- //TDC-GP2與MSP430F413通訊C程序
- #include <msp430x43x.h>
- #include <math.h>
- //#include "heat_meter.h"
- #define Init_GP2 0x70 //初始化TDC
- #define Start_Cycle 0x01 //脈沖發(fā)送
- #define Start_Temp 0x02 //開始溫度測量
- #define Start_Cal_Resonator 0x03 //校準晶振時鐘
- #define Start_Cal_TDC 0x04 //校準TDC
- //定義各管腳工作狀態(tài)名稱
- #define PVCCOn P4OUT |= BIT0
- #define PVCCOff P4OUT = 0;
- #define SSNEn P3OUT &=~BIT0 // GP2 R/W enable
- #define SSNDs P3OUT |= BIT0 // GP2 R/W disable
- #define RSTNHigh P3OUT |= BIT4
- #define RSTNLow P3OUT &=~BIT4
- #define StartEn P1OUT |= BIT6 // GP2 En_Start
- #define StartDs P1OUT &=~BIT6
- #define StopEn P1OUT |= BIT7 // GP2 En_Stop
- #define StopDs P1OUT &=~BIT7
- #define Up P1OUT |= BIT2
- #define Down P1OUT |= BIT3
- #define Close P1OUT &=~(BIT2 + BIT3)
- //配置GP2流量測量
- //const unsigned char ConfigGP2[23] = {0x50,0x80,0x37,0x8A,0x68,0x81,0x21,0x44,0x00,0x82,0xE0,0x32,0x00,0x83,0x08,0x33,0x00,0x84,0x20,0x34,0x00,0x70,0x01};
- const unsigned char ReadGP2STAT[3] = {0xB4,0x55,0x55};
- const unsigned char ReadRes0[5] = {0xB0,0x55,0x55,0x55,0x55};
- const unsigned char ReadRes1[5] = {0xB1,0x55,0x55,0x55,0x55};
- const unsigned char ReadRes2[5] = {0xB2,0x55,0x55,0x55,0x55};
- const unsigned char ReadRes3[5] = {0xB3,0x55,0x55,0x55,0x55};
- //以下為初始化函數
- void InitialPort(void);//初始化端口
- //以下為內部函數定義,詳細說明見函數部分
- void InitialGP2(void);//初始化GP2
- void OpCodeGP2 (unsigned char opcode); // 寫1 Byte op-codes 到 GP2
- void ConfigGP2 (unsigned long data); // 配置GP2寄存器
- void MeasureTemp(void);//溫度測量
- void ReadGP2ST(void);//讀GP2狀態(tài)寄存器
- void ReadData(unsigned char Count,volatile unsigned char * point,volatile unsigned char * point_d);//讀GP2結果寄存器數據
- void FireStart(void);// 發(fā)送點火脈沖
- void CalStart(void);//校準時鐘測量
- void HXOn(void);//切換校準時鐘時高速晶振狀態(tài)到開啟
- void HXOff(void);//切換校準時鐘時高速晶振狀態(tài)到關閉
- void NOP10(void);// 10_NOP()機器周期延遲
- void TempCal(void);//溫度校準測量
- #pragma memory = no_init
- unsigned long DisplayData[8];//0:heat,1:cool,2:volume,3:heatKwh,4:volumeL,5:workTime,6:LCDDate,7:LCDTime
- #pragma memory = default
- unsigned char SPITxCount,SPIRxCount;
- unsigned char SPIMaskBuf[5];
- unsigned char Res0[4];
- unsigned char Res1[4];
- unsigned char Res2[4];
- unsigned char Res3[4];
- unsigned int GP2ST;
- unsigned long T1,T2,T3,T4;
- unsigned long PT1,PT2;
- float CorrectFactor;
- const float A = 3.862314E-3;
- const float B = -6.531493E-7;
- union longValue
- unsigned long uWord;
- unsigned char lByte[4];
- union intValue
- unsigned int uInt;
- unsigned char lByte[2];
- void main(void)
- InitialPort();
- _EINT();
- SPIRxCount = 0;
- Delay(50000);
- _NOP();
- PVCCOn;
- InitialGP2(); //初始化GP2
- while(1)
- //HXOn();
- //Delay(5000);
- CalStart(); //時鐘校準
- //HXOff();
- //MeasureTemp();
- //_NOP();
- //TempCal();
- //Display(PT1);
- //LCDRAM[3] |= 0x80;
- //StopWTD();
- //AdjustLCD();
- //RunLCD();
- Close;
- Up;
- FireStart();
- Close;
- Down;
- LPM0;
- ReadGP2ST();
- ReadData(5,(unsigned char *)ReadRes0,(unsigned char *)Res0);
- ReadData(5,(unsigned char *)ReadRes1,(unsigned char *)Res1);
- ReadData(5,(unsigned char *)ReadRes2,(unsigned char *)Res2);
- ReadData(5,(unsigned char *)ReadRes3,(unsigned char *)Res3);
- _NOP();
- StopWTD();
- LPM3;
- /*InitialGP2();
- Close;
- Down;
- FireStart();
- Close;
- Up;
- //LPM0;
- StopWTD();
- LPM3;
- //端口初始化
- WDTCTL = WDTPW + WDTHOLD; // Stop WDT
- //FLL_CTL0 = XCAP14PF; //set load capacitance for 32k xtal
- //SCFQCTL = SCFQ_4M;
- //LCDCTL = LCDON + LCD4MUX + LCDP1; // STK LCD 4Mux, S0-S19
- //BTCTL = BTFRFQ0; // STK LCD freq
- P5SEL = 0xFC; // Common and Rxx all selected
- P4DIR |= BIT0; //PVCC
- P1SEL |= BIT5;
- P1DIR |= BIT2 + BIT3 + BIT5 + BIT6 + BIT7; //P1.2 SW2,P1.3 SW1
- //P1.5 32.768kHz Output as GP2 Clock
- //P1.6 as GP2 En_Start,P1.7 as GP2 En_Stop
- P2DIR |= BIT2 + BIT3;
- P2IE |= BIT7;
- P2IES |= BIT7;
- TACTL = TASSEL_1 + MC_2 + TACLR; //ACLK, continous mode
- ME1 |= USPIE0; // Enable USART0 SPI mode
- UCTL0 |= CHAR + SYNC + MM; // 8-bit SPI Master **SWRST**
- UTCTL0 |= /*CKPH + */SSEL1 + SSEL0 + STC; // SMCLK, 3-pin mode
- UBR00 = 0x02; // UCLK/2
- UBR10 = 0x00; // 0
- UMCTL0 = 0x00; // no modulation
- UCTL0 &= ~SWRST; // Initalize USART state machine
- IE1 |= URXIE0; // Receive interrupt enable
- P3SEL |= 0x0E; // P3.1-3 SPI option select
- P3DIR |= BIT0 + BIT4; // P3.0 output direction
- TBCTL = TBSSEL_1 + ID_2 + TBCLR; //Setup Timer_B
- TBCCR1 = 16384;
- TBCCTL1 =CCIE;
- TBCTL |= MC_2;
- //GP2 寄存器配置
- unsigned char i = 0;
- SSNDs;
- _NOP();
- RSTNHigh;
- _NOP();
- RSTNLow;
- _NOP();
- RSTNHigh;
- StartEn; //開啟start_en
- StopEn; //開啟stop_en
- OpCodeGP2(0x50); // GP2復位
- _NOP();
- ConfigGP2(0x80338468);//內部不分頻,fire脈沖頻率為1MHz,發(fā)送3個fire脈沖。對于4MHz時鐘校準是基于8個周期的32K時鐘,高速時鐘持續(xù)工作,溫度測量應用高速時鐘128us周期時間,2次熱身測量,4個溫度測量端口(2個溫度傳感器,一個測冷水,一個測熱水)。TDC自動校準,選擇測量范圍2
- _NOP();
- ConfigGP2(0x81214400);//ALU計算第一個stop - start
- _NOP();
- ConfigGP2(0x82E01900); //啟動所有GP2中斷源,設置第一個stop的使能窗口,在50us后允許接受第一個stop脈沖
- _NOP();
- ConfigGP2(0x83081A00);//設置第2個stop的使能窗口,在51us后允許接受第二個stop脈沖, 256us后未接到stop信號溢出
- _NOP();
- ConfigGP2(0x84201A80);//設置第3個stop德使能窗口,在52us后允許接受第三個stop脈沖
- _NOP();
- ConfigGP2(0x85000000);
- _NOP();
- OpCodeGP2(0x70); //Init
- //Delay(4000);
- _NOP();
- OpCodeGP2(0x01); //Start Cycle
- //ReadGP2ST();
- _NOP();
- unsigned char i;
- union longValue vardata;
- Delay(500);
- OpCodeGP2(Start_Temp);
- Delay(500); //wait for measurement finish
- ReadGP2ST();
- if(GP2ST & 0x1E00)
- T1 = 0;
- T2 = 0;
- T3 = 0;
- T4 = 0;
- return;
- _NOP();
- for (i = 0;i < 4;i++)
- vardata.lByte[i] = Res0[i];
- T1 = vardata.uWord;
- vardata.lByte[i] = Res1[i];
- T2 = vardata.uWord;
- vardata.lByte[i] = Res2[i];
- T3 = vardata.uWord;
- vardata.lByte[i] = Res3[i];
- T4 = vardata.uWord;
- _NOP();
- unsigned char i;
- unsigned int High16,Low16;
- float buf;
- union intValue varint;
- OpCodeGP2(0x03);
- LPM0;
- varint.lByte[0] = vardata.lByte[0];
- varint.lByte[1] = vardata.lByte[1];
- Low16 = varint.uInt;
- varint.lByte[0] = vardata.lByte[2];
- varint.lByte[1] = vardata.lByte[3];
- High16 = varint.uInt;
- buf = (float)Low16;
- CorrectFactor = buf/65536 + High16;
- CorrectFactor *=1000;
- Display(CorrectFactor);
- LCDRAM[4] |= 0x80;
- AdjustLCD();
- RunLCD();
- void HXOn(void)
