#include<reg52.h>
#include<intrins.h>
/*DS1302 端口設(shè)置 */
sbit SCK=P3^6; //DS1302時鐘
sbit SDA=P3^4; //DS1302 IO
sbit RST= P3^5; // DS1302復位
bit ReadRTC_Flag; //讀DS1302全局變量
/* 12864端口定義*/
#define LCD_data P0 //帶字庫液晶12864數(shù)據(jù)口
sbit LCD_RS = P2^4; //寄存器選擇輸入
sbit LCD_RW = P2^5; //液晶讀/寫控制
sbit LCD_EN = P2^6; //液晶使能控制
sbit PSB=P2^1; //并口控制
sbit RES=P2^7;
uchar code dis1[] = {" 電子設(shè)計天地 "}; //液晶顯示的漢字
uchar code dis2[] = {"有志者,事竟成!"};
uchar code dis4[] = {'0','1','2','3','4','5','6','7','8','9'};
unsigned char temp;
#define delayNOP() {_nop_();_nop_();_nop_();_nop_();};
void lcd_pos(uchar X,uchar Y); //確定顯示位置
unsigned char l_tmpdate[7]={0,7,16,19,10,1,9};//秒分時日月周年09-10-1916:07:00
code unsigned char write_rtc_address[7]={0x80,0x82,0x84,0x86,0x88,0x8a,0x8c}; //秒分時日月周年 最低位讀寫位
code unsigned char read_rtc_address[7]={0x81,0x83,0x85,0x87,0x89,0x8b,0x8d};
void Write_Ds1302_byte(unsigned char temp);
void Write_Ds1302( unsigned char address,unsigned char dat );
unsigned char Read_Ds1302 ( unsigned char address );
void Read_RTC(void);//read RTC
void Set_RTC(void); //set RTC
void InitTIMER0(void);//inital timer0
/* 延時函數(shù) */
void delay(unsigned int m) //延時程序
unsigned int i,j;
for(i=0;i<m;i++)
for(j=0;j<10;j++);
/*檢查LCD忙狀態(tài) */
/*lcd_busy為1時,忙,等待。lcd-busy為0時,閑,可寫指令與數(shù)據(jù)。 */
bit lcd_busy()
bit result;
LCD_RS = 0;
LCD_RW = 1;
LCD_EN = 1;
delayNOP();
result = (bit)(P0&0x80);
LCD_EN = 0;
return(result);
/*寫指令數(shù)據(jù)到LCD */
/*RS=L,RW=L,E=高脈沖,D0-D7=指令碼。 */
void lcd_wcmd(uchar cmd)
while(lcd_busy());
LCD_RS = 0;
LCD_RW = 0;
LCD_EN = 0;
_nop_();
_nop_();
P0 = cmd;
delay(1);
LCD_EN = 1;
delay(1);
LCD_EN = 0;
/*寫顯示數(shù)據(jù)到LCD */
/*RS=H,RW=L,E=高脈沖,D0-D7=數(shù)據(jù)。 */
void lcd_wdat(uchar dat)
while(lcd_busy());
LCD_RS = 1;
LCD_RW = 0;
LCD_EN = 0;
P0 = dat;
delayNOP();
LCD_EN = 1;
delay(1);
LCD_EN = 0;
/* LCD初始化設(shè)定 */
void lcd_init()
P0=0xFF;
P2=0xFF;
delay(40);
PSB=1; //并口方式。
delay(1);
RES=0;
delay(1);
RES=1;
delay(10);
lcd_wcmd(0x30);
delay(100);
lcd_wcmd(0x30);
delay(37);
lcd_wcmd(0x08);
delay(100);
lcd_wcmd(0x10);
delay(100);
lcd_wcmd(0x0c); //顯示開,關(guān)光標
delay(100);
lcd_wcmd(0x01); //清除LCD的顯示內(nèi)容
delay(100);
lcd_wcmd(0x06);
delay(100);
/* 設(shè)定顯示位置 */
uchar pos;
if (X==0)
{X=0x80;}
else if (X==1)
{X=0x90;}
else if (X==2)
{X=0x88;}
else if (X==3)
{X=0x98;}
pos = X+Y ;
lcd_wcmd(pos); //顯示地址
TMOD|=0x01;//定時器設(shè)置 16位
TH0=0xef;//初始化值
TL0=0xf0;
ET0=1;
TR0=1;
EA=1;
