查看: 5501|回復(fù): 2
51單片機匯編指令集(附記憶方法).doc 文件下載
ID:125232 發(fā)表于 2016-6-5 13:50 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
51單片機匯編指令集
一、數(shù)據(jù)傳送類指令(7種助記符)
MOV(英文為Move):對內(nèi)部數(shù)據(jù)寄存器RAM和特殊功能寄存器SFR的數(shù)據(jù)進行傳送;
MOVC(Move Code)讀取程序存儲器數(shù)據(jù)表格的數(shù)據(jù)傳送;
MOVX (Move External RAM) 對外部RAM的數(shù)據(jù)傳送;
XCH (Exchange) 字節(jié)交換;
XCHD (Exchange low-order Digit) 低半字節(jié)交換;
PUSH (Push onto Stack) 入棧;
POP  (Pop from Stack) 出棧;
二、算術(shù)運算類指令(8種助記符)
ADD(Addition) 加法;
ADDC(Add with Carry) 帶進位加法;
SUBB(Subtract with Borrow) 帶借位減法;
DA(Decimal Adjust) 十進制調(diào)整;
INC(Increment) 加1;
DEC(Decrement) 減1;
MUL(Multiplication、Multiply) 乘法;
DIV(Division、Divide) 除法;
三、邏輯運算類指令(10種助記符)
ANL(AND Logic) 邏輯與;
ORL(OR Logic) 邏輯或;
XRL(Exclusive-OR Logic) 邏輯異或;
CLR(Clear) 清零;
CPL(Complement) 取反;
RL(Rotate left) 循環(huán)左移;
RLC(Rotate Left throught theCarry flag) 帶進位循環(huán)左移;
RR(Rotate Right) 循環(huán)右移;
RRC (Rotate Right throught the Carry flag) 帶進位循環(huán)右移;
SWAP (Swap) 低4位與高4位交換;
四、控制轉(zhuǎn)移類指令(17種助記符)
ACALL(Absolute subroutine Call)子程序絕對調(diào)用;
LCALL(Long subroutine Call)子程序長調(diào)用;
RET(Return from subroutine)子程序返回;
RETI(Return from Interruption)中斷返回;
SJMP(Short Jump)短轉(zhuǎn)移;
AJMP(Absolute Jump)絕對轉(zhuǎn)移;
LJMP(Long Jump)長轉(zhuǎn)移;
CJNE (Compare Jump if Not Equal)比較不相等則轉(zhuǎn)移;
DJNZ (Decrement Jump if Not Zero)減1后不為0則轉(zhuǎn)移;
JZ (Jump if Zero)結(jié)果為0則轉(zhuǎn)移;
JNZ (Jump if Not Zero) 結(jié)果不為0則轉(zhuǎn)移;
JC (Jump if the Carry flag isset)有進位則轉(zhuǎn)移;
JNC (Jump if Not Carry)無進位則轉(zhuǎn)移;
JB (Jump if the Bit is set)位為1則轉(zhuǎn)移;
JNB (Jump if the Bit is Not set) 位為0則轉(zhuǎn)移;
JBC(Jump if the Bit is set andClear the bit) 位為1則轉(zhuǎn)移,并清除該位;
NOP (No Operation) 空操作;
五、位操作指令(1種助記符)
CLR  位清零;
SETB(Set Bit) 位 置1 。
8種常用偽指令
1.ORG   16位地址 ;
此指令用在原程序或數(shù)據(jù)塊的開始,指明此語句后面目標(biāo)程序或數(shù)據(jù)塊存放的起始地址。
2.[標(biāo)號:] DB 字節(jié)數(shù)據(jù)項表;
將項表中的字節(jié)數(shù)據(jù)存放到從標(biāo)號開始的連續(xù)字節(jié)單元中。例如:SEG: DB 88H,100,“7”,“C”
3.[標(biāo)號:]DW   雙字節(jié)數(shù)據(jù)項表;
定義16位地址表,16地址按低位地址存低位字節(jié),高位地址存高位字節(jié)。
例如:TAB: DW  1234H,7BH