- ConfigGP2(0x80324668);
- void HXOff(void)
- ConfigGP2(0x80324E68);
- void OpCodeGP2 (unsigned char opcode) // send a 1 Byte opcode to the TDC-GP2
- SSNDs;
- _NOP();
- SSNEn;
- _NOP();
- IE1 &=~ URXIE0; // Receive interrupt disable
- TXBUF0 = opcode;
- while (!(IFG1 & UTXIFG0));
- NOP10();
- //LPM0;
- SSNDs;
- IFG1 &=~ URXIFG0;
- void ConfigGP2 (unsigned long data) // 配置TDC-GP2 寄存器
- unsigned char i;
- vardata.uWord = data;
- SSNDs;
- _NOP();
- SSNEn;
- _NOP();
- //TXBUF0 = vardata.lByte[3];
- //LPM0;
- TXBUF0 = vardata.lByte[3-i];
- LPM0;
- SSNDs;
- SSNDs;
- SSNEn;
- SPIRxCount = 0;
- for(i = 0; i < 3;i++)
- TXBUF0 = ReadGP2STAT[i];
- LPM0;
- //NOP10();
- SSNDs;
- GP2ST = SPIMaskBuf[1];
- GP2ST <<= 8;
- GP2ST |= SPIMaskBuf[2];
- void ReadData(unsigned char Count, volatile unsigned char * point,volatile unsigned char * point_d)
- unsigned char i;
- SSNDs;
- SSNEn;
- SPIRxCount = 0;
- for(i = 0;i < Count;i++)
- TXBUF0 = *(point + i);
- LPM0;
- //NOP10();
- SSNDs;
- for(i = 1;i < 5;i++)
- * (point_d + i - 1) = SPIMaskBuf[5 - i];
- float temp,temp1,tempref;
- temp1 = T4;
- tempref = T1;
- temp = temp1 / tempref;
- PT1 = temp * 100000;
- interrupt[UART0RX_VECTOR] void s_receive(void)
- while ((IFG1 & UTXIFG0) == 0);
- if (SPIRxCount < 5)
- SPIMaskBuf[SPIRxCount] = RXBUF0;
- SPIRxCount ++;
- //SSNDs;
- else
- SPIRxCount = 0;
- LPM0_EXIT;
- void NOP10(void)
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- _NOP();
- interrupt [TIMERB1_VECTOR] void timerb1_int(void)
- TBCCR1 +=16384;
- TBCCTL1 &=~CCIFG;
- //ClearWTD();
- _BIC_SR_IRQ(LPM3_bits);
- interrupt [PORT2_VECTOR] void GP2_int(void)
- P2IFG = 0;
- LPM0_EXIT;
- <msp430x43x.h>
- * Standard register and bit definitions for the Texas Instruments
- * MSP430 microcontroller.
- * This file supports assembler and C/EC++ development for
- * MSP430x43x devices.
- * Version 2.0
- #ifndef __msp430x43x
- #define __msp430x43x
- #if (((__TID__ >> 8) & 0x7F) != 0x2b) /* 0x2b = 43 dec */
- #error MSP430X43X.H file for use with ICC430/A430 only
- #endif
- #ifdef __IAR_SYSTEMS_ICC__
- #include <in430.h>
- #pragma language=extended
- #define DEFC(name, address) __no_init volatile unsigned char name @ address;
- #define DEFW(name, address) __no_init volatile unsigned short name @ address;
- #endif /* __IAR_SYSTEMS_ICC__ */
- #ifdef __IAR_SYSTEMS_ASM__
- #define DEFC(name, address) sfrb name = address;
- #define DEFW(name, address) sfrw name = address;
- #endif /* __IAR_SYSTEMS_ASM__*/
- #ifdef __cplusplus
- #define READ_ONLY
- #else
- #define READ_ONLY const
- #endif
- * STANDARD BITS
- #define BIT0 (0x0001)
- #define BIT1 (0x0002)
- #define BIT2 (0x0004)
- #define BIT3 (0x0008)
- #define BIT4 (0x0010)
- #define BIT5 (0x0020)
- #define BIT6 (0x0040)
- #define BIT7 (0x0080)
- #define BIT8 (0x0100)
- #define BIT9 (0x0200)
- #define BITA (0x0400)
- #define BITB (0x0800)
- #define BITC (0x1000)
- #define BITD (0x2000)
- #define BITE (0x4000)
- #define BITF (0x8000)
- * STATUS REGISTER BITS
- #define C (0x0001)
- #define Z (0x0002)
- #define N (0x0004)
- #define V (0x0100)
- #define GIE (0x0008)
- #define CPUOFF (0x0010)
- #define OSCOFF (0x0020)
- #define SCG0 (0x0040)
- #define SCG1 (0x0080)
- /* Low Power Modes coded with Bits 4-7 in SR */
- #ifndef __IAR_SYSTEMS_ICC /* Begin #defines for assembler */
- #define LPM0 (CPUOFF)
- #define LPM1 (SCG0+CPUOFF)
- #define LPM2 (SCG1+CPUOFF)
- #define LPM3 (SCG1+SCG0+CPUOFF)
- #define LPM4 (SCG1+SCG0+OSCOFF+CPUOFF)
- /* End #defines for assembler */
- #else /* Begin #defines for C */
- #define LPM0_bits (CPUOFF)
- #define LPM1_bits (SCG0+CPUOFF)
- #define LPM2_bits (SCG1+CPUOFF)
- #define LPM3_bits (SCG1+SCG0+CPUOFF)
- #define LPM4_bits (SCG1+SCG0+OSCOFF+CPUOFF)
- #define LPM0 _BIS_SR(LPM0_bits) /* Enter Low Power Mode 0 */
- #define LPM0_EXIT _BIC_SR_IRQ(LPM0_bits) /* Exit Low Power Mode 0 */
- #define LPM1 _BIS_SR(LPM1_bits) /* Enter Low Power Mode 1 */
- #define LPM1_EXIT _BIC_SR_IRQ(LPM1_bits) /* Exit Low Power Mode 1 */
- #define LPM2 _BIS_SR(LPM2_bits) /* Enter Low Power Mode 2 */
- #define LPM2_EXIT _BIC_SR_IRQ(LPM2_bits) /* Exit Low Power Mode 2 */
- #define LPM3 _BIS_SR(LPM3_bits) /* Enter Low Power Mode 3 */
- #define LPM3_EXIT _BIC_SR_IRQ(LPM3_bits) /* Exit Low Power Mode 3 */
- #define LPM4 _BIS_SR(LPM4_bits) /* Enter Low Power Mode 4 */
- #define LPM4_EXIT _BIC_SR_IRQ(LPM4_bits) /* Exit Low Power Mode 4 */
- #endif /* End #defines for C */
- * PERIPHERAL FILE MAP
- * SPECIAL FUNCTION REGISTER ADDRESSES + CONTROL BITS
- #define IE1_ (0x0000) /* Interrupt Enable 1 */
- DEFC( IE1 , IE1_)
- #define U0IE_ (IE1_) /* UART0 Interrupt Enable Register */
- DEFC( U0IE , U0IE_)
- #define WDTIE (0x01)
- #define OFIE (0x02)
- #define NMIIE (0x10)
- #define ACCVIE (0x20)
- #define URXIE0 (0x40)
- #define UTXIE0 (0x80)
- #define IFG1_ (0x0002) /* Interrupt Flag 1 */
- DEFC( IFG1 , IFG1_)
- #define U0IFG_ (IFG1_) /* UART0 Interrupt Flag Register */
- DEFC( U0IFG , U0IFG_)
- #define WDTIFG (0x01)
- #define OFIFG (0x02)
- #define NMIIFG (0x10)
- #define URXIFG0 (0x40)
- #define UTXIFG0 (0x80)
- #define ME1_ (0x0004) /* Module Enable 1 */
- DEFC( ME1 , ME1_)
- #define U0ME_ (ME1_) /* UART0 Module Enable Register */
- DEFC( U0ME , U0ME_)
- #define URXE0 (0x40)
- #define USPIE0 (0x40)
- #define UTXE0 (0x80)
- #define IE2_ (0x0001) /* Interrupt Enable 2 */
- DEFC( IE2 , IE2_)
- #define BTIE (0x80)
- #define IFG2_ (0x0003) /* Interrupt Flag 2 */
- DEFC( IFG2 , IFG2_)
- #define BTIFG (0x80)
- * WATCHDOG TIMER
- #define WDTCTL_ (0x0120) /* Watchdog Timer Control */
- DEFW( WDTCTL , WDTCTL_)
- /* The bit names have been prefixed with "WDT" */
- #define WDTIS0 (0x0001)
- #define WDTIS1 (0x0002)
- #define WDTSSEL (0x0004)
- #define WDTCNTCL (0x0008)
- #define WDTTMSEL (0x0010)
- #define WDTNMI (0x0020)
- #define WDTNMIES (0x0040)
- #define WDTHOLD (0x0080)
- #define WDTPW (0x5A00)
- /* WDT-interval times [1ms] coded with Bits 0-2 */
- /* WDT is clocked by fMCLK (assumed 1MHz) */
- #define WDT_MDLY_32 (WDTPW+WDTTMSEL+WDTCNTCL) /* 32ms interval (default) */
- #define WDT_MDLY_8 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS0) /* 8ms " */
- #define WDT_MDLY_0_5 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1) /* 0.5ms " */
