#include <reg52.h>
#include "LCD1602.h"
#include "UART.h"
#include "Delay.h"
#include "GPS.h"
#include "config.h"
void main(void)
unsigned char i;
Uart_Init();
LCD1602_Init();
GPS_lock=1;
GPSUSE_satellite[0]='0';
GPSUSE_satellite[1]='0';
if(Data_legitimate==0) //無GPS信號(hào)時(shí)
LCD1602_WriteCMD(CMD_clear);
Print_String(line_one," RTrobot GPS");
Print_String(line_two,"Please Waiting. ");
while(Data_legitimate==0);
Delay_Ms(200);
else //有GPS信號(hào)
if(Data_legitimate|0x01) //GPGGA處理
if(GPS_lock==0) //未定位
Print_String(line_two,"Waiting...");
else //已定位
Print_Char(line_one,0,GPS_longitude_dir); //顯示經(jīng)度
for(i=0;i<3;i++)
Print_Char(line_one,i+1,GPS_longitude[i]);
Print_Char(line_one,4,'.');
for(i=3;i<10;i++)
Print_Char(line_one,i+2,GPS_longitude[i]);
Print_Char(line_two,0,GPS_latitude_dir); //顯示緯度
Print_Char(line_two,1,' ');
for(i=0;i<2;i++)
Print_Char(line_two,i+2,GPS_latitude[i]);
Print_Char(line_two,4,'.');
for(i=2;i<9;i++)
Print_Char(line_two,i+3,GPS_latitude[i]);
Data_legitimate&=~0x01;
Delay_Ms(500);
串口中斷
void uart(void) interrupt 4
unsigned char UART_data;
if(RI)
UART_data=SBUF;
switch(UART_data)
case '$':
GPSDATA_number=0; //GPS數(shù)據(jù)類型清空
GPSDATA_mode=1; //接收命令模式
GPSDATA_count=0; //接收位數(shù)清空
break;
case ',':
GPSDOT_count++; //逗號(hào)計(jì)數(shù)加1
GPSDATA_count=0;
break;
case '*':
switch(GPSDATA_number)
case 1:
Data_legitimate|=0x01;//GPGGA
break;
case 2:
Data_legitimate|=0x02;//GPGSV
break;
case 3:
Data_legitimate|=0x04;//GPRMC
break;
GPSDATA_mode=0;
break;
default:
if(GPSDATA_mode==1) //類型種類判斷
GPSDATA_cmd[GPSDATA_count]=UART_data; //接收字符放入類型緩存
if(GPSDATA_count==4) //如果類型數(shù)據(jù)接收完畢,判斷類型
if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='G'&&GPSDATA_cmd[4]=='A')//判斷GPGGA
GPSDATA_number=1;
GPSDATA_mode=2;
GPSDOT_count=0;
GPSDATA_count=0;
if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='G'&&GPSDATA_cmd[3]=='S'&&GPSDATA_cmd[4]=='V')//判斷GPGSV
GPSDATA_number=2;
GPSDATA_mode=2;
GPSDOT_count=0;
GPSDATA_count=0;
if(GPSDATA_cmd[0]=='G'&&GPSDATA_cmd[1]=='P'&&GPSDATA_cmd[2]=='R'&&GPSDATA_cmd[3]=='M'&&GPSDATA_cmd[4]=='C')//判斷GPRMC
GPSDATA_number=3;
GPSDATA_mode=2;
GPSDOT_count=0;
GPSDATA_count=0;
其他類型照搬
else if(GPSDATA_mode==2) //接收數(shù)據(jù)處理
switch (GPSDATA_number)
case 1: //類型1數(shù)據(jù)接收。GPGGA
switch(GPSDOT_count)
case 2: //緯度處理
if(GPSDATA_count<9)
GPS_latitude[GPSDATA_count]=UART_data;
break;
case 3: //緯度方向處理
if(GPSDATA_count<1)
GPS_latitude_dir=UART_data;
break;
case 4: //經(jīng)度處理
if(GPSDATA_count<10)
GPS_longitude[GPSDATA_count]=UART_data;
break;
case 5: //經(jīng)度方向處理
if(GPSDATA_count<1)
GPS_longitude_dir=UART_data;
break;
case 6: //定位判斷
if(GPSDATA_count<1)
GPS_lock=UART_data;
break;
case 7: //GPS使用衛(wèi)星個(gè)數(shù)
if(GPSDATA_count<2)
GPSUSE_satellite[GPSDATA_count]=UART_data;
break;
case 9: //海拔高度處理
if(GPSDATA_count<6)
GPS_altitude[GPSDATA_count]=UART_data;
break;
break;
case 2: //類型2數(shù)據(jù)接收。GPGSV
case 3: //GPS可見衛(wèi)星個(gè)數(shù)
if(GPSDATA_count<2)
GPSVISIBLE_satellite[GPSDATA_count]=UART_data;
break;
break;
case 3: //類型3數(shù)據(jù)接收。GPRMC
case 1: //時(shí)間處理
if(GPSDATA_count<6)
GPS_time[GPSDATA_count]=UART_data;
break;
case 2: //定位判斷
if(GPSDATA_count<1)
if(UART_data=='A')
GPS_lock=1;
if(UART_data=='V')
GPS_lock=0;
break;
case 3: //緯度處理
if(GPSDATA_count<9)
break;
case 4: //緯度方向處理
if(GPSDATA_count<1)
