我做了個 2.4G 遙控器 下面有附圖 有源碼 有感興趣的 可以學(xué)學(xué) 了 。當(dāng)時做的時候也學(xué)習(xí)了很長時間 。由于自己感興趣 ,就學(xué)下去了 收益匪淺啊。很適合初學(xué)者看看了 。本程序 做個小車 小船的 灼灼有余了 。這是發(fā)射程序 #include <reg51.h>#include <intrins.h>
#define u8 unsigned char
#define u16 unsigned int
//STC12 系列新增寄存器
sfr IPH=0xb7;
sfr P4=0xc0;
sfr P4SW=0xbb;
sfr P1ASF=0x9d;
sfr P4M0=0xb4;
sfr P3M0=0xb2;
sfr P3M1=0xb1;
sfr P2M0=0x96;
sfr P0M0=0x94;
sfr ADC_CONTR=0xbc;
sfr ADC_RES=0xbd;
sfr ADC_RESL=0xbe;
sfr BRT=0x9c;
sfr AUXR=0x8e;
sfr WAKE_CLKO=0x8f;
sfr IAP_DATA=0xc2;
sfr IAP_ADDRH=0xc3;
sfr IAP_ADDRL=0xc4;
sfr IAP_CMD=0xc5;
sfr IAP_TRIG=0xc6;
sfr IAP_CONTR=0xc7;
sfr CCON = 0xD8; //PCA control register
sbit CCF0 = CCON^0; //PCA module-0 interrupt flag
sbit CCF1 = CCON^1; //PCA module-1 interrupt flag
sbit CR = CCON^6; //PCA timer run control bit
sfr CMOD = 0xD9; //PCA mode register
sfr CL = 0xE9; //PCA base timer LOW
sfr CH = 0xF9; //PCA base timer HIGH
sfr CCAPM0 = 0xDA; //PCA module-0 mode register
sfr CCAP0L = 0xEA; //PCA module-0 capture register LOW
sfr CCAP0H = 0xFA; //PCA module-0 capture register HIGH
sfr CCAPM1 = 0xDB; //PCA module-1 mode registers
sfr CCAP1L = 0xEB; //PCA module-1 capture register LOW
sfr CCAP1H = 0xFB; //PCA module-1 capture register HIGH
/* STC15W404AS寄存器補充
sfr AUXR1 = 0XA2;
sfr AUXR = 0X8E;
sfr TH2 = 0XD6;
sfr TL2 = 0XD7;
sfr P4 = 0xc0;
sfr P5 = 0xc8;
sfr P3M0=0xB2;
sfr SPSTAT = 0xCD; //
sfr SPCTL = 0xCE; //
sfr SPDAT = 0xCF; */
//定時器2
//sfr T2H=0xd6;
//sfr T2L=0xd7;
//sfr IE2=0xaf;
//ADC
//sfr ADC_CONTR = 0xBC; //帶AD系列
//sfr ADC_RES = 0xBD; //帶AD系列
//sfr ADC_RESL = 0xBE; //帶AD系列
//sfr P1ASF = 0x9D;
sfr PCON2 = 0x97;
#define ADC_POWER 0x80//ADC電源控制位
#define ADC_FLAG 0x10//ADC完成標(biāo)志
#define ADC_START 0x08//ADC起始控制位
#define ADC_SPEEDLL 0x00//540個時鐘轉(zhuǎn)換一次
#define ADC_SPEEDL 0x20//360時鐘
#define ADC_SPEEDH 0x40//180時鐘
#define ADC_SPEEDHH 0x60//90時鐘
unsigned char recv_buf[6]={0,0,0,0,1,1};//NRF24模塊可以一次發(fā)射32個字節(jié),這里只用6個,代表6個通道。
sbit NRF_CE = P0^1;
sbit NRF_CSN = P0^0;
sbit NRF_MISO = P0^5;
sbit NRF_MOSI = P0^2;
sbit NRF_SCK = P0^3;
sbit NRF_IRQ = P0^4;
/*sbit NRF_IRQ = P5^5;
sbit NRF_MISO = P1^4;
sbit NRF_MOSI = P1^3;
sbit NRF_SCK = P1^5;
sbit NRF_CSN = P1^2;
sbit NRF_CE = P5^4; */
sbit SW1=P3^7;//開關(guān)通道1
sbit SW2=P3^6;//開關(guān)通道2
sbit SW_Mix1=P3^5;//混控開關(guān)1
//sbit Beep=P3^4;//蜂鳴器