- #define WDT_MDLY_0_064 (WDTPW+WDTTMSEL+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
- /* WDT is clocked by fACLK (assumed 32KHz) */
- #define WDT_ADLY_1000 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL) /* 1000ms " */
- #define WDT_ADLY_250 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
- #define WDT_ADLY_16 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
- #define WDT_ADLY_1_9 (WDTPW+WDTTMSEL+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
- /* Watchdog mode -> reset after expired time */
- #define WDT_MRST_32 (WDTPW+WDTCNTCL) /* 32ms interval (default) */
- #define WDT_MRST_8 (WDTPW+WDTCNTCL+WDTIS0) /* 8ms " */
- #define WDT_MRST_0_5 (WDTPW+WDTCNTCL+WDTIS1) /* 0.5ms " */
- #define WDT_MRST_0_064 (WDTPW+WDTCNTCL+WDTIS1+WDTIS0) /* 0.064ms " */
- #define WDT_ARST_1000 (WDTPW+WDTCNTCL+WDTSSEL) /* 1000ms " */
- #define WDT_ARST_250 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS0) /* 250ms " */
- #define WDT_ARST_16 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1) /* 16ms " */
- #define WDT_ARST_1_9 (WDTPW+WDTCNTCL+WDTSSEL+WDTIS1+WDTIS0) /* 1.9ms " */
- /* INTERRUPT CONTROL */
- /* These two bits are defined in the Special Function Registers */
- /* #define WDTIE 0x01 */
- /* #define WDTIFG 0x01 */
- * DIGITAL I/O Port1/2
- #define P1IN_ (0x0020) /* Port 1 Input */
- READ_ONLY DEFC( P1IN , P1IN_)
- #define P1OUT_ (0x0021) /* Port 1 Output */
- DEFC( P1OUT , P1OUT_)
- #define P1DIR_ (0x0022) /* Port 1 Direction */
- DEFC( P1DIR , P1DIR_)
- #define P1IFG_ (0x0023) /* Port 1 Interrupt Flag */
- DEFC( P1IFG , P1IFG_)
- #define P1IES_ (0x0024) /* Port 1 Interrupt Edge Select */
- DEFC( P1IES , P1IES_)
- #define P1IE_ (0x0025) /* Port 1 Interrupt Enable */
- DEFC( P1IE , P1IE_)
- #define P1SEL_ (0x0026) /* Port 1 Selection */
- DEFC( P1SEL , P1SEL_)
- #define P2IN_ (0x0028) /* Port 2 Input */
- READ_ONLY DEFC( P2IN , P2IN_)
- #define P2OUT_ (0x0029) /* Port 2 Output */
- DEFC( P2OUT , P2OUT_)
- #define P2DIR_ (0x002A) /* Port 2 Direction */
- DEFC( P2DIR , P2DIR_)
- #define P2IFG_ (0x002B) /* Port 2 Interrupt Flag */
- DEFC( P2IFG , P2IFG_)
- #define P2IES_ (0x002C) /* Port 2 Interrupt Edge Select */
- DEFC( P2IES , P2IES_)
- #define P2IE_ (0x002D) /* Port 2 Interrupt Enable */
- DEFC( P2IE , P2IE_)
- #define P2SEL_ (0x002E) /* Port 2 Selection */
- DEFC( P2SEL , P2SEL_)
- * DIGITAL I/O Port3/4
- #define P3IN_ (0x0018) /* Port 3 Input */
- READ_ONLY DEFC( P3IN , P3IN_)
- #define P3OUT_ (0x0019) /* Port 3 Output */
- DEFC( P3OUT , P3OUT_)
- #define P3DIR_ (0x001A) /* Port 3 Direction */
- DEFC( P3DIR , P3DIR_)
- #define P3SEL_ (0x001B) /* Port 3 Selection */
- DEFC( P3SEL , P3SEL_)
- #define P4IN_ (0x001C) /* Port 4 Input */
- READ_ONLY DEFC( P4IN , P4IN_)
- #define P4OUT_ (0x001D) /* Port 4 Output */
- DEFC( P4OUT , P4OUT_)
- #define P4DIR_ (0x001E) /* Port 4 Direction */
- DEFC( P4DIR , P4DIR_)
- #define P4SEL_ (0x001F) /* Port 4 Selection */
- DEFC( P4SEL , P4SEL_)
- * DIGITAL I/O Port5/6
- #define P5IN_ (0x0030) /* Port 5 Input */
- READ_ONLY DEFC( P5IN , P5IN_)
- #define P5OUT_ (0x0031) /* Port 5 Output */
- DEFC( P5OUT , P5OUT_)
- #define P5DIR_ (0x0032) /* Port 5 Direction */
- DEFC( P5DIR , P5DIR_)
- #define P5SEL_ (0x0033) /* Port 5 Selection */
- DEFC( P5SEL , P5SEL_)
- #define P6IN_ (0x0034) /* Port 6 Input */
- READ_ONLY DEFC( P6IN , P6IN_)
- #define P6OUT_ (0x0035) /* Port 6 Output */
- DEFC( P6OUT , P6OUT_)
- #define P6DIR_ (0x0036) /* Port 6 Direction */
- DEFC( P6DIR , P6DIR_)
- #define P6SEL_ (0x0037) /* Port 6 Selection */
- DEFC( P6SEL , P6SEL_)
- * BASIC TIMER
- #define BTCTL_ (0x0040) /* Basic Timer Control */
- DEFC( BTCTL , BTCTL_)
- /* The bit names have been prefixed with "BT" */
- #define BTIP0 (0x01)
- #define BTIP1 (0x02)
- #define BTIP2 (0x04)
- #define BTFRFQ0 (0x08)
- #define BTFRFQ1 (0x10)
- #define BTDIV (0x20) /* fCLK2 , ACLK:256 */
- /*#define BTRESET (0x40)*/ /* incorrect :BT is reset and BTIFG is reset if this bit is set */
- #define BTHOLD (0x40) /* BT1 is held if this bit is set */
- #define BTSSEL (0x80) /* fBT , fMCLK (main clock) */
- #define BTCNT1_ (0x0046) /* Basic Timer Count 1 */
- DEFC( BTCNT1 , BTCNT1_)
- #define BTCNT2_ (0x0047) /* Basic Timer Count 2 */
- DEFC( BTCNT2 , BTCNT2_)
- /* Frequency of the BTCNT2 coded with Bit 5 and 7 in BTCTL */
- #define BT_fCLK2_ACLK (0x00)
- #define BT_fCLK2_ACLK_DIV256 (BTDIV)
- #define BT_fCLK2_MCLK (BTSSEL)
- /* Interrupt interval time fINT coded with Bits 0-2 in BTCTL */
- #define BT_fCLK2_DIV2 (0x00) /* fINT , fCLK2:2 (default) */
- #define BT_fCLK2_DIV4 (BTIP0) /* fINT , fCLK2:4 */
- #define BT_fCLK2_DIV8 (BTIP1) /* fINT , fCLK2:8 */
- #define BT_fCLK2_DIV16 (BTIP1+BTIP0) /* fINT , fCLK2:16 */
- #define BT_fCLK2_DIV32 (BTIP2) /* fINT , fCLK2:32 */
- #define BT_fCLK2_DIV64 (BTIP2+BTIP0) /* fINT , fCLK2:64 */
- #define BT_fCLK2_DIV128 (BTIP2+BTIP1) /* fINT , fCLK2:128 */
- #define BT_fCLK2_DIV256 (BTIP2+BTIP1+BTIP0) /* fINT , fCLK2:256 */
- /* Frequency of LCD coded with Bits 3-4 */
- #define BT_fLCD_DIV32 (0x00) /* fLCD , fACLK:32 (default) */
- #define BT_fLCD_DIV64 (BTFRFQ0) /* fLCD , fACLK:64 */
- #define BT_fLCD_DIV128 (BTFRFQ1) /* fLCD , fACLK:128 */
- #define BT_fLCD_DIV256 (BTFRFQ1+BTFRFQ0) /* fLCD , fACLK:256 */
- /* LCD frequency values with fBT,fACLK */
- #define BT_fLCD_1K (0x00) /* fACLK:32 (default) */
- #define BT_fLCD_512 (BTFRFQ0) /* fACLK:64 */
- #define BT_fLCD_256 (BTFRFQ1) /* fACLK:128 */
- #define BT_fLCD_128 (BTFRFQ1+BTFRFQ0) /* fACLK:256 */
- /* LCD frequency values with fBT,fMCLK */
- #define BT_fLCD_31K (BTSSEL) /* fMCLK:32 */
- #define BT_fLCD_15_5K (BTSSEL+BTFRFQ0) /* fMCLK:64 */
- #define BT_fLCD_7_8K (BTSSEL+BTFRFQ1+BTFRFQ0) /* fMCLK:256 */
- /* with assumed vlues of fACLK,32KHz, fMCLK,1MHz */
- /* fBT,fACLK is thought for longer interval times */
- #define BT_ADLY_0_064 (0x00) /* 0.064ms interval (default) */
- #define BT_ADLY_0_125 (BTIP0) /* 0.125ms " */
- #define BT_ADLY_0_25 (BTIP1) /* 0.25ms " */
- #define BT_ADLY_0_5 (BTIP1+BTIP0) /* 0.5ms " */
- #define BT_ADLY_1 (BTIP2) /* 1ms " */
- #define BT_ADLY_2 (BTIP2+BTIP0) /* 2ms " */
- #define BT_ADLY_4 (BTIP2+BTIP1) /* 4ms " */
- #define BT_ADLY_8 (BTIP2+BTIP1+BTIP0) /* 8ms " */