4.名字 EQU 表達式  或名字=表達式;
用與給一個表達式賦值或給字符串起名字。之后名字可用做程序地址,數(shù)據(jù)地址或立即數(shù)地址使用。名字必須是一字母開頭的字母數(shù)字串。
例如:COUNT=10 或 SPACE  EQU  10H
5.名字 DATA 直接字節(jié)地址;
給8位內(nèi)部RAM單元起個名字,名字必須是一字母開頭的字母數(shù)字串。同一單元可起多個名字。
例如:ERROR DATA  80H
6.名字 XDATA 直接字節(jié)地址;
給8位外部RAM起個名字,名字規(guī)定同DATA偽指令。
例如:IO_PORT XDATA  0CF04H
7.名字 BIT 位指令;
給一可位尋址的位單元起個名字,規(guī)定同DATA偽指令。
例如:SWT BIT 30H
8.[標(biāo)號:]。牛危模
指出源程序到此結(jié)束,匯編對其后的程序語句不予理睬。源程序只在主程序最后使用一個END。
指 令 集(111條)
助 記 符
說明
字節(jié)
周期
代 碼
1.數(shù)據(jù)傳送指令(30條)
  MOV  A,Rn
  寄存器送 A
  1
  1
  E8--EF
  MOV  A,data
  直接字節(jié)送A
  2
  1
  E5
  MOV  A,@Ri
  間接RAM 送A
  1
  1
  E6--E7
  MOV  A,#data
  立接數(shù)送 A
  2
  1
  74
  MOV  Rn,A
  A  送寄存器
  1
  1
  F8--FF
  MOV  Rn,data
  直接數(shù)送寄存器
  2
  2
  A8--AF
  MOV  Rn,#data
  立即數(shù)送寄存器
  2
  1
  78--7F
  MOV  data,A
  A  送直接字節(jié)
  2
  1
  F5
  MOV  data,Rn
  寄存器送直接字節(jié)
  2
  1
  88—8F
  MOV  data,data
  直接字節(jié)送直接字節(jié)
  3
  2
  85
  MOV  data,@Ri
  間接 Rn 送直接字節(jié)
  2
  2
  86;87
  MOV  data,#data
  立即數(shù)送直接字節(jié)
  3
  2
  75
  MOV  @Ri,A
  A  送間接 Rn
  1
  2
  F6;F7
  MOV  @Ri,data
  直接字節(jié)送間接Rn
  1
  1
  A6;A7
  MOV  @Ri,#data
  立即數(shù)送間接 Rn
  2
  2
  76;77
  MOV  DPTR,#data16
  16  位常數(shù)送數(shù)據(jù)指針
  3
  1
  90
  MOV  C,bit
  直接位送進位位
  2
  1
  A2
  MOV  bit,C
  進位位送直接位
  2
  2
  92
  MOVC  A,@A+DPTR
  A+DPTR  尋址程序存貯字節(jié)送 A
  3
  2
  93
  MOVC  A,@A+PC
  A+PC  尋址程序存貯字節(jié)送A
  1
  2
  83
  MOVX  A,@Ri
  外部數(shù)據(jù)送A(8 位地址)
  1
  2
  E2;E3
  MOVX  A,@DPTR
  外部數(shù)據(jù)送A(16 位地址)
  1
  2
  E0
  MOVX  @Ri,A
  A  送外部數(shù)據(jù)(8  位地址)
  1
  2
  F2;F3
  MOVX  @DPTR,A
  A  送外部數(shù)據(jù)(16  位地址)
  1
  2
  F0
  PUSH  data
  直接字節(jié)進棧道,SP 加1
  2
  2
  C0
  POP  data
  直接字節(jié)出棧,SP 減1
  2
  2
  D0
  XCH  A,Rn
  寄存器與 A 交換
  1
  1
  C8—CF
  XCH  A,data
  直接字節(jié)與A 交換
  2
  1
  C5
  XCH  A,@Ri
  間接Rn 與A 交換
  1
  1
  C6;C7
  XCHD  A,@Ri
  間接Rn 與A 低半字節(jié)交換
  1
  1
  D6;D7
2.邏輯運算指令(35條)
  ANL  A,Rn
  寄存器與到A
  1
  1
  58—5F
  ANL  A,data
  直接字節(jié)與到A
  2
  1
  55
  ANL  A,@Ri
  間接RAM與到A
  1
  1
  56;57
  ANL  A,#data
