查看: 3916|回復(fù): 1
開(kāi)玩笑小程序
ID:127496 發(fā)表于 2016-6-21 01:20 | 顯示全部樓層 |閱讀模式
這兒有一些“開(kāi)玩笑”小程序。
代碼是我自己寫的。如要轉(zhuǎn)載,可不注明出處。
廢話不多說(shuō),開(kāi)始啦
第一個(gè):
on error resume next
const pmm="密碼你自己設(shè)定"
dim ab
ab=false
ppo=MsgBox ("接下來(lái),請(qǐng)?jiān)?44秒內(nèi)連續(xù)按“確定”一千次,否則,你的電腦會(huì)關(guān)機(jī)……",VbInformation+vbyesno)
if ppo=vbNo then
    mm=inputbox("輸入密碼,就可取消","pass","密碼")
    if mm=pmm then
        msgbox "正確"
        ab=true
    end if
    msgbox "密碼錯(cuò)誤!"
end if
dim WSHshellA
set WSHshellA = wscript.createobject("wscript.shell")
WSHshellA.run "cmd.exe /c shutdown -r -t 444 -c ""請(qǐng)?jiān)谑O碌拿雰?nèi)連續(xù)按“確定”一千次,否則就會(huì)關(guān)機(jī)。嘿嘿!"" ",0 ,true
Dim a
a = 0
Do While a < 1000
    if ab=true then
        dim WSHshell
        set WSHshell = wscript.createobject("wscript.shell")
        WSHshell.run "cmd.exe /c shutdown -a",0 ,true
        exit do
    end if
    a = a + 1
    b = 1000-a
    MsgBox "第" & a & "次,加油,還有"& b &"次",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal,"加油"
Loop
msgbox "恭喜你成功了!"
'===============================到此為止(這行不要)========================
把以上代碼寫到記事本里,然后保存為VBS的擴(kuò)展名(*.vbs)
效果你最好別自己試,否則……你的手說(shuō)不定抽筋呢……
第二個(gè):
dim WSHshellA
WSHshellA.run "cmd.exe /c shutdown -r -t 60 -c ""說(shuō)我是豬,不說(shuō)“我是豬”就會(huì)關(guān)機(jī),不信……試下。"" ",0 ,true
dim a
do while(a <> "我是豬")
a = inputbox ("說(shuō)我是豬,就可以不關(guān)機(jī),快點(diǎn),說(shuō) ""我是豬"" ","好好考慮吧……","你才是",8000,7000)
if a="你才是"then
  if df<>"yes" then
   dim df
   df="yes"
   msgbox "敢罵我,你再罵一次試看看!",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
   msgbox "好哇,天堂有路你不走,關(guān)機(jī)無(wú)門你偏來(lái),關(guān)機(jī)吧~~~",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
   WSHshellA.run "cmd.exe /c shutdown -r -t 0 -c ""說(shuō)我是豬,不說(shuō)“我是豬”就會(huì)關(guān)機(jī),不信……試下。"" ",0 ,true
  end if
end if
loop
dim WSHshell
msgbox chr(13) + "早說(shuō)不就行了嘛",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
msgbox chr(13) + "哈哈哈哈,人才,人才呀",vbApplicationModa+VbMsgBoxSetFore+vbSystemModal
一樣的,保存擴(kuò)展名為“vbs”(*.vbs)
第三個(gè),是相當(dāng)于鑰匙,運(yùn)行后能停止關(guān)機(jī)倒計(jì)時(shí):
dim WSHshell
msgbox "成功解除!",VbInformation,"信息"
好了,文章結(jié)束,大家記住啊,玩笑可別開(kāi)的過(guò)火了啊
ID:110225 發(fā)表于 2016-11-10 19:01 | 顯示全部樓層
保存成*.vbs就可以運(yùn)行了嗎?
