/***********************語音溫度計(jì)**************************
/***********以下源代碼是主程序部分main.c**********/
#include <at89x51.h>
#include "LCD1602.h"
#include "clock.h"
#include "key.h"
#include "DS18B20.h"
#include "temp.h"
#include "BEEP.h"
#include "ISD1420.h"
#include "speakTEMP.h"
void delayMs(unsigned int ms) //延時(shí)K*1ms,12.000mhz
{ unsigned char j;
while(ms--)
{for(j=0; j<=125; j++);}
void init() //主初始化
{ P1=0xff; //初始化p1口,全設(shè)為1 P3=0xff;
top_temp = 30;
bottom_temp = 1;
delayMs(500);
initLCM( );
initClock();
initTemp();
BEEP = 1;
void main(void)
{ init( ); //初始化
while (1)
{ scan_key(); //鍵盤掃描子函數(shù)
delayMs(10);
ReadTemperature( ); // 讀取溫度子函數(shù)
if(temp > top_temp || temp < (char)bottom_temp) beep();
displayTemp(); //顯示溫度子函數(shù)
if(DisplayTimeFlag) //判斷顯示模式
displayClock(); // 顯示時(shí)間子函數(shù)
displayTempLim(); //顯示溫度上下限子函數(shù)
delayMs(10);
/***********以下源代碼是顯示子程序 LCD1602.h 部分**********/
#ifndef __LCD1602_H__
#define __LCD1602_H__
#include <intrins.h>
#define BUSY 0x80 //lcd忙檢測標(biāo)志
#define DATAPORT P0
sbit LCM_RS=P3^7; //數(shù)據(jù)/命令端
sbit LCM_RW=P3^6; //讀/寫選擇端
sbit LCM_EN=P2^7; //LCD使能信號(hào)
void delay_LCM(unsigned int); //LCD延時(shí)子程序延時(shí)ms
void initLCM(void); //LCD初始化子程序
void lcd_wait(void); //LCD檢測忙子程序
void WriteCommandLCM(unsigned char WCLCM,unsigned char BusyC); //寫指令到ICM子函數(shù)
void WriteDataLCM(unsigned char WDLCM); //寫數(shù)據(jù)到LCM子函數(shù)
void DisplayOneChar(unsigned char X,unsigned char Y,unsigned char DData); //顯示指定坐標(biāo)的一個(gè)字符子函數(shù)
void DisplayListChar(unsigned char X,unsigned char Y,unsigned char code *DData); //顯示指定坐標(biāo)的一串字符子函數(shù)
void delay_LCM(unsigned int k) //延時(shí)K*1ms,12.000mhz
{ unsigned int i,j;
for(i=0;i<k;i++)
{for(j=0;j<60;j++)
//寫指令到LCM子函數(shù)
{ if(BusyC)lcd_wait();
DATAPORT=WCLCM;
LCM_RS=0; // 選中指令寄存器
LCM_RW=0; // 寫模式
LCM_EN=1;
_nop_(); _nop_(); _nop_();
LCM_EN=0;
void WriteDataLCM(unsigned char WDLCM) // 寫數(shù)據(jù)到LCM子函數(shù)
{ lcd_wait( ); //檢測忙信號(hào)
DATAPORT=WDLCM;
LCM_RS=1; // 選中數(shù)據(jù)寄存器
LCM_RW=0; // 寫模式
LCM_EN=1;
LCM_EN=0;}
void lcd_wait(void) // lcm內(nèi)部等待函數(shù)
{ DATAPORT=0xff;
LCM_EN=1;LCM_RS=0; LCM_RW=1;
while(DATAPORT&BUSY)
{ LCM_EN=0;_nop_(); _nop_();
LCM_EN=1; _nop_(); _nop_();}
LCM_EN=0;}
void initLCM( ) // LCM初始化子函數(shù)
{ DATAPORT=0;
delay_LCM(15);
WriteCommandLCM(0x38,0); //三次顯示模式設(shè)置,不檢測忙信號(hào)
delay_LCM(5);
delay_LCM(5);
delay_LCM(5);
WriteCommandLCM(0x38,1); //8bit數(shù)據(jù)傳送,2行顯示,5*7字型,檢測忙信號(hào)
WriteCommandLCM(0x08,1); //關(guān)閉顯示,檢測忙信號(hào)
WriteCommandLCM(0x01,1); //清屏,檢測忙信號(hào)