  立即數(shù)與到A
  2
  1
  54
  ANL  data,A
  A與到直接字節(jié)
  2
  1
  52
  ANL  data,#data
  立即數(shù)與到直接字節(jié)
  3
  2
  53
  ANL  C,bit
  直接位與到進位位
  2
  2
  82
  ANL  C,/bit
  直接位的反碼與到進位位
  2
  2
  B0
  ORL  A,Rn
  寄存器或到A
  1
  1
  48—4F
  ORL  A,data
  直接字節(jié)或到A
  2
  1
  45
  ORL  A,@Ri
  間接RAM或到A
  1
  1
  46;47
  ORL  A,#data
  立即數(shù)或到A
  2
  1
  44
  ORL  data,A
  A或到直接字節(jié)
  2
  1
  42
  ORL  data,#data
  立即數(shù)或到直接字節(jié)
  3
  2
  43
  ORL  C,bit
  直接位或到進位位
  2
  2
  72
  ORL  C,/bit
  直接位的反碼或到進位位
  2
  2
  A0
  XRL  A,Rn
  寄存器異或到A
  1
  1
  68—6F
  XRL  A,data
  直接字節(jié)異或到A
  2
  1
  65
  XRL  A,@Ri
  間接RAM異或到A
  1
  1
  66;67
  XRL  A,#data
  立即數(shù)異或到A
  2
  1
  64
  XRL  data,A
  A異或到直接字節(jié)
  2
  1
  62
  XRL  data,#data
  立即數(shù)異或到直接字節(jié)
  3
  2
  63
  SETB  C
  進位位置 1
  1
  1
  D3
  SETB  bit
  直接位置 1
  2
  1
  D2
  CLR  A
  A清0
  1
  1
  E4
  CLR  C
  進位位清 0
  1
  1
  C3
  CLR  bit
  直接位清 0
  2
  1
  C2
  CPL  A
  A求反碼
  1
  1
  F4
  CPL  C
  進位位取反
  1
  1
  B3
  CPL  bit
  直接位取反
  2
  1
  B2
  RL  A
  A循環(huán)左移一位
  1
  1
  23
  RLC  A
  A  帶進位左移一位
  1
  1
  33
  RR  A
  A右移一位
  1
  1
  03
  RRC  A
  A  帶進位右移一位
  1
  1
  13
  SWAP  A
  A  半字節(jié)交換
  1
  1
  C4
3.算術(shù)運算指令(24條)
  ADD  A,Rn
  寄存器加到A
  1
  1
  28—2F
  ADD  A,data
  直接字節(jié)加到A
  2
  1
  25
  ADD  A,@Ri
  間接RAM 加到A
  1
  1
  26;27
  ADD  A,#data
  立即數(shù)加到A
  2
  1
  24
  ADDC  A,Rn
  寄存器帶進位加到 A
  1
  1
  38—3F
  ADDC  A,data
  直接字節(jié)帶進位加到A
  2
  1
  35
  ADDC  A,@Ri
  間接RAM 帶進位加到A
  1
  1
  36;37
  ADDC  A,#data
  立即數(shù)帶進位加到 A
  2
  1
  34
  SUBB  A,Rn
  從A 中減去寄存器和進位
  1
  1
  98—9F
  SUBB  A,data
  從A 中減去直接字節(jié)和進位
  2
  1
  95
  SUBB  A,@Ri
  從A 中減去間接RAM 和進位
  1
  1
  96;97
  SUBB  A,#data
  從A 中減去立即數(shù)和進位
  2
  1
  94
  INC  A
  A加1
  1
  1
  04
  INC  Rn
  寄存器加 1
  1
  1
  08—0F
  INC  data
  直接字節(jié)加1
  2
  1
  05
  INC  @Ri
  間接RAM 加1
  1
  1
  06;07
  INC  DPTR
  數(shù)據(jù)指針加1
  1
  2
  A3
  DEC  A
  A減1
  1
  1
  14
  DEC  Rn
  寄存器減 1
  1
  1
  18—1F
  DEC  data
  直接字節(jié)減1
  2
  1
  15
  DEC  @Ri
  間接RAM 減1
  1
