查看: 2849|回復(fù): 4
linking... *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS ...
ID:262 發(fā)表于 2016-3-11 20:57 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這是我根據(jù)別人的代碼加以優(yōu)化的,沒有錯(cuò)誤只是有警告linking...
    SEGMENT: ?PR?KAISHI_KEYSCAN?1
Program Size: data=34.0 xdata=0 code=701
creating hex file from "1"...
"1" - 0 Error(s), 1 Warning(s).,求大神指教怎么改
#include <reg51.h>
unsigned char code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
sbit start_stop = P3^6;
sbit reset = P3^7;
sbit key1 = P1^0;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit key4 = P1^3;
sbit key5 = P1^4;
sbit key6 = P1^5;
sbit key7 = P1^6;
sbit key8 = P1^7;
sbit state = P3^4;
sbit kaishi=P3^1;
uchar start_stop_flag = 0;
uchar key_flag = 0;
uchar reset_flag = 0;
uchar action = 0;
uchar kaishi_flag=0;//開始標(biāo)志
uchar second = 20;//倒計(jì)時(shí)20秒
uchar timer0_count = 0;
uchar number = 0;
uchar number_display = 0;
/*延時(shí)函數(shù)*/
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
/*數(shù)碼管顯示驅(qū)動(dòng)函數(shù)*/
void display(uchar number,uchar second)
        uchar second_first,second_second;
        second_first = second / 10;
        second_second = second % 10;
        P2 = 0xfe;
        P0 = table[number];
        delay(2);
        P2 = 0xfd;
        P0 = 0x40;
        delay(2);
        P2 = 0xfb;
        P0 = table[second_first];
        delay(2);
        P2 = 0xf7;
        P0 = table[second_second];
        delay(2);
/*開始鍵掃描函數(shù)*/
void start_stop_keyscan()
        if(start_stop == 0)
                delay(8);
                if((start_stop == 0)&&(!start_stop_flag))
                        start_stop_flag = 1;
                        action  = 1;
                        TR0 = 1;
                        state = 0;
/*八位搶答鍵掃描函數(shù)*/
key_scan8()
        if(key1 == 0)
                delay(8);
                if((key1 == 0)&&(!key_flag))
                        key_flag = 1;
                        number  = 1;
                        number_display = number;
        else if(key2 == 0)
                   delay(8);
                   if((key2 == 0)&&(!key_flag))
                             key_flag = 1;
                            number  = 2;
        else  if(key3 == 0)
                  delay(8);
                  if((key3 == 0)&&(!key_flag))
                     key_flag = 1;
                         number  = 3;
        else if(key4 == 0)
                 delay(8);
                 if((key4 == 0)&&(!key_flag))
                        key_flag = 1;
                        number  = 4;
        else if(key5 == 0)
              delay(8);
                  if((key5 == 0)&&(!key_flag))
                          key_flag = 1;
                          number  = 5;
        else if(key6 == 0)
                  delay(8);
                  if((key6 == 0)&&(!key_flag))
                          key_flag = 1;
                          number  = 6;
        else if(key7 == 0)
                  delay(8);
                  if((key7 == 0)&&(!key_flag))
                          key_flag = 1;
                          number  = 7;
        else  if(key8 == 0)
                  delay(8);
                  if((key8 == 0)&&(!key_flag))
                          key_flag = 1;
                          number  = 8;
            key_flag = 0;
                number  = 0;
        if(number_display != 0)
                return 1;
                return 0;
/*復(fù)位鍵掃描函數(shù)*/
reset_keyscan()
        if(reset == 0)
                delay(8);
                if((reset == 0)&&(!reset_flag))
                {        second=20;
                        reset_flag = 1;
                        number_display = 0;
                        state = 1;
                reset_flag = 0;
/*主持人開始函數(shù)*/
kaishi_keyscan()
        if(kaishi == 0)
                delay(8);
                if((kaishi == 0)&&(!kaishi_flag))
                        kaishi_flag = 1;
                        number_display = 0;
                        state = 1;
                kaishi_flag = 0;
/*主函數(shù)*/
    TMOD=0x01;
    TH0=0x3c;
        TL0=0xb0;
        EA=1;
        ET0=1;
        TR0=0;
           while((kaishi == 0)&&(!kaishi_flag))
              start_stop_keyscan();
                  reset_keyscan();
                  while(action)
                        while(!key_scan8())
                                display(number_display,second);
