查看: 5514|回復(fù): 0
LIS3DH datasheet及初始化
ID:147530 發(fā)表于 2016-11-12 15:51 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
/* Copyright (c) [2014 iCreative]. All Rights Reserved. * Licensed under the Apache License, Version 2.0 (the "License");
* you may not use this file except in compliance with the License.
* You may obtain a copy of the License at
    http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software
* distributed under the License is distributed on an "AS IS" BASIS,
* WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
* See the License for the specific language governing permissions and
* limitations under the License.
* File Name          :
* Author             :
* Version            : $Revision:$
* Date               : $Date:$
* Description        :
* HISTORY:
* Date               | Modification                    | Author
* 28/03/2014         | Initial Revision                |
/* Includes ------------------------------------------------------------------*/
#include "spi_master.h"
extern uint8_t   SPIMasterBuffer[];
extern uint8_t   SPISlaveBuffer[];
extern volatile uint8_t  SPIReadLength, SPIWriteLength;
#ifdef FEATURE_SENSOR_LIS3DH
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
* Function Name  : LIS3DH_ReadReg
* Description  : Generic Reading function. It must be fullfilled with either
*   : I2C or SPI reading functions
* Input   : Register Address
* Output  : Data REad
* Return  : None
bool LIS3DH_ReadReg(u8_t Reg, u8_t* Data)
    /* Write transaction */
    uint8_t transfer_size = 2;
    SPIMasterBuffer[0] = Reg | LIS3DH_READBIT;
    spi_master_enable(SPI0);
    ASSERT(spi_master_tx_rx((uint32_t *)NRF_SPI0,transfer_size,SPIMasterBuffer,SPISlaveBuffer));
    spi_master_disable(SPI0);
    /* Send received value back to the caller */
    *Data = SPISlaveBuffer[1];
    return true;
* Function Name  : LIS3DH_WriteReg
* Description  : Generic Writing function. It must be fullfilled with either
*   : I2C or SPI writing function
* Input   : Register Address, Data to be written
* Output  : None
* Return  : None
u8_t LIS3DH_WriteReg(u8_t WriteAddr, u8_t Data)
    SPIWriteLength = 2;
    SPIReadLength = 0;
    SPIMasterBuffer[0] = WriteAddr;
    SPIMasterBuffer[1] = (Data);
    /* Check if we got an ACK or TIMEOUT error */
    ASSERT(spi_master_tx_rx((uint32_t *)NRF_SPI0,SPIWriteLength,SPIMasterBuffer,SPISlaveBuffer));
    return true;
/* Private functions ---------------------------------------------------------*/
* Function Name  : LIS3DH_GetWHO_AM_I
* Description    : Read identification code by WHO_AM_I register
* Input          : Char to empty by Device identification Value
* Output         : None
* Return         : Status [value of FSS]
status_t LIS3DH_GetWHO_AM_I(u8_t* val)
    if( !LIS3DH_ReadReg(LIS3DH_WHO_AM_I, val) )
        return MEMS_ERROR;
    return MEMS_SUCCESS;
* Function Name  : LIS3DH_GetStatusAUX
* Description    : Read the AUX status register
* Input          : Char to empty by status register buffer
* Output         : None
* Return         : Status [MEMS_ERROR, MEMS_SUCCESS]
status_t LIS3DH_GetStatusAUX(u8_t* val)
    if( !LIS3DH_ReadReg(LIS3DH_STATUS_AUX, val) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetStatusAUXBIT
* Description    : Read the AUX status register BIT
* Input          : LIS3DH_STATUS_AUX_321OR, LIS3DH_STATUS_AUX_3OR, LIS3DH_STATUS_AUX_2OR, LIS3DH_STATUS_AUX_1OR,
                   LIS3DH_STATUS_AUX_321DA, LIS3DH_STATUS_AUX_3DA, LIS3DH_STATUS_AUX_2DA, LIS3DH_STATUS_AUX_1DA
* Output         : None
* Return         : Status of BIT [MEMS_ERROR, MEMS_SUCCESS]
status_t LIS3DH_GetStatusAUXBit(u8_t statusBIT, u8_t* val)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_STATUS_AUX, &value) )
        return MEMS_ERROR;
    if(statusBIT == LIS3DH_STATUS_AUX_321OR) {
        if(value &= LIS3DH_STATUS_AUX_321OR) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_3OR) {
        if(value &= LIS3DH_STATUS_AUX_3OR) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_2OR) {
        if(value &= LIS3DH_STATUS_AUX_2OR) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_1OR) {
        if(value &= LIS3DH_STATUS_AUX_1OR) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_321DA) {
        if(value &= LIS3DH_STATUS_AUX_321DA) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_3DA) {
        if(value &= LIS3DH_STATUS_AUX_3DA) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_2DA) {
        if(value &= LIS3DH_STATUS_AUX_2DA) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_STATUS_AUX_1DA) {
        if(value &= LIS3DH_STATUS_AUX_1DA) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    return MEMS_ERROR;
* Function Name  : LIS3DH_SetODR
* Description    : Sets LIS3DH Output Data Rate
* Input          : Output Data Rate
* Output         : None
status_t LIS3DH_SetODR(LIS3DH_ODR_t ov)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG1, &value) )
        return MEMS_ERROR;
    value &= 0x0f;
