多功能電子鐘
- 下面是一個多功能的電子萬年歷的程序。
- 主要功能:
- 1、顯示當前的日期及標準北京時間
- 2、實時檢測當前溫度并通過1602顯示出來
- 3、具有可調的鬧鐘功能,通過按鍵調整鬧鐘的起
- 鬧時間
- 4、通過按鍵實現畫面的切換
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- uchar code digit[]={"0123456789"}; //定義字符數組顯示數字
- uchar code Error[]="Error!Check!"; //說明沒有檢測到DS18B20
- uchar code table[]="Alarm Clock";
- uchar code table1[]="0123456789";
- uchar code table2[]="WEEK";
- uchar code table3[]="Today is fine!";
- uchar code table4[]="HELLO!";
- uchar code table5[]="Made by lanxiaoling";
- uchar code table6[]="Happy new year!";//1.1
- uchar code table7[]="Valentine's Day"; //2.14
- /*uchar code table8[]="Qing Ming jie!";//4.5
- uchar code table9[]="Happy Labor Day!";//5.1
- uchar code table10[]="Duan Wu jie!";//6.15
- uchar code table11[]="Army day!";//8.1
- uchar code table12[]="Teacher's Day!";//9.10
- uchar code table13[]="National Day!";//10.1
- 以下是對液晶模塊的操作程序
- sbit RS=P2^0; //寄存器選擇位,將RS位定義為P2.0引腳
- sbit RW=P2^1; //讀寫選擇位,將RW位定義為P2.1引腳
- sbit E=P2^2; //使能信號位,將E位定義為P2.2引腳
- sbit BF=P0^7; //忙碌標志位,,將BF位定義為P0.7引腳
- sbit DQ=P2^6;
- sbit T_RST=P1^5;
- sbit T_CLK=P1^3;
- sbit T_IO=P1^4;
- sbit beep=P2^4;
- sbit key1=P3^0; //調鬧鐘的小時即x
- sbit key2=P3^1; //調鬧鐘的分鐘即y
- sbit key3=P3^2; //顯示切換
- sbit key4=P3^3;
- sbit ACC0=ACC^0;
- sbit ACC7=ACC^7;
- uchar time; //設置全局變量,專門用于嚴格延時
- static uchar x=0x08,y=30;
- uchar t_sec,sec1,sec2;
- uchar t_min,min1,min2;
- uchar t_hour,hour1,hour2;
- uchar t_mon,mon1,mon2;
- uchar t_day,day1,day2;
- uchar t_year,year1,year2;
- uchar week,week1;
- uchar com,inf;
- void tixing(unsigned char mm,unsigned dd);
- void show();
- void delay1(uchar t)
- uchar a,b;
- for(a=t;a>0;a--)
- for(b=110;b>0;b--);
- 函數功能:延時1ms
- (3j+2)*i=(3×33+2)×10=1010(微秒),可以認為是1毫秒
- void delay1ms()
- uchar i,j;
- for(i=0;i<10;i++)
- for(j=0;j<33;j++)
- 函數功能:延時若干毫秒
- 入口參數:n
- void delaynms(uchar n)
- uchar i;
- for(i=0;i<n;i++)
- delay1ms();
- 函數功能:判斷液晶模塊的忙碌狀態(tài)
- 返回值:result。result=1,忙碌;result=0,不忙
- bit BusyTest(void)
- bit result;
- RS=0; //根據規(guī)定,RS為低電平,RW為高電平時,可以讀狀態(tài)
- RW=1;
- E=1; //E=1,才允許讀寫
- _nop_(); //空操作
- _nop_();
- _nop_();
- _nop_(); //空操作四個機器周期,給硬件反應時間
- result=BF; //將忙碌標志電平賦給result
- E=0; //將E恢復低電平
- return result;
- 函數功能:將模式設置指令或顯示地址寫入液晶模塊
- 入口參數:dictate
- void WriteInstruction (uchar dictate)
- while(BusyTest()==1); //如果忙就等待
- RS=0; //根據規(guī)定,RS和R/W同時為低電平時,可以寫入指令
- RW=0;
- E=0; //E置低電平(根據表8-6,寫指令時,E為高脈沖,
