查看: 3551|回復(fù): 4
大家?guī)臀铱纯窗。粋超聲波測距再用數(shù)碼管顯示距離,但顯示有問題
ID:141911 發(fā)表于 2016-10-9 23:34 | 顯示全部樓層 |閱讀模式
#include"reg52.h"  //頭文件包含
#include<intrins.h>
sbit LED0=P1^0;     //LED燈個位定義
sbit LED1=P1^1;  //LED燈十位定義
sbit LED2=P1^2;  //LED燈百位定義
sbit LED3=P1^3;  //LED燈千位定義
sbit LED4=P1^4;  //LED燈使能
sbit Trig=P1^0;  //超聲波傳感器使能引腳定義
sbit Echo=P3^2;  //超聲波傳感器回波引腳定義
float time=0;    //回波總時間
unsigned int distance=0; //距離(cm)
unsigned char timeH=0;   //定時器1定時值高八位
unsigned char timeL=0;   //定時器1定時值低八位
unsigned char counter=0; //定時器0計數(shù)值
unsigned char LedBuf[6];
unsigned char code LED_num[10]={
0xC0,0xF9,0xA4,0xB0,0x99,
0x92,0x82,0xF8,0x80,0x90}; //數(shù)碼管真值
bit success=0;      // 回波接收成功標(biāo)志
void delay(unsigned int x)// 延時程序(x=1,i=10)時延時50us
  unsigned int i,j;
  for(j=0;j<x;j++)
    for(i=0;i<10;i++)
        _nop_();//空指令
        _nop_();
void display()
    signed char i;
    unsigned char buf[6];
    for(i=0;i<6;i++)
         buf[i] = (unsigned char)(distance%10);
         distance /= 10;
    for(i=5;i>=1;i--)
        if(buf[i] == 0)
           LedBuf[i] = 0xFF;
           break;
    for(;i>=0;i--)
         LedBuf[i] = LED_num[buf[i]];
void main(void)
   Trig = 0;    //使能管腳初始拉低
   TMOD &= 0x11;//定時器0和1設(shè)定為16位工作模式
   TH0 = 0x3C;    //-5000>>8 = 60
   TL0 = 0xB0;    //-5000%256 = 176
   TR0 = 1;    //開定時器0
   ET0 = 1;    //定時器0中斷允許
   EX0 = 1;    //外部中斷0允許
   IT0 = 1;    //外部中斷0下降沿觸發(fā)
   EA = 1;    //開總中斷
   LED3 = 1;
   LED4 = 0;
      if(success == 1)//判斷是否接收成功
         distance = (time * 0.017- 10);//根據(jù)時間求出距離
         success = 0;
      display();
void LedScan()
   static unsigned char i=0;
   P0 = 0xFF;
   P1 = (P1 & 0xF8) | i;
   P0 = LedBuf[i];
   if(i<5)
      i++;
      i = 0;
void Timer0int() interrupt 1 //50ms*4=0.2s,每0.2秒測一次距
   EA = 0;
   TR0 = 0;
   counter++;
   if(counter==4)
      Trig = 1;
      delay(1);
      Trig = 0;
      TH1 = 0;
      TL1 = 0;
      TR1 = 1;
      counter = 0;
   TH0 = 0x3C;
   TL0 = 0xB0;
   TR0 = 1;
   EA = 1;
   LedScan();
void exint() interrupt 0 //外部中斷0用于檢測回波下降沿
   TR1 = 0;
   timeH = TH1;
   timeL = TL1;
   TH1 = 0;
   TL1 = 0;
   time = timeH * 256 + timeL;
   success = 1;
ID:90663 發(fā)表于 2016-10-10 10:58 來自觸屏版 | 顯示全部樓層
有具體電路么?顯示部分
ID:141911 發(fā)表于 2016-10-10 21:59 | 顯示全部樓層
摟貓睡覺的魚 發(fā)表于 2016-10-10 10:58
有具體電路么?顯示部分
有電路,用的宋雪松的板子,但是好像貼不上圖
ID:245469 發(fā)表于 2017-12-20 20:12 | 顯示全部樓層
你的1.0引腳sbit Trig和LED0
ID:245469 發(fā)表于 2017-12-20 20:13 | 顯示全部樓層
你的1.0引腳定義了兩次。