    value |= ov<<LIS3DH_ODR_BIT;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG1, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetTemperature
* Description    : Sets LIS3DH Output Temperature
* Input          : MEMS_ENABLE, MEMS_DISABLE
* Output         : None
* Note           : For Read Temperature by LIS3DH_OUT_AUX_3, LIS3DH_SetADCAux and LIS3DH_SetBDU
       functions must be ENABLE
status_t LIS3DH_SetTemperature(State_t state)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_TEMP_CFG_REG, &value) )
        return MEMS_ERROR;
    value &= 0xBF;
    value |= state<<LIS3DH_TEMP_EN;
    value |= state<<LIS3DH_ADC_PD;
    if( !LIS3DH_WriteReg(LIS3DH_TEMP_CFG_REG, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetADCAux
* Description    : Sets LIS3DH Output ADC
* Output         : None
status_t LIS3DH_SetADCAux(State_t state)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x7F;
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetAuxRaw
* Description    : Read the Aux Values Output Registers
* Input          : Buffer to empty
* Output         : Aux Values Registers buffer
status_t LIS3DH_GetAuxRaw(LIS3DH_Aux123Raw_t* buff)
    u8_t valueL;
    u8_t valueH;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_1_L, &valueL) )
        return MEMS_ERROR;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_1_H, &valueH) )
        return MEMS_ERROR;
    buff->AUX_1 = (u16_t)( (valueH << 8) | valueL )/16;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_2_L, &valueL) )
        return MEMS_ERROR;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_2_H, &valueH) )
        return MEMS_ERROR;
    buff->AUX_2 = (u16_t)( (valueH << 8) | valueL )/16;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_3_L, &valueL) )
        return MEMS_ERROR;
    if( !LIS3DH_ReadReg(LIS3DH_OUT_3_H, &valueH) )
        return MEMS_ERROR;
    buff->AUX_3 = (u16_t)( (valueH << 8) | valueL )/16;
* Function Name  : LIS3DH_GetTempRaw
* Description    : Read the Temperature Values by AUX Output Registers OUT_3_H
* Output         : Temperature Values Registers buffer
status_t LIS3DH_GetTempRaw(i8_t* buff)
    u8_t valueL;
    u8_t valueH;
        return MEMS_ERROR;
        return MEMS_ERROR;
    *buff = (i8_t)( valueH );
* Function Name  : LIS3DH_SetMode
* Description    : Sets LIS3DH Operating Mode
* Input          : Modality (LIS3DH_NORMAL, LIS3DH_LOW_POWER, LIS3DH_POWER_DOWN)
* Output         : None
status_t LIS3DH_SetMode(LIS3DH_Mode_t md)
    u8_t value;
    u8_t value2;
    status_t ret;
    static   u8_t ODR_old_value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG1, &value) ) {
        ret = MEMS_ERROR;
        goto out;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG4, &value2) ) {
        ret = MEMS_ERROR;
        goto out;
    if((value & 0xF0)==0)
        value = value | (ODR_old_value & 0xF0); //if it comes from POWERDOWN
    switch(md) {
        case LIS3DH_POWER_DOWN:
            ODR_old_value = value;
            value &= 0x0F;
            break;
        case LIS3DH_NORMAL:
            value &= 0xF7;
            value |= (MEMS_RESET<<LIS3DH_LPEN);
            value2 &= 0xF7;
            value2 |= (MEMS_SET<<LIS3DH_HR);   //set HighResolution_BIT
            break;
        case LIS3DH_LOW_POWER:
            value &= 0xF7;
            value |=  (MEMS_SET<<LIS3DH_LPEN);
            value2 &= 0xF7;
            value2 |= (MEMS_RESET<<LIS3DH_HR); //reset HighResolution_BIT
            break;
        default:
            ret = MEMS_ERROR;
            goto out;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG1, value) ) {
        ret = MEMS_ERROR;
        goto out;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG4, value2) ) {
        ret = MEMS_ERROR;
        goto out;
    ret = MEMS_SUCCESS;
out:
    return ret;
* Function Name  : LIS3DH_SetAxis
* Description    : Enable/Disable LIS3DH Axis
* Input          : LIS3DH_X_ENABLE/DISABLE | LIS3DH_Y_ENABLE/DISABLE | LIS3DH_Z_ENABLE/DISABLE
* Output         : None
* Note           : You MUST use all input variable in the argument, as example
status_t LIS3DH_SetAxis(LIS3DH_Axis_t axis)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xF8;
    value |= (0x07 & axis);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetFullScale
* Description    : Sets the LIS3DH FullScale
* Input          : LIS3DH_FULLSCALE_2/LIS3DH_FULLSCALE_4/LIS3DH_FULLSCALE_8/LIS3DH_FULLSCALE_16
* Output         : None
status_t LIS3DH_SetFullScale(LIS3DH_Fullscale_t fs)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG4, &value) )
        return MEMS_ERROR;
    value &= 0xCF;
    value |= (fs<<LIS3DH_FS);
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG4, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetBDU
* Description    : Enable/Disable Block Data Update Functionality
* Input          : ENABLE/DISABLE
* Output         : None
status_t LIS3DH_SetBDU(State_t bdu)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x7F;
