說明: 8051單片機(jī)超級終端, 基于VT100協(xié)議,提供完整源碼,命令參數(shù)解析部分代碼借鑒VIVI的源代碼
只添加了四條命令,help;prompt;clear;reboot;需要可以自己添加,比如內(nèi)存查看命令等等
作者:蔣建軍
仿真工程文件及所有完整程序等資料下載地址:
http://www.torrancerestoration.com/bbs/dpj-56304-1.html
部分單片機(jī)源程序:
- #include "HyperTerminal.h"
- char idata SerialBuffer[MAX_SERIAL_BUFFER_SIZE];
- char idata PromptBuffer[MAX_PROMPT_BUFFER_SIZE];
- char idata CursorPosion;
- char idata ExecCommandFlag;
- COMMAND CommandList[MAX_COMMAND_NUM] = {
- {"help",Help," help -- Command help"},
- {"prompt",Prompt," prompt <string> -- Change a prompt"},
- {"clear",Clear," clear -- Clear screen"},
- {"reboot",Reboot," reboot -- Reboot the MCU"}
- void Help(char argc, const char **argv)
- char i;
- argv = argv;
- switch(argc)
- case 1:
- for(i = 0; i < MAX_COMMAND_NUM; i++)
- SerialSendStr(CommandList[i].HelpString);
- SerialSendStr("\r\n");
- break;
- default:
- SerialSendStr(" Invalid 'help' command: too many arguments\r\n");
- SerialSendStr(" Usage:\r\n");
- SerialSendStr(" help\r\n");
- break;
- void Prompt(char argc, const char **argv)
- switch(argc)
- case 2:
- if(strlen(argv[1]) >= MAX_PROMPT_BUFFER_SIZE)
- SerialSendStr(" Warnning:Your argument is too long!\r\n\r\n");
- break;
- memcpy(PromptBuffer,argv[1],MAX_PROMPT_BUFFER_SIZE);
- SerialSendStr(" Prompt is chagned to \"");
- sprintf(&SerialBuffer[0],"%s\"\r\n\r\n",&PromptBuffer[0]);
- SerialSendStr(&SerialBuffer[0]);
- break;
- default:
- SerialSendStr(" Invalid 'prompt' command: too few or many arguments\r\n");
- SerialSendStr(" prompt <string>\r\n");
- break;
- void Clear(char argc, const char **argv)
- argv = argv;
- switch(argc)
- case 1:
- SerialSendStr(CLEARSCREEN);
- break;
- default:
- SerialSendStr(" Invalid 'clear' command: too many arguments\r\n");
- SerialSendStr(" clear\r\n");
- break;
- void Reboot(char argc, const char **argv)
- argv = argv;
- switch(argc)
- case 1:
- (*(void(*)())0)();
- break;
- default:
- SerialSendStr(" Invalid 'reboot' command: too many arguments\r\n");
- SerialSendStr(" reboot\r\n");
- break;
- void InitHyperTerminal(void)
- TMOD |= 0x20; /* timer1, mode 2, 8 bit reload */
- SCON = 0x50; /* serial mode 1, 8 bit uart, enable receive */
- PCON = 0x80; /* SMOD = 1, double baud */
- TH1 = 0xFF; /* baud = 57600, fosc = 11.0592MHZ */
- TL1 = 0xFF;
- RI = 0; /* clear receive flag */
- TI = 0; /* clear send flag */
- TR1 = 1; /* start timer1 */
- ES = 1; /* enable serial interrupt */
- EA = 1; /* enable all interrupt */
- CursorPosion = 0;
- ExecCommandFlag = 0;
- memset(&SerialBuffer[0],'\0',MAX_SERIAL_BUFFER_SIZE);
- memcpy(&PromptBuffer[0],"-->>",MAX_PROMPT_BUFFER_SIZE);
- SerialSendStr(F_LIGHTGREEN);
- SerialSendStr(B_BLACK);
- SerialSendStr("-----------------------------\r\n");
- SerialSendStr(" The 8051 Hyper Terminal,by JJJ\r\n");
- SerialSendStr(" 123456789 \r\n");
- SerialSendStr(&PromptBuffer[0]);
- void SerialSendByte(char dat)
- SBUF = dat;
- while(TI == 0);
- TI = 0;
- void SerialSendStr(char *str)
- while(*str != '\0')
- SerialSendByte(*str);
- str++;
- void SerialInterrupt(void) interrupt 4 using 3
- char SbufTemp;
- if(RI)
- RI = 0;
- SbufTemp = SBUF;
- switch(SbufTemp)
- case 0x08:
- case 0x06:
- case 0x07:
- case 0x7E:
- case 0x7F:
- if(CursorPosion > 0)
- CursorPosion--;
- SerialSendByte(0x08);
- SerialSendByte(' ');
- SerialBuffer[CursorPosion] = '\0';
- break;
- case '\r':
- case '\n':
- case '\0':
- SerialSendByte('\r');
- SerialSendByte('\n');
- ExecCommandFlag = 1;
- break;
- case '\t':
- break;
- default:
- if(CursorPosion < MAX_SERIAL_BUFFER_SIZE)
- SerialBuffer[CursorPosion] = SbufTemp;
- SerialSendByte(SbufTemp);
- CursorPosion++;
- else
- CursorPosion = 0;
- SerialSendStr("\r\n Warnning:Your command string is too long!\r\n\r\n");
- break;
- void ParseArgs(char *argstr,char *argc_p,char **argv, char **resid)
- char argc = 0;
- char c;
- PARSESTATE stackedState,lastState = PS_WHITESPACE;
- while ((c = *argstr) != 0)
- PARSESTATE newState;
- if (c == ';' && lastState != PS_STRING && lastState != PS_ESCAPE)
- break;
- if (lastState == PS_ESCAPE)
- newState = stackedState;
- else if (lastState == PS_STRING)
- if (c == '"')
- newState = PS_WHITESPACE;
- *argstr = 0;
- else
- newState = PS_STRING;
- else if ((c == ' ') || (c == '\t'))
- *argstr = 0;
- else if (c == '"')
- *argstr++ = 0;
- argv[argc++] = argstr;
- else if (c == '\\')
- stackedState = lastState;
- newState = PS_ESCAPE;
- else
- if (lastState == PS_WHITESPACE)
- newState = PS_TOKEN;
- lastState = newState;
- argstr++;
- argv[argc] = NULL;
- if (argc_p != NULL)
- *argc_p = argc;
- if (*argstr == ';')
- *argstr++ = '\0';
- *resid = argstr;
- void ExecCommand(char *buf)
- char argc,*argv[8],*resid,i;
- COMMAND *Command = 0;
- while(*buf)
- memset(argv,0,sizeof(argv));
- ParseArgs(buf, &argc, argv, &resid);
- if(argc > 0)
- Command = &CommandList[i];
- if(strncmp(Command->CommandName,argv[0],strlen(argv[0])) == 0)
- break;
- else
- Command = 0;
- if(Command == 0)
- SerialSendStr(" Could not found \"");
- SerialSendStr(argv[0]);
- SerialSendStr("\" command\r\n");
- SerialSendStr(" If you want to konw available commands, type 'help'\r\n\r\n");
- else
- Command->CommandFunc(argc,argv);
- buf = resid;
- void RunHyperTerminal(void)
- if(ExecCommandFlag)
- ExecCommand(&SerialBuffer[0]);
- CursorPosion = 0;