- // 就是讓E從0到1發(fā)生正跳變,所以應先置"0"
- _nop_();
- _nop_(); //空操作兩個機器周期,給硬件反應時間
- P0=dictate; //將數據送入P0口,即寫入指令或地址
- _nop_();
- _nop_();
- _nop_();
- E=1; //E置高電平
- _nop_();
- _nop_();
- _nop_();
- E=0; //當E由高電平跳變成低電平時,液晶模塊開始執(zhí)行命令
- 函數功能:指定字符顯示的實際地址
- 入口參數:x
- void WriteAddress(unsigned char x)
- WriteInstruction(x|0x80); //顯示位置的確定方法規(guī)定為"80H+地址碼x"
- 函數功能:將數據(字符的標準ASCII碼)寫入液晶模塊
- 入口參數:y(為字符常量)
- void WriteData(uchar y)
- RS=1; //RS為高電平,RW為低電平時,可以寫入數據
- RW=0;
- P0=y; //將數據送入P0口,即將數據寫入液晶模塊
- _nop_();
- _nop_();
- _nop_();
- E=1; //E置高電平
- _nop_();
- _nop_();
- _nop_();
- 函數功能:對LCD的顯示模式進行初始化設置
- void LcdInitiate(void)
- delaynms(15); //延時15ms,首次寫指令時應給LCD一段較長的反應時間
- WriteInstruction(0x38); //顯示模式設置:16×2顯示,5×7點陣,8位數據接口
- delaynms(5); //延時5ms ,給硬件一點反應時間
- WriteInstruction(0x38); //連續(xù)三次,確保初始化成功
- WriteInstruction(0x0c); //顯示模式設置:顯示開,無光標,光標不閃爍
- WriteInstruction(0x06); //顯示模式設置:光標右移,字符不移
- WriteInstruction(0x01); //清屏幕指令,將以前的顯示內容清除
- void write_com(uchar com)//向1602寫指令
- RS=0;
- RW=0;
- P0=com;
- delaynms(10);
- E=1;
- delaynms(10);
- E=0;
- 函數功能:將DS18B20傳感器初始化,讀取應答信號
- 出口參數:flag
- bit Init_DS18B20(void)
- bit flag; //儲存DS18B20是否存在的標志,flag=0,表示存在;flag=1,表示不存在
- DQ = 1; //先將數據線拉高
- for(time=0;time<2;time++) //略微延時約6微秒
- DQ = 0; //再將數據線從高拉低,要求保持480~960us
- for(time=0;time<200;time++) //略微延時約600微秒
- ; //以向DS18B20發(fā)出一持續(xù)480~960us的低電平復位脈沖
- DQ = 1; //釋放數據線(將數據線拉高)
- for(time=0;time<10;time++)
- ; //延時約30us(釋放總線后需等待15~60us讓DS18B20輸出存在脈沖)
- flag=DQ; //讓單片機檢測是否輸出了存在脈沖(DQ=0表示存在)
- for(time=0;time<200;time++) //延時足夠長時間,等待存在脈沖輸出完畢
- return (flag); //返回檢測成功標志
- 函數功能:從DS18B20讀取一個字節(jié)數據
- 出口參數:dat
- uchar ReadOneChar(void)
- uchar i=0;
- uchar dat; //儲存讀出的一個字節(jié)數據
- for (i=0;i<8;i++)
- DQ =1; // 先將數據線拉高
- _nop_(); //等待一個機器周期
- DQ = 0; //單片機從DS18B20讀書據時,將數據線從高拉低即啟動讀時序
- dat>>=1;
- DQ = 1; //將數據線"人為"拉高,為單片機檢測DS18B20的輸出電平作準備
- ; //延時約6us,使主機在15us內采樣
- if(DQ==1)
- dat|=0x80; //如果讀到的數據是1,則將1存入dat
- else
- dat|=0x00;//如果讀到的數據是0,則將0存入dat
- //將單片機檢測到的電平信號DQ存入r[i]
- for(time=0;time<8;time++)
- ; //延時3us,兩個讀時序之間必須有大于1us的恢復期
- return(dat); //返回讀出的十進制數據
- 函數功能:向DS18B20寫入一個字節(jié)數據
- 入口參數:dat
- void WriteOneChar(uchar dat)
- uchar i=0;
- for (i=0; i<8; i++)
- DQ =1; // 先將數據線拉高
- DQ=0; //將數據線從高拉低時即啟動寫時序
- DQ=dat&0x01; //利用與運算取出要寫的某位二進制數據,
- //并將其送到數據線上等待DS18B20采樣
- ;//延時約30us,DS18B20在拉低后的約15~60us期間從數據線上采樣
- DQ=1; //釋放數據線
- for(time=0;time<1;time++)
- ;//延時3us,兩個寫時序間至少需要1us的恢復期
