查看: 5027|回復(fù): 9
單片機(jī)雙機(jī)通信能不能傳送數(shù)組
ID:147040 發(fā)表于 2016-11-15 11:11 來自手機(jī) | 顯示全部樓層 |閱讀模式
假如甲單片機(jī)發(fā)送數(shù)組char a [4] ={1,2,3,4};SBUF=a;乙單片機(jī)接收char b [4];
該怎么接收,接收完成后a數(shù)組與b數(shù)組的值是否完全一致?
ID:1 發(fā)表于 2016-11-15 11:18 | 顯示全部樓層
  1. //============================================
  2. B 機(jī)(顯示數(shù)據(jù))的程序如下:
  3. //--------------------------------
  4. #include<reg52.h>
  5. unsigned char  re_i = 0, r_buf[7] = {0,0,0,0,0,0,0};
  6. unsigned char  a = 13, b = 57, c = 40, d;
  7. //--------------------------------
  8. void delayms(unsigned int xms)
  9. {
  10.     unsigned  int i, j;
  11.     for(i = xms; i > 0; i--)  for(j = 110; j > 0; j--);
  12. }
  13. //--------------------------------
  14. void display()
  15. {
  16.     char  i, dis[6];
  17.     char code table[] = {
  18.       0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xd8,0x80,0x90};
  19.     char code WEI[] = {1,2,4,8,16,32};
  20.     dis[0] = a / 10; dis[1] = a % 10;
  21.     dis[2] = b / 10; dis[3] = b % 10;
  22.     dis[4] = c / 10; dis[5] = c % 10;
  23.     for (i = 0; i < 6; i++) {
  24.       P0 = table[dis[i]];
  25.       P2 = WEI[i]; delayms(10); P2 = 0;
  26.     }
  27. }
  28. //--------------------------------
  29. init()
  30. {
  31.     PCON = 0;
  32.     SCON = 0x50;
  33.     TMOD = 0x20;
  34.     TH1 = 0xfd;
  35.     TL1 = 0xfd;
  36.     TR1 = 1;
  37.     ES = 1;
  38.     EA = 1;
  39. }
  40. //--------------------------------
  41. main()        //乙機(jī)主函數(shù)
  42. {
  43.     init();
  44.     while(1) {
  45.       display();
  46.     }
  47. }
  48. //--------------------------------
  49. recv_abc()  interrupt 4  //乙機(jī)接收
  50. {
  51.     if (RI) {
  52.       RI = 0;
  53.       d = SBUF;
  54.       if (d == '
  55. )  re_i = 0;
  56.       r_buf[re_i] = d;
  57.       re_i++;
  58.       if (re_i == 7) {
  59.         re_i = 0;
  60.         a = (r_buf[1] - '0') * 10 + (r_buf[2] - '0');
  61.         b = (r_buf[3] - '0') * 10 + (r_buf[4] - '0');
  62.         c = (r_buf[5] - '0') * 10 + (r_buf[6] - '0');
  63.       }
  64.     }
  65. }
  66. //============================================
  67. A 機(jī)(產(chǎn)生數(shù)據(jù))的程序如下:
  68. //--------------------------------
  69. #include<reg52.h>
  70. unsigned char  a = 13, b = 57, c = 40, d;
  71. bit  sec;
  72. //--------------------------------
  73. init()
  74. {
  75.     PCON = 0;
  76.     SCON = 0x50;
  77.     TMOD = 0x21;
  78.     TH1 = 0xfd;
  79.     TL1 = 0xfd;
  80.     TR1 = 1;
  81.     EA = 1;
  82.     TH0 = 0x4c;
  83.     TR0 = 1;
  84.     ET0 = 1;
  85. }
  86. //--------------------------------
  87. send(unsigned char x)    //甲機(jī)發(fā)送
  88. {
  89.     SBUF = x;  while(!TI);  TI = 0;
  90. }
  91. //--------------------------------
  92. main()        //甲機(jī)主函數(shù)
