查看: 5205|回復(fù): 0
MSP430讀取ADC0832并LCD1602顯示
ID:3721 發(fā)表于 2016-6-13 14:27 | 顯示全部樓層 |閱讀模式
#include "io430.h"
unsigned char tb1[]=" Power:";
unsigned char tb2[]="Volt";
unsigned char tb3[]="   low Power";
unsigned char tb4[]="   Power Full";
unsigned char tb5[]=" percent:";
//      P1=dat; rs=P2.4,e=P2.5                 /////
//   ADC0832: CLK=P2.0;DI=P2.1;             ////
//      DO=P2.2;   CS=P2.3                         ////
void w1602(unsigned char t,unsigned char dat)
  char n;
  if(t==0)
    P2OUT &=~BIT4;
    P2OUT |=BIT4;
  P1OUT =dat;
  P2OUT &=~BIT5;
  n=5;
  while(n--);
  P2OUT |=BIT5;
  n=10;
  while(n--);
  P2OUT &=~BIT5;
unsigned char rADC0832()
  unsigned char temp=0,k;
  P2OUT |=BIT3;
   __no_operation();
  P2OUT &=~BIT3;  //start
  P2OUT &=~BIT0;
  __no_operation();
  P2OUT |=BIT1;
  __no_operation();
  P2OUT |=BIT0;
  __no_operation();//DI=1
  P2OUT &=~BIT0;
  __no_operation();
  P2OUT |=BIT0;
  __no_operation(); //DI=1
  P2OUT &=~BIT0;
  P2OUT &=~BIT1;
  __no_operation();
  P2OUT |=BIT0;
  P2OUT &=~BIT0;
  __no_operation();
  P2OUT |=BIT0;
  P2OUT &=~BIT0;
  for(k=0;k<8;k++)
     temp=temp<<1;
     P2OUT |=BIT0;
     if(P2IN & BIT2)temp |=0x01;
     P2OUT &=~BIT0;
  return temp;
void init1602()
  w1602(0,0x38);
  w1602(0,0x06);
  w1602(0,0x0c);
  w1602(0,0x01);
int main( void )
  // Stop watchdog timer to prevent time out reset
  WDTCTL = WDTPW + WDTHOLD;
  unsigned int d,d1,dd;
  P1DIR =0xff;
  P2DIR =0x3B;
  //P2REN |=BIT2;
  P2OUT |=BIT2;
  init1602();
        d=196 * rADC0832();//25000(3V=153(29988) 3.7=189(37)
        dd=100*(rADC0832()-153)/36;
        w1602(0,0x80);
        for(d1=0;d1<7;d1++)
          w1602(1,tb1[d1]);
        w1602(1,(d/10000)+0x30);
        w1602(1,0x2E);
        w1602(1,(d%10000)/1000+0x30);
        w1602(1,((d%10000)%1000)/100+0x30);
        for(d1=0;d1<4;d1++)
          w1602(1,tb2[d1]);
        w1602(1,0x20);
        w1602(1,0x20);
        w1602(0,0xc0);
        if(d<29988)
                for(d1=0;d1<12;d1++)
                w1602(1,tb3[d1]);
                w1602(1,0x20);
                w1602(1,0x20);
                w1602(1,0x20);
                w1602(1,0x20);
             if(d>37044)
                   for(d1=0;d1<13;d1++)
                       w1602(1,tb4[d1]);
                   w1602(1,0x20);
                   w1602(1,0x20);
                   w1602(1,0x20);
                   for(d1=0;d1<9;d1++)
                       w1602(1,tb5[d1]);
                   if((dd/10)==0)
                     w1602(1,0x20);
                      w1602(1,dd/10+0x30);
                   w1602(1,dd%10+0x30);
                   w1602(1,0x25);
                   w1602(1,0x20);
                   w1602(1,0x20);
                   w1602(1,0x20);
                   w1602(1,0x20);
ADC0832的時(shí)序圖詳解:http://www.torrancerestoration.com/bbs/dpj-51688-1.html