//sbit LED_Battery=P3^3;//1s電池低壓報警燈
sbit LED_NRF=P3^2;//NRF模塊信號不好報警燈
u8 TxAllCount=0;//發(fā)射總次數(shù)
u8 TxOKCount=0;//發(fā)射成功次數(shù)
u8 Time10Ms=0;//蜂鳴器鳴叫時間
有些搖桿,阻值5K的,搖到最上方,還有大概1K的阻值,阻值并不是0的樣子。
有些搖桿,搖到最上邊阻值就是0了。
這樣搖不到底的搖桿,我不做轉(zhuǎn)換了,電調(diào)有行程調(diào)節(jié)的。
接舵機倒無所謂,大不了轉(zhuǎn)不了45度,我轉(zhuǎn)個30°也湊合了。
u8 pianyi=25;//搖桿上限偏移范圍上限值,默認(rèn)25,你也可以修改。
/********** 你可以從這里復(fù)制NRF24L01的全部代碼了 ***********/
/********** NRF24L01寄存器操作命令 ***********/
#define READ_REG 0x00 //讀配置寄存器,低5位為寄存器地址
#define WRITE_REG 0x20 //寫配置寄存器,低5位為寄存器地址
#define RD_RX_PLOAD 0x61 //讀RX有效數(shù)據(jù),1~32字節(jié)
#define WR_TX_PLOAD 0xA0 //寫TX有效數(shù)據(jù),1~32字節(jié)
#define FLUSH_TX 0xE1 //清除TX FIFO寄存器.發(fā)射模式下用
#define FLUSH_RX 0xE2 //清除RX FIFO寄存器.接收模式下用
#define REUSE_TX_PL 0xE3 //重新使用上一包數(shù)據(jù),CE為高,數(shù)據(jù)包被不斷發(fā)送.
#define NRF_NOP 0xFF //空操作,可以用來讀狀態(tài)寄存器
/********** NRF24L01寄存器地址 *************/
#define CONFIG 0x00 //配置寄存器地址
#define EN_AA 0x01 //使能自動應(yīng)答功能
#define EN_RXADDR 0x02 //接收地址允許
#define SETUP_AW 0x03 //設(shè)置地址寬度(所有數(shù)據(jù)通道)
#define SETUP_RETR 0x04 //建立自動重發(fā)
#define RF_CH 0x05 //RF通道
#define RF_SETUP 0x06 //RF寄存器
#define STATUS 0x07 //狀態(tài)寄存器
#define OBSERVE_TX 0x08 // 發(fā)送檢測寄存器
#define CD 0x09 // 載波檢測寄存器
#define RX_ADDR_P0 0x0A // 數(shù)據(jù)通道0接收地址
#define RX_ADDR_P1 0x0B // 數(shù)據(jù)通道1接收地址
#define RX_ADDR_P2 0x0C // 數(shù)據(jù)通道2接收地址
#define RX_ADDR_P3 0x0D // 數(shù)據(jù)通道3接收地址
#define RX_ADDR_P4 0x0E // 數(shù)據(jù)通道4接收地址
#define RX_ADDR_P5 0x0F // 數(shù)據(jù)通道5接收地址
#define TX_ADDR 0x10 // 發(fā)送地址寄存器
#define RX_PW_P0 0x11 // 接收數(shù)據(jù)通道0有效數(shù)據(jù)寬度(1~32字節(jié))
#define RX_PW_P1 0x12 // 接收數(shù)據(jù)通道1有效數(shù)據(jù)寬度(1~32字節(jié))
#define RX_PW_P2 0x13 // 接收數(shù)據(jù)通道2有效數(shù)據(jù)寬度(1~32字節(jié))
#define RX_PW_P3 0x14 // 接收數(shù)據(jù)通道3有效數(shù)據(jù)寬度(1~32字節(jié))
#define RX_PW_P4 0x15 // 接收數(shù)據(jù)通道4有效數(shù)據(jù)寬度(1~32字節(jié))
#define RX_PW_P5 0x16 // 接收數(shù)據(jù)通道5有效數(shù)據(jù)寬度(1~32字節(jié))
#define FIFO_STATUS 0x17 // FIFO狀態(tài)寄存器
/****** STATUS寄存器bit位定義 *******/
#define MAX_TX 0x10 //達(dá)到最大發(fā)送次數(shù)中斷
#define TX_OK 0x20 //TX發(fā)送完成中斷
#define RX_OK 0x40 //接收到數(shù)據(jù)中斷
/********* 24L01發(fā)送接收數(shù)據(jù)寬度定義 ***********/
#define TX_ADR_WIDTH 5 //5字節(jié)地址寬度
#define RX_ADR_WIDTH 5 //5字節(jié)地址寬度
#define TX_PLOAD_WIDTH 6 //32字節(jié)有效數(shù)據(jù)寬度