void Write_Ds1302_Byte(unsigned char temp)
unsigned char i;
for(i=0;i<8;i++) //循環(huán)8次 寫入數(shù)據(jù)
SCK=0;
SDA=temp&0x01; //每次傳輸?shù)妥止?jié)
temp>>=1; //右移一位
SCK=1;
RST=0;
_nop_();
SCK=0;
_nop_();
RST=1;
_nop_(); //啟動
Write_Ds1302_Byte(address); //發(fā)送地址
Write_Ds1302_Byte(dat); //發(fā)送數(shù)據(jù)
RST=0; //恢復
unsigned char i,temp=0x00;
RST=0;
_nop_();
SCK=0;
_nop_();
RST=1;
_nop_();
for (i=0;i<8;i++) //循環(huán)8次 讀取數(shù)據(jù)
if(SDA)
temp|=0x80; //每次傳輸?shù)妥止?jié)
SCK=0;
temp>>=1; //右移一位
SCK=1;
RST=0;
_nop_(); //以下為DS1302復位的穩(wěn)定時間
RST=0;
SCK=0;
_nop_();
SCK=1;
_nop_();
SDA=0;
_nop_();
SDA=1;
_nop_();
return(temp); //返回
void Read_RTC(void) //讀取 日歷
unsigned char i,*P;
P=read_rtc_address;//地址傳遞
for(i=0;i<7;i++) //分7次讀取 秒分時日月周年
l_tmpdate[i]=Read_Ds1302 (*P);
P++;
void Set_RTC(void) //設(shè)定 日歷
unsigned char i,*p,tmp;
for(i=0;i<7;i++)
{ //BCD處理
tmp=l_tmpdate[i]/10;
l_tmpdate[i]=l_tmpdate[i]%10;
l_tmpdate[i]=l_tmpdate[i]+tmp*16;
Write_Ds1302(0x8E,0X00);
p=write_rtc_address; //傳地址
for(i=0;i<7;i++) //7次寫入 秒分時日月周年
Write_Ds1302(*p,l_tmpdate[i]);
p++;
Write_Ds1302(0x8E,0x80);
void tim(void) interrupt 1 using 1//中斷,用于數(shù)碼管掃描
static unsigned char i,num;
TH0=0xf5;
TL0=0xe0;
//P0=table[l_tmpdisplay]; //查表法得到要顯示數(shù)字的數(shù)碼段
//P2=table1;
i++;
if(i==8)
i=0;
num++;
if(20==num) //隔段時間讀取1302的數(shù)據(jù)。時間間隔可以調(diào)整
ReadRTC_Flag=1; //使用標志位判斷
num=0;
uchar i;
InitTIMER0();
Set_RTC();
lcd_init();
delay(100);
//初始化LCD
if(ReadRTC_Flag)
ReadRTC_Flag=0;
Read_RTC();
lcd_pos(0,0); //設(shè)置顯示位置為第一行的第1個字符
i = 0;
while(dis1[i] != '\0')
{ //顯示字符
lcd_wdat(dis1[i]);
i++;
lcd_pos(1,0); //設(shè)置顯示位置為第二行的第1個字符
i = 0;
delay(10);
while(dis2[i] != '\0')
lcd_wdat(dis2[i]); //顯示字符
i++;
lcd_pos(2,0);
lcd_wdat(dis4[l_tmpdate[6]/16]); //DS1302是BCD碼,進行處理得到十位與個位數(shù)。
lcd_pos(2,1);
lcd_wdat(dis4[l_tmpdate[6]%16]);
lcd_pos(2,2);
lcd_wdat('-');
lcd_pos(2,3);
lcd_wdat(dis4[l_tmpdate[4]/16]);
lcd_pos(2,4);
lcd_wdat(dis4[l_tmpdate[4]%16]);
lcd_pos(2,5);
lcd_wdat('-');
lcd_pos(2,6);
lcd_wdat(dis4[l_tmpdate[3]/16]);
lcd_pos(2,7);
lcd_wdat(dis4[l_tmpdate[3]%16]); //設(shè)置顯示位置為第三行的第1個字符
lcd_pos(3,0); //設(shè)置顯示位置為第四行的第1個字符
lcd_wdat(dis4[l_tmpdate[2]/16]);
lcd_pos(3,1);
lcd_wdat(dis4[l_tmpdate[2]%16]);
lcd_pos(3,2);
lcd_wdat(':');
lcd_pos(3,3);
lcd_wdat(dis4[l_tmpdate[1]/16]);
lcd_pos(3,4);
lcd_wdat(dis4[l_tmpdate[1]%16]);
lcd_pos(3,5);
lcd_wdat(':');
lcd_pos(3,6);
lcd_wdat(dis4[l_tmpdate[0]/16]);
lcd_pos(3,7);
lcd_wdat(dis4[l_tmpdate[0]%16]);
