查看: 1916|回復(fù): 0
矩陣鍵盤顯示0—f
ID:146913 發(fā)表于 2016-11-8 21:29 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <STC15Fxxxx.h>
#include <intrins.h>
unsigned char code duan[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,0
unsigned char code wei[]={
0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f
uchar num,temp;
sbit SDA1=P4^0;
sbit SCL1=P4^3;
sbit SCL2=P5^4;
uchar keyscan();
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--);
void Whc_in(unsigned char Data)
unsigned char i;
for(i=0;i<8;i++)
SCL1=0;
SDA1=Data&0x80;
Data<<=1;
SCL1=1;
void Whc_out(void)
SCL2=0;
_nop_();
SCL2=1;
void Disp(unsigned char m,unsigned char n)
Whc_in(wei[n]);
Whc_in(duan[m]);
Whc_out();
delay(10);
            Disp(keyscan(),0);
uchar keyscan()
            P0=0xfe;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xee:num=1;
                                break;
                            case 0xde:num=2;
                                break;
                            case 0xbe:num=3;
                                break;
                            case 0x7e:num=4;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xfd;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xed:num=5;
                                break;
                            case 0xdd:num=6;
                                break;
                            case 0xbd:num=7;
                                break;
                            case 0x7d:num=8;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xfb;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xeb:num=9;
                                break;
                            case 0xdb:num=10;
                                break;
                            case 0xbb:num=11;
                                break;
                            case 0x7b:num=12;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
            P0=0xf7;
            temp=P0;
            temp=temp&0xf0;
            while(temp!=0xf0)
                    delay(5);
                    temp=P0;
                    temp=temp&0xf0;
                    while(temp!=0xf0)
                        temp=P0;
                    switch(temp)
                            case 0xe7:num=13;
                                break;
                            case 0xd7:num=14;
                                break;
                            case 0xb7:num=15;
                                break;
                            case 0x77:num=16;
                                break;
                    while(temp!=0xf0)
                            temp=P0;
                            temp=temp&0xf0;
return num;
