最近研究的一些心得!
全部資料下載:
041 LCD12864顯示實驗.zip
(71.8 KB, 下載次數(shù): 26)
2016-5-20 16:22 上傳
點擊文件名下載附件
5
- /**********************HJ-2G V8.0 專業(yè)級AVR開發(fā)板例程************************
- * 平臺:HJ-2G V8 AVR開發(fā)板 +ICC7.22 +ATMETA16
- * 名稱:驅動開發(fā)板上的12864液晶
- * 公司:慧凈電子
- * 淘寶:http://shop37031453.taobao.com
- * 網站:www.hjmcu.com
- * 編寫:HJMCU
- * 日期:2008-8-08
- * QQ : 121350852 398115088
- * 晶振:內部12M晶振
- * 說明:免費開源,不提供源代碼分析,有問題直接到慧凈論壇交流
- * 論壇:http://hjdz.5d6d.net
- #include "iom16v.h" //包含型號頭文件
- #include "macros.h" //包含"位"操作頭文件
- #include "stdio.h" //標準輸入輸出頭文件
- #include "AVR_PQ1A.h" //包含自定義常量頭文件
- #pragma data:code //以下是字模工具取出的圖片數(shù)組
- const uchar GDRAM[1024]={0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
- 0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,
- 0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,
- 0x20,0x7F,0xFF,0xC0,0xFF,0xFF,0x80,0xFF,0xFF,0x80,0xFF,0xFF,0x83,0xFF,0xFE,0x04,
- 0x20,0x40,0x00,0x40,0x80,0x00,0x80,0x80,0x00,0x80,0x80,0x00,0x82,0x00,0x02,0x04,
- 0x20,0x00,0x00,0x00,0x00,0x60,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x04,
- 0x2F,0xFF,0xFF,0xFF,0xC1,0xF8,0x7F,0xBF,0xC1,0xE3,0x9C,0x00,0x78,0x1E,0x3F,0xC4,
- 0x26,0xD9,0xB6,0x6D,0x80,0x60,0x33,0x1B,0x63,0x31,0x8C,0x00,0xCC,0x33,0x1B,0x64,
- 0x26,0xD9,0xB6,0x6D,0x80,0x60,0x1E,0x1B,0x66,0x31,0x8C,0x01,0x8C,0x61,0x9B,0x64,
- 0x27,0xF9,0xFE,0x7F,0x80,0x60,0x0C,0x1B,0x66,0x01,0x8C,0x01,0x80,0x61,0x9B,0x64,
- 0x27,0xF9,0xFE,0x7F,0x80,0x60,0x1E,0x1B,0x66,0x01,0x8C,0x01,0x80,0x61,0x9B,0x64,
- 0x23,0x30,0xCC,0x33,0x1C,0x6C,0x33,0x1B,0x63,0x31,0x9C,0x70,0xCC,0x33,0x1B,0x64,
- 0x23,0x30,0xCC,0x33,0x1C,0x78,0x7F,0xBF,0xF1,0xE0,0xFC,0x70,0x78,0x1E,0x3F,0xF4,
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
- #pragma data:data
- 函數(shù)名稱: LCD12864_portini
- 功 能: 初始化12864液晶用到的IO口
- 參 數(shù): 無
- 返回值 : 無
- void LCD12864_portini(void)
- LCDb_CTRL_DDR |= BIT(LCDb_RS)|BIT(LCDb_RW)|BIT(LCDb_E)|BIT(LCDb_RST);//配置控制管腳為輸出
- LCDb_DATA_DDR |= 0xFF; //配置數(shù)據管腳為輸出
- LCDb_SET_RST; //不使能復位端
- 函數(shù)名稱: LCD12864_readbyte
- 功 能: 從12864液晶讀出一個字節(jié)數(shù)據或者指令
- 參 數(shù): DatCmd--為iDat時是數(shù)據,為iCmd時是指令
- 返回值 : dByte--讀回的數(shù)據或者指令
- uchar LCD12864_readbyte(uchar DatCmd)
- uchar dByte;
- if (DatCmd == iCmd) //指令操作
- LCDb_CLR_RS;
- else
- LCDb_SET_RS;
- LCDb_SET_RW; //讀操作
- LCDb_SET_E;
- LCDb_DATA_DDR=0x00; //數(shù)據總線定義為輸入
- dByte=LCDb_DI; //讀數(shù)據或者指令
- Delayms(1); //時序調整
- LCDb_CLR_E;
- LCDb_DATA_DDR|=0xff; //數(shù)據總線還原為輸出
- return dByte;
- 函數(shù)名稱: LCD12864_sendbyte
- 功 能: 向12864液晶寫入一個字節(jié)數(shù)據或者指令
- dByte--為寫入12864的數(shù)據或者指令
- 返回值 : 無
- void LCD12864_sendbyte(uchar DatCmd, uchar dByte)
- LCDb_CLR_RS;
- else
- LCDb_SET_RS;
- LCDb_CLR_RW; //寫操作
- LCDb_SET_E;
- LCDb_DO = dByte; //寫入數(shù)據
- Delayus(100);
- LCDb_CLR_E;
- 函數(shù)名稱: LCD12864_sendstr
- 功 能: 向12864液晶寫入一個字符串
- 參 數(shù): ptString--字符串指針
- 返回值 : 無
- void LCD12864_sendstr(uchar *ptString)
- while((*ptString)!='\0') //字符串未結束一直寫
- LCD12864_sendbyte(iDat, *ptString++);
- 函數(shù)名稱: LCD12864_clear
- 功 能: 12864液晶清屏
- 參 數(shù): 無
- 返回值 : 無
- void LCD12864_clear(void)
- LCD12864_sendbyte(iCmd,LCDb_CLS);
- Delayms(2);// 清屏指令寫入后,2ms 的延時是很必要的!!!