WriteCommandLCM(0x06,1); //顯示光標(biāo)右移設(shè)置,檢測忙信號(hào)
WriteCommandLCM(0x0c,1); //顯示屏打開,光標(biāo)不顯示,不閃爍,檢測忙信號(hào)
void DisplayOneChar(unsigned char X,unsigned char Y,unsigned char DData)// 顯示指定坐標(biāo)的一個(gè)字符子函數(shù)
{ Y&=1; X&=15;
if(Y)X|=0x40; //若y為1(顯示第二行),地址碼+0X40
X|=0x80; //指令碼為地址碼+0X80
WriteCommandLCM(X,0);
WriteDataLCM(DData);
void DisplayListChar(unsigned char X,unsigned char Y,unsigned char code *DData) // 顯示指定坐標(biāo)的一串字符子函數(shù)
{ unsigned char ListLength=0;
Y&=0x01;
X&=0x0f;
while(X<16)
{ DisplayOneChar(X,Y,DData[ListLength]);
ListLength++;
X++;}
#endif
/*********以下源代碼是時(shí)鐘功能實(shí)現(xiàn)子程序 clock.h部分**********/
#ifndef __CLOCK_H__
#define __CLOCK_H__
extern unsigned char seconde; //定義并初始化時(shí)鐘變量
extern unsigned char minite;
extern unsigned char hour;
extern unsigned char mstcnt;
extern unsigned char code str0[];
void initClock(void);
void delay_CLOCK(unsigned int ms); //clock延時(shí)子程序
void displayClock(void);
unsigned char seconde=0; //定義并初始化時(shí)鐘變量
unsigned char minite=0;
unsigned char hour=12;
unsigned char mstcnt=0;
unsigned char code str0[]={"--- : : -----"};
void initClock(void) //定時(shí)器t0初始化
{ initLCM( );
TMOD=0x01; //time0為定時(shí)器,方式1
TCON = 0x01 ; //觸發(fā)方式為脈沖負(fù)邊沿觸發(fā)
TH0=0x3c; //預(yù)置計(jì)數(shù)初值
TL0=0xb0;
EA=1; ET0=1; TR0=1; EX0=1; }
void displayClock(void) //液晶顯示子函數(shù)1正常顯示
{ WriteCommandLCM(0x0c,1);
DisplayListChar(0,0,str0);
DisplayOneChar(3,0,hour/10+0x30);
DisplayOneChar(4,0,hour%10+0x30);
DisplayOneChar(6,0,minite/10+0x30);
DisplayOneChar(7,0,minite%10+0x30);
DisplayOneChar(9,0, seconde/10+0x30);
DisplayOneChar(10,0,seconde%10+0x30);
void timer0(void) interrupt 1 using 0 //定時(shí)器0方式1,50ms中斷一次
{ TH0=0x3c; TL0=0xb0;
mstcnt++;
if(mstcnt>=20 ) {seconde++; mstcnt=0; }
if(seconde>=60) {minite++; seconde=0;}
if(minite>=60 ) {hour++; minite=0; }
if(hour>=24 ) {hour=0;}
#endif
/***********以下源代碼是鍵盤控制部分 key.h **********/
#ifndef __KEY_H__
#define __KEY_H__
#include "temp.h"
#include "clock.h"
#define ENTER (!(P2_1)) // 按鍵低電平有效
#define FUNCTION_KEY (!(P2_4))
#define UP_KEY (!(P2_3))
#define DOWN_KEY (!(P2_2))
extern unsigned char DisplayTimeFlag;
void scan_key(void);
unsigned char DisplayTimeFlag = 1;
void delay_key(unsigned int ms)
{ unsigned char j;
while(ms--)
void scan_key(void) //鍵盤掃描
{ static char ct=0;
P1=ct;
if(FUNCTION_KEY)
{ delay_key(10);
if(FUNCTION_KEY)
{ ct++;
if(ct>5) ct=0;
if(ct==4 || ct==5) DisplayTimeFlag=0;//溫度范圍設(shè)置模式
else DisplayTimeFlag=1; //時(shí)間顯示模式
delay_key(100);}}
else if(ENTER)
{ delay_key(10);
if(ENTER)
{ if(ct==0) speak_temp(temp);