#define RX_PLOAD_WIDTH 6 //32字節(jié)有效數(shù)據(jù)寬度
uchar xdata TX_ADDRESS[TX_ADR_WIDTH]={0x68,0x86,0x66,0x88,0x28};
uchar xdata RX_ADDRESS[RX_ADR_WIDTH]={0x68,0x86,0x66,0x88,0x28};
void Delay1ms() //@12.000MHz 軟件延時1ms
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void delay_ms(unsigned char i) //延時n毫秒 0~255ms
while(--i)
Delay1ms();
void DelayMs(unsigned int i) //延時N毫秒,0~65535ms
while(--i)
Delay1ms();
/* 初始化硬件SPI口 */
void SPI_Init(void) //如果用模擬SPI,這個就不要調(diào)用了,它是開啟硬件SPI
SPSTAT |= 0xC0; //SPI狀態(tài)寄存器全部清0 SPIF和WCOL清0
SPCTL = 0xD0; //0xD0=11010000 ,表示SPI開啟,主機模式,SPI頻率為主頻四分之一
/* SPI數(shù)據(jù)收發(fā)函數(shù) 硬件SPI */
uchar SPI_RW(uchar tr_data)
uchar i=0;
SPSTAT |= 0xc0; //SPI狀態(tài)寄存器全部清0 SPIF和WCOL清0
SPDAT=tr_data; //將數(shù)據(jù)放到SPI數(shù)據(jù)寄存器中
while(((SPSTAT&0x80)!=0x80)&&(i<20)) //SPSTAT&0x80 SPI數(shù)據(jù)傳輸完成標(biāo)志 如果沒完成傳輸,就延時1ms
i++;
delay_ms(1); //20ms內(nèi)沒完成,則跳出
return SPDAT; //返回傳輸?shù)臄?shù)據(jù)值
// 下面是“模擬SPI” 如果不用硬件SPI,可以用模擬SPI
uchar SPI_RW(uchar byte)
uchar bit_ctr;
for(bit_ctr=0;bit_ctr<8;bit_ctr++) // 輸出8位
NRF_MOSI=(byte&0x80); // MSB TO MOSI
byte=(byte<<1); // shift next bit to MSB
NRF_SCK=1;
byte|=NRF_MISO; // capture current MISO bit
NRF_SCK=0;
return byte;
/* 函數(shù)功能:給24L01的寄存器寫值(一個字節(jié)) */
/* 入口參數(shù):reg 要寫的寄存器地址 */
/* value 給寄存器寫的值 */
/* 出口參數(shù):status 狀態(tài)值 */
uchar NRF24L01_Write_Reg(uchar reg,uchar value)
uchar status;
NRF_CSN=0; //CSN=0;
status = SPI_RW(reg);//發(fā)送寄存器地址,并讀取狀態(tài)值
SPI_RW(value);
NRF_CSN=1; //CSN=1;
return status;
/* 函數(shù)功能:讀24L01的寄存器值 (一個字節(jié)) */
/* 入口參數(shù):reg 要讀的寄存器地址 */
/* 出口參數(shù):value 讀出寄存器的值 */
uchar NRF24L01_Read_Reg(uchar reg)
uchar value;
NRF_CSN=0; //CSN=0;
SPI_RW(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
value = SPI_RW(NRF_NOP);
NRF_CSN=1; //CSN=1;
return value;
/* 函數(shù)功能:讀24L01的寄存器值(多個字節(jié)) */
/* 入口參數(shù):reg 寄存器地址 */
/* *pBuf 讀出寄存器值的存放數(shù)組 */
/* len 數(shù)組字節(jié)長度 */
uchar NRF24L01_Read_Buf(uchar reg,uchar *pBuf,uchar len)
uchar status,u8_ctr;
NRF_CSN=0; //CSN=0
status=SPI_RW(reg);//發(fā)送寄存器地址,并讀取狀態(tài)值
for(u8_ctr=0;u8_ctr<len;u8_ctr++)
pBuf[u8_ctr]=SPI_RW(0XFF);//讀出數(shù)據(jù)
NRF_CSN=1; //CSN=1
return status; //返回讀到的狀態(tài)值
/* 函數(shù)功能:給24L01的寄存器寫值(多個字節(jié)) */
/* *pBuf 值的存放數(shù)組 */
uchar NRF24L01_Write_Buf(uchar reg, uchar *pBuf, uchar len)
NRF_CSN=0;
