查看: 2358|回復(fù): 2
pic編譯求助
ID:105780 發(fā)表于 2016-3-5 15:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
網(wǎng)上收到了一段程序,編譯出錯。求智者幫忙,怎樣修改出錯內(nèi)容:
Build C:\Users\Administrator\Desktop\wenk\wenk for device 16F628A
Using driver C:\Program Files\HI-TECH Software\PICC\PRO\9.65\bin\picc.exe
Make: The target "C:\Users\Administrator\Desktop\wenk\wenk.p1" is out of date.
Executing: "C:\Program Files\HI-TECH Software\PICC\PRO\9.65\bin\picc.exe" --pass1 C:\Users\Administrator\Desktop\wenk\wenk.c -q --chip=16F628A -P --runtime=default --opt=default -D__DEBUG=1 -g --asmlist "--errformat=Error   [%n] %f; %l.%c %s" "--msgformat=Advisory[%n] %s" "--warnformat=Warning [%n] %f; %l.%c %s"
Error   [141] C:\Users\Administrator\Desktop\wenk\pc68.h; 2.24 can't open include file "defineports.h": No such file or directory
********** Build failed! **********
代碼如下:
#include "defineports.h"
__CONFIG(INTIO & WDTEN & MCLRDIS & BOREN & LVPDIS & PWRTEN);
//各種模式定義,位操作
#define MODE_NORMAL     0x00
#define MODE_SETTING    0x01
#define MODE_NO_NTC     0x02
unsigned char currMode = 0;
#define NTC_TEMP_BUFF_NUM 6
signed char prevCfgTemp = 60;
signed char cfgTemp = 60;
signed char currTemp = 0;    //當(dāng)前NTC所測得的溫度
signed char ntcTempBuff[NTC_TEMP_BUFF_NUM];
unsigned char ntcTempBuffCnt = 0;
//EEPROM
#define EE_VERIFY_ADDR      0x20
#define EE_VERIFY_VALUE     0x35
#define EE_CFG_TEMP_ADDR    0x21
//用于按鍵防抖
unsigned char downKeyHistory = 0;
unsigned char upKeyHistory = 0;
bit downKeyPressed = 0;
bit upKeyPressed = 0;
bit halfSecond = 0; //每500ms反轉(zhuǎn)一次
bit revertLed = 0;
unsigned int tickNum = 0;
unsigned int btnIdleTicks = 0;
//PID系數(shù)和中間變量
#define PID_PROPORTION  8  // 比例系數(shù)
#define PID_INTEGRAL    1  // 積分系數(shù)
#define PID_DERIVATIVE  1  // 微分系數(shù)
signed char pidLastError = 0;  // 上次偏差
signed int pidSumError = 0;    // 歷史誤差累計值
signed int pidResult = 0;
//以度為單位的NTC溫度查找表,起始溫度為-9度(因為只有兩位數(shù)碼管)
/* 換一個NTC后,如果知道B值,則修改此python代碼中的B值,然后執(zhí)行生成此表
import math
B = 3800
sOut = "#define TBL_NTC_TEMP_NUM 110\nconst unsigned int tblNtcTemp[TBL_NTC_TEMP_NUM] = {\n"
for i in range(-9, 100, 10):
    sl = []
    for j in range(i, i + 10):
        sl.append('%.0f' % (10000 * math.exp(B * (1 / (273.15 + j) - 1 / (273.15 + 25) ) ) ) )
    sOut += '    ' + ', '.join(sl) + ',\n'
sOut += '};'
with open('c:/tblntctemp.txt', 'w') as f:
    f.write(sOut)
    31057, 29915, 28822, 27778, 26778, 25822, 24906, 24029, 23190, 22385,
    21614, 20875, 20166, 19486, 18834, 18208, 17607, 17029, 16475, 15943,
    15431, 14939, 14466, 14011, 13574, 13153, 12748, 12357, 11982, 11620,
    11272, 10936, 10613, 10301, 10000, 9710, 9430, 9160, 8900, 8648,
    8406, 8171, 7945, 7726, 7515, 7311, 7113, 6922, 6738, 6559,
    6386, 6219, 6058, 5901, 5750, 5603, 5461, 5323, 5190, 5060,
    4935, 4814, 4696, 4582, 4471, 4364, 4260, 4159, 4061, 3965,
    3873, 3783, 3696, 3612, 3529, 3450, 3372, 3296, 3223, 3152,
    3083, 3015, 2950, 2886, 2824, 2764, 2705, 2648, 2592, 2538,
    2485, 2434, 2384, 2335, 2288, 2242, 2197, 2153, 2110, 2068,
    2028, 1988, 1949, 1912, 1875, 1839, 1804, 1770, 1737, 1704,
