查看: 4823|回復: 2
如何將*.ile轉(zhuǎn)換成*.il文件
ID:140343 發(fā)表于 2016-9-24 19:30 | 顯示全部樓層 |閱讀模式
procedure( NlDecrypt( inputFile  @optional outputFile "tt")
     prog( (inp out line)
if( inputFile then
     unless( outputFile
outputFile = sprintf(nil "%s.dec" inputFile)
     when( isFile( outputFile )
print( "You must specify a file that doesn't exist!!!\n" )
hiGetAttention( )
return()
     unless( inp = infile(inputFile)
printf("Unable to open input file: %s\n" inputFile)
return()
     unless( out = outfile(outputFile "w")
printf("Unable to open output file: %s\n" outputFile)
return()
     while( line = lineread(inp)
when( line != t
     pprint(line out)
     close(inp)
     close(out)
     printf("You must at least specify an input file!\n")
     return()
) ; ** if inputFile **
return(t)
     ) ; ** let  **
) ; ** procedure  **
NlDecrypt( "abc.ile" "abc.il")
ID:585063 發(fā)表于 2019-7-16 14:00 | 顯示全部樓層
這個是什么程序啊,需要怎么去運行啊。大師能夠幫忙回答下嗎
ID:1047545 發(fā)表于 2022-10-13 14:17 | 顯示全部樓層
大佬,請問咋們運用啊?不會操作