- dat>>=1; //將dat中的各二進制位數據右移1位
- for(time=0;time<4;time++)
- ; //稍作延時,給硬件一點反應時間
- 函數功能:顯示沒有檢測到DS18B20
- void display_error(void)
- uchar i;
- WriteAddress(0x00); //寫顯示地址,將在第1行第1列開始顯示
- i = 0; //從第一個字符開始顯示
- while(Error[i] != '\0') //只要沒有寫到結束標志,就繼續(xù)寫
- WriteData(Error[i]); //將字符常量寫入LCD
- i++; //指向下一個字符
- delaynms(100); //延時100ms較長時間,以看清關于顯示的說明
- while(1) //進入死循環(huán),等待查明原因
- 函數功能:顯示溫度的小數點
- void display_dot(void)
- WriteAddress(0x80+0x40+0x03); //寫顯示地址,將在第2行第10列開始顯示
- WriteData('.'); //將小數點的字符常量寫入LCD
- delaynms(50); //延時1ms給硬件一點反應時間
- 函數功能:顯示溫度的單位(Cent)
- void display_cent(void)
- WriteAddress(0x80+0x40+0x05); //寫顯示地址,將在第2行第13列開始顯示
- WriteData(0xdf);
- WriteAddress(0x80+0x40+0x06);
- WriteData('C');
- 函數功能:顯示溫度的整數部分
- 入口參數:x
- void display_temp1(unsigned char x)
- uchar j,k,l; //j,k,l分別儲存溫度的百位、十位和個位
- j=x/100; //取百位
- k=(x%100)/10; //取十位
- l=x%10; //取個位
- WriteAddress(0x80+0x40); //寫顯示地址,將在第2行第7列開始顯示
- WriteData(digit[j]); //將百位數字的字符常量寫入LCD
- WriteData(digit[k]); //將十位數字的字符常量寫入LCD
- WriteData(digit[l]); //將個位數字的字符常量寫入LCD
- 函數功能:顯示溫度的小數數部分
- 入口參數:x
- void display_temp2(uchar x)
- WriteAddress(0x80+0x40+0x04); //寫顯示地址,將在第2行第11列開始顯示
- WriteData(digit[x]); //將小數部分的第一位數字字符常量寫入LCD
- 函數功能:做好讀溫度的準備
- void ReadyReadTemp(void)
- Init_DS18B20(); //將DS18B20初始化
- WriteOneChar(0xCC); // 跳過讀序號列號的操作
- WriteOneChar(0x44); // 啟動溫度轉換
- for(time=0;time<100;time++)
- ; //溫度轉換需要一點時間
- WriteOneChar(0xCC); //跳過讀序號列號的操作
- WriteOneChar(0xBE); //讀取溫度寄存器,前兩個分別是溫度的低位和高位
- 向1302寫一個字節(jié)
- void input_BYTE(uchar dat)
- uchar i;
- ACC=dat;
- for(i=8;i>0;i--)
- T_IO=ACC0;
- T_CLK=1;
- T_CLK=0;
- ACC=(ACC>>1);
- 1302讀出一個字節(jié)
- uchar output_BYTE()
- uchar i;
- for(i=8;i>0;i--)
- ACC=(ACC>>1);
- ACC7=T_IO;
- T_CLK=1;
- T_CLK=0;
- return (ACC);
- 寫數據
- void write_1302(uchar add,uchar dat)
- T_RST=0;
- T_CLK=0;
- T_RST=1;
- input_BYTE(add);
- input_BYTE(dat);
- T_CLK=1;
- T_RST=0;
- 讀數據
- uchar read_1302(uchar add)
- uchar inf;
- T_RST=0;
- T_CLK=0;
- T_RST=1;
- input_BYTE(add);
- inf=output_BYTE();
- T_CLK=1;
- T_RST=0;
- return (inf);
- void init_1302()
- write_1302(0x8e,0x00);//關閉寫保護;
- // write_1302(0x90,0xaa);//設置充電方式;
- write_1302(0x80,0x00);//秒寄存器初始化;
- write_1302(0x82,0x29);//分.......
- write_1302(0x84,0x08);//時.......
- write_1302(0x86,0x03);//日........
- write_1302(0x88,0x06);//月.......
- write_1302(0x8a,0x05);//星期...
- write_1302(0x8c,0x11);//年......