{ct=0; DisplayTimeFlag=1;}
delay_key(100);}}
else if(UP_KEY)
{ delay_key(10);
if(UP_KEY)
{ if(ct==1)
{ if(seconde>=60)
{seconde=0; minite++;}else
{seconde=0;}
}else if(ct==2)
{ minite++;if(minite>=60) minite=0;}
else if(ct==3)
{ hour++; if(hour>=24) hour=0;}
else if(ct==4)
{ top_temp++;if(top_temp>=100) top_temp=30;}
else if(ct==5)
{ bottom_temp++; if(bottom_temp>=top_temp) bottom_temp=1;}
delay_key(100);}
else if(DOWN_KEY)
{ delay_key(10);
if(DOWN_KEY)
{ if(ct==1)
{seconde=0;}
else if(ct==2)
{ if(minite<=0) minite=59;
else minite--;}
else if(ct==3)
{ if(hour<=0) hour=23;
else hour--;}
else if(ct==4)
{ top_temp--;
if(top_temp<=bottom_temp)
{ if(bottom_temp>=30)
top_temp=bottom_temp+10;
{top_temp=30;}
else if(ct==5)
{ bottom_temp--;
if(bottom_temp<=-30) bottom_temp=1;}
delay_key(100);
#endif
/***********以下源代碼是DS18B20.h 部分**********/
#ifndef __DS18B20_H__
#define __DS18B20_H__
sbit DQ=P2^0; //DS18b20通道
void delay_18B20(unsigned int i);
void Init_DS18B20(void) ;
unsigned char ReadOneChar(void);
void WriteOneChar(unsigned char dat);
void delay_18B20(unsigned int i) //ds18b20延遲子函數(shù)(晶振12MHz )
{ while(i--); }
void Init_DS18B20(void) //ds18b20初始化函數(shù)
{ unsigned char x=0;
DQ = 1; //DQ復(fù)位
delay_18B20(8); //稍做延時(shí)
DQ = 0; //單片機(jī)將DQ拉低
delay_18B20(80); //精確延時(shí) 大于 480us
DQ = 1; //拉高總線
delay_18B20(14);
x = DQ; //稍做延時(shí)后 如果x=0則初始化成功 x=1則初始化失敗
delay_18B20(20);}
unsigned char ReadOneChar(void) // ds18b20讀一個(gè)字節(jié)
{ unsigned char i=0;
unsigned char dat = 0;
for (i=8;i>0;i--)
{ DQ = 0; // 給脈沖信號(hào)
dat>>=1;
DQ = 1; // 給脈沖信號(hào)
if(DQ)
dat|=0x80;
delay_18B20(4); }
return(dat);
void WriteOneChar(unsigned char dat) //ds18b20寫一個(gè)字節(jié)
for (i=8; i>0; i--)
{ DQ = 0;
DQ = dat&0x01;
delay_18B20(5);
DQ = 1;
dat>>=1;}
#endif
/***********以下源代碼是溫度量測部分temp.h **********/
#ifndef __TEMP_H__
#define __TEMP_H__
extern unsigned char temp1,temp2;
extern unsigned char temp,top_temp,bottom_temp;
extern unsigned char code str1[];
extern unsigned char code str2[];
void ReadTemperature(void);
void initTemp(void);
void displayTemp(void);
void displayTempLim(void);
unsigned char code str1[]={"temp: . oC----"};
unsigned char code str2[]={"--lim: -- ---"};
void delay_Temp(unsigned int ms) //延時(shí)K*1ms,12.000mhz
{ unsigned char j;
while(ms--)
void ReadTemperature(void) //讀取ds18b20當(dāng)前溫度
{ unsigned char a=0;
unsigned char b=0;
Init_DS18B20();
WriteOneChar(0xCC); // 跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0x44); // 啟動(dòng)溫度轉(zhuǎn)換
delay_Temp(100); // this message is very important
Init_DS18B20();
