查看: 1901|回復(fù): 0
51數(shù)控
ID:115908 發(fā)表于 2016-4-22 13:15 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
/*#include"reg51.h"
sbit PWM=P1^0;
sbit DEC=P1^1;
sbit INC=P1^2;
sbit seg=P1^3;
sbit cp=P1^4;
sbit DAT=P1^5;
uint high;
bit stop;
uchar tab[16] = {0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
void delayms(uchar n)
{   uchar i,j,k;
        for(i=0;i<n;i++)
          for(j=0;j<100;j++)
            for(k=0;k<5;k++);
void delay(uint N)
{        while(--N);
void writebyte_164(uchar Dat)
{        uchar temp,i;
        temp=Dat;
        for(i=0;i<8;i++)
        { cp=0;
          if(temp&0x80) DAT=1;
          else DAT=0;
          cp=1;
          temp<<=1;
{   PWM=0;
        seg=0;
        EX0=1;
        IT0=1;
        EA=1;
        writebyte_164(tab[0]);
        seg=1;
        while(!stop);
        { PWM=1;
          delay(high);
          PWM=0;
          delay(300-high);
void int0()interrupt 0
{        PWM=0;
        if(!stop) stop=1;
        if(!DEC) high-=10;
        if(!INC) high+=10;
        seg=0;
        writebyte_164(tab[high/2%10]);
        writebyte_164(tab[high/2%100/10]|0x80);
        writebyte_164(tab[high/2/100]);
        seg=1;
        delayms(255);
#include"reg51.h"
#include"intrins.h"     //_nop_();延時(shí)函數(shù)用
#define ulong unsigned long
sbit PWM=P1^0;
sbit DEC=P1^1;
sbit INC=P1^2;
sbit seg=P1^3;
sbit cp=P1^4;
sbit DAT=P1^5;
sbit sda=P2^0;          //數(shù)據(jù)線
sbit scl=P2^1;          //時(shí)鐘線
uint high;
bit flag;
{   uchar i,j,k;
        for(i=0;i<n;i++)
          for(j=0;j<100;j++)
            for(k=0;k<5;k++);
void delay(uint N)
{        while(--N);
//啟動(dòng)(SCL為高,SDA由高變?yōu)榈褪且粋(gè)開始條件)
void start()
        sda=1;    //數(shù)據(jù)線置高,
        _nop_();  //延時(shí)
        scl=1;    //時(shí)鐘線置高
        _nop_();  //延時(shí)
        sda=0;    //數(shù)據(jù)線置低,由高變低
        _nop_();  //延時(shí)
        scl=0;    //時(shí)鐘線置低,準(zhǔn)備發(fā)送或接收數(shù)據(jù),總線進(jìn)入忙狀態(tài)(I2C總線在空閑狀態(tài)時(shí),SDA與SCL均被置高)
        _nop_();  //延時(shí)
//停止(SCL為高,SDA由低變?yōu)楦呤且粋(gè)結(jié)束條件)
void stop()
        _nop_();                 //延時(shí)
        scl=1;                   //時(shí)鐘線置高
        _nop_();                 //延時(shí)
        sda=1;                   //數(shù)據(jù)線置高,由低變高
        _nop_();                 //延時(shí)
//檢測(cè)應(yīng)答(所有的地址和數(shù)據(jù)字都是以8bit,在第9個(gè)時(shí)鐘周期,從器件發(fā)出"0"信號(hào)來作為收到一個(gè)字的應(yīng)答信號(hào))
void checkACK()                   //主器件檢測(cè)從器件是否返回應(yīng)答
        scl=1;                        //時(shí)鐘線置高
        _nop_();                      //延時(shí)
        while(sda==1);                //等待第9個(gè)時(shí)鐘周期器件發(fā)出的響應(yīng)信號(hào)"0"
        scl=0;                        //時(shí)鐘線置低
        _nop_();                      //延時(shí)
//發(fā)送應(yīng)答(發(fā)送方為主器件,接收方為從器件,控制器作為從器件接收完1數(shù)據(jù)時(shí),發(fā)送應(yīng)答信號(hào)
void sendACK(bit ACK)
    if(ACK)sda=1;            //如果i位為1則發(fā)送1,即發(fā)送"非應(yīng)答信號(hào)"
      else sda=0;            //如果i位為0則發(fā)送0,即發(fā)送"應(yīng)答信號(hào)"
    scl=1;                   //時(shí)鐘線置高,給一個(gè)脈沖
        _nop_();                 //延時(shí)
        scl=0;                   //時(shí)鐘線置低
        _nop_();                 //延時(shí)
