查看: 2687|回復(fù): 1
LED點(diǎn)陣C語言程序
ID:147427 發(fā)表于 2016-11-30 18:53 | 顯示全部樓層 |閱讀模式
#include<reg52.h>
#define uint  unsigned int
sbit d_led=P2^5;
sbit dula=P2^6;
sbit wela=P2^7;
uchar code table[]={                        //列顯示數(shù)組
0xFF,0xFF,0xDB,0xA5,0xBD,0xDB,0xE7,0xFF,
0xff,0xff,0xff,0xff,0xff,0xff,0xff,0xff,
0xFF,0xC3,0xBD,0xBB,0xF7,0xEF,0xDF,0xC1
uchar code table1[]={                 //行顯示數(shù)組
0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80
delay(uint z)
          while(z--);
{        uchar i,j,k,a;
        wela=0;
                a=20;
                while(a)
                        for(i=0;i<8;i++)
                                dula=1;                  //列顯示
                                P0=table[j++];
                                dula=0;
                                d_led=1;           //行顯示
                                P0=table1[i];
                                d_led=0;
                                delay(200);
                                d_led=1;    //清屏
                                P0=0x00;
                                d_led=0;
                        j++;
                 j++;
                 j=k;
                 if(k>32)
                         k=0;
                 i=0;
相關(guān)帖子
ID:140371 發(fā)表于 2016-12-1 17:13 | 顯示全部樓層
將 ˋ主程式段改成: (試看看)
     for(j=0;j<2;j++)
              for(k=0;k<240;k++)
                for(i=0;i<8;i++)
                                dula=1;                  //列顯示
                                P0=table[j*8+i];
                                dula=0;
                                d_led=1;           //行顯示
                                P0=table1[i];
                                d_led=0;
                                delay(200);
                                d_led=1;    //清屏
                                P0=0x00;
                                d_led=0;
