查看: 1741|回復(fù): 0
呼吸燈單片機(jī)源碼
ID:152303 發(fā)表于 2016-12-5 15:16 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include <AT89X52.h>
#define MAX 0x50   //定時(shí)上限定義
#define MIN 0x00   //定時(shí)下限定義
#define TIMELINE 11         //時(shí)間分頻常數(shù)
#define TRUE  1
#define FALSE 0             //標(biāo)志位常數(shù)
unsigned int TimeCounter;
bit ArrowFlg = 0;         //方向標(biāo)志位
unsigned char upCounter,downCounter;    //增加計(jì)數(shù)器和減少計(jì)數(shù)器
sbit LED=P2^0;
//T0的中斷服務(wù)子函數(shù)
void T0Deal() interrupt 1 using 0
        TH0=0xf1;
        TL0=0xf1;
        TR0=1;
        TimeCounter++;  //定時(shí)計(jì)數(shù)器增加
        if(TimeCounter == TIMELINE)
                if((upCounter == MAX)&&(downCounter == MIN))  //計(jì)數(shù)方向標(biāo)志位切換
      ArrowFlg = FALSE;
                if((upCounter == MIN)&&(downCounter == MAX))
      ArrowFlg= TRUE;
                if(ArrowFlg == 1)   //如果是增加計(jì)數(shù)
      upCounter++;
      downCounter--;
                else               //如果是減少計(jì)數(shù)
      upCounter--;
      downCounter++;
                TimeCounter=0;
//延時(shí)函數(shù)
void Delay(unsigned int i)
        unsigned int j;
        while(i--)
                for(j=0;j<32;j++);     //延時(shí)
        upCounter = MIN;
        downCounter = MAX;     //計(jì)數(shù)器初始化
        TMOD = 0x01;          //設(shè)置定時(shí)器工作方式
        TH0 = 0xF0;
        TL0 = 0xF0 ;          //T0初始化值
        EA = 1;
        ET0 = 1;              //開中斷
        TR0 = 1;              //啟動(dòng)T0
                LED=0;            //輸出變化的PWM波形
                Delay(downCounter);
                LED=1;
                Delay(upCounter);