- #define BT_ADLY_16 (BTDIV) /* 16ms " */
- #define BT_ADLY_32 (BTDIV+BTIP0) /* 32ms " */
- #define BT_ADLY_64 (BTDIV+BTIP1) /* 64ms " */
- #define BT_ADLY_125 (BTDIV+BTIP1+BTIP0) /* 125ms " */
- #define BT_ADLY_250 (BTDIV+BTIP2) /* 250ms " */
- #define BT_ADLY_500 (BTDIV+BTIP2+BTIP0) /* 500ms " */
- #define BT_ADLY_1000 (BTDIV+BTIP2+BTIP1) /* 1000ms " */
- #define BT_ADLY_2000 (BTDIV+BTIP2+BTIP1+BTIP0) /* 2000ms " */
- /* fCLK2,fMCLK (1MHz) is thought for short interval times */
- /* the timing for short intervals is more precise than ACLK */
- /* NOTE */
- /* Be sure that the SCFQCTL-Register is set to 01Fh so that fMCLK,1MHz */
- /* Too low interval time results in interrupts too frequent for the processor to handle! */
- #define BT_MDLY_0_002 (BTSSEL) /* 0.002ms interval *** interval times */
- #define BT_MDLY_0_004 (BTSSEL+BTIP0) /* 0.004ms " *** too short for */
- #define BT_MDLY_0_008 (BTSSEL+BTIP1) /* 0.008ms " *** interrupt */
- #define BT_MDLY_0_016 (BTSSEL+BTIP1+BTIP0) /* 0.016ms " *** handling */
- #define BT_MDLY_0_032 (BTSSEL+BTIP2) /* 0.032ms " */
- #define BT_MDLY_0_064 (BTSSEL+BTIP2+BTIP0) /* 0.064ms " */
- #define BT_MDLY_0_125 (BTSSEL+BTIP2+BTIP1) /* 0.125ms " */
- #define BT_MDLY_0_25 (BTSSEL+BTIP2+BTIP1+BTIP0)/* 0.25ms " */
- /* Reset/Hold coded with Bits 6-7 in BT(1)CTL */
- /* this is for BT */
- #define BTRESET_CNT1 (BTRESET) /* BTCNT1 is reset while BTRESET is set */
- #define BTRESET_CNT1_2 (BTRESET+BTDIV) /* BTCNT1 .AND. BTCNT2 are reset while ~ is set */
- /* this is for BT1 */
- #define BTHOLD_CNT1 (BTHOLD) /* BTCNT1 is held while BTHOLD is set */
- #define BTHOLD_CNT1_2 (BTHOLD+BTDIV) /* BT1CNT1 .AND. BT1CNT2 are held while ~ is set */
- /* INTERRUPT CONTROL BITS */
- /* #define BTIE 0x80 */
- /* #define BTIFG 0x80 */
- * SYSTEM CLOCK, FLL+
- #define SCFI0_ (0x0050) /* System Clock Frequency Integrator 0 */
- DEFC( SCFI0 , SCFI0_)
- #define FN_2 (0x04) /* fDCOCLK , 2*fNominal */
- #define FN_3 (0x08) /* fDCOCLK , 3*fNominal */
- #define FN_4 (0x10) /* fDCOCLK , 4.5*fNominal */
- #define FN_8 (0x20) /* fDCOCLK , 10*fNominal */
- #define FLLD0 (0x40) /* Loop Divider Bit : 0 */
- #define FLLD1 (0x80) /* Loop Divider Bit : 1 */
- #define FLLD_1 (0x00) /* Multiply Selected Loop Freq. By 1 */
- #define FLLD_2 (0x40) /* Multiply Selected Loop Freq. By 2 */
- #define FLLD_4 (0x80) /* Multiply Selected Loop Freq. By 4 */
- #define FLLD_8 (0xC0) /* Multiply Selected Loop Freq. By 8 */
- #define SCFI1_ (0x0051) /* System Clock Frequency Integrator 1 */
- DEFC( SCFI1 , SCFI1_)
- #define SCFQCTL_ (0x0052) /* System Clock Frequency Control */
- DEFC( SCFQCTL , SCFQCTL_)
- /* System clock frequency values fMCLK coded with Bits 0-6 in SCFQCTL */
- /* #define SCFQ_32K 0x00 fMCLK,1*fACLK only a range from */
- #define SCFQ_64K (0x01) /* fMCLK,2*fACLK 1+1 to 127+1 is possible */
- #define SCFQ_128K (0x03) /* fMCLK,4*fACLK */
- #define SCFQ_256K (0x07) /* fMCLK,8*fACLK */
- #define SCFQ_512K (0x0F) /* fMCLK,16*fACLK */
- #define SCFQ_1M (0x1F) /* fMCLK,32*fACLK */
- #define SCFQ_2M (0x3F) /* fMCLK,64*fACLK */
- #define SCFQ_4M (0x7F) /* fMCLK,128*fACLK */
- #define SCFQ_M (0x80) /* Modulation Disable */
- #define FLL_CTL0_ (0x0053) /* FLL+ Control 0 */
- DEFC( FLL_CTL0 , FLL_CTL0_)
- #define DCOF (0x01) /* DCO Fault Flag */
- #define LFOF (0x02) /* Low Frequency Oscillator Fault Flag */
- #define XT1OF (0x04) /* High Frequency Oscillator 1 Fault Flag */
- #define XT2OF (0x08) /* High Frequency Oscillator 2 Fault Flag */
- #define OSCCAP0 (0x10) /* XIN/XOUT Cap 0 */
- #define OSCCAP1 (0x20) /* XIN/XOUT Cap 1 */
- #define XTS_FLL (0x40) /* 1: Selects high-freq. oscillator */
- #define DCOPLUS (0x80) /* DCO+ Enable */
- #define XCAP0PF (0x00) /* XIN Cap = XOUT Cap = 0pf */
- #define XCAP10PF (0x10) /* XIN Cap = XOUT Cap = 10pf */
- #define XCAP14PF (0x20) /* XIN Cap = XOUT Cap = 14pf */
- #define XCAP18PF (0x30) /* XIN Cap = XOUT Cap = 18pf */
- #define FLL_CTL1_ (0x0054) /* FLL+ Control 1 */
- DEFC( FLL_CTL1 , FLL_CTL1_)
- #define FLL_DIV0 (0x00) /* FLL+ Divide Px.x/ACLK 0 */
- #define FLL_DIV1 (0x01) /* FLL+ Divide Px.x/ACLK 1 */
- #define SELS (0x04) /* Peripheral Module Clock Source (0: DCO, 1: XT2) */
- #define SELM0 (0x08) /* MCLK Source Select 0 */
- #define SELM1 (0x10) /* MCLK Source Select 1 */
- #define XT2OFF (0x20) /* High Frequency Oscillator 2 (XT2) disable */
- #define FLL_DIV_1 (0x00) /* FLL+ Divide Px.x/ACLK By 1 */
- #define FLL_DIV_2 (0x01) /* FLL+ Divide Px.x/ACLK By 2 */
- #define FLL_DIV_4 (0x02) /* FLL+ Divide Px.x/ACLK By 4 */
- #define FLL_DIV_8 (0x03) /* FLL+ Divide Px.x/ACLK By 8 */
- #define SELM_DCO (0x00) /* Select DCO for CPU MCLK */
- #define SELM_XT2 (0x10) /* Select XT2 for CPU MCLK */
- #define SELM_A (0x18) /* Select A (from LFXT1) for CPU MCLK */
- #define SMCLKOFF (0x40) /* Peripheral Module Clock (SMCLK) disable */
- /* #define OFIFG 0x02 */
- /* #define OFIE 0x02 */
- * Brown-Out, Supply Voltage Supervision (SVS)
- #define SVSCTL_ (0x0056) /* SVS Control */
- DEFC( SVSCTL , SVSCTL_)
- #define SVSFG (0x01)
- #define SVSOP (0x02)
- #define SVSON (0x04)
- #define PORON (0x08)
- #define VLDOFF (0x00)
- #define VLDON (0x10)
- #define VLD_1_8V (0x10)
- * LCD
- #define LCDCTL_ (0x0090) /* LCD Control */
- DEFC( LCDCTL , LCDCTL_)
- /* the names of the mode bits are different from the spec */
- #define LCDON (0x01)
- #define LCDLOWR (0x02)
- #define LCDSON (0x04)
- #define LCDMX0 (0x08)
- #define LCDMX1 (0x10)
- #define LCDP0 (0x20)
- #define LCDP1 (0x40)
- #define LCDP2 (0x80)
- /* Display modes coded with Bits 2-4 */
- #define LCDSTATIC (LCDSON)
- #define LCD2MUX (LCDMX0+LCDSON)
- #define LCD3MUX (LCDMX1+LCDSON)
- #define LCD4MUX (LCDMX1+LCDMX0+LCDSON)
- /* Group select code with Bits 5-7 Seg.lines Dig.output */
- #define LCDSG0 (0x00) /* --------- Port Only (default) */
- #define LCDSG0_1 (LCDP0) /* S0 - S15 see Datasheet */
- #define LCDSG0_2 (LCDP1) /* S0 - S19 see Datasheet */
- #define LCDSG0_3 (LCDP1+LCDP0) /* S0 - S23 see Datasheet */
- #define LCDSG0_4 (LCDP2) /* S0 - S27 see Datasheet */
- #define LCDSG0_5 (LCDP2+LCDP0) /* S0 - S31 see Datasheet */
- #define LCDSG0_6 (LCDP2+LCDP1) /* S0 - S35 see Datasheet */
- #define LCDSG0_7 (LCDP2+LCDP1+LCDP0) /* S0 - S39 see Datasheet */