status = SPI_RW(reg);//發(fā)送寄存器值(位置),并讀取狀態(tài)值
for(u8_ctr=0; u8_ctr<len; u8_ctr++)
SPI_RW(*pBuf++); //寫入數(shù)據(jù)
NRF_CSN=1;
//為避免編譯器函數(shù)重入錯誤,所以又改名復(fù)制的函數(shù),和上面的函數(shù)一個樣
uchar NRF24L01_Write_BufData(uchar reg, uchar *pBuf, uchar len)
NRF_CSN=0;
NRF_CSN=1;
/* 函數(shù)功能:24L01接收數(shù)據(jù) */
/* 入口參數(shù):rxbuf 接收數(shù)據(jù)數(shù)組 */
/* 返回值: 0 成功收到數(shù)據(jù) */
/* 1 沒有收到數(shù)據(jù) */
uchar NRF24L01_RxPacket(uchar *rxbuf)
uchar state;
state=NRF24L01_Read_Reg(STATUS); //讀取狀態(tài)寄存器的值
NRF24L01_Write_Reg(WRITE_REG+STATUS,state); //清除TX_DS或MAX_RT中斷標(biāo)志
if(state&RX_OK)//接收到數(shù)據(jù)
NRF24L01_Read_Buf(RD_RX_PLOAD,rxbuf,RX_PLOAD_WIDTH);//讀取數(shù)據(jù)
NRF24L01_Write_Reg(FLUSH_RX,0xff);//清除RX FIFO寄存器
return 0;
return 1;//沒收到任何數(shù)據(jù)
/* 函數(shù)功能:設(shè)置24L01為發(fā)送模式 */
/* 入口參數(shù):txbuf 發(fā)送數(shù)據(jù)數(shù)組 */
/* 返回值; 0x10 達(dá)到最大重發(fā)次數(shù),發(fā)送失敗*/
/* 0x20 成功發(fā)送完成 */
/* 0xff 發(fā)送失敗 */
uchar NRF24L01_TxPacket(uchar *txbuf)
uchar state;
// uchar i;
NRF_CE=0;//CE拉低,使能24L01配置
NRF24L01_Write_BufData(WR_TX_PLOAD,txbuf,TX_PLOAD_WIDTH);//寫數(shù)據(jù)到TX BUF 32個字節(jié)
NRF_CE=1;//CE置高,使能發(fā)送
while(NRF_IRQ==1);//等待發(fā)送完成
if(state&MAX_TX)//達(dá)到最大重發(fā)次數(shù)
NRF24L01_Write_Reg(FLUSH_TX,0xff);//清除TX FIFO寄存器
return MAX_TX;
if(state&TX_OK)//發(fā)送完成
return TX_OK;
return 0xff;//發(fā)送失敗
/* 函數(shù)功能:檢測24L01是否存在 */
/* 返回值; 0 存在 */
/* 1 不存在 */
//檢測原理就是存入NRF模塊一段數(shù)據(jù),然后再讀出來比較一下是否一致
uchar NRF24L01_Check(void)
uchar check_in_buf[5]={0x11,0x22,0x33,0x44,0x55};
uchar check_out_buf[5]={0x00};
NRF_CE=0;
NRF24L01_Write_Buf(WRITE_REG+TX_ADDR, check_in_buf, 5);
NRF24L01_Read_Buf(READ_REG+TX_ADDR, check_out_buf, 5);
if((check_out_buf[0] == 0x11)&&\
(check_out_buf[1] == 0x22)&&\
(check_out_buf[2] == 0x33)&&\
(check_out_buf[3] == 0x44)&&\
(check_out_buf[4] == 0x55))return 0;
else return 1;
void NRF24L01_SET_TX_Mode(void)
NRF_CE=0;
NRF24L01_Write_Reg(WRITE_REG+CONFIG,0x0e); // 配置為無線發(fā)送模式
NRF_CE=1;
void NRF24L01_SET_RX_Mode(void)
NRF_CE=0;
NRF24L01_Write_Reg(WRITE_REG+CONFIG, 0x0f); // 配置為無線接收模式
NRF_CE=1;
void NRF24L01_RT_Init(void) //NRF24L01_Write_Reg(WRITE_REG+CONFIG,0x0e); 發(fā)射時0x0e,記得修改
NRF_CE=0; //進(jìn)行配置,要首先禁止模塊功能
NRF24L01_Write_Reg(WRITE_REG+RX_PW_P0,RX_PLOAD_WIDTH);//選擇通道0的有效數(shù)據(jù)寬度
NRF24L01_Write_Buf(WRITE_REG+TX_ADDR,(uchar*)TX_ADDRESS,TX_ADR_WIDTH);//寫TX節(jié)點地址
