查看: 10317|回復(fù): 6
用DS1302與1602LCD設(shè)計的可調(diào)式電子日歷與時鐘 屏幕不顯示字符 求指導(dǎo)
ID:137190 發(fā)表于 2016-9-9 01:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
單片機源程序如下:
  1. #include<reg51.h>
  2. #include<string.h>
  3. #include<intrins.h>
  5. #define uint unsigned int
  6. sbit SDA=P1^0;                    //1302的IO口
  7. sbit CLK=P1^1;                   //1302的時鐘線
  8. sbit RST=P1^2;                   //1302的復(fù)位線
  9. sbit RS=P2^0;                   //1602寄存器選擇
  10. sbit RW=P2^1;                   //1602讀寫控制
  11. sbit E=P2^2;                        //1602的啟動
  12. sbit K1=P3^4;                        //調(diào)時選擇
  13. sbit K2=P3^5;                         //加
  14. sbit K3=P3^6;                          //減
  15. sbit K4=P3^7;                          //確定
  16. uchar tcount=0;
  17. uchar monthsdays[]={0,31,0,31,30,31,30,31,31,30,31,30,31};
  18. uchar*week[]={"SUN","MON","TUS","WEN","THU","FRI","SAT"};
  19. uchar LCD_buffer1[]={"DATE 00-00-00   "};
  20. uchar LCD_buffer2[]={"TIME 00-00-00   "};
  21. uchar datetime[7];
  22. char adjust_index=-1;
  23. uchar change_flag[]="-MHDM-Y";
  24. void delay(uint z);
  25. void set_ds1302();
  26. void gettime();
  27. uchar read_date(uchar addr);
  28. void write_ds1302(uchar addr,uchar dat);
  29. void write_a_byte_to_ds1302(uchar x);
  30. uchar get_a_byte_from_ds1302();
  31. uchar read1602state();
  32. void busy_wait();
  33. void write_date(uchar dat);
  34. void write_com(uchar cmd);
  35. void init_lcd1602();
  36. void set_weizhi(uchar p);
  37. void display_string(uchar p,uchar*s);
  38. void format_datetime(uchar d,uchar*a);
  39. uchar runnian(uint y);
  40. void refresh_week_day();
  41. void datetime_adjust(char x);
  42. /////////主程序
  43. void main()
  44. {
  45. init_lcd1602();
  46. IE=0x83;
  47. IP=0x01;
  48. IT0=1;
  49. TMOD=0X01;
  50. TH0=5000/256;
  51. TL0=5000%256;
  52. TR0=1;
  53. while(1)
  54. {
  55. if(adjust_index==-1)
  56. gettime();
  57. }
  58. }
  59. /////////////////延時
  60. void delay(uint z)
  61. {
  62. uchar i;
  63. while(z--)
  64. for(i=0;i<120;i++);
  65. }
  66. ////////////設(shè)置時間
  67. void set_ds1302()
  68. {
  69. uchar i;
  70. write_ds1302(0x8e,0x00);
  71. for(i=1;i<7;i++)
  72. {
  73. write_ds1302(0x80+2*i,(datetime[i]/10<<4)|(datetime[i]%10));
  74. }
  75. write_ds1302(0x8e,0x80);
  76. }
  77. /////////////讀取當(dāng)前日期時間
  78. void gettime()
  79. {
  80. uchar i;
  81. for(i=0;i<7;i++)
  82. {
  83. datetime[i]=read_date(0x81+2*i);
  84. }
  85. }
  86. /////////////從1302指定位置讀數(shù)
  87. uchar read_date(uchar addr)
  88. {
  89. uchar dat;
  90. RST=0;
  91. CLK=0;
  92. RST=1;
  93. write_a_byte_to_ds1302(addr);
  94. dat=get_a_byte_from_ds1302();
  95. CLK=1;
  96. RST=0;
  97. return dat;
  98. }
  99. //////////////向1302某地址寫數(shù)據(jù)
  100. void write_ds1302(uchar addr,uchar dat)
  101. {
  102. CLK=0;
  103. RST=1;
  104. write_a_byte_to_ds1302(addr);
