電路介紹:
1.此項目采用51單片機實現(xiàn)音樂盒的功能,同時電路中采用模擬示波器,可以實時查看波形的變動。
2.通過一個可調(diào)電阻實現(xiàn)音頻信號的音量大小
3.基于8歐姆/1w的喇叭作為音頻輸出部件
proteus仿真原理圖:
源代碼:
- #include<reg52.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- sbit SPK = P2^7;
- uchar tone_h; //高音
- uchar tone_l; //低音
- uint note = 1; //音符
- uchar beat; //節(jié)拍
- uchar code chuzhi[3][16]={ //音調(diào)對應的計數(shù)初值
- 0xff,0xff,//占0位
- 0xf8,0x8c,//低1
- 0xf9,0x5b,// 2
- 0xfa,0x15,// 3
- 0xfa,0x67,// 4
- 0xfb,0x04,// 5
- 0xfb,0x90,// 6
- 0xfc,0x0c,//低7
- 0xff,0xff,//占0位
- 0xfc,0x44,//中1
- 0xfc,0xac,// 2
- 0xfd,0x09,// 3
- 0xfd,0x34,// 4
- 0xfd,0x82,// 5
- 0xfd,0xc8,// 6
- 0xfe,0x06,//中7
- 0xff,0xff,//占0位
- 0xfe,0x22,//高1
- 0xfe,0x56,// 2
- 0xfe,0x85,// 3
- 0xfe,0x9a,// 4
- 0xfe,0xc1,// 5
- 0xfe,0xe4,// 6
- 0xff,0x03 //高7
- //****** 測試曲譜 ****** 個位:音調(diào) ,十位:低中高音 對應 0 1 2,千百位:節(jié)拍 1~16
- uint code test2[] = { 120, //曲速 暫時未用到
- 401,402,403,404,405,406,407,
- 611,612,613,614,615,616,617,
- 821,822,823,824,825,826,827,
- 0xffff //0xffff表示結(jié)尾
- //****** 生日快樂 ******
- uint code test[] = { 120,
- 205,205,406,405,411,807,
- 205,205,406,405,412,811,
- 205,205,415,413,411,407,406,
- 314,114,413,411,413,812,
- 305,105,406,405,411,807,
- 305,105,406,405,412,811,
- 305,105,415,413,411,
- 407,406,314,114,413,411,412,811,410,
- 0xffff
- void delayms(uint ms) /*ms 等于1時,延時1ms 等于2時,延時2ms,以此類推*/
- uchar a,b,c; //+3
- while(ms--)
- for(c=1;c>0;c--) // 1+2 = 3
- for(b=142;b>0;b--) // 1*( 1+142*2)) = 285
- for(a=2;a>0;a--); // 142*(1+2*2) = 710
- void delay125ms(uint pai) //延時 ?*125ms 即?個節(jié)拍
- uchar a,b,c;
- while(pai--)
- for(c=239;c>0;c--)
- for(b=104;b>0;b--)
- for(a=1;a>0;a--);
- void timer0() interrupt 1
- TH0 = tone_h;
- TL0 = tone_l;
- SPK = ~SPK;
- void timer_init()
- EA = 1;
- ET0 = 1;
- PT0 = 1;
- TMOD = 0x11;
- TH0 = 255;
- TL0 = 255;
- void main()
- timer_init();
- note = 1;
- while(1)
- if(test[note] == 0xffff)
- note = 1;
- if(test[note]%10 != 0) //音調(diào)不為0 【音調(diào)為0時表示不發(fā)聲,但有節(jié)拍】
- tone_h = TH0 = chuzhi[test[note]%100/10][(test[note]%10)*2 ]; //音調(diào)高位 【二維數(shù)組 第1維表示低中高音,第二維表示音調(diào)】
- tone_l = TL0 = chuzhi[test[note]%100/10][(test[note]%10)*2 + 1]; //音調(diào)低位
- TR0 = 1;
- delay125ms(test[note]/100); //節(jié)拍
- TR0 = 0;
- delayms(30);
- note++; //下一個音符
復制代碼
全部資料(壓縮包)下載:
原理圖和源代碼.rar
(40.6 KB, 下載次數(shù): 239)
2016-6-6 20:46 上傳
點擊文件名下載附件
