查看: 1823|回復(fù): 0
按下k2 數(shù)碼管開始跑表,但是數(shù)碼管上顯示不出跑表過程,求好心人看看怎么解決
ID:115593 發(fā)表于 2016-5-1 10:17 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
第二次按下K2暫停跑表,正常顯示xx秒xx毫秒。
#include "reg52.h"
#include<intrins.h>
#define ulong unsigned long
#define N_key    0     //按鍵沒被按下
#define S_key    1   //  單擊
#define D_key    2    //雙擊
#define L_key    3     //長安
#define key_state_0 0
#define key_state_1 1
#define key_state_2 2
#define key_state_3 3
sbit key1 = P3^0;
sbit key2 = P3^2;
unsigned char time_10ms_ok = 0;
unsigned char key = 0;
//引腳定義:
sbit LED8_0 = P1^0;        //定義數(shù)碼管陽級控制腳(千位)
sbit LED8_1 = P1^1;        //定義數(shù)碼管陽級控制腳(百位)
sbit LED8_2 = P1^2;        //定義數(shù)碼管陽級控制腳(十位)
sbit LED8_3 = P1^3;        //定義數(shù)碼管陽級控制腳(個位)
sbit LED=P1^7;
sbit led=P1^6;
uchar  Flag_Fresh = 0; // 刷新標志
bit flag=1;
bit sflag,dflag,lflag;
bit T1keyflag,INT0flag;
unsigned char disp_BUF[4];        //顯示緩沖區(qū)(4個字節(jié),對應(yīng)4個數(shù)碼管)
                                //disp_BUF[0]   disp_BUF[1]   disp_BUF[2]   disp_BUF[3]
                                //    千位         百位         十位           個位
uchar shi,fen,counter;
uint count=0;
uint miao=0;
const unsigned char leddata[]={
                0x03,  //"0"         顯示碼/段碼/字形碼
                0x9F,  //"1"
                0x25,  //"2"
                0x0D,  //"3"
                0x99,  //"4"
                0x49,  //"5"
                0x41,  //"6"
                0x1F,  //"7"
                0x01,  //"8"
                0x09,  //"9"
                0x11,  //"A"
                0xC1,  //"B"
                0x63,  //"C"
                0x85,  //"D"
                0x61,  //"E"
                0x71,  //"F"
                0x91,  //"H"
                0xE3,  //"L"
                0x13,  //"n"
                0x83,  //"u"
                0x31,  //"P"
                0xC5,  //"o"
                0xFD,  //"-"
                0xFF,  //熄滅
                                0xFE,
                0x11  //自定義
enum KeyState{StateInit,StateAffirm,StateSingle,StateRepeat};
//======================================函數(shù)聲明=======================
  void delay20ms(void);
  void HEXtoBCD_miao(uchar count);
  void display_LED(void);
    void HEXtoBCD_shi(uchar miao);
     void delay();
//=================延時函數(shù)================================================//
void delay()
        unsigned int j;
        //for(i=0; i<100; i++)
                for(j=0; j<200; j++);        //軟件延時
//=========================T0初始化========================================//
void T0_init(void)
        TMOD = 0x01;                                    // 設(shè)置定時器0工作在模式1下
        TH0 = 0xDC;                                             // 定時10ms
        TL0 = 0x00;                                             // 賦初始值
        PT0=0;
        EA=1;
        ET0=1;
   // TR0 = 1;//啟動定時器0;
//======================================外部中斷0初始化================
void INT0init()
        EA=1;
        EX0=1;
        IT0=1;
//===================================================T1初始化=============
void T1_Init(void)                //10毫秒@12.000MHz
        TMOD &= 0x0F;                //設(shè)置定時器模式
        TMOD |= 0x10;                //設(shè)置定時器模式
         PT1=1;
        TL1 = 0xF0;                //設(shè)置定時初值
        TH1 = 0xD8;                //設(shè)置定時初值
        TF1 = 0;                //清除TF1標志
        TR1 = 1;                //定時器1開始計時
        EA=1;
        ET1=1;
//=============================================開機初始化=================
void start_init()
            delay20ms();
            disp_BUF[0] = leddata[22];
            disp_BUF[1] = leddata[22];
            disp_BUF[2] = leddata[22];
            disp_BUF[3] = leddata[22];
            P0=0xff;