//段對應(yīng)關(guān)系
//RB0-G, RB1-F, RB2-B, RB3-A, RB4-E, RB5-D, RB6-DP, RB7-C
//0 - 9,
//'-', 'E', 'H', 'L'
unsigned char segMap[] = {0x41, 0x7b, 0xc2, 0x52, 0x78, 0x54, 0x44, 0x73, 0x40, 0x50,
    0xfe, 0xc4, 0x68, 0xcd};
#define SEG_IDX_DASH  10
#define SEG_IDX_E     11
#define SEG_IDX_H     12
#define SEG_IDX_L     13
unsigned char digit0Seg = 0;
unsigned char digit1Seg = 0;
//延時函數(shù),一個循環(huán)剛好10個指令,在最后加上函數(shù)調(diào)用的花銷7個指令即可。
//假定4m晶體,則:
//延時0.5ms可以用:delayit(50)
//延時1ms可以用:delayit(100)
//延時10ms可以用:delayit(1000)
void delayit(unsigned int d)
    while(--d){;}
//EEPROM寫數(shù)據(jù)函數(shù)
void SaveCfgToEeprom()
    unsigned char n;
    if (prevCfgTemp == cfgTemp)
        return;
    for (n = 2; n > 0; n--)
        while (WR == 1);
        if (n == 2)
            EEADR = EE_CFG_TEMP_ADDR;
            EEDATA = (unsigned char)cfgTemp;
            EEADR = EE_VERIFY_ADDR;
            EEDATA = EE_VERIFY_VALUE;
        WREN = 1;
        EECON2 = 0x55;
        EECON2 = 0xaa;
        WR = 1;
    while (WR == 1);
    WREN = 0;
    prevCfgTemp = cfgTemp;
//EEPROM讀數(shù)據(jù)函數(shù)
void RestoreCfgFromEeprom()
    while (RD == 1);
    RD = 1;
    while (RD == 1);
    if (EEDATA != EE_VERIFY_VALUE)
        return;
    RD = 1;
    while (RD == 1);
    cfgTemp = (signed char)EEDATA;
    if ((cfgTemp < -9) || (cfgTemp > 99))
        cfgTemp = 50;
//掃描按鍵事件,并且更新當(dāng)前模式狀態(tài)
void ScanButtons()
    if (currMode & MODE_NO_NTC)
        return;
    downKeyHistory = downKeyHistory << 1 | !PORT_BUTTON_DOWN;
    if ((downKeyHistory & 0x07) == 0x07) //確定按鍵按下
        downKeyPressed = 1;
        btnIdleTicks = 0;
        downKeyPressed = 0;
    upKeyHistory = upKeyHistory << 1 | !PORT_BUTTON_UP;
    if ((upKeyHistory & 0x07) == 0x07) //確定按鍵按下
        upKeyPressed = 1;
        btnIdleTicks = 0;
        upKeyPressed = 0;
    if (currMode & MODE_SETTING)
        if (((downKeyHistory & 0x0f) == 0x07) && !upKeyPressed)
            if (--cfgTemp < -9)
                cfgTemp = 99;
        else if (((upKeyHistory & 0x0f) == 0x07) && !downKeyPressed)
            if (++cfgTemp > 99)
                cfgTemp = -9;
        //設(shè)置模式下4s無動作則自動退出
        if (btnIdleTicks > 800)
            currMode = MODE_NORMAL;
            ntcTempBuffCnt = 0;
            pidResult = 0;
            SaveCfgToEeprom();
    else if ((currMode == MODE_NORMAL) && downKeyPressed && upKeyPressed)
        currMode |= MODE_SETTING;
        PORT_HEATER = 0;
//三中取二判斷端口狀態(tài)
unsigned char PortNtcStatus()
    unsigned char p = 0;
    if (PORT_NTC)
        p++;
    delayit(1);
    if (PORT_NTC)
        p++;
    delayit(1);
    if (PORT_NTC)
        p++;
    if (p >= 2)
        return 1;
        return 0;
//判斷NTC是否正常連接,原理是改變另一個端口輸出值,看其是否跟著改變
unsigned char IsNtcAvailable()
    unsigned int cnt = 1000;
    TRIS_MEASURER = 1;
    TRIS_REF_RESISTOR = 1;
    TRIS_NTC = 1;
    if (PortNtcStatus())
        TRIS_MEASURER = 0;
        PORT_MEASURER = 0;
        while (PortNtcStatus() && (cnt > 0))
            cnt--;
        TRIS_MEASURER = 0;
        PORT_MEASURER = 1;
        while ((PortNtcStatus() == 0) && (cnt > 0))
