查看: 1688|回復(fù): 0
幫忙看看 51的定時(shí)器點(diǎn)亮數(shù)碼管編程從00-99對(duì)嗎?
ID:148777 發(fā)表于 2016-11-19 07:09 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg51.h>
sbit dula=P2^6;
sbit wela=P2^7;
uchar num,dunum;
uchar code table_du[]={
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
display(uint);
delay(uchar);
        EA=1;
        ET0=1;
        TMOD=0x01;
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        TR0=1;
     if(num==20)
          num=0;
            if(dunum==100);
                 dunum=0;
                 dunum++;
  display(dunum);
void time0() interrupt 1
{TH0=(65536-50000)/256;
  num++;
display(uint dunum)
            P0=table_du[dunum/10];
                dula=1;
                dula=0;
                P0=0xfe;
                wela=1;
                wela=0;
                delay(145);
                P0=table_du[dunum%10];
                dula=1;
                dula=0;
                P0=0xfd;
                wela=1;
                wela=0;
                delay(145);
                return(0);
         delay(uchar x)
         uchar a,b;
                for(a=x;a>0;a--)
                for(b=200;b>0;b--);
                return(0);
