查看: 2550|回復(fù): 5
請(qǐng)教一下這個(gè)程序幾處不懂的地方
ID:143848 發(fā)表于 2016-10-29 09:29 來自手機(jī) | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這是個(gè)熱敏電阻3950的測溫單片機(jī)里程序,不過有幾個(gè)地方不太明白,還望請(qǐng)教。第一個(gè)code        uint VOL[]和code        uint Temper[]中的數(shù)據(jù)是怎么計(jì)算查表得到的。第二個(gè)問題         result=(uint)((res/2048.0-1.0)*500.0);
                 temp1=abs(result-VOL[0]);
                 for(i=1;i<150;i++)
                         temp2=abs(result-VOL[i]);
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
                 }這一部分,我最不明白,還有那個(gè)公式是什么意思?
請(qǐng)看程序:#include <reg52.h>
#include <intrins.h>
#include <math.h>
typedef unsigned char uchar;
typedef unsigned int  uint;
code        uint VOL[]={                343,        339,        339,        335,        332,        332,        328,        324,        320,        320,
                                                        316,        312,        312,        308,        304,        300,        300,        296,        292,        292,
                                                        289,        285,        285,        281,        277,        273,        273,        269,        265,        265,
                                                        261,        257,        257,        253,        250,        250,        246,        242,        242,        238,
                                                        234,        234,        230,        230,        226,        222,        222,        218,        218,        214,
                                                        210,        210,        207,        207,        203,        199,        199,        195,        195,        191,
                                                        191,        187,        187,        183,        179,        179,        175,        175,        171,        171,
                                                        167,        167,        164,        164,        160,        160,        160,        156,        156,        152,
                                                        152,        148,        148,        144,        144,        140,        140,        140,        136,        136,
                                                        132,        132,        132,        128,        128,        125,        125,        125,        121,        121,
                                                        121,        117,        113,        109,        109,        105,        101,        101,        97,                97,
                                                        93,                89,                89,                85,                85,                82,                82,                78,                78,                74,
                                                        74,                70,                70,                66,                66,                66,                62,                62,                58,                58,
                                                        58,                54,                54,                54,                50,                50,                50,                46,                46,                46,
                                                        42,                42,                42,                42,                39,                39,                39,                39,                35,                35};
code        uint Temper[]={                100,        150,        200,        250,        300,        350,        400,        450,        500,        550,
                                                        600,        650,        700,        750,        800,        850,        900,        950,        1000,        1050,
                                                        1100,        1150,        1200,        1250,        1300,        1350,        1400,        1450,        1500,        1550
                                                        1600,        1650,        1700,        1750,        1800,        1850,        1900,        1950,        2000,        2050,
                                                        2100,        2150,        2200,        2250,        2300,        2350,        2400,        2450,        2500,        2550,
                                                        2600,        2650,        2700,        2750,        2800,        2850,        2900,        2950,        3000,        3050,
                                                        3100,        3150,        3200,        3250,        3300,        3350,        3400,        3450,        3500,        3550,
                                                        3600,        3650,        3700,        3750,        3800,        3850,        3900,        3950,        4000,        4050,