- /* NOTE: YOU CAN ONLY USE THE 'S' OR 'G' DECLARATIONS FOR A COMMAND */
- /* MOV #LCDSG0_3+LCDOG2_7,&LCDCTL ACTUALY MEANS MOV #LCDP1,&LCDCTL! */
- #define LCDOG1_7 (0x00) /* --------- Port Only (default) */
- #define LCDOG2_7 (LCDP0) /* S0 - S15 see Datasheet */
- #define LCDOG3_7 (LCDP1) /* S0 - S19 see Datasheet */
- #define LCDOG4_7 (LCDP1+LCDP0) /* S0 - S23 see Datasheet */
- #define LCDOG5_7 (LCDP2) /* S0 - S27 see Datasheet */
- #define LCDOG6_7 (LCDP2+LCDP0) /* S0 - S31 see Datasheet */
- #define LCDOG7 (LCDP2+LCDP1) /* S0 - S35 see Datasheet */
- #define LCDOGOFF (LCDP2+LCDP1+LCDP0) /* S0 - S39 see Datasheet */
- #define LCDMEM_ (0x0091) /* LCD Memory */
- #define LCDMEM (LCDMEM_) /* LCD Memory (for assembler) */
- #else
- #define LCDMEM ((char*) LCDMEM_) /* LCD Memory (for C) */
- #endif
- #define LCDM1_ (LCDMEM_) /* LCD Memory 1 */
- DEFC( LCDM1 , LCDM1_)
- #define LCDM2_ (0x0092) /* LCD Memory 2 */
- DEFC( LCDM2 , LCDM2_)
- #define LCDM3_ (0x0093) /* LCD Memory 3 */
- DEFC( LCDM3 , LCDM3_)
- #define LCDM4_ (0x0094) /* LCD Memory 4 */
- DEFC( LCDM4 , LCDM4_)
- #define LCDM5_ (0x0095) /* LCD Memory 5 */
- DEFC( LCDM5 , LCDM5_)
- #define LCDM6_ (0x0096) /* LCD Memory 6 */
- DEFC( LCDM6 , LCDM6_)
- #define LCDM7_ (0x0097) /* LCD Memory 7 */
- DEFC( LCDM7 , LCDM7_)
- #define LCDM8_ (0x0098) /* LCD Memory 8 */
- DEFC( LCDM8 , LCDM8_)
- #define LCDM9_ (0x0099) /* LCD Memory 9 */
- DEFC( LCDM9 , LCDM9_)
- #define LCDM10_ (0x009A) /* LCD Memory 10 */
- DEFC( LCDM10 , LCDM10_)
- #define LCDM11_ (0x009B) /* LCD Memory 11 */
- DEFC( LCDM11 , LCDM11_)
- #define LCDM12_ (0x009C) /* LCD Memory 12 */
- DEFC( LCDM12 , LCDM12_)
- #define LCDM13_ (0x009D) /* LCD Memory 13 */
- DEFC( LCDM13 , LCDM13_)
- #define LCDM14_ (0x009E) /* LCD Memory 14 */
- DEFC( LCDM14 , LCDM14_)
- #define LCDM15_ (0x009F) /* LCD Memory 15 */
- DEFC( LCDM15 , LCDM15_)
- #define LCDM16_ (0x00A0) /* LCD Memory 16 */
- DEFC( LCDM16 , LCDM16_)
- #define LCDM17_ (0x00A1) /* LCD Memory 17 */
- DEFC( LCDM17 , LCDM17_)
- #define LCDM18_ (0x00A2) /* LCD Memory 18 */
- DEFC( LCDM18 , LCDM18_)
- #define LCDM19_ (0x00A3) /* LCD Memory 19 */
- DEFC( LCDM19 , LCDM19_)
- #define LCDM20_ (0x00A4) /* LCD Memory 20 */
- DEFC( LCDM20 , LCDM20_)
- #define LCDMA_ (LCDM10_) /* LCD Memory A */
- DEFC( LCDMA , LCDMA_)
- #define LCDMB_ (LCDM11_) /* LCD Memory B */
- DEFC( LCDMB , LCDMB_)
- #define LCDMC_ (LCDM12_) /* LCD Memory C */
- DEFC( LCDMC , LCDMC_)
- #define LCDMD_ (LCDM13_) /* LCD Memory D */
- DEFC( LCDMD , LCDMD_)
- #define LCDME_ (LCDM14_) /* LCD Memory E */
- DEFC( LCDME , LCDME_)
- #define LCDMF_ (LCDM15_) /* LCD Memory F */
- DEFC( LCDMF , LCDMF_)
- * USART
- #define PENA (0x80) /* UCTL */
- #define PEV (0x40)
- #define SPB (0x20) /* to distinguish from stackpointer SP */
- #define CHAR (0x10)
- #define LISTEN (0x08)
- #define SYNC (0x04)
- #define MM (0x02)
- #define SWRST (0x01)
- #define CKPH (0x80) /* UTCTL */
- #define CKPL (0x40)
- #define SSEL1 (0x20)
- #define SSEL0 (0x10)
- #define URXSE (0x08)
- #define TXWAKE (0x04)
- #define STC (0x02)
- #define TXEPT (0x01)
- #define FE (0x80) /* URCTL */
- #define PE (0x40)
- #define OE (0x20)
- #define BRK (0x10)
- #define URXEIE (0x08)
- #define URXWIE (0x04)
- #define RXWAKE (0x02)
- #define RXERR (0x01)
- * USART 0
- #define U0CTL_ (0x0070) /* USART 0 Control */
- DEFC( U0CTL , U0CTL_)
- #define U0TCTL_ (0x0071) /* USART 0 Transmit Control */
- DEFC( U0TCTL , U0TCTL_)
- #define U0RCTL_ (0x0072) /* USART 0 Receive Control */
- DEFC( U0RCTL , U0RCTL_)
- #define U0MCTL_ (0x0073) /* USART 0 Modulation Control */
- DEFC( U0MCTL , U0MCTL_)
- #define U0BR0_ (0x0074) /* USART 0 Baud Rate 0 */
- DEFC( U0BR0 , U0BR0_)
- #define U0BR1_ (0x0075) /* USART 0 Baud Rate 1 */
- DEFC( U0BR1 , U0BR1_)
- #define U0RXBUF_ (0x0076) /* USART 0 Receive Buffer */
- READ_ONLY DEFC( U0RXBUF , U0RXBUF_)
- #define U0TXBUF_ (0x0077) /* USART 0 Transmit Buffer */
- DEFC( U0TXBUF , U0TXBUF_)
- /* Alternate register names */
- #define UCTL0_ U0CTL_ /* USART 0 Control */
- DEFC( UCTL0 , UCTL0_)
- #define UTCTL0_ U0TCTL_ /* USART 0 Transmit Control */
- DEFC( UTCTL0 , UTCTL0_)
- #define URCTL0_ U0RCTL_ /* USART 0 Receive Control */
- DEFC( URCTL0 , URCTL0_)
- #define UMCTL0_ U0MCTL_ /* USART 0 Modulation Control */
- DEFC( UMCTL0 , UMCTL0_)
- #define UBR00_ U0BR0_ /* USART 0 Baud Rate 0 */
- DEFC( UBR00 , UBR00_)
- #define UBR10_ U0BR1_ /* USART 0 Baud Rate 1 */
- DEFC( UBR10 , UBR10_)
- #define RXBUF0_ U0RXBUF_ /* USART 0 Receive Buffer */
- READ_ONLY DEFC( RXBUF0 , RXBUF0_)
- #define TXBUF0_ U0TXBUF_ /* USART 0 Transmit Buffer */
- DEFC( TXBUF0 , TXBUF0_)
- #define UCTL_0_ U0CTL_ /* USART 0 Control */
- DEFC( UCTL_0 , UCTL_0_)
- #define UTCTL_0_ U0TCTL_ /* USART 0 Transmit Control */
- DEFC( UTCTL_0 , UTCTL_0_)
- #define URCTL_0_ U0RCTL_ /* USART 0 Receive Control */
- DEFC( URCTL_0 , URCTL_0_)
- #define UMCTL_0_ U0MCTL_ /* USART 0 Modulation Control */
- DEFC( UMCTL_0 , UMCTL_0_)
- #define UBR0_0_ U0BR0_ /* USART 0 Baud Rate 0 */
- DEFC( UBR0_0 , UBR0_0_)
- #define UBR1_0_ U0BR1_ /* USART 0 Baud Rate 1 */
- DEFC( UBR1_0 , UBR1_0_)
- #define RXBUF_0_ U0RXBUF_ /* USART 0 Receive Buffer */
- READ_ONLY DEFC( RXBUF_0 , RXBUF_0_)
- #define TXBUF_0_ U0TXBUF_ /* USART 0 Transmit Buffer */
- DEFC( TXBUF_0 , TXBUF_0_)
- * Timer A
- #define TAIV_ (0x012E) /* Timer A Interrupt Vector Word */
- READ_ONLY DEFW( TAIV , TAIV_)
- #define TACTL_ (0x0160) /* Timer A Control */
- DEFW( TACTL , TACTL_)
- #define TACCTL0_ (0x0162) /* Timer A Capture/Compare Control 0 */
- DEFW( TACCTL0 , TACCTL0_)
- #define TACCTL1_ (0x0164) /* Timer A Capture/Compare Control 1 */
- DEFW( TACCTL1 , TACCTL1_)
- #define TACCTL2_ (0x0166) /* Timer A Capture/Compare Control 2 */
- DEFW( TACCTL2 , TACCTL2_)
- #define TAR_ (0x0170) /* Timer A */
- DEFW( TAR , TAR_)
- #define TACCR0_ (0x0172) /* Timer A Capture/Compare 0 */
- DEFW( TACCR0 , TACCR0_)
- #define TACCR1_ (0x0174) /* Timer A Capture/Compare 1 */
- DEFW( TACCR1 , TACCR1_)
- #define TACCR2_ (0x0176) /* Timer A Capture/Compare 2 */
- DEFW( TACCR2 , TACCR2_)
- #define CCTL0_ TACCTL0_ /* Timer A Capture/Compare Control 0 */
- DEFW( CCTL0 , CCTL0_)
- #define CCTL1_ TACCTL1_ /* Timer A Capture/Compare Control 1 */
