查看: 1706|回復(fù): 0
單片機(jī)1602顯示程序
ID:149673 發(fā)表于 2016-11-23 11:02 | 只看該作者 回帖獎勵 |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
uchar code table[]="  I LOVE YOU!";
uchar code table1[]="  我愛單片機(jī)";
sbit lcden=P3^4;
sbit lcdrs=P3^5;
sbit dula=P2^6;
sbit wela=P2^7;
uchar num;
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void write_com(uchar com)
        lcdrs=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_data(uchar date)
        lcdrs=1;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void init()
        dula=0;
        wela=0;
        lcden=0;
        write_com(0x38);
        write_com(0x0f);
        write_com(0x06);
        write_com(0x01);
        init();
        write_com(0x82);
        for(num=0;num<11;num++)
                write_data(table[num]);
                delay(5);
        write_com(0x80+0x41);
        for(num=0;num<13;num++)
                write_data(table1[num]);
                delay(5);
        while(1);
