* nrf905_reseive.c
* Created: 2016/7/17 11:18:37
* Author: Knight
#define F_CPU 8000000UL
#include <avr/io.h>
#include <avr/interrupt.h>
#include <util/delay.h>
#define TXEN_set PORTA|=(1<<PA7)//PA7
#define TXEN_clr PORTA&=~(1<<PA7)
#define PWR_set PORTA|=(1<<PA6)
#define PWR_clr PORTA&=~(1<<PA6)
#define CE_set PORTC|=(1<<PC7)
#define CE_clr PORTC&=~(1<<PC7)
#define AM (PINC&(1<<PC6))//PC6
#define DR (PINA&(1<<PA5))//PA5
#define CSN_clr PORTB&=~(1<<PB4)
#define CSN_set PORTB|=(1<<PB4)
#define CLK_H PORTB|=(1<<PB2)
#define CLK_L PORTB&=~(1<<PB2)
#define SID_H PORTB|=(1<<PB1)
#define SID_L PORTB&=~(1<<PB1)
uint buffer[4]={0x39,0x38,0x37,0x36};
uint i;
void write_hz(uchar *hz)
while(*hz!='\0')
write_data(*hz); //寫入漢字
hz++;
void send_byte(uchar byte)
uint i;
for (i=0;i<8;i++)
CLK_L;//低電平
if(byte&0x80)
SID_H; //為1 給1
SID_L; //為0 給0
CLK_H;//高電平
byte=byte<<1;
void write_com(uchar com)
send_byte(0xf8);//step 1
send_byte(0xf0&com);//step 2
send_byte(0xf0&(com<<4));//step 3
_delay_ms(10);
void write_data(uchar data)
send_byte(0xfa);
send_byte(0xf0&data);
send_byte(0xf0&(data<<4));
_delay_ms(10);
void lcd12864_init()
write_com(0x30);
_delay_ms(10);
write_com(0x0c);//整體和游標(biāo)顯示
_delay_ms(10);
write_com(0x01);
_delay_ms(10);
void SPI_Master_init()
SPCR=0x5c;//使能SPI,主機(jī)模式,2分頻
SPSR=0x00;
void spi_write(char wData)
SPDR = wData;
while(!(SPSR&(1<<SPIF)));
uchar spi_read(void)
return SPDR;
uint TX_RF[11]={0x00,//寫RF寄存器
0x4c,
0x0c,
0x44,//RXTX地址寬度
0x04,//RX32有效字節(jié)
0x04,//TX32有效字節(jié)
0xcc,
0xcc,
0xcc,
0xcc,
0x58//CRC16位效驗(yàn)允許
void nrf905_init()//RF寄存器的配置
PORTC&=~(1<<PC6);
PORTA&=~(1<<PA5);
PWR_set;
TXEN_set;//standby模式
CE_clr;
CSN_clr;
for(i=0;i<11;i++)
spi_write(TX_RF[i]);
CSN_set;
void RX_packet()
TXEN_clr;//接收模式
CE_set;
_delay_us(500);
i=10;
while(!AM)//地址匹配后進(jìn)入standby模式,開始接收數(shù)據(jù)
i--;
_delay_us(100);
if(i==0)break;
CE_clr;//進(jìn)入standby模式 !!�。。。。。。。。。。。。。。〗邮諗�(shù)據(jù)的時(shí)候是在哪個(gè)模式??
CSN_clr;
spi_write(0x24);//開始接收數(shù)據(jù)
for(i=0;i<4;i++)
buffer[i]=spi_read();write_data(9);//第二波的時(shí)候停在了這里!!讀905時(shí)停下
CSN_set;
while(!DR);//數(shù)據(jù)接收完成后置位DR
CE_clr;
void display()
for(i=0;i<4;i++)
write_data(buffer[i]);
int main(void)
DDRA=0xc0;//DDRA|=(1<<PA6)|(1<<PA7)|(0<<PA5);
DDRC|=(1<<PC7);DDRC&=~(1<<PC6);//DDRC|=(0<<PC6)|(1<<PC7);
DDRB=0xbf;//DDRB|=(1<<PB1)|(1<<PB2)|(1<<PB4)|(1<<PB5)|(0<<PB6)|(1<<PB7);
SPI_Master_init();
lcd12864_init();
nrf905_init();
write_com(0x80);
RX_packet();//停在這
display();
我試了下他只讀出一個(gè)值就停在那了,上面的spi_read();
怎么辦,大神們能看看嗎