- write_1302(0x8e,0x80);//打開寫保護;
- 鬧鐘顯示子程序
- void show_naozhong(uchar x,uchar y)
- uchar i,x1,x2,y1,y2;
- x1=x/10; //十位
- x2=x%10;//個位
- WriteAddress(0x80+0x0b); //顯示鬧鐘的小時部分
- WriteData(table1[x1]);
- WriteAddress(0x80+0x0c);
- WriteData(table1[x2]);
- y1=y/10; //十位
- y2=y%10;//個位
- WriteAddress(0x80+0x0e); //顯示鬧鐘的分鐘部分
- WriteData(table1[y1]);
- WriteAddress(0x80+0x0f);
- WriteData(table1[y2]);
- WriteAddress(0x80+0x0d); //顯示小時與分鐘之間的那個冒號
- WriteData(':');
- WriteAddress(0x80); //顯示字符串:Alarm Clock
- for(i=0;i<11;i++)
- WriteData(table[i]);
- WriteAddress(0x80+0x40); //顯示字符串:Today is fine!
- for(i=0;i<14;i++)
- WriteData(table3[i]);
- void main(void)
- uchar i;
- uchar TL; //儲存暫存器的溫度低位
- uchar TH; //儲存暫存器的溫度高位
- uchar TN; //儲存溫度的整數部分
- uchar TD; //儲存溫度的小數部分
- LcdInitiate(); //將液晶初始化
- init_1302();
- delaynms(5); //延時5ms給硬件一點反應時間
- // if(Init_DS18B20()==1)
- // display_error();
- EA=1;//開總中斷
- EX1=1;//開外部中斷1
- IT1=0;//下降沿觸發(fā)
- WriteAddress(0x80+0x10);
- for(i=0;i<6;i++)
- WriteData(table4[i]);
- WriteAddress(0x80+0x50);
- for(i=0;i<16;i++)
- WriteData(table5[i]);
- for(i=0;i<16;i++)
- write_com(0x18);
- delaynms(250);
- delaynms(250);
- delaynms(250);
- delaynms(250);
- write_com(0x01);
- while(1)
- t_sec=read_1302(0x81);//讀秒 ;
- sec1=t_sec&0x0f;
- sec2=(t_sec>>4);
- t_min=read_1302(0x83);//讀分 ;
- min1=t_min&0x0f;
- min2=(t_min>>4);
- t_hour=read_1302(0x85);//讀小時 ;
- hour1=t_hour&0x0f;
- hour2=(t_hour>>4);
- // WriteAddress(0x80+0x40+0x08); //顯示小時
- // WriteData(table1[hour2]);
- // WriteAddress(0x80+0x40+0x09);
- // WriteData(table1[hour1]);
- t_day=read_1302(0x87);//讀日;
- day1=t_day&0x0f;
- day2=(t_day>>4);
- t_mon=read_1302(0x89);//讀月 ;
- mon1=t_mon&0x0f;
- mon2=(t_mon>>4);
- week=read_1302(0x8b);//讀星期 ;
- week1=week&0x0f;
- t_year=read_1302(0x8d);//讀年 ;
- year1=t_year&0x0f;
- year2=(t_year>>4);
- WriteAddress(0x80+0x06);
- WriteData('2');
- WriteAddress(0x80+0x07);
- WriteData('0');
- WriteAddress(0x80); //顯示星期(0x80~0x80+0x05)
- for(i=0;i<4;i++)
- WriteData(table2[i]);
- WriteAddress(0x80+0x04);
- WriteData(table1[week1]);
- WriteAddress(0x80+0x08);//顯示年
- WriteData(table1[year2]);
- WriteAddress(0x80+0x09);
- WriteData(table1[year1]);
- WriteAddress(0x80+0x0a); //顯示‘/’
- WriteData('/');
- WriteAddress(0x80+0x0b);//顯示月
- WriteData(table1[mon2]);
- WriteData(table1[mon1]);
- WriteAddress(0x80+0x0d); //顯示‘/’
- WriteData('/');
- WriteAddress(0x80+0x0e);//顯示日
- WriteData(table1[day2]);
- WriteData(table1[day1]);
- /*第一行在此顯示完畢*/
- display_dot(); //顯示溫度的小數點
- display_cent(); //顯示溫度的單位
- WriteAddress(0x80+0x40+0x08); //顯示小時
- WriteData(table1[hour2]);
- WriteAddress(0x80+0x40+0x09);
- WriteData(table1[hour1]);
- WriteAddress(0x80+0x40+0x0a); //顯示':'
- WriteData(':');