//===================延時環(huán)數(shù)==============================================//
void Delay5ms()                //@12.000MHz
        unsigned char i, j;
        i = 10;
        j = 183;
        do
                while (--j);
        } while (--i);
        unsigned int i;
        for(i=0; i<3850; i++);
//============================//數(shù)碼管顯示=====================================//
        unsigned char temp,i;
        temp = 0xfe;                //1111 1110          1111 1100                 1111 1010
                               //                1111 1101               1111 1011
        for(i=0; i<4; i++)
                P1 = temp;                        //temp中是“位選”
                temp = (temp<<1)|0x01;
                P0 = disp_BUF[i];        //送“段碼”(要顯示的內(nèi)容)
                delay();                //掃描刷新時間(頻率)
                                //時間長——會閃爍、時間短——會模糊(有其他的筆畫)
//========函數(shù)名稱:HEXtoBCD===============================================
//函數(shù)功能:轉(zhuǎn)換一個小于9999的十六進制數(shù)為BCD碼(非壓縮)并放入顯示緩沖區(qū)disp_BUF[0]--disp_BUF[3]中================================//
   if(shi> 59)shi =0;
   disp_BUF[0] = leddata[miao/10];//得到時的高位,并送到相應(yīng)的顯示緩沖區(qū)
           P0=0xff;
    if(flag)
        disp_BUF[1] = leddata[miao%10]&0xfe;      //小數(shù)點閃爍
   disp_BUF[1] = leddata[miao%10];  //得到時的低位,并送到相應(yīng)的顯示緩沖區(qū)
         P0=0xff;
  if(miao>99) miao=0;
   disp_BUF[2] = leddata[count/10];        //得到秒的高位,并送到相應(yīng)的顯示緩沖區(qū)
        P0=0xff;  //消除鬼影
   disp_BUF[3] = leddata[count%10];        //得到秒的位,并送到相應(yīng)的顯示緩沖區(qū)
   P0=0xff;
// ============================================外部中斷counter處理函數(shù)========================
void counterhandle()
  if(counter==1)
  EA=1;
  TR0=1;
else if(counter==2)
    EA=1;
    TR0=0;
else if(counter==3)
  TR0=0;
   EA=1;
   count=0;
   miao=0;
   counter=0;
//============================================標志處理函數(shù)==============================
  void flaghandle()
if(dflag==1)
                            disp_BUF[0] = leddata[1];
                             P0=0xff;
                            disp_BUF[1] = leddata[2];
                               P0=0xff;
                            disp_BUF[2] = leddata[3];
                              P0=0xff;
                            disp_BUF[3] = leddata[4];
                               P0=0xff;
                            dflag=0;
if(sflag==1)
                            disp_BUF[0] = leddata[16];
                              P0=0xff;
                            disp_BUF[1] = leddata[14];
                              P0=0xff;
                            disp_BUF[2] = leddata[17];
                              P0=0xff;
                            disp_BUF[3] = leddata[21];
                               P0=0xff;
                            sflag=0;
if(lflag==1)
      if(flag)
                           disp_BUF[0] = leddata[23];
                           disp_BUF[1] = leddata[23];
                           disp_BUF[2] = leddata[23];
                           disp_BUF[3] = leddata[23];
         else              {
                          lflag=0;
//===========================================按鍵掃描======================
unsigned char key_driver(void)
    static unsigned char key_state = key_state_0;   // 變量初始化
    static unsigned  int  keytime = 0;
    unsigned char  key_return = N_key;
   bit key_press;        //定義一個位
    key_press = key1;                                                            //P3^0的按下狀態(tài),按下0,不按為1
    switch (key_state)
      case key_state_0:
        if (!key_press) key_state = key_state_1;                                       //如果按鍵被按下,置狀態(tài)1
        break;
      case key_state_1:
       if (!key_press)        //判斷狀態(tài)1
        {        //如果按鍵還是被按下的 “去抖”
             keytime = 0;                                                            //按下時間初始值為0
             key_state = key_state_2;                                                           //按鍵還是被按下的,置狀態(tài)2
             key_state = key_state_0;                                                    //否則置狀態(tài)0,再次進行按鍵判斷
        break;
      case key_state_2:
        if(key_press)                                                 //如果按鍵是沒被按下的,key_press為1 即條件為真。按下為0,條件為假
             key_return = S_key;        // 狀態(tài)2中按鍵是被松開的,即判斷為單擊
             key_state = key_state_0;           //返回狀態(tài)0,進行下次的按鍵操作
        else if (++keytime >= 1000)            // if條件為假按鍵還是被按下的,進行key_time自增運算,再進行key_time>=1000的判斷
             key_return = L_key;        //如果條件成立、則定義為長按的操作
             key_state = key_state_3;   // 進入狀態(tài)3
        break;        //跳出循環(huán)
      case key_state_3:                                  // 執(zhí)行狀態(tài)3的操作
        if (key_press) key_state = key_state_0;    //如果按鍵被松開了,返回狀態(tài)0
        break;
    return key_return;                                                 //返回值key_return
unsigned char key_read(void)                                 // 鍵值處理函數(shù)
    static unsigned char key_m = key_state_0 ; //靜態(tài)變量 key_m,key_time_1。
     static unsigned int key_time_1 = 0;
    unsigned char key_return = N_key,key_temp;                         //
    key_temp = key_driver();                                         //key_temp=        key_return。(S_key或者L_key)
    switch(key_m)
        case key_state_0:                                            //狀態(tài)0的操作
            if (key_temp == S_key )                   // 如果判斷為單擊
                 key_time_1 = 0;             // key_time_1初始值為0
                 key_m = key_state_1;                 // 進入狀態(tài)2
                 key_return = key_temp;   // 狀態(tài)0里,將 key_temp的值給key_return
            break;
        case key_state_1:                                 //狀態(tài)1
            if (key_temp == S_key)       //單擊之后還有一次按鍵
                 key_return = D_key;    // 定為雙擊
                 key_m = key_state_0;  // 返回狀態(tài)0
                 if(++key_time_1 >= 500)//key_time_1        自增,如果大于等于500 (兩次按鍵時間間隔大于50)
                      key_return = S_key;// 定義為單擊
                      key_m = key_state_0;// 返回狀態(tài)0
             break; //跳出循環(huán)
    return key_return;                                   // 返回值key_return
//===========================================主函數(shù)=======================
void main(void)
         T1_Init() ;
         T0_init();
         INT0init();
     start_init();
    if(INT0flag==1)
              HEXtoBCD_shi(miao);
        HEXtoBCD_miao(count);
         INT0flag=0;
         display_LED();
      else if(T1keyflag==1)
        T1keyflag=0;
         display_LED();                 //數(shù)碼管顯示
//======================================T0    T1   中斷函數(shù)========================
void T0_ISR(void) interrupt 1
        TL0 = 0x00;
     count++;
             if(count==100)
        count=0;
        miao++;
        led=~led;
         flag=~flag;
        if(miao>59)
        miao=0;
void T1_ISR(void) interrupt 3
    TL1 = 0xF0;                //設(shè)置定時0初值
        LED=~LED;
     flaghandle();
        key = key_read(); //沒10ms得到一次 key_return
    T1keyflag=1;
                        if (key == L_key)  //長按清零
                          lflag=1;
                else if(key == S_key) //單擊
                                sflag=1;
            else if(key == D_key) //雙擊停止
               dflag=1;
  void INT0_ISR(void) interrupt 0
  delay20ms();
  EA=0;
  counter++;
  INT0flag=1;
  counterhandle();