    value |= (bdu<<LIS3DH_BDU);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetBLE
* Description    : Set Endianess (MSB/LSB)
* Input          : BLE_LSB / BLE_MSB
* Output         : None
status_t LIS3DH_SetBLE(LIS3DH_Endianess_t ble)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xBF;
    value |= (ble<<LIS3DH_BLE);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetSelfTest
* Description    : Set Self Test Modality
* Input          : LIS3DH_SELF_TEST_DISABLE/ST_0/ST_1
* Output         : None
status_t LIS3DH_SetSelfTest(LIS3DH_SelfTest_t st)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xF9;
    value |= (st<<LIS3DH_ST);
        return MEMS_ERROR;
* Function Name  : LIS3DH_HPFClick
* Description    : Enable/Disable High Pass Filter for click
* Input          : MEMS_ENABLE/MEMS_DISABLE
* Output         : None
status_t LIS3DH_HPFClickEnable(State_t hpfe)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG2, &value) )
        return MEMS_ERROR;
    value &= 0xFB;
    value |= (hpfe<<LIS3DH_HPCLICK);
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG2, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_HPFAOI1
* Description    : Enable/Disable High Pass Filter for AOI on INT_1
* Output         : None
status_t LIS3DH_HPFAOI1Enable(State_t hpfe)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xFE;
    value |= (hpfe<<LIS3DH_HPIS1);
        return MEMS_ERROR;
* Function Name  : LIS3DH_HPFAOI2
* Description    : Enable/Disable High Pass Filter for AOI on INT_2
* Output         : None
status_t LIS3DH_HPFAOI2Enable(State_t hpfe)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xFD;
    value |= (hpfe<<LIS3DH_HPIS2);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetHPFMode
* Description    : Set High Pass Filter Modality
* Input          : LIS3DH_HPM_NORMAL_MODE_RES/LIS3DH_HPM_REF_SIGNAL/
       LIS3DH_HPM_NORMAL_MODE/LIS3DH_HPM_AUTORESET_INT
* Output         : None
status_t LIS3DH_SetHPFMode(LIS3DH_HPFMode_t hpm)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x3F;
    value |= (hpm<<LIS3DH_HPM);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetHPFCutOFF
* Description    : Set High Pass CUT OFF Freq
* Input          : HPFCF [0,3]
* Output         : None
status_t LIS3DH_SetHPFCutOFF(LIS3DH_HPFCutOffFreq_t hpf)
    u8_t value;
    if (hpf > 3)
        return MEMS_ERROR;
        return MEMS_ERROR;
    value &= 0xCF;
    value |= (hpf<<LIS3DH_HPCF);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetFilterDataSel
* Description    : Set Filter Data Selection bypassed or sent to FIFO OUT register
* Input          : MEMS_SET, MEMS_RESET
* Output         : None
status_t LIS3DH_SetFilterDataSel(State_t state)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xF7;
    value |= (state<<LIS3DH_FDS);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetInt1Pin
* Description    : Set Interrupt1 pin Function
* Input          :  LIS3DH_CLICK_ON_PIN_INT1_ENABLE/DISABLE    | LIS3DH_I1_INT1_ON_PIN_INT1_ENABLE/DISABLE |
                    LIS3DH_I1_INT2_ON_PIN_INT1_ENABLE/DISABLE  | LIS3DH_I1_DRDY1_ON_INT1_ENABLE/DISABLE    |
                    LIS3DH_I1_DRDY2_ON_INT1_ENABLE/DISABLE     | LIS3DH_WTM_ON_INT1_ENABLE/DISABLE         |
                    LIS3DH_INT1_OVERRUN_ENABLE/DISABLE
* example        : SetInt1Pin(LIS3DH_CLICK_ON_PIN_INT1_ENABLE | LIS3DH_I1_INT1_ON_PIN_INT1_ENABLE |
                    LIS3DH_I1_INT2_ON_PIN_INT1_DISABLE | LIS3DH_I1_DRDY1_ON_INT1_ENABLE | LIS3DH_I1_DRDY2_ON_INT1_ENABLE |
                    LIS3DH_WTM_ON_INT1_DISABLE | LIS3DH_INT1_OVERRUN_DISABLE   )
* Note           : To enable Interrupt signals on INT1 Pad (You MUST use all input variable in the argument, as example)
* Output         : None
status_t LIS3DH_SetInt1Pin(LIS3DH_IntPinConf_t pinConf)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG3, &value) )
        return MEMS_ERROR;
    value &= 0x00;
    value |= pinConf;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG3, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetInt2Pin
* Description    : Set Interrupt2 pin Function
* Input          : LIS3DH_CLICK_ON_PIN_INT2_ENABLE/DISABLE   | LIS3DH_I2_INT1_ON_PIN_INT2_ENABLE/DISABLE |
                   LIS3DH_I2_INT2_ON_PIN_INT2_ENABLE/DISABLE | LIS3DH_I2_BOOT_ON_INT2_ENABLE/DISABLE |
                   LIS3DH_INT_ACTIVE_HIGH/LOW
* example        : LIS3DH_SetInt2Pin(LIS3DH_CLICK_ON_PIN_INT2_ENABLE/DISABLE | LIS3DH_I2_INT1_ON_PIN_INT2_ENABLE/DISABLE |
                   LIS3DH_INT_ACTIVE_HIGH/LOW)
* Note           : To enable Interrupt signals on INT2 Pad (You MUST use all input variable in the argument, as example)
* Output         : None
status_t LIS3DH_SetInt2Pin(LIS3DH_IntPinConf_t pinConf)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG6, &value) )
        return MEMS_ERROR;
    value &= 0x00;
    value |= pinConf;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG6, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetClickCFG
* Description    : Set Click Interrupt config Function
* Input          : LIS3DH_ZD_ENABLE/DISABLE | LIS3DH_ZS_ENABLE/DISABLE  | LIS3DH_YD_ENABLE/DISABLE  |
                   LIS3DH_YS_ENABLE/DISABLE | LIS3DH_XD_ENABLE/DISABLE  | LIS3DH_XS_ENABLE/DISABLE
* example        : LIS3DH_SetClickCFG( LIS3DH_ZD_ENABLE | LIS3DH_ZS_DISABLE | LIS3DH_YD_ENABLE |
                               LIS3DH_YS_DISABLE | LIS3DH_XD_ENABLE | LIS3DH_XS_ENABLE)
* Output         : None
status_t LIS3DH_SetClickCFG(u8_t status)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CLICK_CFG, &value) )
        return MEMS_ERROR;
    value &= 0xC0;
    value |= status;
    if( !LIS3DH_WriteReg(LIS3DH_CLICK_CFG, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetClickTHS
* Description    : Set Click Interrupt threshold
* Input          : Click-click Threshold value [0-127]
* Output         : None
status_t LIS3DH_SetClickTHS(u8_t ths)
    if(ths>127)
        return MEMS_ERROR;
    if( !LIS3DH_WriteReg(LIS3DH_CLICK_THS, ths) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetClickLIMIT
* Description    : Set Click Interrupt Time Limit
* Input          : Click-click Time Limit value [0-127]
* Output         : None
status_t LIS3DH_SetClickLIMIT(u8_t t_limit)
    if(t_limit>127)
        return MEMS_ERROR;
    if( !LIS3DH_WriteReg(LIS3DH_TIME_LIMIT, t_limit) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetClickLATENCY
* Description    : Set Click Interrupt Time Latency
* Input          : Click-click Time Latency value [0-255]
* Output         : None
status_t LIS3DH_SetClickLATENCY(u8_t t_latency)
    if( !LIS3DH_WriteReg(LIS3DH_TIME_LATENCY, t_latency) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetClickWINDOW
* Description    : Set Click Interrupt Time Window
* Input          : Click-click Time Window value [0-255]
* Output         : None
status_t LIS3DH_SetClickWINDOW(u8_t t_window)
    if( !LIS3DH_WriteReg(LIS3DH_TIME_WINDOW, t_window) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetClickResponse
* Description    : Get Click Interrupt Response by CLICK_SRC REGISTER
* Input          : char to empty by Click Response Typedef
* Output         : None
status_t LIS3DH_GetClickResponse(u8_t* res)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CLICK_SRC, &value) )
        return MEMS_ERROR;
    value &= 0x7F;
    if((value & LIS3DH_IA)==0) {
        *res = LIS3DH_NO_CLICK;
    } else {
        if (value & LIS3DH_DCLICK) {
            if (value & LIS3DH_CLICK_SIGN) {
                if (value & LIS3DH_CLICK_Z) {
                    *res = LIS3DH_DCLICK_Z_N;
                if (value & LIS3DH_CLICK_Y) {
                    *res = LIS3DH_DCLICK_Y_N;
                if (value & LIS3DH_CLICK_X) {
                    *res = LIS3DH_DCLICK_X_N;
            } else {
                    *res = LIS3DH_DCLICK_Z_P;
                    *res = LIS3DH_DCLICK_Y_P;
                    *res = LIS3DH_DCLICK_X_P;
        } else {
                    *res = LIS3DH_SCLICK_Z_N;
                    *res = LIS3DH_SCLICK_Y_N;
                    *res = LIS3DH_SCLICK_X_N;
            } else {
                    *res = LIS3DH_SCLICK_Z_P;
                    *res = LIS3DH_SCLICK_Y_P;
                    *res = LIS3DH_SCLICK_X_P;
    return MEMS_ERROR;
* Function Name  : LIS3DH_Int1LatchEnable
* Description    : reboot sensor, reset mem registers function
* Output         : None
status_t LIS3DH_RESET_MEM(void)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG5, &value) )
        return MEMS_ERROR;
    value &= 0x7F;
    value |= 1<<LIS3DH_BOOT;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG5, value) )
        return MEMS_ERROR;
* Description    : Enable Interrupt 1 Latching function
* Output         : None
status_t LIS3DH_Int1LatchEnable(State_t latch)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xF7;
    value |= latch<<LIS3DH_LIR_INT1;
        return MEMS_ERROR;
* Function Name  : LIS3DH_ResetInt1Latch
* Description    : Reset Interrupt 1 Latching function
* Input          : None
* Output         : None
status_t LIS3DH_ResetInt1Latch(void)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_INT1_SRC, &value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetIntConfiguration
* Description    : Interrupt 1 Configuration (without LIS3DH_6D_INT)
* Input          : LIS3DH_INT1_AND/OR | LIS3DH_INT1_ZHIE_ENABLE/DISABLE | LIS3DH_INT1_ZLIE_ENABLE/DISABLE...
* Output         : None
status_t LIS3DH_SetIntConfiguration(LIS3DH_Int1Conf_t ic)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_INT1_CFG, &value) )
        return MEMS_ERROR;
    value &= 0x40;
    value |= ic;
    if( !LIS3DH_WriteReg(LIS3DH_INT1_CFG, value) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetIntMode
* Description    : Interrupt 1 Configuration mode (OR, 6D Movement, AND, 6D Position)
* Input          : LIS3DH_INT_MODE_OR, LIS3DH_INT_MODE_6D_MOVEMENT, LIS3DH_INT_MODE_AND,
       LIS3DH_INT_MODE_6D_POSITION
* Output         : None