- 函數(shù)名稱: LCD12864_readBF
- 功 能: 12864液晶清屏
- 參 數(shù): 無
- 返回值 : busy--為1時忙,為0時可以接收指令
- uchar LCD12864_readBF(void)
- uchar busy;
- busy=LCD12864_readbyte(iCmd); //讀回BF標志和地址
- if(busy&0x80) //如果忙,返回忙狀態(tài)
- busy=1;
- else //不忙,可以寫入
- busy=0;
- return busy;
- 函數(shù)名稱: LCD12864_gotoXY
- 功 能: 移動到指定位置
- 參 數(shù): Row--指定的行
- Col--指定的列
- 返回值 : 無
- void LCD12864_gotoXY(uchar Row, uchar Col)
- switch (Row) //選擇行
- case 2:
- LCD12864_sendbyte(iCmd, LCDb_L2 + Col); break; //寫入第2行的指定列
- case 3:
- LCD12864_sendbyte(iCmd, LCDb_L3 + Col); break; //寫入第3行的指定列
- case 4:
- LCD12864_sendbyte(iCmd, LCDb_L4 + Col); break; //寫入第4行的指定列
- default:
- LCD12864_sendbyte(iCmd, LCDb_L1 + Col); break; //寫入第1行的指定列
- 函數(shù)名稱: LCD12864_initial
- 功 能: 12864液晶初始化
- 參 數(shù): 無
- 返回值 : 無
- void LCD12864_initial(void)
- Delayms(100); // 等待內部復位
- LCD12864_portini(); //端口初始化
- LCD12864_sendbyte(iCmd, LCDb_FUNCTION); //功能、模式設定
- while(LCD12864_readBF());
- LCD12864_sendbyte(iCmd, LCDb_ON); //打開顯示
- LCD12864_clear(); //清屏
- LCD12864_sendbyte(iCmd, LCDb_ENTRY); // 輸入模式設定
- 函數(shù)名稱: LCD12864_opGDRAM
- 功 能: 向GDRAM寫入數(shù)據,并顯示(完成繪圖功能)
- 參 數(shù): ptGDRAM--GDRAM數(shù)據指針
- 返回值 : 無
- void LCD12864_opGDRAM(const uchar *ptGDRAM)
- uchar i,j;
- uint x=0;
- while(LCD12864_readBF()); //讀忙標志
- LCD12864_sendbyte(iCmd,LCDb_EXTCMD1); //擴充指令集,并關閉繪圖顯示
- //寫入并顯示上半屏幕
- for(i=0;i<32;i++) //行地址計數(shù)
- for(j=0;j<8;j++) //列地址計數(shù)
- LCD12864_sendbyte(iCmd,0x80|i);//輸入行地址
- Delayus(10);
- LCD12864_sendbyte(iCmd,0x80|j);//輸入列地址
- Delayus(10);
- LCD12864_sendbyte(iDat,ptGDRAM[x++]); //輸入高位字節(jié)數(shù)據
- Delayus(10);
- LCD12864_sendbyte(iDat,ptGDRAM[x++]); //輸入低位字節(jié)數(shù)據
- Delayus(10);
- //寫入并顯示下半屏幕
- for(i=0;i<32;i++)
- for(j=8;j<16;j++)
- Delayus(10);
- Delayus(10);
- Delayus(10);
- Delayus(10);
- Delayus(10);
- LCD12864_sendbyte(iCmd,LCDb_EXTCMD2); //打開繪圖顯示
- LCD12864_sendbyte(iCmd,LCDb_BASCMD); //還原回基本指令集模式
- 函數(shù)名稱: main
- 功 能: 12864液晶驅動主程序
- 參 數(shù): 無
- 返回值 : 無
- void main(void)
- uchar i;
- Board_init( ); //初始化開發(fā)板
- LCD12864_initial(); //初始化12864液晶
- while(1)
- LCD12864_clear();
- LCD12864_gotoXY(1,0); //第1行,第1列顯示
- LCD12864_sendstr("HJ-2G AVR 開發(fā)板");
- LCD12864_gotoXY(2,2); //第2行,第3列顯示
- LCD12864_sendstr("慧凈制作");
- LCD12864_gotoXY(3,0); //第3行,第1列顯示
- LCD12864_sendstr("電話:18691419224");
- LCD12864_gotoXY(4,1); //第4行,第2列顯示
- LCD12864_sendstr("www.hjmcu.com ");
- Delayms(2000); //延時等待
復制代碼