  1
  16;17
  MUL  AB
  A乘B
  1
  4
  A4
  DIV  AB
  A被B除
  1
  4
  84
  DA  A
  A十進制調(diào)整
  1
  1
  D4
  4.轉(zhuǎn)移指令(22條)
  AJMP  addr 11
  絕對轉(zhuǎn)移
  2
  2
  *1
  LJMP  addr 16
  長轉(zhuǎn)移
  3
  2
  02
  SJMP  rel
  短轉(zhuǎn)移
  2
  2
  80
  JMP  @A+DPTR
  相對于DPTR 間接轉(zhuǎn)移
  1
  2
  73
  JZ  rel
  若A=0 則轉(zhuǎn)移
  2
  2
  60
  JNZ  rel
  若A≠0 則轉(zhuǎn)移
  2
  2
  70
  JC  rel
  若C=1 則轉(zhuǎn)移
  2
  2
  40
  JNC  rel
  若C≠1 則轉(zhuǎn)移
  2
  2
  50
  JB  bit,rel
  若直接位=1 則轉(zhuǎn)移
  3
  2
  20
  JNB  bit,rel
  若直接位=0 則轉(zhuǎn)移
  3
  2
  30
  JBC  bit,rel
  若直接位=1 則轉(zhuǎn)移且清除
  3
  2
  10
  CJNE  A,data,rel
  直接數(shù)與 A 比較,不等轉(zhuǎn)移
  3
  2
  B5
  CJNE  A,#data,rel
  立即數(shù)與 A 比較,不等轉(zhuǎn)移
  3
  2
  B4
  CJNE  @Ri,#data,rel
  立即數(shù)與間接RAM比較,不等轉(zhuǎn)移
  3
  2
  B6;B7
  CJNE  Rn,#data,rel
  立即數(shù)與寄存器比較不等轉(zhuǎn)移
  3
  2
  B8—BF
  DJNZ  Rn,rel
  寄存器減 1 不為0 轉(zhuǎn)移
  2
  2
  D8—DF
  DJNZ  data,rel
  直接字節(jié)減1 不為 0 轉(zhuǎn)移
  3
  2
  D5
  ACALL  addr 11
  絕對子程序調(diào)用
  2
  2
  *1
  LCALL  addr 16
  子程序調(diào)用
  3
  2
  12
  RET
  子程序調(diào)用返回
  1
  2
  22
  RETI
  中斷程序調(diào)用返回
  1
  2
  32
  NOP
  空操作
  1
  1
  00
六.記憶方法
MCS-51使用匯編語言指令,它共有44個操作碼助記符,33種功能,
其操作數(shù)有#data、direct、Rn、@Ri等。這里先介紹指令助記符及其相關(guān)符號的記憶方法。
一、助記符號的記憶方法
1
表格列舉法
把44個指令助記符按功能分為五類,每類列表記憶。此處從略,請讀者自己總結(jié)。
2
英文還原法
單片機的操作碼助記符是該指令功能的英文縮寫,將縮寫還原成英語原文,再對照漢
語有助于理解其助記符含義,從而加強記憶。例如:
增量 INC-Incremect 減量 DNC-Decrement
短轉(zhuǎn)移 SJMP-Short jump 長轉(zhuǎn)移 LJMP-Long jump
比較轉(zhuǎn)移 CJNE-Compare jump not equality
絕對轉(zhuǎn)移 AJMP-Absolute jump 空操作 NOP-No operation
交換 XCH-Exchange 加法 ADD-Addition
乘法 MUL-Multiplication 除法 DIV-Division
左環(huán)移 RL-Rotate left 進位左環(huán)移 RLC-Rotate
left carry
右環(huán)移 RR-Rotate right 進位右環(huán)移RRC-Rotate
right carry
3
功能模塊記憶法
單片機的44個指令助記符,按所屬指令功能可分為五大類,每類又可以按功能相似原
則為2~3組。這樣,化整為零,各個擊破,實現(xiàn)快速記憶。
1
)數(shù)據(jù)傳送組。 2)加減運算組
MOV
內(nèi)部數(shù)據(jù)傳送 ADD 加法
MOVC
程序存儲器傳送 ADDC 帶進位加法
MOVX
外部數(shù)據(jù)傳送 SUBB 帶進位減法
3
)邏輯運算組。 4)子程序調(diào)用組。
ANL
邏輯與 LCALL 長調(diào)用
ORL
邏輯或 ALALL 絕對調(diào)用
XRL
邏輯異或 RET 子程序返回
二、指令的記憶方法