status_t LIS3DH_SetIntMode(LIS3DH_Int1Mode_t int_mode)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x3F;
    value |= (int_mode<<LIS3DH_INT_6D);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetInt6D4DConfiguration
* Description    : 6D, 4D Interrupt Configuration
* Input          : LIS3DH_INT1_6D_ENABLE, LIS3DH_INT1_4D_ENABLE, LIS3DH_INT1_6D_4D_DISABLE
* Output         : None
status_t LIS3DH_SetInt6D4DConfiguration(LIS3DH_INT_6D_4D_t ic)
    u8_t value;
    u8_t value2;
        return MEMS_ERROR;
    if( !LIS3DH_ReadReg(LIS3DH_CTRL_REG5, &value2) )
        return MEMS_ERROR;
    if(ic == LIS3DH_INT1_6D_ENABLE) {
        value &= 0xBF;
        value |= (MEMS_ENABLE<<LIS3DH_INT_6D);
        value2 &= 0xFB;
        value2 |= (MEMS_DISABLE<<LIS3DH_D4D_INT1);
    if(ic == LIS3DH_INT1_4D_ENABLE) {
        value &= 0xBF;
        value2 &= 0xFB;
        value2 |= (MEMS_ENABLE<<LIS3DH_D4D_INT1);
    if(ic == LIS3DH_INT1_6D_4D_DISABLE) {
        value &= 0xBF;
        value |= (MEMS_DISABLE<<LIS3DH_INT_6D);
        value2 &= 0xFB;
        return MEMS_ERROR;
    if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG5, value2) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_Get6DPosition
* Description    : 6D, 4D Interrupt Position Detect
* Input          : Byte to empty by POSITION_6D_t Typedef
* Output         : None
status_t LIS3DH_Get6DPosition(u8_t* val)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x7F;
    switch (value) {
        case LIS3DH_UP_SX:
            *val = LIS3DH_UP_SX;
            break;
        case LIS3DH_UP_DX:
            *val = LIS3DH_UP_DX;
            break;
        case LIS3DH_DW_SX:
            *val = LIS3DH_DW_SX;
            break;
        case LIS3DH_DW_DX:
            *val = LIS3DH_DW_DX;
            break;
        case LIS3DH_TOP:
            *val = LIS3DH_TOP;
            break;
        case LIS3DH_BOTTOM:
            *val = LIS3DH_BOTTOM;
            break;
* Function Name  : LIS3DH_SetInt1Threshold
* Description    : Sets Interrupt 1 Threshold
* Input          : Threshold = [0,31]
* Output         : None
status_t LIS3DH_SetInt1Threshold(u8_t ths)
    if (ths > 127)
        return MEMS_ERROR;
    if( !LIS3DH_WriteReg(LIS3DH_INT1_THS, ths) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetInt1Duration
* Description    : Sets Interrupt 1 Duration
* Input          : Duration value
* Output         : None
status_t LIS3DH_SetInt1Duration(LIS3DH_Int1Conf_t id)
    if (id > 127)
        return MEMS_ERROR;
    if( !LIS3DH_WriteReg(LIS3DH_INT1_DURATION, id) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_FIFOModeEnable
* Description    : Sets Fifo Modality
* Input          : LIS3DH_FIFO_DISABLE, LIS3DH_FIFO_BYPASS_MODE, LIS3DH_FIFO_MODE,
       LIS3DH_FIFO_STREAM_MODE, LIS3DH_FIFO_TRIGGER_MODE
* Output         : None
status_t LIS3DH_FIFOModeEnable(LIS3DH_FifoMode_t fm)
    u8_t value;
    if(fm == LIS3DH_FIFO_DISABLE) {
        if( !LIS3DH_ReadReg(LIS3DH_FIFO_CTRL_REG, &value) )
            return MEMS_ERROR;
        value &= 0x1F;
        value |= (LIS3DH_FIFO_BYPASS_MODE<<LIS3DH_FM);
        if( !LIS3DH_WriteReg(LIS3DH_FIFO_CTRL_REG, value) )           //fifo mode bypass
            return MEMS_ERROR;
            return MEMS_ERROR;
        value &= 0xBF;
        if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG5, value) )               //fifo disable
            return MEMS_ERROR;
    if(fm == LIS3DH_FIFO_BYPASS_MODE)   {
            return MEMS_ERROR;
        value &= 0xBF;
        value |= MEMS_SET<<LIS3DH_FIFO_EN;
        if( !LIS3DH_WriteReg(LIS3DH_CTRL_REG5, value) )               //fifo enable
            return MEMS_ERROR;
            return MEMS_ERROR;
        value &= 0x1f;
        value |= (fm<<LIS3DH_FM);                     //fifo mode configuration
            return MEMS_ERROR;
    if(fm == LIS3DH_FIFO_MODE)   {
            return MEMS_ERROR;
        value &= 0xBF;
            return MEMS_ERROR;
            return MEMS_ERROR;
        value &= 0x1f;
            return MEMS_ERROR;
    if(fm == LIS3DH_FIFO_STREAM_MODE)   {
            return MEMS_ERROR;
        value &= 0xBF;
            return MEMS_ERROR;
            return MEMS_ERROR;
        value &= 0x1f;
            return MEMS_ERROR;
    if(fm == LIS3DH_FIFO_TRIGGER_MODE)   {
            return MEMS_ERROR;
        value &= 0xBF;
            return MEMS_ERROR;
            return MEMS_ERROR;
        value &= 0x1f;
            return MEMS_ERROR;
* Function Name  : LIS3DH_SetTriggerInt
* Description    : Trigger event liked to trigger signal INT1/INT2
* Input          : LIS3DH_TRIG_INT1/LIS3DH_TRIG_INT2
* Output         : None
status_t LIS3DH_SetTriggerInt(LIS3DH_TrigInt_t tr)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xDF;
    value |= (tr<<LIS3DH_TR);
        return MEMS_ERROR;
* Function Name  : LIS3DH_SetWaterMark
* Description    : Sets Watermark Value
* Input          : Watermark = [0,31]
* Output         : None
status_t LIS3DH_SetWaterMark(u8_t wtm)
