float px = 0.0;import processing.serial.*;
Serial port;
float val;
void setup(){
size(440,220);
fill(255,20,50);
println(Serial.list());
String arduinoPort = Serial.list()[1];
port = new Serial(this,arduinoPort,9600);
void draw(){
background(0);
stroke(255);
if(port.available()>0){
val = port.read();
val= map(val,0,255,0,height);
rect(40,val-10,360,20);
int sensorPin = A0;
int val = 0;
void setup(){
Serial.begin(9600);
void loop(){
val = analogRead(sensorPin);
val = map(val,0,1023,0,255);
Serial.write(val);
//Serial.println();
//Serial.println(val);
delay(100);
Serial port;
float val;
int x;
float easing = 0.05;
float easedVal;
void setup(){
size(440,440);
frameRate(30);
smooth();
fill(255,20,50);
background(0);
void draw(){
val = port.read();
float targetVal = val;easedVal += (targetVal-easedVal) * easing;
stroke(0);
line(x,0,x,height);
stroke(255);
line(x+1,0,x+1,height);
line(x,220,x,val);
line(x,440,x,easedVal+220);
x++;
if(x>width){
x =0;
int sensorPin = A0;
int val = 0;
void setup(){
Serial.begin(9600);
void loop(){
Serial.write(val);
//Serial.println();
delay(100);
Serial port;
float val;
float angle;
float radius;
void setup(){
size(440,440);
frameRate(30);
smooth();
strokeWeight(2);
fill(255,20,50);
background(0);
void draw(){
val = port.read();
radius = map(val,0,255,0,height*0.45);
int middleX = width/2;
int middleY = height/2;
float x = middleX +cos(angle)*height/2;
float y = middleY + sin(angle)*height/2;
stroke(0);
line(middleX,middleY,x,y);
x = middleX +cos(angle)*radius;
y = middleY + sin(angle)*radius;
stroke(255);
angle += 0.01;
int sensorPin = A0;
int val = 0;
void setup(){
Serial.begin(9600);
void loop(){
Serial.write(val);
//Serial.println();
delay(100);