- DEFW( CCTL1 , CCTL1_)
- #define CCTL2_ TACCTL2_ /* Timer A Capture/Compare Control 2 */
- DEFW( CCTL2 , CCTL2_)
- #define CCR0_ TACCR0_ /* Timer A Capture/Compare 0 */
- DEFW( CCR0 , CCR0_)
- #define CCR1_ TACCR1_ /* Timer A Capture/Compare 1 */
- DEFW( CCR1 , CCR1_)
- #define CCR2_ TACCR2_ /* Timer A Capture/Compare 2 */
- DEFW( CCR2 , CCR2_)
- #define TASSEL2 (0x0400) /* unused */ /* to distinguish from USART SSELx */
- #define TASSEL1 (0x0200) /* Timer A clock source select 0 */
- #define TASSEL0 (0x0100) /* Timer A clock source select 1 */
- #define ID1 (0x0080) /* Timer A clock input devider 1 */
- #define ID0 (0x0040) /* Timer A clock input devider 0 */
- #define MC1 (0x0020) /* Timer A mode control 1 */
- #define MC0 (0x0010) /* Timer A mode control 0 */
- #define TACLR (0x0004) /* Timer A counter clear */
- #define TAIE (0x0002) /* Timer A counter interrupt enable */
- #define TAIFG (0x0001) /* Timer A counter interrupt flag */
- #define MC_0 (0*0x10) /* Timer A mode control: 0 - Stop */
- #define MC_1 (1*0x10) /* Timer A mode control: 1 - Up to CCR0 */
- #define MC_2 (2*0x10) /* Timer A mode control: 2 - Continous up */
- #define MC_3 (3*0x10) /* Timer A mode control: 3 - Up/Down */
- #define ID_0 (0*0x40) /* Timer A input divider: 0 - /1 */
- #define ID_1 (1*0x40) /* Timer A input divider: 1 - /2 */
- #define ID_2 (2*0x40) /* Timer A input divider: 2 - /4 */
- #define ID_3 (3*0x40) /* Timer A input divider: 3 - /8 */
- #define TASSEL_0 (0*0x100) /* Timer A clock source select: 0 - TACLK */
- #define TASSEL_1 (1*0x100) /* Timer A clock source select: 1 - ACLK */
- #define TASSEL_2 (2*0x100) /* Timer A clock source select: 2 - SMCLK */
- #define TASSEL_3 (3*0x100) /* Timer A clock source select: 3 - INCLK */
- #define CM1 (0x8000) /* Capture mode 1 */
- #define CM0 (0x4000) /* Capture mode 0 */
- #define CCIS1 (0x2000) /* Capture input select 1 */
- #define CCIS0 (0x1000) /* Capture input select 0 */
- #define SCS (0x0800) /* Capture sychronize */
- #define SCCI (0x0400) /* Latched capture signal (read) */
- #define CAP (0x0100) /* Capture mode: 1 /Compare mode : 0 */
- #define OUTMOD2 (0x0080) /* Output mode 2 */
- #define OUTMOD1 (0x0040) /* Output mode 1 */
- #define OUTMOD0 (0x0020) /* Output mode 0 */
- #define CCIE (0x0010) /* Capture/compare interrupt enable */
- #define CCI (0x0008) /* Capture input signal (read) */
- #define OUT (0x0004) /* PWM Output signal if output mode 0 */
- #define COV (0x0002) /* Capture/compare overflow flag */
- #define CCIFG (0x0001) /* Capture/compare interrupt flag */
- #define OUTMOD_0 (0*0x20) /* PWM output mode: 0 - output only */
- #define OUTMOD_1 (1*0x20) /* PWM output mode: 1 - set */
- #define OUTMOD_2 (2*0x20) /* PWM output mode: 2 - PWM toggle/reset */
- #define OUTMOD_3 (3*0x20) /* PWM output mode: 3 - PWM set/reset */
- #define OUTMOD_4 (4*0x20) /* PWM output mode: 4 - toggle */
- #define OUTMOD_5 (5*0x20) /* PWM output mode: 5 - Reset */
- #define OUTMOD_6 (6*0x20) /* PWM output mode: 6 - PWM toggle/set */
- #define OUTMOD_7 (7*0x20) /* PWM output mode: 7 - PWM reset/set */
- #define CCIS_0 (0*0x1000) /* Capture input select: 0 - CCIxA */
- #define CCIS_1 (1*0x1000) /* Capture input select: 1 - CCIxB */
- #define CCIS_2 (2*0x1000) /* Capture input select: 2 - GND */
- #define CCIS_3 (3*0x1000) /* Capture input select: 3 - Vcc */
- #define CM_0 (0*0x4000u) /* Capture mode: 0 - disabled */
- #define CM_1 (1*0x4000u) /* Capture mode: 1 - pos. edge */
- #define CM_2 (2*0x4000u) /* Capture mode: 1 - neg. edge */
- #define CM_3 (3*0x4000u) /* Capture mode: 1 - both edges */
- * Timer B
- #define TBIV_ (0x011E) /* Timer B Interrupt Vector Word */
- READ_ONLY DEFW( TBIV , TBIV_)
- #define TBCTL_ (0x0180) /* Timer B Control */
- DEFW( TBCTL , TBCTL_)
- #define TBCCTL0_ (0x0182) /* Timer B Capture/Compare Control 0 */
- DEFW( TBCCTL0 , TBCCTL0_)
- #define TBCCTL1_ (0x0184) /* Timer B Capture/Compare Control 1 */
- DEFW( TBCCTL1 , TBCCTL1_)
- #define TBCCTL2_ (0x0186) /* Timer B Capture/Compare Control 2 */
- DEFW( TBCCTL2 , TBCCTL2_)
- #define TBR_ (0x0190) /* Timer B */
- DEFW( TBR , TBR_)
- #define TBCCR0_ (0x0192) /* Timer B Capture/Compare 0 */
- DEFW( TBCCR0 , TBCCR0_)
- #define TBCCR1_ (0x0194) /* Timer B Capture/Compare 1 */
- DEFW( TBCCR1 , TBCCR1_)
- #define TBCCR2_ (0x0196) /* Timer B Capture/Compare 2 */
- DEFW( TBCCR2 , TBCCR2_)
- #define SHR1 (0x4000) /* Timer B Compare latch load group 1 */
- #define SHR0 (0x2000) /* Timer B Compare latch load group 0 */
- #define TBCLGRP1 (0x4000) /* Timer B Compare latch load group 1 */
- #define TBCLGRP0 (0x2000) /* Timer B Compare latch load group 0 */
- #define CNTL1 (0x1000) /* Counter lenght 1 */
- #define CNTL0 (0x0800) /* Counter lenght 0 */
- #define TBSSEL2 (0x0400) /* unused */
- #define TBSSEL1 (0x0200) /* Clock source 1 */
- #define TBSSEL0 (0x0100) /* Clock source 0 */
- #define TBCLR (0x0004) /* Timer B counter clear */
- #define TBIE (0x0002) /* Timer B interrupt enable */
- #define TBIFG (0x0001) /* Timer B interrupt flag */
- #define TBSSEL_0 (0*0x0100) /* Clock Source: TBCLK */
- #define TBSSEL_1 (1*0x0100) /* Clock Source: ACLK */
- #define TBSSEL_2 (2*0x0100) /* Clock Source: SMCLK */
- #define TBSSEL_3 (3*0x0100) /* Clock Source: INCLK */
- #define CNTL_0 (0*0x0800) /* Counter lenght: 16 bit */
- #define CNTL_1 (1*0x0800) /* Counter lenght: 12 bit */
- #define CNTL_2 (2*0x0800) /* Counter lenght: 10 bit */
- #define CNTL_3 (3*0x0800) /* Counter lenght: 8 bit */
- #define SHR_0 (0*0x2000) /* Timer B Group: 0 - individually */
- #define SHR_1 (1*0x2000) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
- #define SHR_2 (2*0x2000) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
- #define SHR_3 (3*0x2000) /* Timer B Group: 3 - 1 group (all) */
- #define TBCLGRP_0 (0*0x2000) /* Timer B Group: 0 - individually */
- #define TBCLGRP_1 (1*0x2000) /* Timer B Group: 1 - 3 groups (1-2, 3-4, 5-6) */
- #define TBCLGRP_2 (2*0x2000) /* Timer B Group: 2 - 2 groups (1-3, 4-6)*/
- #define TBCLGRP_3 (3*0x2000) /* Timer B Group: 3 - 1 group (all) */
- /* Additional Timer B Control Register bits are defined in Timer A */
- #define SLSHR1 (0x0400) /* Compare latch load source 1 */
