.000V shunt reference 1.0%
FZER LM4040A IM3-4.1 Max L SOT23 4.096V shunt reference 0.1%
FZES LM4040B IM3-4.1 Max L SOT23 4.096V shunt reference 0.2 %
FZET LM4040C IM3-4.1 Max L SOT23 4.096V shunt reference 0.5%
FZEU LM4040DIM3-4.1 Max L SOT23 4.096V shunt reference 1.0%
FZEV LM4040A IM3-5.0 Max L SOT23 5.000V shunt reference 0.1%
FZEW LM4040B IM3-5.0 Max L SOT23 5.000V shunt reference 0.2 %
FZEX LM4040C IM3-5.0 Max L SOT23 5.000V shunt reference 0.5%
FZEY LM4040D IM3-5.0 Max L SOT23 5.000V shunt reference 1.0%
FZEZ MAZ803LUR Max ZB SOT23 "microproc -ve reset gen, 5.0V"
FZFA MAZ803MUR Max ZB SOT23 "microproc -ve reset gen, 5.0V"
FZFB MAZ803TUR Max ZB SOT23 "microproc -ve reset gen, 3.3V"
FZFC MAZ803SUR Max ZB SOT23 "microproc -ve reset gen, 3.3V"
FZFD MAZ803RUR Max ZB SOT23 "microproc -ve reset gen, 3.0V"
FZGH MAZ6006AUR Max L SOT23 1.250V 0.2% shunt V reference
FZGI MAZ6006BUR Max L SOT23 1.250V 0.5% shunt V reference
FZGJ MAZ6006CUR Max L SOT23 1.250V 1.0% shunt V reference
FZGK MAZ6007AUR Max L SOT23 2.480V 0.2% shunt V reference
FZGL MAZ6007BUR Max L SOT23 2.480V 0.5% shunt V reference
FZGM MAZ6007CUR Max L SOT23 2.480V 1.0% shunt V reference
FZGN MAZ6008AUR Max L SOT23 2.500V 0.2% shunt V reference
FZGO MAZ6008BUR Max L SOT23 2.500V 0.5% shunt V reference
FZGP MAZ6008CUR Max L SOT23 2.500V 1.0% shunt V reference
FZGQ MAZ6009AUR Max L SOT23 3.000V 0.2% shunt V reference
FZGR MAZ6009BUR Max L SOT23 3.000V 0.5% shunt V reference
FZGS MAZ6009CUR Max L SOT23 3.000V 1.0% shunt V reference |