break;
case 5: //經(jīng)度處理
break;
case 6: //經(jīng)度方向處理
if(GPSDATA_count<1)
break;
case 7: //速度處理
if(GPSDATA_count<5)
GPS_speed[GPSDATA_count]=UART_data;
break;
case 8: //方位角處理
if(GPSDATA_count<5)
GPS_Angle[GPSDATA_count]=UART_data;
break;
case 9: //日期
if(GPSDATA_count<6)
GPS_date[GPSDATA_count]=UART_data;
break;
break;
GPSDATA_count++; //接收數(shù)位加1
break;
#define LCD1602_DB0_DB7 P0 //1602液晶數(shù)據(jù)端口
sbit LCD1602_RS = P1^0; //1602液晶指令/數(shù)據(jù)選擇引腳
sbit LCD1602_RW = P1^1; //1602液晶讀寫引腳
sbit LCD1602_E = P1^5; //1602液晶使能引腳
定義LCD1602指令集 (詳細(xì)請(qǐng)見查看1602指令集手冊(cè))
#define CMD_clear 0x01 // 清除屏幕
#define CMD_back 0x02 // DDRAM回零位
#define CMD_ac 0x06 // 讀入后AC(指針)加1,向右寫
#define CMD_display 0x0c // 開顯示_關(guān)光標(biāo)_關(guān)光標(biāo)閃爍
#define CMD_set 0x38 // 8位總線_2行顯示
#define line_one 0x80 // 第一行寫入地址
#define line_two 0xc0 // 第二行寫入地址
LCD1602測(cè)忙,若LCD1602處于忙狀態(tài),本函數(shù)將等待至非忙狀態(tài)
void LCD1602_TestBusy(void)
LCD1602_DB0_DB7 = 0xff; //設(shè)備讀狀態(tài)
LCD1602_RS = 0;
LCD1602_RW = 1;
LCD1602_E = 1;
while(LCD1602_DB0_DB7&0x80); //等待LCD空閑
LCD1602_E = 0;
寫指令程序
void LCD1602_WriteCMD(unsigned char LCD1602_command)
LCD1602_TestBusy();
LCD1602_DB0_DB7 = LCD1602_command;
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_E = 1;
LCD1602_E = 0;
向LCD1602寫數(shù)據(jù)
void LCD1602_WriteData(unsigned char LCD1602_data)
LCD1602_TestBusy();
LCD1602_DB0_DB7 = LCD1602_data;
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_E = 1;
LCD1602_E = 0;
打印字符串程序(本函數(shù)調(diào)用指針函數(shù))
向LCD發(fā)送一個(gè)字符串,長度48字符之內(nèi)
在第一行第一位處從左向右打印字符串
void Print_String(unsigned char line,unsigned char *str)
LCD1602_WriteCMD(line);
while(*str != '\0')
LCD1602_WriteData(*str++);
*str = 0;
打印字符程序
向LCD發(fā)送一個(gè)字符,
line為行數(shù)(使用line_one,line_two定義使用),num為位置,data為打印字符
void Print_Char (unsigned char line,unsigned char num,unsigned char date)
LCD1602_WriteCMD(line+num);
LCD1602_WriteData(date);
LCD1602初始化
void LCD1602_Init(void)
LCD1602_WriteCMD(CMD_set); // 顯示模式設(shè)置:顯示2行,每個(gè)字符為5*7個(gè)像素
LCD1602_WriteCMD(CMD_clear); // 顯示清屏
LCD1602_WriteCMD(CMD_back); // 數(shù)據(jù)指針指向第1行第1個(gè)字符位置
LCD1602_WriteCMD(CMD_ac); // 顯示光標(biāo)移動(dòng)設(shè)置:文字不動(dòng),光標(biāo)右移
LCD1602_WriteCMD(CMD_display); // 顯示開及光標(biāo)設(shè)置:顯示開,光標(biāo)開,閃爍開
void Uart_Init(void)
EA=1;
ES=1;
SCON = 0x50;
TMOD = 0x20;
PCON=0x00;
TH1 = 0xFD;
TL1 = 0xfd;
TR1 = 1;
RI = 0;
接收數(shù)據(jù)是否完整
1有效
0無效
unsigned char Data_legitimate=0;
GPS是否定位
1有效
0無效
unsigned char GPS_lock;
unsigned char GPSUSE_satellite[2];
unsigned char GPSVISIBLE_satellite[2];
GPS數(shù)據(jù)類型
1GPGGA
2GPGSV
3GPRMC
unsigned char GPSDATA_number;
GPS數(shù)據(jù)模式
0結(jié)束模式
1類型模式
2數(shù)據(jù)模式
unsigned char GPSDATA_mode;
逗號(hào)計(jì)數(shù)器
unsigned char GPSDOT_count;
位數(shù)計(jì)數(shù)器
unsigned char GPSDATA_count;
類型模式存儲(chǔ)數(shù)組
unsigned char GPSDATA_cmd[5];
緯度
unsigned char GPS_latitude[9];
緯度方向
unsigned char GPS_latitude_dir;
經(jīng)度
unsigned char GPS_longitude[10];
經(jīng)度方向
unsigned char GPS_longitude_dir;
GPS速度
unsigned char GPS_speed[5]={'0','0','0','.','0'};
海拔高度
unsigned char GPS_altitude[6];
日期
unsigned char GPS_date[6];
時(shí)間
unsigned char GPS_time[6];
方位角
unsigned char GPS_Angle[5]={'0','0','0','0','0'};
方位角
unsigned char OUT_speed[5];
void Delay_Ms (unsigned int a)
unsigned int i;
while( a-- != 0)
for(i = 0; i < 600; i++);