                                if(second == 0)
                                        second = 20;
                                        break;
                                TR0 = 0;
                                second = 0;
                                action = 0;
                                break;
/*中斷服務(wù)函數(shù)*/
void timer0() interrupt 1
        TH0=0x3c;
        TL0=0xb0;
        timer0_count++;
        if(timer0_count == 20)
                timer0_count = 0;
                second--;
                if(second == 0)
                        TR0 = 0;
                        number_display = 0;
                        state = 1;
                        action = 0;
ID:262 發(fā)表于 2016-3-11 20:58 | 只看該作者
沒有錯(cuò)誤,運(yùn)行沒啥大問(wèn)題的,這樣搶答器這樣已經(jīng)不錯(cuò)了,干嘛還要這么較真。
//void kaishi_keyscan()這個(gè)函數(shù)沒用到,不影響,注釋了就不會(huì)有警告了,還有一個(gè)帶返回值的函數(shù)沒寫返回值參數(shù)類型,不過(guò)也不影響,下面這個(gè)改好了,沒有警告了。你看一下可以用嗎,
#include <reg51.h>
sbit reset = P3^7;
sbit key1 = P1^0;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit key4 = P1^3;
sbit key5 = P1^4;
sbit key6 = P1^5;
sbit key7 = P1^6;
sbit key8 = P1^7;
sbit state = P3^4;
sbit kaishi=P3^1;
uchar key_flag = 0;
uchar action = 0;
uchar kaishi_flag=0;//????
uchar second = 20;//???20?
uchar number = 0;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
        P2 = 0xfe;
        P0 = table[number];
        delay(2);
        P2 = 0xfd;
        P0 = 0x40;
        delay(2);
        P2 = 0xfb;
        delay(2);
        P2 = 0xf7;
        delay(2);
        if(start_stop == 0)
                delay(8);
                        action  = 1;
                        TR0 = 1;
                        state = 0;
uchar key_scan8()
        if(key1 == 0)
                delay(8);
                        key_flag = 1;
                        number  = 1;
        else if(key2 == 0)
                   delay(8);
                             key_flag = 1;
                            number  = 2;
        else  if(key3 == 0)
                  delay(8);
                     key_flag = 1;
                         number  = 3;
        else if(key4 == 0)
                 delay(8);
                        key_flag = 1;
                        number  = 4;
        else if(key5 == 0)
              delay(8);
                          key_flag = 1;
                          number  = 5;
        else if(key6 == 0)
                  delay(8);
                          key_flag = 1;
                          number  = 6;
        else if(key7 == 0)
                  delay(8);
                          key_flag = 1;
                          number  = 7;
        else  if(key8 == 0)
                  delay(8);
                          key_flag = 1;
                          number  = 8;
            key_flag = 0;
                number  = 0;
                return 1;
                return 0;
void reset_keyscan()
        if(reset == 0)
                delay(8);
                {        second=20;
                        reset_flag = 1;
                        number_display = 0;
                        state = 1;
                reset_flag = 0;
//        if(kaishi == 0)
//                delay(8);
//                if((kaishi == 0)&&(!kaishi_flag))
//                        kaishi_flag = 1;
//                        number_display = 0;
//                        state = 1;
//        else
//                kaishi_flag = 0;
    TMOD=0x01;
    TH0=0x3c;
        TL0=0xb0;
        EA=1;
        ET0=1;
        TR0=0;
                  reset_keyscan();
                  while(action)
                        while(!key_scan8())
                                if(second == 0)
                                        second = 20;
                                        break;
                                TR0 = 0;
                                second = 0;
                                action = 0;
                                break;
        TH0=0x3c;
        TL0=0xb0;
        timer0_count++;
                timer0_count = 0;
                second--;
                if(second == 0)
                        TR0 = 0;
                        number_display = 0;
                        state = 1;
                        action = 0;
非常感謝撒,因?yàn)槭且隹荚囋O(shè)計(jì)還要焊接電路板,老師要求比較嚴(yán)格,親,你給我改的我運(yùn)行之后發(fā)現(xiàn)有個(gè)問(wèn)題,就是我斷開開關(guān)我的數(shù)碼管依然還是倒計(jì)時(shí)
不好意思啊,原來(lái)開始函數(shù)注掉了,沒看到