1
指令操作數(shù)的有關(guān)符號
MCS
-51的尋址方式共有六種:立即數(shù)尋址、直接尋址、寄存器尋址、寄存器間址、變
址尋址、相對尋址。我們必須掌握其表示的方法。
1
)立即數(shù)與直接地址。ata表示八位立即數(shù),#data16表示是十六位立即數(shù),data或
direct
表示直接地址。
2
)Rn(n=0-7)、A、B、CY、DPTR寄存器尋址變量。
3
)@R0、@R1、@DPTR、SP表示寄存器間址變量。
4
)DPTR+A、PC+A表示變址尋址的變量。
5
)PC+rel(相對量)表示相對尋址變量。
記住指令的助記符,掌握不同尋址方式的指令操作數(shù)的表示方法,為我們記憶匯編指
令打下了基礎(chǔ)。MCS-51指令雖多,但按功能可分為五類,
其中數(shù)據(jù)傳送類28條,算術(shù)運算類24條,邏輯操作類25條,控制轉(zhuǎn)移類17條,布爾位操作
類17條。在每類指令里,根據(jù)其功能,抓住其源、
目的操作數(shù)的不同組合,再輔之以下方法,是完全能記住的。
我們約定,可能的目的操作數(shù)按(#data/direct/A/Rn/@Ri)順序表示。
對于MOV指令,其目的操作數(shù)按A、Rn、direct、@Ri的順序書寫,則可以記住MOV的15
條指令。例如以累加器A為目的操作數(shù),可寫出如下4條指令。
MOV A
,#data/direct/A/Rn/@Ri
以此類推,寫出其它指令。
MOV Rn
,#data/direct/A
MOV direct
MOV @Ri
,#data/direct/A
2
指令圖示記憶法
圖示記憶法是把操作功能相同或相似、但其操作數(shù)不同的指令,用圖形和箭頭將目
的、源操作數(shù)的關(guān)系表示出來的一種記憶方法。
例如:由助記符MOV、MOVX、MOVC組成的送數(shù)組指令,可以用圖1、2幫助記憶。
由助記符CJNE形成的四條指令,也可以用圖示法表示,如圖3。
CJNE A
,#data,rel CJNE A,direct,rel
CJNE @Rn
,#data,rel CJNE @Ri,#data,rel
另外,對于由(ANL、ORL、ARL)形成的18條邏輯操作指令,有關(guān)A的四條環(huán)移指令,
也可以用圖示法表示,請讀者自行畫出記憶。
3
相似功能歸類法
在MCS-51指令中,我們發(fā)現(xiàn)部分指令其操作碼不同,但功能相似,而操作數(shù)則完全一
樣。相似功能歸類法就是把具有這樣特點的指令放在一起記憶,
只要記住其中的一條,其余的也就記住了。如加、減法的十二條指令,與、或、非的十八
條指令,現(xiàn)列舉如下。
ADD/ADDC/SUBB A
,#data/direct/Rn/@Ri
ANL/ORL/XRL A
ANL/ORL/XRL direct
,#data/a
上述每一排指令,功能相似,其操作數(shù)都相同。其它的如加1(INC)、減1(DEC)指令也
可照此辦理。
4
口訣記憶法
對于有些指令,我們可以把相關(guān)的功能用精練的語言編成一句話來記憶。如PUSH
direct
和POP direct這兩條指令。
初學(xué)者常常分不清堆棧SP的變化情況,為此編成這樣一句話:(SP的內(nèi)容)加1(direct的內(nèi)
容)再入棧,(SP的內(nèi)容)彈出(到direct單元)SP才減1。
又如乘法指令中積的存放,除法指令中被除數(shù)和除數(shù)以及商的存放,都可以編成口訣記憶
如下。
MUL AB
高位積(存于)B,低位積(存于)A。
DIV AB A
除以B,商(存于)A余(下)B。
上面介紹了幾種快速記憶單片機指令的方法,希望能起到拋磚引玉的作用,相信讀者
在學(xué)習(xí)單片機的過程中能找到適合自己的方法來記憶。
但是,有了好的方法還不夠,還需要實踐,即多讀書上的例題和別人編寫的程序,自己再
結(jié)合實際編寫一些程序。只有這樣,
才能更好更快地掌握單片機指令系統(tǒng)。
以上圖文的Word格式文檔下載(內(nèi)容和本網(wǎng)頁上的一模一樣,方便保存):
51單片機匯編指令集(附記憶方法) (1).doc (134.06 KB, 下載次數(shù): 62)
admin + 50 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂1 踩
ID:975745 發(fā)表于 2021-10-28 17:03 | 只看該作者
很好的文章,可以下載嗎。
ID:624685 發(fā)表于 2021-10-28 20:09 | 只看該作者
收藏了,匯編還沒學(xué),以后慢慢學(xué)
無效樓層,該帖已經(jīng)被刪除
