查看: 2869|回復(fù): 0
我寫了一段點(diǎn)陣滾動(dòng)顯示的代碼,但是每一段結(jié)束會(huì)有如圖錯(cuò)誤
ID:107782 發(fā)表于 2016-3-8 22:55 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
10黑幣
驅(qū)動(dòng)點(diǎn)陣的是max7219,代碼在下面,要?jiǎng)討B(tài)顯示的是”I 愛心 U“,心形符號(hào)打不出來,用文字表達(dá)
#include <reg52.h>
#include <intrins.h>
#define uint  unsigned int
//定義Max7219端口
sbit Max7219_pinCLK = P2^2;
sbit Max7219_pinCS  = P2^1;
sbit Max7219_pinDIN = P2^0;
uchar code disp1[5][8]={
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3C,0x18,0x18,0x18,0x18,0x18,0x3C,0x00,
0x66,0xE7,0xFF,0xFF,0x7E,0x3C,0x18,0x00,0xC3,0xC3,0xC3,0xC3,0xC3,0xC3,0x7E,0x3C,
uchar i=0;
void Delay_xms(uint x)
uint i,j;
for(i=0;i<x;i++)
  for(j=0;j<112;j++);
//功能:向MAX7219(U3)寫入字節(jié)
//入口參數(shù):DATA
//出口參數(shù):無
//說明:
void Write_Max7219_byte(uchar DATA)
            uchar i;
                Max7219_pinCS=0;
            for(i=8;i>=1;i--)
            Max7219_pinCLK=0;
            Max7219_pinDIN=DATA&0x80;
            DATA=DATA<<1;
            Max7219_pinCLK=1;
//功能:向MAX7219寫入數(shù)據(jù)
//入口參數(shù):address、dat
//出口參數(shù):無
//說明:
void Write_Max7219(uchar address,uchar dat)
     Max7219_pinCS=0;
         Write_Max7219_byte(address);           //寫入地址,即數(shù)碼管編號(hào)
     Write_Max7219_byte(dat);               //寫入數(shù)據(jù),即數(shù)碼管顯示數(shù)字
         Max7219_pinCS=1;
void Init_MAX7219(void)
    Write_Max7219(0x09, 0x00);       //譯碼方式:BCD碼
Write_Max7219(0x0a, 0x03);       //亮度
Write_Max7219(0x0b, 0x07);       //掃描界限;8個(gè)數(shù)碼管顯示
Write_Max7219(0x0c, 0x01);       //掉電模式:0,普通模式:1
Write_Max7219(0x0f, 0x00);
void main(void)
//Write_Max7219(0x0f, 0x00);
//Delay_xms(500);
           TMOD=0x01;
           TH0=0xfc;
           TL0=0x67;
           ET0=1;
           TR0=1;
           EA=1;
           while(1);
void time()  interrupt 1
         static uchar tmr=0,j=0,k=0;
         TH0=0xfc;
         TL0=0x67;
          Delay_xms(50);
Init_MAX7219();
Delay_xms(200);
  for(j=0;j<5;j++)
   for(i=1;i<9;i++)
    Write_Max7219(i,disp1[j][i-1+k]);
   Delay_xms(500);
  Delay_xms(200);
   k++;
if(k>=8)k=0;
  tmr++;
  if(tmr>=250)
           tmr=0;
