2016-9-25 23:21 上傳
2016-9-25 23:21 上傳
2016-9-25 23:21 上傳
萬年歷的所有資料下載:
萬年歷.zip
(118.48 KB, 下載次數(shù): 48)
2016-9-25 23:22 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
源程序:
- #include<reg52.h>
- #define uint unsigned int
- #define uchar unsigned char
- uchar code table[]={"0000-00-00"};
- uchar code table1[]={"00:00:00"};
- uchar code table2[]={"MONTUSWEDTHUFRISATSUN"};
- sbit rs=P2^0;
- sbit rw=P2^1;
- sbit e=P2^2;
- sbit key1=P2^3;
- sbit key2=P2^4;
- sbit key3=P2^5;
- char num,shi1=0,fen=0,miao=0,ri=0,yue=0;uchar xingqi=1;
- int nianqian=0,nianhou=0;
- void delay(unsigned int z)
- uchar x,y;
- for(x=z;x>0;x--)
- for(y=110;y>0;y--);
- void write_com(uchar com)
- rs=0;
- rw=0;
- P0=com;
- delay(5);
- e=1;
- delay(5);
- e=0;
- void write_data(uchar date)
- rs=1;
- rw=0;
- P0=date;
- delay(5);
- e=1;
- delay(5);
- e=0;
- void init()
- rs=0;
- write_com(0x38);
- write_com(0x0c);
- write_com(0x06);
- write_com(0x01);
- delay(5);
- void write_wang(uchar add,uchar date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- write_com(0x80+0X40+add);
- write_data(0x30+shi);
- write_data(0x30+ge);
- void write_wang1(uchar add,uchar date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- write_com(0x80+add);
- void write_wang2(uchar add,int date)
- uchar shi,ge;
- shi=date/10;
- ge=date%10;
- void keycan()
- uchar i;uchar num1;
- if(key1==0)
- delay(1);
- if(key1==0)
- num1++;
- while(!key1);
- if(num1==1)
- TR0=0;
- write_com(0x80+0x40+7);
- write_com(0x0f);
- if(num1==2)
- write_com(0x80+0x40+4);
- if(num1==3)
- write_com(0x80+0x40+1);
- if(num1==4)
- write_com(0x80+9);
- if(num1==5)
- write_com(0x80+6);
- if(num1==6)
- write_com(0x80+3);
- if(num1==7)
- write_com(0x80+1);
- if(num1==8)
- write_com(0x80+13);
- if(num1>=9)
- num1=0;
- TR0=1;
- write_com(0x0c);
- if(num1!=0)
- if(key2==0)
- delay(1);
- if(key2==0)
- while(key2!=1);
- if(num1==1)
- miao++;
- if(miao==60)
- miao=0;
- write_wang(6,miao);
- write_com(0x80+0x40+6);
- if(num1==2)
- fen++;
- if(fen==60)
- fen=0;
- write_wang(3,fen);
- write_com(0x80+0x40+3);
- if(num1==3)
- shi1++;
- if(shi1==24)
- shi1=0;
- write_wang(0,shi1);
- write_com(0x80+0x40);
- if(num1==4)
- ri++;
- if(yue==1||yue==3||yue==5||yue==7||yue==8||yue==10||yue==12)
- if(ri==32)
- ri=1;
- else if(yue==2)
- if((nianqian*100+nianhou)%4==0 && (nianqian*100+nianhou)%100!=0 || (nianqian*100+nianhou)%400==0 )
- if(ri==30)
- ri=1;
- else
- if(ri==29)
- ri=1;
- else
- if(ri==31)
- ri=1;
- write_wang1(8,ri);
- write_com(0x80+8);
- if(num1==5)
- yue++;
- if(yue==13)
- yue=1;
- write_wang1(5,yue);
- write_com(0x80+5);
- if(num1==6)
- nianhou++;
- if(nianhou==100)
- nianhou=0;
- write_wang2(2,nianhou);
- write_com(0x80+2);
- if(num1==7)
- { nianqian++;
- if(nianqian==100)
- nianqian=0;
- write_wang2(0,nianqian);
- write_com(0x80);
- if(num1==8)
- xingqi++;