//寫一字節(jié)
void send_byte(uchar date)       //寫一個(gè)8位字
        uchar i,temp;                //定義局部變量
        temp=date;                   //待發(fā)8位數(shù)據(jù)賦予temp
        for(i=0;i<8;i++)             //循環(huán)8次,每次寫入1位,從最高位開始發(fā)送
        if(temp&0x80)sda=1;      //如果temp最高位為1則發(fā)送1
          else sda=0;            //如果temp最高位為0則發(fā)送0
            _nop_();                 //延時(shí)
                scl=1;                   //給一個(gè)脈沖,發(fā)送sda當(dāng)前這位數(shù)據(jù)
                _nop_();                 //延時(shí),需大于4us(參考數(shù)據(jù)手冊(cè)時(shí)序圖)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                scl=0;                   //時(shí)鐘線置低,準(zhǔn)備下一脈沖
            _nop_();                 //延時(shí),需大于4.7us(參考數(shù)據(jù)手冊(cè)時(shí)序圖)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                temp=temp<<1;            //左移1位,準(zhǔn)備好下1位待發(fā)送的數(shù)據(jù)
        checkACK();                  //查詢是否返回應(yīng)答信號(hào)
//讀一字節(jié)
uchar receive_byte()         //讀一個(gè)8位字
        sda=1;                   //設(shè)置數(shù)據(jù)線為輸入
        _nop_();                 //延時(shí)
        for(i=0;i<8;i++)         //循環(huán)8次,每次讀取1位,從最高位開始接收
                scl=1;               //給一脈沖,準(zhǔn)備發(fā)送1位數(shù)據(jù)
                _nop_();
                _nop_();
                _nop_();
                _nop_();
                temp=(temp<<1)|sda;  //讀取1位數(shù)據(jù),放在temp最低位
                scl=0;               //準(zhǔn)備給下1個(gè)脈沖
                _nop_();
                _nop_();
                _nop_();
                _nop_();
        return temp;             //返回讀取的8位數(shù)據(jù)
//向某I2C器件的某字地址寫一字節(jié)數(shù)據(jù)
void write_word(uchar device_add,uchar word_add,uchar date)  //寫進(jìn)去一個(gè)存儲(chǔ)數(shù)據(jù)
        start();                  //啟動(dòng)
        send_byte(device_add);    //選擇從器件地址,RW位為0,即選擇寫命令
        send_byte(word_add);      //寫字地址
        send_byte(date);          //寫數(shù)據(jù)
        stop();                   //停止
//向某I2C器件的某字地址讀一字節(jié)數(shù)據(jù)
uchar read_word(uchar device_add,uchar word_add)   //讀出一個(gè)存儲(chǔ)的數(shù)據(jù)
        uchar date;
        start();                 //啟動(dòng)
        start();                 //啟動(dòng)
        send_byte(device_add+1); //選擇從器件地址,RW位為1,即選擇讀命令
        date=receive_byte();     //讀數(shù)據(jù)
    sendACK(1);              //發(fā)送非應(yīng)答信號(hào)
        stop();                  //停止
        return date;             //返回讀取結(jié)果數(shù)據(jù)
{        uchar temp,i;
        temp=Dat;
        for(i=0;i<8;i++)
        { cp=0;
          else DAT=0;
          cp=1;
          temp<<=1;
{   PWM=0;
        seg=0;
        EX0=1;
        IT0=1;
        EA=1;
/*        write_word(0xa0,0,0);
        delayms(5); */
        high=(uint)read_word(0xa0,0)*2;
        seg=1;
        if(high==0) while(!flag);
        { PWM=1;
          delay(high);
          PWM=0;
          delay(300-high);
{        PWM=0;
        if(!flag) flag=1;
        if(!DEC) high-=10;
        if(!INC) high+=10;
        if(high>=300) high=290;
        if(high<=0)        high=10;
        write_word(0xa0,0,(high/2));
        seg=0;
        seg=1;
        delayms(255);