NRF24L01_Write_Buf(WRITE_REG+RX_ADDR_P0,(uchar*)RX_ADDRESS,RX_ADR_WIDTH); //設(shè)置TX節(jié)點地址,主要為了使能ACK
NRF24L01_Write_Reg(WRITE_REG+EN_AA,0x01); //使能通道0的自動應(yīng)答
NRF24L01_Write_Reg(WRITE_REG+EN_RXADDR,0x01); //使能通道0的接收地址
NRF24L01_Write_Reg(WRITE_REG+SETUP_RETR,0x1a);//設(shè)置自動重發(fā)間隔時間:500us + 86us;最大自動重發(fā)次數(shù):10次
NRF24L01_Write_Reg(WRITE_REG+RF_CH,40); //設(shè)置RF通道為125
NRF24L01_Write_Reg(WRITE_REG+RF_SETUP,0x27); //7db增益,250kbps
NRF24L01_Write_Reg(WRITE_REG+CONFIG,0x0e); //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
NRF_CE=1; //CE置1,恢復(fù)功能 //0x0e發(fā)射 0x0f接收
} //記得發(fā)送程序和接收程序的配置,要改0e和0f的數(shù)值,要不就要單獨要用一次發(fā)射或者接收設(shè)置。
/********** NRF24L01的全部代碼復(fù)制完成了 ***********/
/*void BEEP(u8 i) //蜂鳴器叫兩聲
Beep=1;
DelayMs(i);
Beep=0;
DelayMs(i);
Beep=1;
DelayMs(i);
Beep=0;
/*void TimeBEEP() //用定時器2讓蜂鳴器間隔鳴叫
AUXR=0x10;//打開定時器2
void InitADC(void) //ADC初始化
P1ASF=0xc3;//打開P1.0,P1.1,P1.6,P1.7的ADC轉(zhuǎn)換功能 因為這里就用了4個腳 0xc3=11000011 對應(yīng)P1.7~P1.0 8個腳
ADC_RES=0;//ADC的值清0
ADC_CONTR=ADC_POWER | ADC_SPEEDLL;//打開ADC的電源 540個時鐘轉(zhuǎn)換一次
delay_ms(2);//延遲2ms等待穩(wěn)定
u16 Get_ADC10bitResult(u8 channel) //獲取10位精度的ADC值
u16 adc;
u8 i;
if(channel > 7) return 1024; //錯誤,返回1024, ADC通道號0~7,不能超過7
ADC_RES = 0; //高位ADC清零
ADC_RESL = 0;//低位ADC清零
ADC_CONTR = (ADC_CONTR & 0xe0) | ADC_START | channel; //打開指定通道的ADC轉(zhuǎn)換
_nop_();
_nop_();
_nop_();
_nop_(); //對ADC_CONTR操作后要4T之后才能訪問
for(i=0; i<250; i++) //250us內(nèi)要轉(zhuǎn)換完成,否則超時跳出
if(ADC_CONTR & ADC_FLAG) //轉(zhuǎn)換完成后,ADC_FLAG=1,所以這里判斷ADC_FLAG是不是為1
ADC_CONTR &= ~ADC_FLAG; //ADC_FLAG手工清0
if(PCON2 & (1<<5))//根據(jù)ADRJ判斷ADC轉(zhuǎn)換值放在哪里 如果是1
adc = (u16)(ADC_RES & 3); //10位AD結(jié)果的高2位放ADC_RES的低2位,低8位在ADC_RESL。
adc = (adc << 8) | ADC_RESL; //3=二進(jìn)制的11 &3是獲取低2位的值 <<8 | ADC_RESL 是獲取低8位的值
else //10位AD結(jié)果的高8位放ADC_RES,低2位在ADC_RESL的低2位。
adc = (u16)ADC_RES;
adc = (adc << 2) | (ADC_RESL & 3);
return adc;
return 1024; //如果超時,返回1024,調(diào)用的程序判斷
注意:下載時,下載界面"硬件選項"中下面的項要固定如下設(shè)置:
不勾選 允許低壓復(fù)位(禁止低壓中斷)
低壓檢測電壓 3.70V
選擇CPU-CORE最高電壓 2.74V
void CheckLiBattery() //檢測電池電壓
if(PCON & (1<<5))//檢測到低電壓
LED_Battery=1; //低壓報警LED燈亮
TimeBEEP(); //蜂鳴器叫
LED_Battery=0; //關(guān)燈
PCON &= ~(1<<5);//低壓檢測標(biāo)志清0 ,為下次檢測做準(zhǔn)備
//u8 GetNewYM(u8 ym,u8 minym,u8 maxym)//根據(jù)最大和最小油門,轉(zhuǎn)換到0~255范圍的新油門值
// //最小油門 中點值固定128 最大油門 轉(zhuǎn)為成0 128 255