- #define SLSHR0 (0x0200) /* Compare latch load source 0 */
- #define CLLD1 (0x0400) /* Compare latch load source 1 */
- #define CLLD0 (0x0200) /* Compare latch load source 0 */
- #define SLSHR_0 (0*0x0200) /* Compare latch load sourec : 0 - immediate */
- #define SLSHR_1 (1*0x0200) /* Compare latch load sourec : 1 - TBR counts to 0 */
- #define SLSHR_2 (2*0x0200) /* Compare latch load sourec : 2 - up/down */
- #define SLSHR_3 (3*0x0200) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
- #define CLLD_0 (0*0x0200) /* Compare latch load sourec : 0 - immediate */
- #define CLLD_1 (1*0x0200) /* Compare latch load sourec : 1 - TBR counts to 0 */
- #define CLLD_2 (2*0x0200) /* Compare latch load sourec : 2 - up/down */
- #define CLLD_3 (3*0x0200) /* Compare latch load sourec : 3 - TBR counts to TBCTL0 */
- * Flash Memory
- #define FCTL1_ (0x0128) /* FLASH Control 1 */
- DEFW( FCTL1 , FCTL1_)
- #define FCTL2_ (0x012A) /* FLASH Control 2 */
- DEFW( FCTL2 , FCTL2_)
- #define FCTL3_ (0x012C) /* FLASH Control 3 */
- DEFW( FCTL3 , FCTL3_)
- #define FRKEY (0x9600) /* Flash key returned by read */
- #define FWKEY (0xA500) /* Flash key for write */
- #define FXKEY (0x3300) /* for use with XOR instruction */
- #define ERASE (0x0002) /* Enable bit for Flash segment erase */
- #define MERAS (0x0004) /* Enable bit for Flash mass erase */
- #define WRT (0x0040) /* Enable bit for Flash write */
- #define BLKWRT (0x0080) /* Enable bit for Flash segment write */
- #define SEGWRT (0x0080) /* old definition */ /* Enable bit for Flash segment write */
- #define FN0 (0x0001) /* Devide Flash clock by 1 to 64 using FN0 to FN5 according to: */
- #define FN1 (0x0002) /* 32*FN5 + 16*FN4 + 8*FN3 + 4*FN2 + 2*FN1 + FN0 + 1 */
- #define FN2 (0x0004)
- #define FN3 (0x0008)
- #define FN4 (0x0010)
- #define FN5 (0x0020)
- #define FSSEL0 (0x0040) /* Flash clock select 0 */ /* to distinguish from USART SSELx */
- #define FSSEL1 (0x0080) /* Flash clock select 1 */
- #define FSSEL_0 (0x0000) /* Flash clock select: 0 - ACLK */
- #define FSSEL_1 (0x0040) /* Flash clock select: 1 - MCLK */
- #define FSSEL_2 (0x0080) /* Flash clock select: 2 - SMCLK */
- #define FSSEL_3 (0x00C0) /* Flash clock select: 3 - SMCLK */
- #define BUSY (0x0001) /* Flash busy: 1 */
- #define KEYV (0x0002) /* Flash Key violation flag */
- #define ACCVIFG (0x0004) /* Flash Access violation flag */
- #define WAIT (0x0008) /* Wait flag for segment write */
- #define LOCK (0x0010) /* Lock bit: 1 - Flash is locked (read only) */
- #define EMEX (0x0020) /* Flash Emergency Exit */
- * Comparator A
- #define CACTL1_ (0x0059) /* Comparator A Control 1 */
- DEFC( CACTL1 , CACTL1_)
- #define CACTL2_ (0x005A) /* Comparator A Control 2 */
- DEFC( CACTL2 , CACTL2_)
- #define CAPD_ (0x005B) /* Comparator A Port Disable */
- DEFC( CAPD , CAPD_)
- #define CAIFG (0x01) /* Comp. A Interrupt Flag */
- #define CAIE (0x02) /* Comp. A Interrupt Enable */
- #define CAIES (0x04) /* Comp. A Int. Edge Select: 0:rising / 1:falling */
- #define CAON (0x08) /* Comp. A enable */
- #define CAREF0 (0x10) /* Comp. A Internal Reference Select 0 */
- #define CAREF1 (0x20) /* Comp. A Internal Reference Select 1 */
- #define CARSEL (0x40) /* Comp. A Internal Reference Enable */
- #define CAEX (0x80) /* Comp. A Exchange Inputs */
- #define CAREF_0 (0x00) /* Comp. A Int. Ref. Select 0 : Off */
- #define CAREF_1 (0x10) /* Comp. A Int. Ref. Select 1 : 0.25*Vcc */
- #define CAREF_2 (0x20) /* Comp. A Int. Ref. Select 2 : 0.5*Vcc */
- #define CAREF_3 (0x30) /* Comp. A Int. Ref. Select 3 : Vt*/
- #define CAOUT (0x01) /* Comp. A Output */
- #define CAF (0x02) /* Comp. A Enable Output Filter */
- #define P2CA0 (0x04) /* Comp. A Connect External Signal to CA0 : 1 */
- #define P2CA1 (0x08) /* Comp. A Connect External Signal to CA1 : 1 */
- #define CACTL24 (0x10)
- #define CACTL25 (0x20)
- #define CACTL26 (0x40)
- #define CACTL27 (0x80)
- #define CAPD0 (0x01) /* Comp. A Disable Input Buffer of Port Register .0 */
- #define CAPD1 (0x02) /* Comp. A Disable Input Buffer of Port Register .1 */
- #define CAPD2 (0x04) /* Comp. A Disable Input Buffer of Port Register .2 */
- #define CAPD3 (0x08) /* Comp. A Disable Input Buffer of Port Register .3 */
- #define CAPD4 (0x10) /* Comp. A Disable Input Buffer of Port Register .4 */
- #define CAPD5 (0x20) /* Comp. A Disable Input Buffer of Port Register .5 */
- #define CAPD6 (0x40) /* Comp. A Disable Input Buffer of Port Register .6 */
- #define CAPD7 (0x80) /* Comp. A Disable Input Buffer of Port Register .7 */
- * ADC12
- #define ADC12CTL0_ (0x01A0) /* ADC12 Control 0 */
- DEFW( ADC12CTL0 , ADC12CTL0_)
- #define ADC12CTL1_ (0x01A2) /* ADC12 Control 1 */
- DEFW( ADC12CTL1 , ADC12CTL1_)
- #define ADC12IFG_ (0x01A4) /* ADC12 Interrupt Flag */
- DEFW( ADC12IFG , ADC12IFG_)
- #define ADC12IE_ (0x01A6) /* ADC12 Interrupt Enable */
- DEFW( ADC12IE , ADC12IE_)
- #define ADC12IV_ (0x01A8) /* ADC12 Interrupt Vector Word */
- DEFW( ADC12IV , ADC12IV_)
- #define ADC12MEM_ (0x0140) /* ADC12 Conversion Memory */
- #define ADC12MEM (ADC12MEM_) /* ADC12 Conversion Memory (for assembler) */
- #else
- #define ADC12MEM ((int*) ADC12MEM_) /* ADC12 Conversion Memory (for C) */
- #endif
- #define ADC12MEM0_ (ADC12MEM_) /* ADC12 Conversion Memory 0 */
- DEFW( ADC12MEM0 , ADC12MEM0_)
- #define ADC12MEM1_ (0x0142) /* ADC12 Conversion Memory 1 */
- DEFW( ADC12MEM1 , ADC12MEM1_)
- #define ADC12MEM2_ (0x0144) /* ADC12 Conversion Memory 2 */
- DEFW( ADC12MEM2 , ADC12MEM2_)
- #define ADC12MEM3_ (0x0146) /* ADC12 Conversion Memory 3 */
- DEFW( ADC12MEM3 , ADC12MEM3_)
- #define ADC12MEM4_ (0x0148) /* ADC12 Conversion Memory 4 */
- DEFW( ADC12MEM4 , ADC12MEM4_)
- #define ADC12MEM5_ (0x014A) /* ADC12 Conversion Memory 5 */
- DEFW( ADC12MEM5 , ADC12MEM5_)
- #define ADC12MEM6_ (0x014C) /* ADC12 Conversion Memory 6 */
- DEFW( ADC12MEM6 , ADC12MEM6_)
- #define ADC12MEM7_ (0x014E) /* ADC12 Conversion Memory 7 */
- DEFW( ADC12MEM7 , ADC12MEM7_)
- #define ADC12MEM8_ (0x0150) /* ADC12 Conversion Memory 8 */
- DEFW( ADC12MEM8 , ADC12MEM8_)
- #define ADC12MEM9_ (0x0152) /* ADC12 Conversion Memory 9 */
- DEFW( ADC12MEM9 , ADC12MEM9_)
- #define ADC12MEM10_ (0x0154) /* ADC12 Conversion Memory 10 */
- DEFW( ADC12MEM10 , ADC12MEM10_)