                                                        4100,        4150,        4200,        4250,        4300,        4350,        4400,        4450,        4500,        4550,
                                                        4600,        4650,        4700,        4750,        4800,        4850,        4900,        4950,        5000,        5050,
                                                        5100,        5200,        5300,        5400,        5500,        5600,        5700,        5800,        5900,        6000,
                                                        6100,        6200,        6300,        6400,        6500,        6600,        6700,        6800,        6900,        7000,
                                                        7100,        7200,        7300,        7400,        7500,        7600,        7700,        7800,        7900,        8000,
                                                        8100,        8200,        8300,        8400,        8500,        8600,        8700,        8800,        8900,        9000,
                                                        9100,        9200,        9300,        9400,        9500,        9600,        9700,        9800,        9900,        10000};
sbit STS=P1^0;
sbit CE = P1^1;
sbit CS=P1^2;
sbit A0=P1^3;
sbit RC=P1^4;
sbit RS=P1^5 ;
sbit RW=P1^6 ;
sbit EN=P1^7 ;
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
uint AD1674_Read(void)
        uint temp;
        uchar temp1,temp2;
        CS=1;        //片選信號(hào)
        CE=0;        //初始化,關(guān)閉數(shù)據(jù)采集
        CS=0;
        A0=0;
        RC=0;
        CE=1;//CE=1,CS=0,RC=0,A0=0啟動(dòng)12位溫度轉(zhuǎn)換
        _nop_();
        while(STS==1);         //等待數(shù)據(jù)采集結(jié)束
        CE=0;         //芯片使能關(guān)閉
        RC=1;
        A0=0;
        CE=1;//CE=1,CS=0,RC=1,12/8=1,A0=0 允許高八位數(shù)據(jù)并行輸出
        _nop_();
        temp1=P0; //讀取轉(zhuǎn)換結(jié)果的高八位
        RC=1;
        A0=1;
        CE=1;//CE=1,CS=0,RC=1,12/8=0,A0=1 允許低四位數(shù)據(jù) 并行輸出
        _nop_();
        temp2=P0;         //讀取轉(zhuǎn)換結(jié)果的第四位
        temp=((temp1<<4)|(temp2&0X0F));          //高位和低位合成實(shí)際溫度,temp2為PO口的高四位
        return (temp);           //還回轉(zhuǎn)換結(jié)果,右移四位是因?yàn)閠emp2為P0口的高四位
/*** 寫數(shù)據(jù)***/
void w_dat(unsigned char dat)
        RS = 1;
        //EN = 0;
        P2 = dat;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 寫命令***/
void w_cmd(unsigned char cmd)
        RS = 0;
//        EN = 0;
        P2 = cmd;
        delay_ms(5);
        RW = 0;
        EN = 1;
        EN = 0;
/*** 發(fā)送字符串到LCD***/
void w_string(unsigned char addr_start, unsigned char *p)
        unsigned char *pp;
        pp = p;
        w_cmd(addr_start);
        while (*pp != '\0')
                w_dat(*pp++);
/*** 初始化1602****/
void Init_LCD1602(void)
        EN = 0;
        w_cmd(0x38);  // 16*2顯示,5*7點(diǎn)陣,8位數(shù)據(jù)接口
        w_cmd(0x0C);  // 顯示器開、光標(biāo)開、光標(biāo)允許閃爍
        w_cmd(0x06);  // 文字不動(dòng),光標(biāo)自動(dòng)右移
        w_cmd(0x01);  // 清屏
void process(uint date,uchar add)
        uchar A[7];
        A[0]=date/1000%10+'0';
        A[1]=date/100%10+'0';
        A[2]='.';
        A[3]=date/10%10+'0';
        A[4]=date%10+'0';
        A[5]='C';
        w_string(add,A);
        uchar i,flag=0;
        uint result,temp1,temp2;
        float        res;
        Init_LCD1602();
        w_string(0x80,"Temper:");
        while (1)
                 res=(float)(AD1674_Read());
                 for(i=1;i<150;i++)
                        if(temp1>=temp2)
                                temp1=temp2;
                                flag=i;
                 process(Temper[flag],0x80+7);
ID:79544 發(fā)表于 2016-10-29 11:36 | 只看該作者
abs(result-VOL[i]); 這個(gè)函數(shù)是調(diào)用庫函數(shù)#include <math.h>進(jìn)行計(jì)算值,表示溫度所對(duì)應(yīng)的AD值,這是我的理解
ID:61002 發(fā)表于 2016-10-29 12:44 | 只看該作者
騰飛的龍 發(fā)表于 2016-10-29 11:36
abs(result-VOL); 這個(gè)函數(shù)是調(diào)用庫函數(shù)#include 進(jìn)行計(jì)算值,表示溫度所對(duì)應(yīng)的AD值,這是我的理解
abs是取絕對(duì)值的
ID:61002 發(fā)表于 2016-10-29 12:49 | 只看該作者
result=(uint)((res/2048.0-1.0)*500.0); 這句話應(yīng)該是根據(jù)你的硬件電路得到的公式,用來把熱敏電阻3950線性化
那兩個(gè)數(shù)組里一個(gè)表示的是溫度,一個(gè)是電阻大小 是一一對(duì)應(yīng)的,轉(zhuǎn)換關(guān)系是每50度內(nèi)溫度和電阻阻值的關(guān)系是線性的
還有問題可以加我qq753388438
ID:143848 發(fā)表于 2016-10-29 20:07 | 只看該作者
g753388438 發(fā)表于 2016-10-29 12:49
result=(uint)((res/2048.0-1.0)*500.0); 這句話應(yīng)該是根據(jù)你的硬件電路得到的公式,用來把熱敏電阻3950線 ...
請(qǐng)問那兩個(gè)定義的數(shù)組怎么來的呢?我是一個(gè)1K的普通電阻串上一個(gè)1K的熱敏電阻然后A/D轉(zhuǎn)換送入單片機(jī)最后顯示出來,這是基本思路
ID:61002 發(fā)表于 2016-10-31 08:26 | 只看該作者
七顆星星 發(fā)表于 2016-10-29 20:07
請(qǐng)問那兩個(gè)定義的數(shù)組怎么來的呢?我是一個(gè)1K的普通電阻串上一個(gè)1K的熱敏電阻然后A/D轉(zhuǎn)換送入單片機(jī)最后 ...
這個(gè)數(shù)組是根據(jù)分度表來的