//// return ym;
// if(ym<128)return (ym-minym)*128/(128-minym); //等比例縮小
// else
// if(ym>128)return 127+(ym-128)*128/(maxym-128);//等比例放大
// else
// return 128;
void GetNRFTxDate()
u8 fy,sj;
recv_buf[0]=Get_ADC10bitResult(0)>>2;//P1.0 一通副翼 >>2的意思就是除以4 10位精度再轉(zhuǎn)8位的
recv_buf[1]=Get_ADC10bitResult(1)>>2;//P1.1 二通升降
recv_buf[2]=Get_ADC10bitResult(6)>>2;//P1.6 三通油門
recv_buf[3]=Get_ADC10bitResult(7)>>2;//P1.7 四通方向
recv_buf[4]=SW1;//P3.7 五通 開關(guān)通道
recv_buf[5]=SW2;//P3.6 六通 開關(guān)通道
fy=recv_buf[0];
sj=recv_buf[1];
if (SW_Mix1==0)//當(dāng)混控開關(guān)1打開
//這里混控可以根據(jù)混控開關(guān),做成副翼和升降混控 方向和油門插速混控等模式
//我只設(shè)定了一個混控開關(guān),郁悶了�;炜匦问教啵瑔纹瑱C引腳不夠用了……你們自己改吧
/* 混控一
比如我改個副翼和升降的混控 也就是一通道和二通道進(jìn)行混控
升降的時候,兩個舵機同一個方向
副翼的時候,兩個舵機方向相反
/* 混控二
雙電機的飛機,方向用電機差速控制,也就是副翼和油門的混控,一通道和三通道混控
加減油門,兩個舵機同一方向
副翼的時候,兩個舵機方向相反
//下面我只寫混控一,混控x之類的,大家可以模仿著寫。其實我也沒寫過。我連架紙飛機都沒。
//先判斷是搖桿是升降還是副翼 加上75作為誤差值
if (fy-pianyi>=128||fy+pianyi<=128)//副翼搖桿移動
recv_buf[1]=255-fy; //升降通道要反相
//先判斷是搖桿是升降還是副翼
if (sj-pianyi>=128||sj+pianyi<=128)//升降搖桿移動
recv_buf[0]=sj; //升降要同相
void Timer0Init(void) //19毫秒@12.000MHz
AUXR &= 0x7F; //定時器時鐘12T模式
TMOD &= 0xF0; //設(shè)置定時器模式
TL0 = 0xC8; //設(shè)置定時初值
TH0 = 0xB5; //設(shè)置定時初值
TF0 = 0; //清除TF0標(biāo)志
TR0 = 1; //定時器0開始計時
ET0 = 1; //開通定時器0中斷
EA = 1; //開啟全部中斷
/*void Timer2Init(void) //10毫秒@12.000MHz
AUXR &= 0xFB; //定時器時鐘12T模式
T2L = 0xF0; //設(shè)置定時初值
T2H = 0xD8; //設(shè)置定時初值
IE2 |=0x04; //ET2=1 //允許定時器2的中斷
EA = 1; //開啟全部中斷
AUXR=0;//禁止定時器2運行
//AUXR |= 0x10; //定時器2開始計時
void main(void)
delay_ms(100); // 延時待系統(tǒng)穩(wěn)定
SW1=1;//初始化開關(guān)通道1
SW2=1;//初始化開關(guān)通道2
SW_Mix1=1;//初始化混控開關(guān)1
LED_NRF=0;//關(guān)掉報警燈
// LED_Battery=0;//關(guān)掉狀態(tài)燈
// Beep=0;//關(guān)掉蜂鳴器
// PCON &= ~(1<<5);//低壓檢測標(biāo)志清0, 上電時標(biāo)志為1
// P3M0=0x10; //P3.4 推挽輸出,要不蜂鳴器聲音太小
InitADC();//初始化ADC
// SPI_Init(); // 初始化SPI口
while(NRF24L01_Check()) // 等待檢測到NRF24L01,程序才會向下執(zhí)行
LED_NRF=1;//狀態(tài)LED燈常亮表示NRF24L01模塊出錯。
NRF24L01_RT_Init(); // 配置NRF24L01為發(fā)射模式
// BEEP(250);//嗶嗶一聲表示OK
Timer0Init();//定時器0初始化
// Timer2Init();//定時器2初始化
// CheckLiBattery();//檢測電池電壓
//定時器0 用來發(fā)射6通道數(shù)據(jù)給接收器
void Timer0() interrupt 1
GetNRFTxDate(); //查詢方式獲得4個通道ADC值和2個開關(guān)通道值
TxAllCount++; //總發(fā)射次數(shù)+1
if(NRF24L01_TxPacket(recv_buf)==TX_OK)//如果發(fā)射沒有失敗
TxOKCount++; //發(fā)射成功次數(shù)+1
