查看: 3377|回復(fù): 0
MOVIFIT-SC的PROFIBUS控制程序(寫的很經(jīng)典)
ID:107189 發(fā)表于 2016-3-6 14:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
IN
OUT
狀態(tài)字1
控制字1
---------------------------------------中文-------------------------------------
注意:兼容兩個或三個過程數(shù)據(jù)字
PI1: 狀態(tài)字 1
PI2: 狀態(tài)字 2
Bit5   : 錯誤/警告 ="1"
Bit8-15: 錯誤位
錯誤碼:
07 - 中間電路電壓高
08 - 無監(jiān)測錯誤
90 - 馬達(dá)-變頻器不匹配
17-24, 37 - CPU 錯誤
25, 94 - EEPROM錯誤
01 - 輸出過程過電流
11 - 輸出過程溫度過高
84 - 馬達(dá)溫度過高
     馬達(dá)-變頻器不匹配
89 - 溫度保護(hù)開關(guān)
     馬達(dá)-變頻器不匹配
06 - 相位錯誤
PO1: 控制字
--------------------------------------English-----------------------------------
note: compatible with 2 process data words (1PO/2PI)
PI1: Status word 1 (drive 1)
PI2: Status word 2 (drive 2)
Bit5   : Fault/Warning ="1"
Bit8-15: Fault number
Fault code:
07 - INTERMEDIATE CIRCUIT TENSION TO HIGH
08 - FAULT N-MONITORING
90 - ALLOCATION MOTOR-INVERTER WRONG
17-24, 37 - CPU FAULT
25, 94 - EEPROM-FAULT
01 - OUTPUT STAGE OVERCURRENT
11 - OUTPUT STAGE OVERTEMPERATURE
84 - OVERTEMPERATURE MOTOR
89 - OVERTEMPERATURE BRAKE
06 - NET-PHASEFAILURE
PO1: CONTROL WORD
    網(wǎng)段:
LAR1  P##_PI1_StatWord1           // copy status words into local variables
      L     #iPI_1
      T     LW [AR1,P#0.0]
      LAR1  P##_PI2_StatWord2
      L     #iPI_2
      T     LW [AR1,P#0.0]
      L     W#16#0                      // zeroes temporary variables
      LAR1  P##_PO1_CtrlWord
      T     LW [AR1,P#0.0]
      A     #iEnableM1                  // check preconditions to enable drive
      AN    #_PI1_StatWord1.FaultWarn
      =     #_PreconOK_M1
      A     #iEnableM2                  // check preconditions to enable drive
      AN    #_PI2_StatWord2.FaultWarn
      =     #_PreconOK_M2
      A     #_PreconOK_M1
      A     #iStartM1
      =     #_PO1_CtrlWord.EnableM1     // enable drive 1
      A     #iReverseM1
      =     #_PO1_CtrlWord.ReverseM1    // enable drive 1 "CCW"
      A     #_PreconOK_M2
      A     #iStartM2
      =     #_PO1_CtrlWord.EnableM2     // enable drive 2
      A     #iReset
      =     #_PO1_CtrlWord.Reset
      A     #iBrakeM1
      A     #_PreconOK_M1
      =     #_PO1_CtrlWord.BrakeRelM1
      A     #iBrakeM2
      A     #_PreconOK_M2
      =     #_PO1_CtrlWord.BrakeRelM2
      A     #_PI1_StatWord1.DriveEn
      A     #_PI1_StatWord1.DriveRdy
      =     #oDrvEnM1                   // drive enable indicator
      A     #_PI2_StatWord2.DriveEn
      A     #_PI2_StatWord2.DriveRdy
      =     #oDrvEnM2                   // drive enable indicator
      L     #_PI1_StatWord1.Status
      L     0
      ==I
      A     #iEnableM1
      AN    #_PI1_StatWord1.DriveRdy
      =     #_24V_Operation             // 24V operation (maintanence switch off)
      A     #_PI1_StatWord1.FaultWarn   // drive fault indicator
      O     #_24V_Operation             // 24V operation (maintanence switch off)
      =     #oFaultM1
      A     #_PI2_StatWord2.FaultWarn   // drive fault indicator
      =     #oFaultM2
      A     #oFaultM1
      JCN   NFL1
      JU    SFL1
NFL1: L     0
SFL1: T     #oFaultNoM1
      A     #oFaultM2
      JCN   NFL2
      L     #_PI2_StatWord2.Status
      JU    SFL2
NFL2: L     0
SFL2: T     #oFaultNoM2
      LAR1  P##_PO1_CtrlWord            // copy local variables into function outputs
      L     LW [AR1,P#0.0]
      T     #oPO_1
      SET
      SAVE