- WriteAddress(0x80+0x40+0x0b); //顯示分鐘
- WriteData(table1[min2]);
- WriteAddress(0x80+0x40+0x0c);
- WriteData(table1[min1]);
- WriteAddress(0x80+0x40+0x0d); //顯示':'
- WriteData(':');
- WriteAddress(0x80+0x40+0x0e); //顯示秒
- WriteData(table1[sec2]);
- WriteAddress(0x80+0x40+0x0f);
- WriteData(table1[sec1]);
- /*第二行在此顯示完畢*/
- ReadyReadTemp(); //讀溫度準備
- TL=ReadOneChar(); //先讀的是溫度值低位
- TH=ReadOneChar(); //接著讀的是溫度值高位
- TN=TH*16+TL/16; //實際溫度值=(TH*256+TL)/16,即:TH*16+TL/16
- //這樣得出的是溫度的整數部分,小數部分被丟棄了
- TD=(TL%16)*10/16; //計算溫度的小數部分,將余數乘以10再除以16取整,
- //這樣得到的是溫度小數部分的第一位數字(保留1位小數)
- display_temp1(TN); //顯示溫度的整數部分
- display_temp2(TD); //顯示溫度的小數部分
- //以下部分是鬧鐘鍵盤檢測程序
- if((x==hour2*10+hour1)&&(y==min2*10+min1))//若時間到了,則開啟鬧鐘
- beep=0;
- else //否則,關閉鬧鐘
- beep=1;
- delaynms(10);
- tixing(t_mon,t_day);
- void exter1()interrupt 2
- uint k;
- write_com(0x01);
- for(k=0;k<2000;k++)
- while(key1==0) //鍵盤掃描.當key1按下時,
- { //鬧鐘的小時部分加一
- delaynms(10);
- if(key1==0) //消抖
- delaynms(10);
- while(key1==0); //松手檢測
- x++;
- if(x==24) //小時部分加到24后自動清零
- x=0;
- while(key2==0) //鍵盤檢測。當key2按下時,
- delaynms(10); //鬧鐘的分鐘部分加一
- if(key2==0) //消抖
- delaynms(10);
- while(key2==0);//松手檢測
- y++;
- if(y==60) //若分鐘部分加到60,則自動清零
- y=0;
- show_naozhong(x,y); //調用鬧鐘顯示程序
- write_com(0x01);
- uchar i;
- if(mm==0x01&&dd==0x01)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table6[i]);
- show();
- if(mm!=0x01||dd!=0x01)
- break;
- if(mm==0x02&&dd==0x14)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table7[i]);
- show();
- if(mm!=0x02||dd!=0x14)
- break;
- /* if(mm==0x04&&dd==0x05)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table8[i]);
- show();
- if(mm!=0x04||dd!=0x05)
- break;
- if(mm==0x05&&dd==0x01)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table9[i]);
- show();
- if(mm!=0x05||dd!=0x01)
- break;
- if(mm==0x06&&dd==0x15)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table10[i]);
- show();
- if(mm!=0x06||dd!=0x15)
- break;
- if(mm==0x08&&dd==0x01)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table11[i]);
- show();
- if(mm!=0x08||dd!=0x01)
- break;
- if(mm==0x09&&dd==0x10)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table12[i]);
- show();
- if(mm!=0x09||dd!=0x10)
- break;
- if(mm==0x10&&dd==0x01)
- while(1)
- for(i=0;i<16;i++)
- WriteData(table13[i]);
- show();
- if(mm!=0x10||dd!=0x01)
- break;
- void show()
- // uchar i;
- day1=t_day&0x0f;
- day2=(t_day>>4);
- mon1=t_mon&0x0f;
- mon2=(t_mon>>4);
- week1=week&0x0f;
- sec1=t_sec&0x0f;
- sec2=(t_sec>>4);
- min1=t_min&0x0f;
- min2=(t_min>>4);
- day1=t_day&0x0f;
- day2=(t_day>>4);
- mon1=t_mon&0x0f;
- mon2=(t_mon>>4);
- week1=week&0x0f;
- WriteData(':');
- WriteData(':');
- /*第二行在此顯示完畢*/
- //以下部分是鬧鐘鍵盤檢測程序
- beep=0;
- else //否則,關閉鬧鐘
- beep=1;
- delaynms(10);
復制代碼