if (TxAllCount==50) //發(fā)射50次以后,計算成功率
if (TxOKCount<40)//丟包大于80%,報警 如果接收器沒上電,也會報警
LED_NRF=1; //NRF模塊指示燈亮起
TimeBEEP(); //蜂鳴器報警
LED_NRF=0; //關(guān)報警燈
TxAllCount=0; //重置計數(shù)
TxOKCount=0;
//定時器2 功能就是讓蜂鳴器發(fā)出200毫秒的一個鳴叫,然后關(guān)掉。
/*void Timer2() interrupt 12
Time10Ms++;
if(Time10Ms<=20) //開始叫
Beep=1;
if(Time10Ms>20)//超過200毫秒停叫
Beep=0;
if(Time10Ms>40)
Time10Ms=0;
AUXR=0;//關(guān)掉定時器2
下面是接收 程序
#include <reg51.h>
//STC12 系列新增寄存器
sfr IPH=0xb7;
sfr P4=0xc0;
sfr P4SW=0xbb;
sfr P1ASF=0x9d;
sfr P4M0=0xb4;
sfr P3M0=0xb2;
sfr P3M1=0xb1;
sfr P2M0=0x96;
sfr P0M0=0x94;
sfr ADC_CONTR=0xbc;
sfr ADC_RES=0xbd;
sfr ADC_RESL=0xbe;
sfr BRT=0x9c;
sfr AUXR=0x8e;
sfr WAKE_CLKO=0x8f;
sfr IAP_DATA=0xc2;
sfr IAP_ADDRH=0xc3;
sfr IAP_ADDRL=0xc4;
sfr IAP_CMD=0xc5;
sfr IAP_TRIG=0xc6;
sfr IAP_CONTR=0xc7;
/* STC15W404AS寄存器補充
sfr AUXR1 = 0XA2;
sfr AUXR = 0X8E;
sfr TH2 = 0XD6;
sfr TL2 = 0XD7;
sfr P4 = 0xc0;
sfr P5 = 0xc8;
sfr P3M0=0xB2;
sfr SPDAT = 0xCF; //
sfr P1M0=0x92;
//ADC
sfr P1ASF = 0x9D;
sfr PCON2 = 0x97;
//定時器2
sfr T2H=0xd6;
sfr T2L=0xd7;
sfr IE2=0xaf;
#define ADC_SPEEDHH 0x60//90時鐘 */
sbit NRF_CE = P0^1;
sbit CH1=P3^2;//通道1
sbit CH2=P3^3;//通道2
sbit CH3=P3^6;//通道3
sbit CH4=P3^7;//通道4
sbit CH5=P1^0;//通道5
sbit CH6=P1^1;//通道6
u8 n=0;//定時器0的中斷次數(shù)
unsigned char i, j;
i = 12;
j = 169;
do
while (--j);
} while (--i);
void Delay4us() //@12.000MHz
unsigned char i;
_nop_();
_nop_();
i = 9;
while (--i);
void Delay_4us(unsigned char i)
while(--i)
Delay4us();
while(--i)
Delay1ms();
while(--i)
Delay1ms();
/* 初始化硬件SPI口 */
uchar i=0;
i++;
//下面是“模擬SPI”
uchar bit_ctr;
NRF_SCK=1;
NRF_SCK=0;
return byte;
/* value 給寄存器寫的值 */
uchar status;
NRF_CSN=0; //CSN=0;
SPI_RW(value);
NRF_CSN=1; //CSN=1;
return status;
uchar value;
NRF_CSN=0; //CSN=0;
NRF_CSN=1; //CSN=1;
return value;
NRF_CSN=0; //CSN=0
NRF_CSN=1; //CSN=1
NRF_CSN=0;
NRF_CSN=1;
uchar NRF24L01_Write_BufData(uchar reg, uchar *pBuf, uchar len) //為避免函數(shù)重入錯誤而加的額外函數(shù)
NRF_CSN=0;
NRF_CSN=1;
uchar state;
return 0;
/* 0xff 發(fā)送失敗 */
uchar state;
// uchar i;
return MAX_TX;
return TX_OK;
/* 返回值; 0 存在 */
/* 1 不存在 */
NRF_CE=0;
else return 1;
NRF_CE=0;
NRF_CE=1;
NRF_CE=0;
NRF_CE=1;
void NRF24L01_RT_Init(void) //NRF24L01_Write_Reg(WRITE_REG+CONFIG,0x0f); 接收是0x0f,記得修改
NRF_CE=0;
NRF24L01_Write_Reg(WRITE_REG+CONFIG,0x0f); //配置基本工作模式的參數(shù);PWR_UP,EN_CRC,16BIT_CRC,接收模式,開啟所有中斷