    u8_t value;
    if(wtm > 31)
        return MEMS_ERROR;
        return MEMS_ERROR;
    value &= 0xE0;
    value |= wtm;
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetStatusReg
* Description    : Read the status register
* Input          : char to empty by Status Reg Value
* Output         : None
status_t LIS3DH_GetStatusReg(u8_t* val)
    if( !LIS3DH_ReadReg(LIS3DH_STATUS_REG, val) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetStatusBIT
* Description    : Read the status register BIT
* Input          : LIS3DH_STATUS_REG_ZYXOR, LIS3DH_STATUS_REG_ZOR, LIS3DH_STATUS_REG_YOR, LIS3DH_STATUS_REG_XOR,
                   LIS3DH_STATUS_REG_ZYXDA, LIS3DH_STATUS_REG_ZDA, LIS3DH_STATUS_REG_YDA, LIS3DH_STATUS_REG_XDA,
       LIS3DH_DATAREADY_BIT
       val: Byte to be filled with the status bit
* Output         : status register BIT
status_t LIS3DH_GetStatusBit(u8_t statusBIT, u8_t* val)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_STATUS_REG, &value) )
        return MEMS_ERROR;
    switch (statusBIT) {
        case LIS3DH_STATUS_REG_ZYXOR:
            if(value &= LIS3DH_STATUS_REG_ZYXOR) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_ZOR:
            if(value &= LIS3DH_STATUS_REG_ZOR) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_YOR:
            if(value &= LIS3DH_STATUS_REG_YOR) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_XOR:
            if(value &= LIS3DH_STATUS_REG_XOR) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_ZYXDA:
            if(value &= LIS3DH_STATUS_REG_ZYXDA) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_ZDA:
            if(value &= LIS3DH_STATUS_REG_ZDA) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_YDA:
            if(value &= LIS3DH_STATUS_REG_YDA) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
        case LIS3DH_STATUS_REG_XDA:
            if(value &= LIS3DH_STATUS_REG_XDA) {
                *val = MEMS_SET;
            } else {
                *val = MEMS_RESET;
    return MEMS_ERROR;
* Function Name  : LIS3DH_GetAccAxesRaw
* Description    : Read the Acceleration Values Output Registers
* Input          : buffer to empity by AxesRaw_t Typedef
* Output         : None
//status_t LIS3DH_GetAccAxesRaw(char* buff)
//    u8_t transfer_size = 6;
//    SPIMasterBuffer[0] = LIS3DH_OUT_X_L| LIS3DH_READBIT | LIS3DH_MSBIT;
//    /* Check if we got an ACK or TIMEOUT error */
//    ASSERT(ic_spi_master_tx_rx((uint32_t *)NRF_SPI0,1,SPIMasterBuffer, transfer_size, buff));
//    return MEMS_SUCCESS;
* Function Name  : LIS3DH_GetInt1Src
* Input          : Char to empty by Int1 source value
* Output         : None
status_t LIS3DH_GetInt1Src(u8_t* val)
    if( !LIS3DH_ReadReg(LIS3DH_INT1_SRC, val) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetInt1SrcBit
* Input          : statusBIT: LIS3DH_INT_SRC_IA, LIS3DH_INT_SRC_ZH, LIS3DH_INT_SRC_ZL.....
*                  val: Byte to be filled with the status bit
* Output         : None
status_t LIS3DH_GetInt1SrcBit(u8_t statusBIT, u8_t* val)
    u8_t value;
        return MEMS_ERROR;
    if(statusBIT == LIS3DH_INT1_SRC_IA) {
        if(value &= LIS3DH_INT1_SRC_IA) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_ZH) {
        if(value &= LIS3DH_INT1_SRC_ZH) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_ZL) {
        if(value &= LIS3DH_INT1_SRC_ZL) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_YH) {
        if(value &= LIS3DH_INT1_SRC_YH) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_YL) {
        if(value &= LIS3DH_INT1_SRC_YL) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_XH) {
        if(value &= LIS3DH_INT1_SRC_XH) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_INT1_SRC_XL) {
        if(value &= LIS3DH_INT1_SRC_XL) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    return MEMS_ERROR;
* Function Name  : LIS3DH_GetFifoSourceReg
* Description    : Read Fifo source Register
* Input          : Byte to empty by FIFO source register value
* Output         : None
status_t LIS3DH_GetFifoSourceReg(u8_t* val)
    if( !LIS3DH_ReadReg(LIS3DH_FIFO_SRC_REG, val) )
        return MEMS_ERROR;
* Function Name  : LIS3DH_GetFifoSourceBit
* Description    : Read Fifo WaterMark source bit
* Input          : statusBIT: LIS3DH_FIFO_SRC_WTM, LIS3DH_FIFO_SRC_OVRUN, LIS3DH_FIFO_SRC_EMPTY
*       val: Byte to fill  with the bit value
* Output         : None
status_t LIS3DH_GetFifoSourceBit(u8_t statusBIT,  u8_t* val)
    u8_t value;
    if( !LIS3DH_ReadReg(LIS3DH_FIFO_SRC_REG, &value) )
        return MEMS_ERROR;
    if(statusBIT == LIS3DH_FIFO_SRC_WTM) {
        if(value &= LIS3DH_FIFO_SRC_WTM) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_FIFO_SRC_OVRUN) {
        if(value &= LIS3DH_FIFO_SRC_OVRUN) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    if(statusBIT == LIS3DH_FIFO_SRC_EMPTY) {
        if(value &= statusBIT == LIS3DH_FIFO_SRC_EMPTY) {
            *val = MEMS_SET;
        } else {
            *val = MEMS_RESET;