  93. {
  94.     init();
  95.     while(1) {
  96.       if(sec) {
  97.         sec = 0;
  98.         send('
  99. );
  100.         send(a / 10 + '0'); send(a % 10 + '0');
  101.         send(b / 10 + '0'); send(b % 10 + '0');
  102.         send(c / 10 + '0'); send(c % 10 + '0');
  103.     } }
  104. }
  105. //--------------------------------
  106. T0_INT()  interrupt 1  //50ms定時(shí)中斷函數(shù)
  107. {
  108.     TH0 = 0x4c;
  109.     d++;
  110.     if (d >= 2) {  //20
  111.       d = 0;
  112.       sec = 1;
  113.       c++;
  114.       if (c == 60) {
  115.         c = 0;
  116.         b++;
  117.         if (b == 60) {
  118.           b = 0;
  119.           a++;
  120.           if (a == 24) a = 0;
  121.     } } }
  122. }
  123. //============================================
  124. 上述的兩個(gè)程序,需分別編譯,生成不同 HEX 文件;再分別用兩個(gè)單片機(jī)來裝入。
  125. 程序執(zhí)行后,即可顯示出來前面插圖的效果。B 機(jī)的顯示器,每秒更新一次數(shù)據(jù)。
  126. 當(dāng)把中間的開關(guān)斷開后,顯示的數(shù)據(jù)便會(huì)停頓,不變了。
  127. 再把中間的開關(guān)接通后,顯示又會(huì)變化,而且數(shù)據(jù)并不受斷開的影響。
  128. 這說明,顯示的內(nèi)容,明顯是從 A 機(jī)傳送來的。
  129. //============================================
  130. 本題目,需要傳送的數(shù)據(jù)有時(shí)、分、秒共三個(gè),這就屬于多字節(jié)的串行通信。
  131. 單片機(jī)的串行通信,每次只能傳送一個(gè)字節(jié),即 0~255。
  132. 多字節(jié)的數(shù)據(jù)傳送,需要制訂協(xié)議。
  133. 否則,連續(xù)傳送一個(gè)一個(gè)的字節(jié),到了接收方,也不知道哪個(gè)是時(shí)、哪個(gè)是分、哪個(gè)是秒。
  134. 這時(shí),一般要采用 ASCII 碼來傳送。
  135. 用 0~9,即代表了一系列有用的數(shù)據(jù)。
  136. 再用一個(gè) 0~9 之外的符號(hào),當(dāng)做《數(shù)據(jù)頭》,就行了。
  137. 本程序,就是以美元符 $ 當(dāng)做數(shù)據(jù)頭。
  138. 傳送了 $ 之后,接著就傳送時(shí)的十位數(shù)、時(shí)的個(gè)位數(shù)、分的十位數(shù)、分的位數(shù)、秒的個(gè)位數(shù)。
  139. 每次發(fā)送數(shù)據(jù),就連續(xù)的發(fā)出七個(gè)字節(jié)。
  140. 接收方收到了 $ 之后,就把后面再收到的當(dāng)做時(shí)、分、秒的十位、個(gè)位保存。
  141. 當(dāng)收齊了七個(gè)字節(jié),就把這后面的六個(gè)字節(jié),送去顯示。
ID:111634 發(fā)表于 2016-11-15 12:22 | 顯示全部樓層
為什么不可以?
ID:147040 發(fā)表于 2016-11-15 13:22 來自手機(jī) | 顯示全部樓層
admin 發(fā)表于 2016-11-15 11:18
簡(jiǎn)直帥的掉渣,我基本懂了。我還有兩個(gè)比較2的問題,
第一個(gè),  send(a / 10 + '0');   a = (r_buf[1] - '0')        這里的+'0'  和  -'0'  是什么意思?
第二個(gè),如果SBUF=120;那么發(fā)送是把120一塊發(fā)送過去,還是分三次‘1’,‘2’,‘0’發(fā)送。
如果我定義char a=120;SBUF=a;那么有是分幾次發(fā)送。
再次感謝!
ID:147040 發(fā)表于 2016-11-15 13:23 來自手機(jī) | 顯示全部樓層
zl2168 發(fā)表于 2016-11-15 12:22
為什么不可以?
菜鳥不太懂(;`O)o
ID:148019 發(fā)表于 2016-11-15 13:52 | 顯示全部樓層
應(yīng)該是不一致的
ID:81808 發(fā)表于 2016-11-15 23:19 | 顯示全部樓層
lucky666 發(fā)表于 2016-11-15 13:22
第一個(gè),  send(a / 10 + '0');   a = (r_buf[1] - ...
第一個(gè),是數(shù)字與ASCII轉(zhuǎn)換;第二個(gè),分一次發(fā)送,改善的是120的16進(jìn)制,就是0x78,二進(jìn)制是_0111_1000
ID:147040 發(fā)表于 2016-11-16 00:05 來自手機(jī) | 顯示全部樓層
yanjibao 發(fā)表于 2016-11-15 23:19
恩,感謝感謝,又學(xué)到了!
ID:148258 發(fā)表于 2016-11-16 15:07 | 顯示全部樓層
當(dāng)然可以了
ID:153758 發(fā)表于 2016-12-10 19:53 來自手機(jī) | 顯示全部樓層
用$當(dāng)數(shù)據(jù)頭,可是在keil里輸入$,編譯會(huì)出錯(cuò)。