            cnt--;
    PORT_MEASURER = 1;
    if (cnt)
        return 1;
        return 0;
//使用PID算法根據(jù)當(dāng)前溫度計算要加熱的時間(加熱周期為Tick中斷的周期)
void CalPidResult()
    signed char curError, dError;
    curError = cfgTemp - currTemp;
    if (curError > 1)
        dError = curError - pidLastError;
        pidSumError += curError;
        pidLastError = dError;
        pidResult = curError*PID_PROPORTION + pidSumError*PID_INTEGRAL + dError*PID_DERIVATIVE;
        pidResult >>= 3;
        pidSumError = 0;
        pidLastError = 1;
        pidResult = 0; //curError * PID_PROPORTION;
    /*if (curError > 10)
        pidResult = 10
    else if (curError > 1)
        pidResult = curError * 2;
        pidResult = 0;*/
//使用普通IO口計算NTC的電阻,進而查表得出當(dāng)前溫度
//軟件濾波算法:采樣多次,然后去掉一個最大值,一個最小值,剩下的取平均
void GetCurrentTemp()
    //因為NTC為通過插座外接,可能會出現(xiàn)斷開、接觸不好、斷路等異常,此變量用于防止死循環(huán)
    unsigned int cntSafe = 20000;
    unsigned int cntNtc, cntRef;
    float resistorNtc, ratio;
    signed int sumTemp;
    unsigned char idx;
    signed char maxTemp, minTemp;
    signed char thisTemp = 0;
    if (IsNtcAvailable() == 0)
        currMode |= MODE_NO_NTC;
        currTemp = 120;
        ntcTempBuffCnt = 0;
        return;
        currMode &= ~MODE_NO_NTC;
    //輸出高電平給電容充電
    TRIS_NTC = 1;
    TRIS_MEASURER = 0;
    PORT_MEASURER = 1;
    PORT_NTC = 0;
    PORT_REF_RESISTOR = 0;
    delayit(50); //讓電容充分充電
    //停止TMR1,重新設(shè)置TMR1
    TMR1ON = 0;
    TMR1H = 0;
    TMR1L = 0;
    //打開NTC端口,讓電容放電,獲取放電時間
    GIE = 0;
    TRIS_MEASURER = 1;
    PORT_NTC = 0;
    TRIS_NTC = 0;
    TMR1ON = 1; //TMR1開始計時
    while ((PORT_MEASURER) && (cntSafe > 0))
        cntSafe--;
    TMR1ON = 0;
    cntNtc = (TMR1H << 8) + TMR1L;
    GIE = 1;
    //NTC可能斷開連接了?
    if (cntSafe == 0)
        currTemp = 120;
        ntcTempBuffCnt = 0;
        return;
    //同樣步驟測試參考電阻,然后通過兩個計數(shù)值的對比就可以計算出NTC電阻
    //輸出高電平給電容充電
    TRIS_NTC = 1;
    TRIS_MEASURER = 0;
    PORT_MEASURER = 1;
    //重新設(shè)置TMR1
    TMR1H = 0;
    TMR1L = 0;
    //打開參考電阻端口,讓電容放電,獲取放電時間
    GIE = 0;
    TRIS_MEASURER = 1;
    TRIS_REF_RESISTOR = 0;
    do {}
    while (PORT_MEASURER);
    TMR1ON = 0;
    cntRef = (TMR1H << 8) + TMR1L;
    GIE = 1;
    TRIS_MEASURER = 0;
    PORT_MEASURER = 1;
    //計算得到當(dāng)前NTC阻值,然后就可以查表得到溫度值了
    if ((cntNtc > 0) && (cntRef > 0))
        ratio = (float)cntNtc / (float)cntRef;
        resistorNtc = REF_RESISTOR_VALUE * ratio;
        if (resistorNtc < tblNtcTemp[TBL_NTC_TEMP_NUM - 1]) //溫度越限
            thisTemp = 120;
        else if (resistorNtc > tblNtcTemp[0])
            thisTemp = -120;
            for (idx = TBL_NTC_TEMP_NUM; idx > 0; idx--)
                if (resistorNtc <= tblNtcTemp[idx - 1])
                    thisTemp = idx - 10; //溫度表從-9度開始
                    break;
    else //計數(shù)值為零可能是短路
        thisTemp = 120;
    //軟件濾波:去掉一個最大值,去掉一個最小值,然后剩下的取平均
    ntcTempBuff[ntcTempBuffCnt] = thisTemp;
    if (++ntcTempBuffCnt >= NTC_TEMP_BUFF_NUM)
        ntcTempBuffCnt = 0;
        //去掉一個最大值和一個最小值,然后剩余取平均
        maxTemp = ntcTempBuff[0];
        minTemp = maxTemp;