WriteOneChar(0xCC); //跳過讀序號(hào)列號(hào)的操作
WriteOneChar(0xBE); //讀取溫度寄存器等前兩個(gè)就是溫度
delay_Temp(100);
a=ReadOneChar(); //讀取溫度值低8位
b=ReadOneChar(); //讀取溫度值高8位
temp1=b<<4;
temp1+=(a&0xf0)>>4; //小數(shù)點(diǎn)前的數(shù)據(jù)
temp2=a&0x0f; //小數(shù)點(diǎn)后的數(shù)據(jù)
temp=temp1; }
void initTemp(void) //定時(shí)器t0初始化
{ top_temp=30;
bottom_temp=1;
initLCM();
Init_DS18B20(); }
void displayTemp(void) //液晶顯示子函數(shù)1正常顯示
DisplayListChar(0,1,str1);
if(((char)temp1)<0)
DisplayOneChar(5,1,'-');
else if(temp1/100) DisplayOneChar(5,1,'1');
else DisplayOneChar(5,1,' ');
DisplayOneChar(6,1,(temp1%100)/10+0x30);
DisplayOneChar(7,1,temp1%10+0x30);
DisplayOneChar(9,1,temp2/10+0x30);
void displayTempLim(void) //液晶顯示溫度范圍子函數(shù)1正常顯示
{ char bt=0;
DisplayListChar(0,0,str2);
if(bottom_temp>=128)
{ DisplayOneChar(6,0,'-');
bt = 256-bottom_temp;
{ DisplayOneChar(6,0,' ');
bt = bottom_temp;
DisplayOneChar(7,0, (bt%100)/10+0x30);
DisplayOneChar(8,0, (bt%10)+0x30);
DisplayOneChar(11,0,(top_temp%100)/10+0x30);
DisplayOneChar(12,0,top_temp%10+0x30);
#endif
/************以下源代碼是報(bào)警子程序部分 BEEP.h****************/
#ifndef __BEEP_H__
#define __BEEP_H__
sbit BEEP = P2^6;
void beep();
void delay_BEEP(unsigned int ms)
{ int j;
while(ms--)
{for(j=0; j<125; j++); //一個(gè)for循環(huán)抵8條匯編}
void beep()
{ unsigned char i ;
for (i=0 ;i<100 ;i++)
{ delay_BEEP(5) ;
BEEP=!BEEP ;}
BEEP=1 ;
#endif
/***************以下源代碼是 ISD1420.h部分******************/
#ifndef __ISD1420_H__
#define __ISD1420_H__
#define ISD1420IO P1 //播音地址端口
sbit playe = P3^3; //開始播音口
extern const unsigned char speak_world[];
void speak_isd1420(unsigned char addr);
const unsigned char speak_world[]=
{0x00,0x00,0x08,0x10,0x18,0x20,0x28,0x30,0x38,0x40,0x48,0x50,0x58};
void delay_ISD1420(unsigned int ms) //延時(shí)K*1ms,12.000mhz
{ int j; while(ms--)
{for(j=0; j<125; j++); } //一個(gè)for循環(huán)抵8條匯編
void speak_isd1420(unsigned char addr) //語音播報(bào)子程序 addr播音地址
{ ISD1420IO = addr; //寫地址
playe = 1;
playe = 0; //開始播音
delay_ISD1420(800);}
#endif
/*******以下源代碼是語音播報(bào)子程序 speakTEMP.h 部分 **********/
#ifndef __SPEAKTEMP_H__
#define __SPEAKTEMP_H__
#include "temp.h"
void speak_temp(unsigned int temp_t);
void speak_temp(unsigned int temp_t) //語音播報(bào)溫度子程序
{ int digit1,digit0;
digit1 = temp_t / 10; //十位
digit0 = temp_t % 10; //個(gè)位
if(digit1==0)
{ speak_isd1420(speak_world[12]); //播現(xiàn)在溫度是
speak_isd1420(speak_world[digit0]); //播個(gè)位
speak_isd1420(speak_world[11]); //播度
else{
speak_isd1420(speak_world[digit1]); //播十位
speak_isd1420(speak_world[10]); //播十
if(digit0!=0)
playe=1;
#endif
