今天看到了個帖子,關(guān)于DM648網(wǎng)口異常的。最終原因是JTAG的TCLK沒有下拉導致。下面是原帖部分內(nèi)容:
We've been having problems with Ethernet comms on our custom board……
The root of the problem is the need for a pull down on the TCK pin, as per TI Advisory note 1.1.4. I added this and the port started to behave itself instantly.
在網(wǎng)上搜到相關(guān)的注釋及說明:
因為JTAG的TCLK與網(wǎng)絡部分的STCICLK共用,STCICLK需要默認下拉,而該引腳在DSP內(nèi)部默認上拉,所以會導致網(wǎng)絡模塊異常。
Figure Workaround Example
Advisory 1.1.4
Revision(s) Affected Details
3-Port Ethernet Switch Subsystem (3PSW) clocking problem normal functional operation earlier (JTAG controller clock) internally shared 3-Port Ethernet Switch Subsystem's (3PSW) STCICLK test debug mode. order 3-Port Ethernet Switch Subsystem (3PSW) proper clocking normal functional operation, STCICLK needs held low. since there internal pullup TCK, keeps 3-Port Ethernet Switch Subsystem from locking external REFCLKP/N proper operation. should externally pulled down with resistor.