        sumTemp = maxTemp;
        for (idx = 1; idx < NTC_TEMP_BUFF_NUM; idx++)
            thisTemp = ntcTempBuff[idx];
            if (thisTemp > maxTemp)
                maxTemp = thisTemp;
            if (thisTemp < minTemp)
                minTemp = thisTemp;
            sumTemp += thisTemp;
        currTemp = (sumTemp - maxTemp - minTemp) >> 2;
        //通過PID計算加熱周期數(shù)
        CalPidResult();
//在數(shù)碼管上顯示溫度
//此函數(shù)僅更新段碼到內(nèi)存緩沖區(qū),然后由Tick中斷函數(shù)輸出到數(shù)碼管顯示,
//Tick中斷每5ms掃描一次數(shù)碼管,無閃爍
void DisplayTemp(signed char temp)
    if (currMode & MODE_NO_NTC) //顯示EE
        digit0Seg = segMap[SEG_IDX_E];
        digit1Seg = digit0Seg;
    else if (temp < -9) //顯示LL
        digit0Seg = segMap[SEG_IDX_L];
    else if (temp > 99) //顯示HH
        digit0Seg = segMap[SEG_IDX_H];
    else if ((temp >= 0) && (temp < 10)) //0-9則高位消隱
        digit0Seg = segMap[temp];
        digit1Seg = 0xff;
    else if (temp < 0)
        temp = -temp;
        digit1Seg = segMap[SEG_IDX_DASH];
        digit1Seg = segMap[temp / 10];
        digit0Seg = segMap[temp % 10];
//顯示子程序
void Display()
    //如果不是正常狀態(tài),則在數(shù)碼管上閃爍設(shè)定的溫度或錯誤信息
    if (currMode)
        if (halfSecond)
            DisplayTemp(cfgTemp);
            digit0Seg = 0xff;
            digit1Seg = 0xff;
        DisplayTemp(currTemp);
//中斷服務(wù)
void interrupt Tick()
    if (TMR2IE && TMR2IF) //定時器2中斷服務(wù)程序
        TMR2IF = 0;
        LED_DIGIT_1 = 1;
        LED_DIGIT_0 = 1;
        if ((++tickNum % 100) == 0)
            halfSecond = !halfSecond;
        if (btnIdleTicks < 2000)
            btnIdleTicks++;
        //加熱處理
        if ((currMode == MODE_NORMAL) && (pidResult > 0))
            PORT_HEATER = 1;
            pidResult--;
            PORT_HEATER = 0;
        //數(shù)碼管消隱
        delayit(5);
        //動態(tài)掃描LED
        revertLed = !revertLed;
        if (revertLed)
            PORTB = digit0Seg;
            if (digit0Seg != 0xff)
                LED_DIGIT_0 = 0;
            PORTB = digit1Seg;
            if (digit1Seg != 0xff)
                LED_DIGIT_1 = 0;
//主函數(shù)入口
    //關(guān)閉模擬比較器
    //CM2 = 1;
    //CM1 = 1;
    //CM0 = 1;
    CMCON = 0x07;
    //關(guān)閉USART
    SPEN = 0;
    TRISA = TRISA_INIT_VALUE;
    PORTA = PORTA_INIT_VALUE;
    TRISB = TRISB_INIT_VALUE;
    PORTB = PORTB_INIT_VALUE;
    delayit(10000);
    //TIMER1設(shè)定為同步定時器,預(yù)分頻1,當(dāng)前暫停計數(shù)
    //TIMER1用于IO口測電阻時計數(shù)使用
    T1CON = 0b00000000;
    TMR1IE = 0;
    //TIMER2產(chǎn)生一個5ms的定時中斷
    T2CON = 0B00100101;
    PR2 = 249;
    TMR2IE = 1;
    PEIE = 1;
    GIE = 1;
    //啟動wdt,預(yù)分頻128,溢出時間大約2.3s
    OPTION_REG = 0b10001111;
    //TO位非零:不是wdt復(fù)位
    if (STATUS & 0x10)
    RestoreCfgFromEeprom();
    while (1)
        GetCurrentTemp();
        ScanButtons();
        Display();
        asm("CLRWDT");
ID:69862 發(fā)表于 2016-3-7 09:06 | 只看該作者
can't open include file "defineports.h":No such file or directory,
不能打開defineports.h,沒有這樣的目錄,你用的PIC什么型號?重新加一個頭文件就可以了。
ID:105780 發(fā)表于 2016-3-7 22:33 | 只看該作者
PIC單片機制作一個恒溫暖手暖腳暖身器,NTC IO測溫.rar (5.66 KB, 下載次數(shù): 4)         編譯有問題,提示出錯