- if(xingqi==8)
- xingqi=1;
- switch(xingqi)
- case 1:
- for(i=0;i<3;i++)
- write_data(table2[i]);
- break;
- case 2:
- for(i=3;i<6;i++)
- break;
- case 3:
- for(i=6;i<9;i++)
- break;
- case 4:
- for(i=9;i<12;i++)
- break;
- case 5:
- for(i=12;i<15;i++)
- break;
- case 6:
- for(i=15;i<18;i++)
- break;
- case 7:
- for(i=18;i<21;i++)
- break;
- if(num1!=0)
- if(key3==0)
- delay(5);
- if(key3==0)
- while(key3!=1);
- if(num1==1)
- miao--;
- if(miao==-1)
- miao=59;
- if(num1==2)
- fen--;
- if(fen==-1)
- fen=59;
- if(num1==3)
- shi1--;
- if(shi1==-1)
- shi1=23;
- if(num1==4)
- ri--;
- if(ri==-1)
- ri=31;
- else if(yue==2)
- if(((nianqian*100+nianhou)%4==0 && (nianqian*100+nianhou)%100!=0 || (nianqian*100+nianhou)%400==0 ))
- if(ri==-1)
- ri=29;
- else
- if(ri==-1)
- ri=28;
- else
- if(ri==-1)
- ri=30;
- if(num1==5)
- yue--;
- if(yue==0)
- yue=12;
- if(num1==6)
- nianhou--;
- if(nianhou==-1)
- nianhou=99;
- if(num1==7)
- nianqian--;
- if(nianqian==-1)
- nianqian=99;
- write_com(0x80);
- if(num1==8)
- xingqi--;
- if(xingqi==0)
- xingqi=7;
- switch(xingqi)
- case 1:
- for(i=0;i<3;i++)
- break;
- case 2:
- for(i=3;i<6;i++)
- break;
- case 3:
- for(i=6;i<9;i++)
- break;
- case 4:
- for(i=9;i<12;i++)
- break;
- case 5:
- break;
- case 6:
- break;
- case 7:
- break;
- void duxianshi()
- write_com(0x80);
- for(num=0;num<10;num++)
- write_data(table[num]);
- delay(5);
- for(num=0;num<3;num++)
- write_data(table2[num]);
- delay(5);
- for(num=0;num<8;num++)
- write_data(table1[num]);
- delay(5);
- void time()
- uchar i;
- if(num==18)
- num=0;
- miao++;
- if(miao==60)
- miao=0;
- fen++;
- if(fen==60)
- fen=0;
- shi1++;
- if(shi1==24)
- shi1=0;
- ri++;
- xingqi++;
- if(xingqi==8)
- xingqi=1;
- switch(xingqi)
- case 1:
- for(i=0;i<3;i++)
- break;
- case 2:
- for(i=3;i<6;i++)
- break;
- case 3:
- for(i=6;i<9;i++)
- break;
- case 4:
- for(i=9;i<12;i++)
- break;
- case 5:
- break;
- case 6:
- break;
- case 7:
- break;
- if(ri==32)
- ri=1;
- yue++;
- if(yue==13)
- yue=1;
- nianhou++;
- if(nianhou==100)
- nianhou=0;
- nianqian++;
- if(nianqian==100)
- nianqian=0;
- nianhou=0;
- yue=0;
- ri=0;
- shi1=0;
- fen=0;
- miao=0;
- for(i=0;i<3;i++)
- else if(yue==2)
- if(ri==29)
- ri=1;
- yue++;
- if(yue==13)
- yue=1;
- nianhou++;
- if(nianhou==100)
- nianhou=0;
- nianqian++;
- if(nianqian==100)
- nianqian=0;
- nianhou=0;
- yue=0;
- ri=0;
- shi1=0;
- fen=0;
- miao=0;
- for(i=0;i<3;i++)
- else
- if(ri==31)
- ri=1;
- yue++;
- if(yue==13)
- yue=1;
- nianhou++;
- if(nianhou==100)
- nianhou=0;
- nianqian++;
- if(nianqian==100)
- nianqian=0;
- nianhou=0;
- yue=0;
- ri=0;
- shi1=0;
- fen=0;
- miao=0;
- for(i=0;i<3;i++)
- void main()
- EA=1;
- ET0=1;
- TMOD=0X01;
- TH0=(65536-50000)/256;
- TL0=(65536-50000)%256;
- init();
- duxianshi();
- num=0;
- TR0=1;
- while(1)
- time();
- keycan();
- void T0_time()interrupt 1
- num++;