    return MEMS_ERROR;
* Function Name  : LIS3DH_GetFifoSourceFSS
* Description    : Read current number of unread samples stored in FIFO
* Input          : Byte to empty by FIFO unread sample value
* Output         : None
status_t LIS3DH_GetFifoSourceFSS(u8_t* val)
    u8_t value;
        return MEMS_ERROR;
    value &= 0x1F;
    *val = value;
* Function Name  : LIS3DH_SetSPIInterface
* Description    : Set SPI mode: 3 Wire Interface OR 4 Wire Interface
* Input          : LIS3DH_SPI_3_WIRE, LIS3DH_SPI_4_WIRE
* Output         : None
status_t LIS3DH_SetSPIInterface(LIS3DH_SPIMode_t spi)
    u8_t value;
        return MEMS_ERROR;
    value &= 0xFE;
    value |= spi<<LIS3DH_SIM;
        return MEMS_ERROR;
bool LIS3DH_enableFiFo(void)
    ASSERT(LIS3DH_SetTemperature(MEMS_ENABLE));
    /* Set data rate and power mode, and enable X/Y/Z */
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG1,
                           LIS3DH_CTRL_REG1_DATARATE_50HZ|    /* Normal mode, 10Hz */
                           LIS3DH_CTRL_REG1_XYZEN));           /* Enable X, Y and Z */
    // Settings for CTRL_REG2:
    // defaults
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG2, 0));
    // Settings for CTRL_REG3
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG3, 0));
    // Settings for CTRL_REG4:
    //CTRL_REG4| 7    6     5      4   3    2     1      0  |
    //   | BDU    BLE     FS1     FS2    HR    ST1   ST0   SIM|
    // FS1:FS2 -->g'range selection 00-->2g;01-->4g;10-->8g;11-->16g:
    // HR = 1  --> high resolution
    // SIM  -->if ==1 serial interface mode is selected(SPI)
    /* Settings for CTRL_REG4 Enable block update and set range to +/-2G */
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG4, 0x08));
    //  ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG5, 0x80));
    /* LIS3DH_CTRL_REG4_BLOCKDATAUPDATE   Enable block update */
    //  LIS3DH_CTRL_REG4_SCALE_2G));        /* +/-2G measurement range */
#ifdef TESTFIFO
    // Settings for CTRL_REG5:
    //CTRL_REG5| 7    6     5      4   3    2    1      0  |
    //    | BOOT   FIFO_EN     --   --      LIR_INT1    D4D_INT1      0   0  |
    ASSERT(LIS3DH_WriteReg( LIS3DH_CTRL_REG5 ,
                            BIT_6 |   /*Enable FIFO*/
                            BIT_3  /*lATCH INTERRUPT request on INT1_SRC register, with INT1_SRC register cleared by reading INT1_SRC itself*/
    //---TESTING CLICK WITH CTRL_REG_6:
    // Settings for CTRL_REG6:
    //CTRL_REG6| 7    | 6   | 5      | 4     | 3    | 2   | 1     | 0  |
    //    | I2_CLICKen  | I2_INT1   | 0   | BOOT_I1 | 0       |      | H_L-ACTIVE  |   -- |
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG6 ,
                           BIT_7 | BIT_6)); /* enable tap and double tap interruppts on INT2 pin*/
    //CLICK_CFG| 7    6     5      4   3    2     1      0  |
    //   | --    --   ZD(DOUB) ZS(SING) YD     YS   XD     XS |
    ASSERT(LIS3DH_WriteReg( LIS3DH_CLICK_CFG ,
                            BIT_5));//Enable interrupt double CLICK-CLICK on Z axis  enable interrupt request on measured accel. value higher than preset threshold
    //CLICK_THS
    //Threshold for click detection (arbitary value) 1LSb = fullscale/128
    ASSERT(LIS3DH_WriteReg( LIS3DH_CLICK_THS , 0x03 ));
    //TIME_LIMIT
    //Time limit a short time frame where in which click is recognised when
    //1.corresponding value in that axis exceeds threshold and
    // 2.comes below threshold.
    // To get detected both should happen in this time limit.
    ASSERT(LIS3DH_WriteReg( LIS3DH_TIME_LIMIT , 0x33 ));
    ASSERT(LIS3DH_WriteReg( LIS3DH_TIME_LATENCY , 0xFF ));
    /* Enable FIFO */
    ASSERT(LIS3DH_WriteReg(LIS3DH_FIFO_CTRL_REG,
                           BIT_6 /* FIFO MODE, trigger signal on INT1 */
    /* Enable interrupt */
    ASSERT(LIS3DH_WriteReg(LIS3DH_INT1_CFG,
#endif
    // Settings for INT1_CFG
    // defaults
    // Settings for INT1_THS
    // defaults
    // Settings for INT1_DUR
    // Defaults
    return true;
void LIS3DH_config_wake_int(bool enable)
#ifdef FEATURE_DEBUG1
    char index,value;
    for(index = 0x21; index <= 0x3D; index ++) {
        LIS3DH_ReadReg(index, &value);
        pr_info("--add:0x%x==v:0x%x \n",index,value);
        // sprintf(str,"--add:0x%x==v:0x%x \r\n",index,value);
        // simple_uart_putstring(str);
#endif
     LIS3DH_WriteReg(LIS3DH_CTRL_REG1,0xA7);
     LIS3DH_WriteReg(LIS3DH_CTRL_REG2,0);
     LIS3DH_WriteReg(LIS3DH_CTRL_REG3,0x40);
     LIS3DH_WriteReg(LIS3DH_CTRL_REG4,00);
     LIS3DH_WriteReg(LIS3DH_CTRL_REG5,0x8);
     LIS3DH_WriteReg(LIS3DH_INT1_THS,0x10);
     LIS3DH_WriteReg(LIS3DH_INT1_DURATION,0);
     LIS3DH_WriteReg(LIS3DH_INT1_CFG,0x3F);
     ASSERT(LIS3DH_SetMode(LIS3DH_NORMAL));
    if(enable) {
        LIS3DH_SetInt1Threshold(33); // 1100 mg        1100/() (35:1.085g)  (34:1.054g) (33:1.023)
        LIS3DH_SetInt1Duration(0);
        LIS3DH_SetIntMode(LIS3DH_INT_MODE_OR);
        LIS3DH_SetInt6D4DConfiguration(LIS3DH_INT1_6D_4D_DISABLE);
