為什么段選中加入delay運行會出錯?求解惑在子函數(shù)void sanmiao(uchar bai,uchar shi,uchar ge)中加注釋的地方
#include <reg52.h>
uchar t = 0;
uchar bai,shi,ge;
sbit dula = P2^6;
sbit wela = P2^7;
void delay(uint z);
void sanmiao(uchar bai,uchar shi,uchar ge);
uchar code table[]={
0x3f, 0x06, 0x5b, 0x4f, 0x66, 0x6d,
0x7d, 0x07, 0x7f, 0x6f, 0x77, 0x7c,
0x39, 0x5e, 0x79, 0x71
void main(void)
uchar temp = 0;
wela = 0;
dula = 0;
TMOD = 0X01;
TH0 = (65536-50000)/256;
TL0 = (65536-50000)%256;
TR0 = 1;
ET0 = 1;
EA = 1;
if(t == 20)
t = 0;
temp++;
if (temp == 100)
temp = 0;
bai = temp/100;
shi = temp%100/10;
ge = temp%10;
sanmiao(bai,shi,ge);
void delay(uint z)//延時程序
uchar i,j;
for(i=z;i>0;i--)
for(j=110;j>0;j--);
//顯示動態(tài)掃描三個數(shù)碼管
dula = 1;
P0 = table[bai];
dula = 0;
//delay(1); //段選加上延時函數(shù)后為什么會出錯??
wela = 1;
P0 = 0xfe;
wela = 0;
delay(5);
dula = 1;
P0 = table[shi];
dula = 0;
//delay(1);
wela = 1;
P0 = 0xfd;
wela = 0;
delay(5);
dula = 1;
P0 = table[ge];
dula = 0;
//delay(1);
wela = 1;
P0 = 0xfb;
wela = 0;
delay(5);
void timer0() interrupt 1
t++;