  105. write_a_byte_to_ds1302(dat);
  106. CLK=0;
  107. RST=0;
  108. }
  109. /////////////向1302寫入一個字節(jié)
  110. void write_a_byte_to_ds1302(uchar x)
  111. {
  112. uchar i;
  113. for(i=0;i<8;i++)
  114. {
  115. SDA=x&0X01;
  116. CLK=1;
  117. CLK=0;
  118. x>>=1;
  119. }
  120. }
  121. /////////從1302中讀取一個字節(jié)
  122. uchar get_a_byte_from_ds1302()
  123. {
  124. uchar i,b=0x00;
  125. for(i=0;i<8;i++)
  126. {
  127. b=_crol_((uchar)SDA,i);
  128. CLK=1;
  129. CLK=0;
  130. }
  131. return b/16*10+b%16;
  132. }
  133. /////////讀1602狀態(tài)
  134. uchar read1602state()
  135. {
  136. uchar state;
  137. RS=0;
  138. RW=1;
  139. E=1;
  140. delay(1);
  141. state=P0;
  142. E=0;
  143. delay(1);
  144. return state;
  145. }
  146. //1602忙等待
  147. void busy_wait()
  148. {
  149. while((read1602state()&0x80)==0x80);
  150. delay(5);
  151. }
  152.   //向1602寫數(shù)據(jù)
  153.   void write_date(uchar dat)
  154.   {
  155.   busy_wait();
  156.   RS=1;
  157.   RW=0;
  158.   E=0;
  159.   P0=dat;
  160.   E=1;
  161.   delay(1);
  162.   E=0;
  163.   }
  164.   //////向1602寫指令
  165.   void write_com(uchar cmd)
  166.   {
  167.   busy_wait();
  168.   RS=0;
  169.   RW=0;
  170.   E=0;
  171.   P0=cmd;
  172.   delay(1);
  173.   E=0;
  174.   }
  175.   ///1602初始化
  176.   void init_lcd1602()
  177.   {
  178.   write_com(0x38);
  179.   delay(1);
  180.   write_com(0x01);
  181.   delay(1);
  182.   write_com(0x06);
  183.   delay(1);
  184.   write_com(0x0c);
  185.   delay(1);
  186.   }
  187.   //設(shè)置1602顯示位置
  188.   void set_weizhi(uchar p)
  189.   {
  190.   write_com(p|0x80);
  191.   }
  192.   void display_string(uchar p,uchar*s)
  193.   {
  194.   uchar i;
  195.   set_weizhi(p);
  196.   for(i=0;i<16;i++)
  197.   {
  198.   write_date(s[i]);
  199.   delay(1);
  200.   }
  201.   }
  202.   //日期 時間值轉(zhuǎn)化為數(shù)字字符
  203.   void format_datetime(uchar d,uchar*a)
  204.   {
  205.   a[0]=d/10+'0';
  206.   a[1]=d%10+'0';
  207.   }
  208.   ///判斷閏年
  209.   uchar runnian(uint y)
  210.   {
  211.   return(y%4==0&&y%100!=0||(y%400==0));
  212.   }
  213.   ///////求2000 1.1開始任何一天是星期幾
  214.   //////////求總天數(shù)后 再求星期幾
  215.   void refresh_week_day()
  216.   {
  217.   uint i,d,w=5;
  218.   for(i=2000;i<2000+datetime[6];i++)
  219.   {
  220.   d=runnian(i)?366:365;
  221.   w=(w+d)%7;
  222.   }
  223.   d=0;
  224.   for(i=1;i<datetime[4];i++)
  225.   d+=monthsdays[i];
  226.   d+=datetime[3];
  227.   datetime[5]=(w+d)%7+1;
  228.   }
  229.   ///調(diào)整處理
  230.   void EX_INT0() interrupt 0
  231.   {
  232.   if(K1==0)
  233.   {
  234.   while(K1==0);
  235.   if(adjust_index==-1||adjust_index==1)
  236.   adjust_index=7;
  237.   adjust_index--;
  238.   if(adjust_index==5)adjust_index=4;
  239.   LCD_buffer2[13]='[';
  240.   LCD_buffer2[14]=change_flag[adjust_index];
  241.   LCD_buffer2[15]=']';
  242.   }
  243.   else
  244.   if(K2==0)