        LIS3DH_Int1LatchEnable(MEMS_ENABLE);
        LIS3DH_SetInt1Pin(LIS3DH_CLICK_ON_PIN_INT1_DISABLE | LIS3DH_I1_INT1_ON_PIN_INT1_ENABLE |
                          LIS3DH_I1_INT2_ON_PIN_INT1_DISABLE | LIS3DH_I1_DRDY1_ON_INT1_DISABLE | LIS3DH_I1_DRDY2_ON_INT1_DISABLE |
                          LIS3DH_WTM_ON_INT1_DISABLE | LIS3DH_INT1_OVERRUN_DISABLE   );
        LIS3DH_SetIntConfiguration(LIS3DH_INT1_OR |
                                   LIS3DH_INT1_ZHIE_ENABLE|
                                   LIS3DH_INT1_ZLIE_DISABLE|
                                   LIS3DH_INT1_YHIE_ENABLE|
                                   LIS3DH_INT1_YLIE_DISABLE|
                                   LIS3DH_INT1_XHIE_ENABLE|
                                   LIS3DH_INT1_XLIE_DISABLE);// z  Low and High int
    } else {
        LIS3DH_SetInt1Pin(LIS3DH_CLICK_ON_PIN_INT1_DISABLE | LIS3DH_I1_INT1_ON_PIN_INT1_DISABLE |
                          LIS3DH_WTM_ON_INT1_DISABLE | LIS3DH_INT1_OVERRUN_DISABLE);
        LIS3DH_SetIntConfiguration(LIS3DH_INT1_AND |
                                   LIS3DH_INT1_ZHIE_DISABLE|
                                   LIS3DH_INT1_YHIE_DISABLE|
                                   LIS3DH_INT1_XHIE_DISABLE|
    for(index = 0x20; index <= 0x3D; index ++) {
        // sprintf(str,"config add:0x%x==v:0x%x \r\n",index,value);
        pr_info("config add:0x%x==v:0x%x \n",index,value);
    index = 0x31;
    index = 0x25;
#endif
uint32_t LIS3DH_getfifo(char * buff)
//    uint8_t i = 0;
    uint8_t fss = 0;
    uint8_t ovrun;
    LIS3DH_GetFifoSourceBit(LIS3DH_FIFO_SRC_OVRUN, &ovrun);
    LIS3DH_GetFifoSourceFSS(&fss);
#define ACC_DATA_LEN 32
    if(MEMS_SET == ovrun){
        fss = ACC_DATA_LEN;
    fss = (fss >> 2) << 2;
//    pr_info( "FSS len %d, ovrun:%d\n", fss, ovrun);
    ic_spi_master_tx_rx((uint32_t *)NRF_SPI0, 1, SPIMasterBuffer, 6*fss, (uint8_t*)(buff));
//    for(i = 0; i < fss; i++) {
//        ic_spi_master_tx_rx((uint32_t *)NRF_SPI0, 1, SPIMasterBuffer, 6, (uint8_t*)(buff + i * 6));
#ifdef FIFO_STREAM_MODE
    //ASSERT(LIS3DH_FIFOModeEnable(LIS3DH_FIFO_STREAM_MODE));
#else
    LIS3DH_FIFOModeEnable(LIS3DH_FIFO_BYPASS_MODE);
    LIS3DH_FIFOModeEnable(LIS3DH_FIFO_MODE);
#endif
    return fss * 6;
uint8_t LIS3DH_Init( LIS3DH_ODR_t freq )
    // bool init_succed;
    uint8_t whoami;
    uint8_t data_t = 0;
    /* Initialise SPI */
    /*!< Sample data at rising edge of clock and shift serial data at falling edge */
    /*!< MSb first */
    uint32_t *spi_base_address = spi_master_init(SPI0,SPI_MODE0,false);
    if (spi_base_address == 0) {
        return false;
    /* get device WHO_AM_I first to see if it exists! */
    ASSERT(LIS3DH_ReadReg(LIS3DH_WHO_AM_I,&whoami));
    ASSERT(whoami == 0x33);
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG1, 0));
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG4, 0));
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG5, 0));
    ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG6, 0));
    ASSERT(LIS3DH_FIFOModeEnable(LIS3DH_FIFO_DISABLE));
    ASSERT(LIS3DH_SetAxis(LIS3DH_X_ENABLE|LIS3DH_Y_ENABLE|LIS3DH_Z_ENABLE));//
    ASSERT(LIS3DH_SetMode(LIS3DH_LOW_POWER)); //ASSERT(LIS3DH_SetMode(LIS3DH_NORMAL));//ASSERT(LIS3DH_SetMode(LIS3DH_LOW_POWER));
    ASSERT(LIS3DH_SetODR(freq));
    LIS3DH_SetFullScale(LIS3DH_FULLSCALE_4);
    ASSERT(LIS3DH_SetBDU(MEMS_ENABLE));
    LIS3DH_FIFOModeEnable(LIS3DH_FIFO_STREAM_MODE);
#else
#endif
    LIS3DH_SetClickCFG(0);
    LIS3DH_SetIntConfiguration(0);
    LIS3DH_ReadReg(0x3f,&data_t);
    data_t = data_t | 0x80;
    LIS3DH_WriteReg(0x3f, data_t);
                for(whoami = 0;whoami <0x20; whoami ++) {
        ASSERT(LIS3DH_ReadReg(LIS3DH_CTRL_REG1+whoami,&data_t));
        LOG(3,"gsensor:%#x value :%#x \r\n", LIS3DH_CTRL_REG1+whoami,data_t);
    return true;
uint8_t LIS3DH_reset(void)
    ASSERT(LIS3DH_RESET_MEM());
    return true;
    @brief  Initialises the SPI block
    1+196 bytes
  197*8 = 1576bits
  1576 /(8*1024*1024)=0.188ms
#define TESTFIFO 1
#if 0
bool LIS3DH_test()
    uint8_t index;
    uint8_t values[256];
    uint32_t pg_size;
    //ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG2,0));
    while(1) {
        //ASSERT(LIS3DH_WriteReg(LIS3DH_CTRL_REG2,ii));
        for(index = 0;index <20; index ++) {
            ASSERT(LIS3DH_ReadReg(LIS3DH_CTRL_REG1+index,values+index));
            //simple_uart_put(values[index]);
        for(pg_size = 0xfffff; pg_size > 0; pg_size --)
         for(index = 0;index <6; index ++)
            ASSERT(LIS3DH_ReadReg(LIS3DH_OUT_X_L+index,acc+index));
            for(pg_size = 0xffff; pg_size > 0; pg_size --);
          simple_uart_put(0x55);
          simple_uart_put(acc[1]);
          simple_uart_put(acc[3]);
          simple_uart_put(acc[5]);
    return true;
#endif
/******************* (C) COPYRIGHT 2013 Bidu *****END OF FILE****/
#endif
LIS3DH.pdf
693.12 KB, 下載次數(shù): 20, 下載積分: 黑幣 -5
3DH datasheet
