查看: 2304|回復: 4
急急急-AD轉換求助
ID:121043 發(fā)表于 2016-5-23 22:22 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
求大神幫助我做一個MAX1241的Isis和PRO。以我給的附件中的ADC0832為例,除了AD轉換器換了,其他的都不要改變,keil仿照我給的附件。附件包含 ADC0832模數轉換與顯示的例子。謝謝大神,等著急用
附件.zip
548.16 KB, 下載次數: 6
ID:114189 發(fā)表于 2016-5-23 23:39 來自觸屏版 | 只看該作者
加我q201792056  發(fā)給我 我看一下
ID:114189 發(fā)表于 2016-5-23 23:42 來自觸屏版 | 只看該作者
加我q 201792056 發(fā)給我 我看一下吧
ID:22218 發(fā)表于 2016-5-24 06:30 | 只看該作者
Digital voltmeter using an
Maxim MAX1241 ADC
connected to an AT90S8515
using the SPI bus
The measured voltage is transmitted
through the STK200 RS232 interface
Communication parameters: 9600 8N1
CodeVisionAVR C Compiler
(C) 1998-2000 Pavel Haiduc, HP InfoTech S.R.L.
Chip type : AT90S8515
Clock frequency : 4.000000 MHz
Memory model : Small
Internal RAM size: 512
External RAM size: 0
Data Stack size : 128
MAX1241 connections to the AT90S8515
[MAX1241] [AT9S8515 DIP40]
1 VDD=5V
2 Vin
3 /SHDN - 1 PB0
4 REF=5V
5 GND - 20 GND
6 DOUT - 7 MISO
7 /CS - 2 PB1
8 SCLK - 8 SCK
THE ISP CABLE SHOULD BE DISCONNECTED FROM
THE STK200 BOARD AFTER PROGRAMMING THE CHIP!
ALSO THE PORTB LED JUMPERS MUST BE OPEN!
#include
// Standard Input/Output functions
#include
// SPI functions
#include
// delays
#include
// MAX1241 Voltage Reference [mV]
#define VREF 5000
// MAX1241 control signals definitions
#define NSHDN PORTB.0
#define NCS PORTB.1
#define DOUT PINB.6
union adcu
unsigned char byte[2];
unsigned int word;
// Make one AD conversion and return the value
unsigned int max1241_read(void)
union adcu adc_data;
// exit MAX1241 from shutdown
NSHDN=1;
// wait 5us for the MAX1241 to wake up
delay_us(5);
// now select the chip to start the conversion
NCS=0;
// wait the conversion to complete
// DOUT will be 0 during conversion
while (DOUT==0);
// DOUT=1 -> conversion completed
// read MSB
adc_data.byte[1]=spi(0);
// read LSB
adc_data.byte[0]=spi(0);
// deselect the chip
NCS=1;
// enter shutdown
NSHDN=0;
// now format the result and return it
return (adc_data.word>>3)&0xfff;
void main(void)
// store the conversion result here
unsigned n;
// Input/Output Ports initialization
// Port A
DDRA=0x00;
PORTA=0x00;
// Port B
// the /SS pin is set as an output
// with level 1, it's required by
// the SPI to work in master mode
DDRB=0xA3;
PORTB=0x12;
// Port C
DDRC=0x00;
PORTC=0x00;
// Port D
DDRD=0x00;
PORTD=0x00;
// UART initialization
// Communication Parameters: 8 Data, 1 Stop, No Parity
// UART Receiver: Off
// UART Transmitter: On
UCR=0x08;
// UART Baud rate: 9600
UBRR=0x19;
// SPI initialization
// SPI Type: Master
// SPI Clock Rate: 1000.000 kHz
// SPI Clock Phase: Cycle Half
// SPI Clock Polarity: Low
// SPI Data Order: MSB First
SPCR=0x50;
putsf("MAX1241 Demo using the CodeVisionAVR C Compiler");
putsf("***********************************************\n");
// Make AD conversions and send the results to RS232
while (1)
n=max1241_read();
printf("MAX1241-> N=%4u U=%4umV\n",n,(unsigned) ((long) n*VREF/4096));
// 0.3 sec. delay
delay_ms(300);
ID:121043 發(fā)表于 2016-5-24 11:46 | 只看該作者
chinomango 發(fā)表于 2016-5-24 06:30
Maxim MAX1241 ADC
沒看懂……我解釋一下吧。使用的是AT89C51芯片,用的是C語言。把我給的里面的ADC0832轉換器換成MAX1241,端口不要改變。然后寫出程序。附件里面有ADC0832的例子。仿照著寫
Powered by 單片機教程網
