查看: 2614|回復(fù): 0
STM32 LCD1602設(shè)計
ID:142741 發(fā)表于 2016-10-14 17:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "LCD1602.h"
#define RS_SET GPIO_SetBits(GPIOC,GPIO_Pin_9)
#define RS_CLR GPIO_ResetBits(GPIOC,GPIO_Pin_9)
#define RW_CLR GPIO_ResetBits(GPIOC,GPIO_Pin_13)
#define RW_SET GPIO_SetBits(GPIOC,GPIO_Pin_13)
#define EN_CLR GPIO_ResetBits(GPIOB,GPIO_Pin_8)
#define EN_SET GPIO_SetBits(GPIOB,GPIO_Pin_8)
#define  GPIO_WriteLow(GPIOx,a)   GPIOx->BSRR=(((uint32_t)(uint8_t)~(a))<<16)|((uint32_t)(uint8_t)(a))        //D′μí8λ
#define  GPIO_WriteHigh(GPIOx,a)  GPIOx->BSRR=(((uint8_t)(uint8_t)~(a))<<24)|(((uint32_t)(uint8_t)(a))<<8)        //D′¸ß8λ
/***************  ÅäÖÃLEDóÃμ½μÄI/O¿ú *******************/
void LCD_GPIO_Config(void)
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOB, ENABLE); // ê1ÄüPB¶Ë¿úê±Öó
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2|GPIO_Pin_3|
        GPIO_Pin_4|GPIO_Pin_5|GPIO_Pin_6|GPIO_Pin_7|        GPIO_Pin_9|GPIO_Pin_13;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_10MHz;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
void delay_nus(unsigned long n)
                unsigned long j;
                while(n--)
                        j=7;
                        while(j--);
void DelayMs(unsigned int t)
                while(t--)
                delay_nus(1100);
void LCD_write_com(unsigned char com)                //D′Ãüáî
                DelayMs(5);
                GPIO_WriteLow(GPIOC,com);        //D′μí8λ
                delay_nus(1);
                EN_CLR;
                delay_nus(1);
                RS_CLR;
                delay_nus(1);
                RW_CLR;
                delay_nus(1);
                EN_SET;
                delay_nus(1);
                EN_CLR;
void LCD_write_data(unsigned char Data)        //D′êy¾Y
                DelayMs(5);
                GPIO_WriteLow(GPIOC,Data);        //D′μí8λ
                delay_nus(1);
                EN_CLR;
                delay_nus(1);
                RS_SET;
                delay_nus(1);
                RW_CLR;
                delay_nus(1);
                delay_nus(1);
                EN_SET;
                delay_nus(1);
                EN_CLR;
                delay_nus(1);
                RS_CLR;
void LCD_write_char(unsigned char y,unsigned char x,unsigned char data) //D′èë×Ö·ûoˉêy £yy,xμú¼¸DDμú¼¸¸ö
                if (y == 0)
                                LCD_write_com(0x80+x);
                                LCD_write_com(0xc0+x);
                LCD_write_data(data);
                delay_nus(50);
void LCD_write_string(unsigned char y,unsigned char x,unsigned char *s )
                if (y == 0)
                while (*s)
                                LCD_write_data(*s);
                                s++;
                                delay_nus(500);
void LCD_Init(void)
                LCD_GPIO_Config();
                DelayMs(1);
                LCD_write_com(0x38);        //êy¾YÏßÎa8룬á½DDÏÔê¾£¬5X7μãÕó
                delay_nus(1);
                LCD_write_com(0x0c);         //¿aÏÔê¾£¬óD1a±ê£¬1a±êéá˸
                delay_nus(1);
                LCD_write_com(0x06);        //1a±êóòòÆ£¬2»òÆÆá
                delay_nus(1);
                LCD_write_com(0x01);        //ÇåÆá
                delay_nus(1);
//                LCD_write_string(0,0, " 1.Set CC  3.Vdc");
//                LCD_write_string(1,0, " 2.Set CP");
