ADXL345怎么才能進(jìn)入自動(dòng)休眠 下面是我的程序,一直進(jìn)不了休眠,大神幫我看看:
Single_Write_ADXL345(POWER_CTL,0x00);
Single_Write_ADXL345(INT_ENABLE,0x00);
Single_Write_ADXL345(BW_RATE,0x08); //0000 0110速率設(shè)定為6.25 參考pdf13頁(yè)
Single_Write_ADXL345(DATA_FORMAT,0x2F); //測(cè)量范圍,正負(fù)16g,13位模式 0X2b D5=1,中斷設(shè)置為低電平有效
Single_Write_ADXL345(THRESH_ACT,0x01); //活動(dòng)閥值(xy)1000MG 62.5mg/L
Single_Write_ADXL345(THRESH_INACT,0x03); // 靜止閥值(xyz?)(根據(jù)實(shí)際調(diào)整) 時(shí)閾
Single_Write_ADXL345(TIME_INACT,0x03); //時(shí)閾 5s
// Single_Write_ADXL345(DUR,0xF0); //敲擊檢測(cè)時(shí)閾
Single_Write_ADXL345(ACT_INACT_CTL,0xEE); //0110 0110 直(交)流耦合 活動(dòng)檢測(cè)使能xy 靜止檢測(cè)使能XY
Single_Write_ADXL345(0x2F,0x10); //中斷引腳映射INT_MAP , 活動(dòng)中斷配置到INT2,靜止中斷到INT1
Single_Write_ADXL345(0x2E,0x18); //中斷使能 INT_ENABLLE
Single_Read_ADXL345(INT_SOURCE); //清零中斷
Single_Write_ADXL345(POWER_CTL,0x34); //電源設(shè)置 休眠使能 0x38 0x08 0x34
Single_Write_ADXL345(0x1E,0x00); //X 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
Single_Write_ADXL345(0x1F,0x00); //Y 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
Single_Write_ADXL345(0x20,0x05); //Z 偏移量 根據(jù)測(cè)試傳感器的狀態(tài)寫入pdf29頁(yè)
中斷發(fā)生后清除:
Single_Read_ADXL345(ACT_TAP_STATUS);