  245.   {
  246.   while(K2==0);
  247.   datetime_adjust(1);
  248.   }
  249.   else
  250.   if(K3==0)
  251.   {
  252.   while(K3==0);
  253.   datetime_adjust(-1);
  254.   }
  255.   else
  256.   if(K4==0)
  257.   {
  258.   while(K4==0);
  259.   set_ds1302();
  260.   LCD_buffer2[13]=' ';
  261.   LCD_buffer2[14]=' ';
  262.   LCD_buffer2[15]=' ';
  263.   adjust_index=-1;
  264.   }
  265.   }
  266. //分時日月年 加減
  267. void datetime_adjust(char x)
  268. {
  269. switch(adjust_index)
  270. {
  271. case 6:
  272. if(x==1&&datetime[6]<99)datetime[6]++;
  273. if(x==-1&&datetime[6]>0)datetime[6]--;
  274. monthsdays[2]=runnian(2000+datetime[6]?29:28);
  275. if(datetime[3]>monthsdays[datetime[4]])
  276. datetime[3]=monthsdays[datetime[4]];
  277. refresh_week_day();
  278. break;
  279. case 4:
  280. if(x==1&&datetime[4]<12)
  281. datetime[4]++;
  282. if(x==-1&&datetime[4]>1)
  283. datetime[4]--;
  284. monthsdays[2]=runnian(2000+datetime[6])?29:28;
  285. if(datetime[3]>monthsdays[datetime[4]])
  286. datetime[3]=monthsdays[datetime[4]];
  287. refresh_week_day();
  288. break;
  289. case 3:
  290. monthsdays[2]=runnian(2000+datetime[6])?29:28;
  291.   if(x==1&&datetime[3]<monthsdays[datetime[4]])
  292.   datetime[3]++;
  293.   if(x==-1&&datetime[3]>0)
  294.   datetime[3]--;
  295.   refresh_week_day();
  296.   break;
  297.   case 2:
  298.   if(x==1&&datetime[2]<23)
  299.   datetime[2]++;
  300.   if(x==-1&&datetime[2]>0)
  301.    datetime[2]--;
  302.    break;
  303.    case 1:
  304.   if(x==1&&datetime[1]<59)
  305.    datetime[1]++;
  306.   if(x==-1&&datetime[1]>0)
  307.    datetime[1]--;
  308.    break;
  309.    }
  310.    }
  311.    void T0_INT() interrupt 1
  312.    {
  313.    TH0=5000/256;
  314.    TL0=5000%256;
  315.    if(++tcount!=2)return;
  316.    tcount=0;
  317.    format_datetime(datetime[6],LCD_buffer1+5);
  318.    format_datetime(datetime[4],LCD_buffer1+8);
  319.    format_datetime(datetime[3],LCD_buffer1+11);
  320.    strcpy(LCD_buffer1+13,week[datetime[5]-1]);
  321.    format_datetime(datetime[2],LCD_buffer2+5);
  322.    format_datetime(datetime[1],LCD_buffer2+8);
  323.    format_datetime(datetime[0],LCD_buffer2+11);
  324.    display_string(0x00,LCD_buffer1);
  325.    display_string(0x40,LCD_buffer2);
  326.    }
程序無法編譯,仿真也不顯示字符怎么辦?如何找錯誤,求大神幫助
下載:
程序.zip
31.8 KB, 下載次數(shù): 249
用DS1302與1602LCD設(shè)計的可調(diào)式電子日歷與時鐘.zip
10.35 KB, 下載次數(shù): 209
參與人數(shù) 3黑幣 +9 收起 理由
是的發(fā)生 + 3 很給力!
29qq + 1 共享資料的黑幣獎勵!
zzdzhf + 5 很給力!
收藏收藏3 分享淘帖 頂 踩
ID:157576 發(fā)表于 2016-12-27 21:10 | 只看該作者
LCD感覺像一個擺設(shè)啊
ID:167465 發(fā)表于 2017-3-2 22:28 | 只看該作者
為什么仿真不成功
ID:270105 發(fā)表于 2018-1-5 13:06 | 只看該作者
為什么LCD1602不顯示出時間啊?
ID:275761 發(fā)表于 2018-1-14 15:38 | 只看該作者
程序可以參考,但有些問題
ID:574538 發(fā)表于 2019-6-29 13:53 | 只看該作者
顯示器顯示不出來?
ID:763892 發(fā)表于 2020-6-2 14:37 來自觸屏版 | 只看該作者
416659851 發(fā)表于 2019-6-29 13:53
顯示器顯示不出來?
有修改好的程序和Proteus文件么