NRF_CE=1; //CE置高 //0x0e發(fā)射 0x0f接收
void Timer0Init(void) //3毫秒@12.000MHz
TL0 = 0x48; //設(shè)置定時初值
TH0 = 0xF4; //設(shè)置定時初值
TR0 = 1; //定時器0開始計時
ET0 = 1; //開通定時器0中斷
EA = 1; //開啟全部中斷
EA = 1; //開啟全部中斷
AUXR=0;//禁止定時器2運行
void main(void)
u16 i; //定義一個16位的計數(shù)變量
// P1M0=0x03;//P1.0 1 為強推挽,銀燕金屬舵機,STC15W408如果不強推挽,動都不動,折騰了我半夜
P3M0=0xCC;//P3.2 3 6 7為強推挽,否則一些金屬舵機會驅(qū)動不了,垃圾輝盛倒一點問題都沒
//SPI_Init(); // 初始化硬件SPI,如果你用模擬SPI口,這個就不要調(diào)用
while(NRF24L01_Check()); // 等待檢測到NRF24L01,程序才會向下執(zhí)行
//如果NRF24L01模塊出錯,程序就卡死在這里了。沒引腳來做報警了,,,殘念。
NRF24L01_RT_Init(); // 配置NRF24L01為接收模式
//Timer2Init();//定時器2初始化
i++; //每次累計大概1us
if(NRF_IRQ==0)//查詢方式來接收數(shù)據(jù)
NRF24L01_RxPacket(recv_buf);//讀取數(shù)據(jù)
i=0; //收到數(shù)據(jù)則清0累計值
/*if(i>60000) //累計60000次是600ms,0.6秒的樣子。
{ //超過0.6秒收不到數(shù)據(jù),則改成平飛滑翔。聽天由命吧
//0~255對應(yīng)1ms~2sm,所以125就是1.5ms,置中
recv_buf[0]=125; //副翼舵機擺臂置90°
recv_buf[1]=125; //升降舵機擺臂置90°
recv_buf[2]=0; //電調(diào)油門置0
recv_buf[3]=125; //方向舵機擺臂置90°
recv_buf[4]=1; //關(guān)掉開關(guān)通道1
recv_buf[5]=1; //關(guān)掉開關(guān)通道2
//定時器0
//這里和蘿莉一樣,還是用延時吧,雖然不是同步輸出,但是舵機理論上能達(dá)到250段分級,移動很平滑
//我用100us定時器同步輸出,只有10段分級,移動不平滑,如果分成100段,定時時間太短難以控制。
void Timer0() interrupt 1 //用定時器0輪流輸出6個通道的PPM
n++; //定義的全局變量,用來做通道自增的
if(n==6)n=0;//輪流輸出6通道信號,整個周期18ms,反正PPM的20ms周期也不是那么嚴(yán)格
if(recv_buf[0]==0)recv_buf[0]=1; //加1,防止延時的時候,0-1=255溢出
if(recv_buf[1]==0)recv_buf[1]=1; //加1,防止延時的時候,0-1=255溢出
if(recv_buf[2]==0)recv_buf[2]=1; //加1,防止延時的時候,0-1=255溢出
if(recv_buf[3]==0)recv_buf[3]=1; //加1,防止延時的時候,0-1=255溢出
switch(n)
{ //每個通道固定1ms高電平,然后根據(jù)通道的ADC,延時4us*通道AD值的高電平,然后改成低低電平。
//通道AD值的范圍是0~255,所以延時的電平時間就是1ms+0~1ms+4*255us,即1ms~2ms高電平 255約等于250
//實際應(yīng)用中,舵機用1ms~2ms的高電平來控制,而不是理論上的0.5~2.5ms
//舵機的擺臂范圍是45°~90°~135°之間移動。分別對應(yīng)1ms~ 1.5ms~ 2ms高電平
case 0:CH1=1,Delay1ms(),Delay_4us(recv_buf[0]),CH1=0;break;//1通道PPM輸出 副翼
case 1:CH2=1,Delay1ms(),Delay_4us(recv_buf[1]),CH2=0;break;//2通道PPM輸出 升降
case 2:CH3=1,Delay1ms(),Delay_4us(recv_buf[2]),CH3=0;break;//3通道PPM輸出 油門
case 3:CH4=1,Delay1ms(),Delay_4us(recv_buf[3]),CH4=0;break;//4通道PPM輸出 方向
case 4: //5通道開關(guān)通道 1ms高電平是關(guān) 2ms高電平是開
CH5=1;
Delay1ms();//固定1ms高電平
if(recv_buf[4]==0)Delay_4us(250);//0表示通道開,1表示通道關(guān)
CH5=0;
break;
case 5: //6通道開關(guān)通道 1ms高電平是關(guān) 2ms高電平是開
CH6=1;
if(recv_buf[5]==0)Delay_4us(250);//0表示通道開,1表示通道關(guān)
CH6=0;
break;
//定時器2 沒用,空著吧
//void Timer2() interrupt 12