- #define ADC12MEM11_ (0x0156) /* ADC12 Conversion Memory 11 */
- DEFW( ADC12MEM11 , ADC12MEM11_)
- #define ADC12MEM12_ (0x0158) /* ADC12 Conversion Memory 12 */
- DEFW( ADC12MEM12 , ADC12MEM12_)
- #define ADC12MEM13_ (0x015A) /* ADC12 Conversion Memory 13 */
- DEFW( ADC12MEM13 , ADC12MEM13_)
- #define ADC12MEM14_ (0x015C) /* ADC12 Conversion Memory 14 */
- DEFW( ADC12MEM14 , ADC12MEM14_)
- #define ADC12MEM15_ (0x015E) /* ADC12 Conversion Memory 15 */
- DEFW( ADC12MEM15 , ADC12MEM15_)
- #define ADC12MCTL_ (0x0080) /* ADC12 Memory Control */
- #define ADC12MCTL (ADC12MCTL_) /* ADC12 Memory Control (for assembler) */
- #else
- #define ADC12MCTL ((char*) ADC12MCTL_) /* ADC12 Memory Control (for C) */
- #endif
- #define ADC12MCTL0_ (ADC12MCTL_) /* ADC12 Memory Control 0 */
- DEFC( ADC12MCTL0 , ADC12MCTL0_)
- #define ADC12MCTL1_ (0x0081) /* ADC12 Memory Control 1 */
- DEFC( ADC12MCTL1 , ADC12MCTL1_)
- #define ADC12MCTL2_ (0x0082) /* ADC12 Memory Control 2 */
- DEFC( ADC12MCTL2 , ADC12MCTL2_)
- #define ADC12MCTL3_ (0x0083) /* ADC12 Memory Control 3 */
- DEFC( ADC12MCTL3 , ADC12MCTL3_)
- #define ADC12MCTL4_ (0x0084) /* ADC12 Memory Control 4 */
- DEFC( ADC12MCTL4 , ADC12MCTL4_)
- #define ADC12MCTL5_ (0x0085) /* ADC12 Memory Control 5 */
- DEFC( ADC12MCTL5 , ADC12MCTL5_)
- #define ADC12MCTL6_ (0x0086) /* ADC12 Memory Control 6 */
- DEFC( ADC12MCTL6 , ADC12MCTL6_)
- #define ADC12MCTL7_ (0x0087) /* ADC12 Memory Control 7 */
- DEFC( ADC12MCTL7 , ADC12MCTL7_)
- #define ADC12MCTL8_ (0x0088) /* ADC12 Memory Control 8 */
- DEFC( ADC12MCTL8 , ADC12MCTL8_)
- #define ADC12MCTL9_ (0x0089) /* ADC12 Memory Control 9 */
- DEFC( ADC12MCTL9 , ADC12MCTL9_)
- #define ADC12MCTL10_ (0x008A) /* ADC12 Memory Control 10 */
- DEFC( ADC12MCTL10 , ADC12MCTL10_)
- #define ADC12MCTL11_ (0x008B) /* ADC12 Memory Control 11 */
- DEFC( ADC12MCTL11 , ADC12MCTL11_)
- #define ADC12MCTL12_ (0x008C) /* ADC12 Memory Control 12 */
- DEFC( ADC12MCTL12 , ADC12MCTL12_)
- #define ADC12MCTL13_ (0x008D) /* ADC12 Memory Control 13 */
- DEFC( ADC12MCTL13 , ADC12MCTL13_)
- #define ADC12MCTL14_ (0x008E) /* ADC12 Memory Control 14 */
- DEFC( ADC12MCTL14 , ADC12MCTL14_)
- #define ADC12MCTL15_ (0x008F) /* ADC12 Memory Control 15 */
- DEFC( ADC12MCTL15 , ADC12MCTL15_)
- #define ADC12SC (0x001) /* ADC12CTL0 */
- #define ENC (0x002)
- #define ADC12TOVIE (0x004)
- #define ADC12OVIE (0x008)
- #define ADC12ON (0x010)
- #define REFON (0x020)
- #define REF2_5V (0x040)
- #define MSH (0x080)
- #define MSC (0x080)
- #define SHT0_0 (0*0x100)
- #define SHT0_1 (1*0x100)
- #define SHT0_2 (2*0x100)
- #define SHT0_3 (3*0x100)
- #define SHT0_4 (4*0x100)
- #define SHT0_5 (5*0x100)
- #define SHT0_6 (6*0x100)
- #define SHT0_7 (7*0x100)
- #define SHT0_8 (8*0x100)
- #define SHT0_9 (9*0x100)
- #define SHT0_10 (10*0x100)
- #define SHT0_11 (11*0x100)
- #define SHT0_12 (12*0x100)
- #define SHT0_13 (13*0x100)
- #define SHT0_14 (14*0x100)
- #define SHT0_15 (15*0x100)
- #define SHT1_0 (0*0x1000)
- #define SHT1_1 (1*0x1000)
- #define SHT1_2 (2*0x1000)
- #define SHT1_3 (3*0x1000)
- #define SHT1_4 (4*0x1000)
- #define SHT1_5 (5*0x1000)
- #define SHT1_6 (6*0x1000)
- #define SHT1_7 (7*0x1000)
- #define SHT1_8 (8*0x1000)
- #define SHT1_9 (9*0x1000)
- #define SHT1_10 (10*0x1000)
- #define SHT1_11 (11*0x1000)
- #define SHT1_12 (12*0x1000)
- #define SHT1_13 (13*0x1000)
- #define SHT1_14 (14*0x1000)
- #define SHT1_15 (15*0x1000)
- #define ADC12BUSY (0x0001) /* ADC12CTL1 */
- #define CONSEQ_0 (0*2)
- #define CONSEQ_1 (1*2)
- #define CONSEQ_2 (2*2)
- #define CONSEQ_3 (3*2)
- #define ADC12SSEL_0 (0*8)
- #define ADC12SSEL_1 (1*8)
- #define ADC12SSEL_2 (2*8)
- #define ADC12SSEL_3 (3*8)
- #define ADC12DIV_0 (0*0x20)
- #define ADC12DIV_1 (1*0x20)
- #define ADC12DIV_2 (2*0x20)
- #define ADC12DIV_3 (3*0x20)
- #define ADC12DIV_4 (4*0x20)
- #define ADC12DIV_5 (5*0x20)
- #define ADC12DIV_6 (6*0x20)
- #define ADC12DIV_7 (7*0x20)
- #define ISSH (0x0100)
- #define SHP (0x0200)
- #define SHS_0 (0*0x400)
- #define SHS_1 (1*0x400)
- #define SHS_2 (2*0x400)
- #define SHS_3 (3*0x400)
- #define CSTARTADD_0 (0*0x1000)
- #define CSTARTADD_1 (1*0x1000)
- #define CSTARTADD_2 (2*0x1000)
- #define CSTARTADD_3 (3*0x1000)
- #define CSTARTADD_4 (4*0x1000)
- #define CSTARTADD_5 (5*0x1000)
- #define CSTARTADD_6 (6*0x1000)
- #define CSTARTADD_7 (7*0x1000)
- #define CSTARTADD_8 (8*0x1000)
- #define CSTARTADD_9 (9*0x1000)
- #define CSTARTADD_10 (10*0x1000)
- #define CSTARTADD_11 (11*0x1000)
- #define CSTARTADD_12 (12*0x1000)
- #define CSTARTADD_13 (13*0x1000)
- #define CSTARTADD_14 (14*0x1000)
- #define CSTARTADD_15 (15*0x1000)
- #define INCH_0 (0) /* ADC12MCTLx */
- #define INCH_1 (1)
- #define INCH_2 (2)
- #define INCH_3 (3)
- #define INCH_4 (4)
- #define INCH_5 (5)
- #define INCH_6 (6)
- #define INCH_7 (7)
- #define INCH_8 (8)
- #define INCH_9 (9)
- #define INCH_10 (10)
- #define INCH_11 (11)
- #define INCH_12 (12)
- #define INCH_13 (13)
- #define INCH_14 (14)
- #define INCH_15 (15)
- #define SREF_0 (0*0x10)
- #define SREF_1 (1*0x10)
- #define SREF_2 (2*0x10)
- #define SREF_3 (3*0x10)
- #define SREF_4 (4*0x10)
- #define SREF_5 (5*0x10)
- #define SREF_6 (6*0x10)
- #define SREF_7 (7*0x10)
- #define EOS (0x80)
- * Interrupt Vectors (offset from 0xFFE0)
- #define BASICTIMER_VECTOR (0 * 2) /* 0xFFE0 Basic Timer */
- #define PORT2_VECTOR (1 * 2) /* 0xFFE2 Port 2 */
- #define PORT1_VECTOR (4 * 2) /* 0xFFE8 Port 1 */
- #define TIMERA1_VECTOR (5 * 2) /* 0xFFEA Timer A CC1-2, TA */
- #define TIMERA0_VECTOR (6 * 2) /* 0xFFEC Timer A CC0 */
- #define ADC_VECTOR (7 * 2) /* 0xFFEE ADC */
- #define USART0TX_VECTOR (8 * 2) /* 0xFFF0 USART 0 Transmit */
- #define USART0RX_VECTOR (9 * 2) /* 0xFFF2 USART 0 Receive */
- #define WDT_VECTOR (10 * 2) /* 0xFFF4 Watchdog Timer */
- #define COMPARATORA_VECTOR (11 * 2) /* 0xFFF6 Comparator A */
- #define TIMERB1_VECTOR (12 * 2) /* 0xFFF8 Timer B 1-2 */
- #define TIMERB0_VECTOR (13 * 2) /* 0xFFFA Timer B 0 */
- #define NMI_VECTOR (14 * 2) /* 0xFFFC Non-maskable */
- #define RESET_VECTOR (15 * 2) /* 0xFFFE Reset [Highest Priority] */
- #define UART0TX_VECTOR USART0TX_VECTOR
- #define UART0RX_VECTOR USART0RX_VECTOR
- * End of Module
- #pragma language=default
- #endif /* #ifndef __msp430x43x */
復制代碼
