一個貪食蛇的程序,下面是仿真原理圖,以及程序運(yùn)行效果:
貪食蛇的仿真工程文件和所有源碼下載:
貪吃蛇.rar
(221.89 KB, 下載次數(shù): 20)
2016-12-13 18:52 上傳
點(diǎn)擊文件名下載附件
部分源程序預(yù)覽:
- #include "t6963c.h"
- #include "at89x51.h"
- #include "MoveDeal.h"
- #include "160128_driver.h"
- | 注意:晶振為22.1184MHz |
- //按鍵端口宏定義
- #define KEY_UP_MOVE P1_0 //上移鍵端口
- #define KEY_LEFT_MOVE P1_1 //左移鍵端口
- #define KEY_RIGHT_MOVE P1_2 //右移鍵端口
- #define KEY_DOWN_MOVE P1_3 //下移鍵端口
- #define KEY_OK P1_4 //確定鍵端口
- #define KEY_SPEED_MOVE P3_2 //加速鍵端口
- #define KEY_CUSTOMS P3_3 //選關(guān)鍵端口
- #define KEY_RESTORAL P3_4 //復(fù)位鍵端口
- //全局變量定義
- //游戲速度,初始值為GRADE_1(1秒移動一次蛇頭)
- unsigned char m_Speed = GRADE_1;
- //更新顯示標(biāo)志,當(dāng)m_Flag為1時要刷新界面
- bit m_Flag = 0;
- //更新時間標(biāo)志,當(dāng)m_TimeFlag為1時要刷新時間
- bit m_TimeFlag = 0;
- //選關(guān)按鈕是否被按下標(biāo)志位
- bit m_IsChoose = 0;
- //時間變量
- unsigned int m_Time = 0;
- //蛇頭運(yùn)動方向,初始值為MOVE_DOWN(默認(rèn)向下運(yùn)動)
- unsigned char m_MoveState = MOVE_DOWN;
- //延時10ms子程序(為鍵盤消抖服務(wù))
- void Delay_10ms()
- unsigned char a, b, c;
- for (a = 0; a < 10; a++)
- for (b = 0; b < 3; b++)
- for (c = 0; c < 220; c++);
- /*清除字符函數(shù)*/
- void ClearChar()
- Set_xy(7,9);
- Write_8_Data(0,NOC_WR);//G
- Set_xy(7,10);
- Write_8_Data(0,NOC_WR);//A
- Set_xy(7,11);
- Write_8_Data(0,NOC_WR);//M
- Set_xy(7,12);
- Write_8_Data(0,NOC_WR);//E
- Set_xy(7,15);
- Write_8_Data(0,NOC_WR);//O
- Set_xy(7,16);
- Write_8_Data(0,NOC_WR);//V
- Set_xy(7,17);
- Set_xy(7,18);
- Write_8_Data(0,NOC_WR);//R
- //游戲結(jié)束或復(fù)位時的while循環(huán)
- void Loop()
- while (1) /*判斷確定建是否按下,屏蔽其他鍵的功能*/
- if (!KEY_OK)
- Delay_10ms();
- if(!KEY_OK)
- while(!KEY_OK); /*等待確定鍵被按下*/
- m_Time = 0; /*初始時間*/
- ClearChar(); /*清除字符*/
- RandFood(); /*隨機(jī)食物生成*/
- break;
- /*-----------------------------主程序開始---------------------------------*/
- void main()
- TMOD = 0x01; /*定時器設(shè)置(只用到了定時器1)*/
- InitializeSeries(); /*串口初始化*/
- TH0 = 0x4C;TL0 = 0x00; /*定時器0初始值設(shè)定(25ms中斷一次)*/
- EA = TR0 = 1; /*開啟定時器0定時*/
- Init_disply(0); /*初始化開機(jī)界面顯示*/
- SendString("Relive childhood popularity."); /*虛擬終端顯示*/
- SendString("Challenge the limits of intellectual.");
- SendString("GreedySnaker based on single-chip design.\r");
- SendString("Game instructions:");
- SendString("[0] key is Choice_Customs.");
- SendString("[1] key is Left_Move.");
- SendString("[2] key is Down_Move.");
- SendString("[3] key is Right_Move.");
- SendString("[5] key is On_Move.");
- SendString("[Enter] key is pause.");
- SendString("[SpaceBar] key is SpeedUp_Move.");
- while(1) /*判斷確定建是否按下,屏蔽其他鍵的功能*/
- if(!KEY_OK)
- Delay_10ms();
- if(!KEY_OK)
- while(!KEY_OK);
- break;
- Circle(63, 79, 60, 0); /*清除圓*/
- Clear_LCD(); /*清屏顯示*/
- Line(63, 0, 63, 127, 1); /*畫分隔線*/
- InitStruct(); /*初始化結(jié)構(gòu)體數(shù)組*/
- Init_disply(1); /*初始化游戲開始界面顯示*/
- ET0=1; /*開啟定時器0中斷*/
- while(1) /*進(jìn)入主循環(huán),鍵盤掃描開始,響應(yīng)按鍵事件*/
- if(!KEY_LEFT_MOVE) /*響應(yīng)向左運(yùn)動事件*/
- Delay_10ms();
- while(!KEY_LEFT_MOVE);
- if (m_MoveState != MOVE_RIGHT) /*如果蛇頭運(yùn)動方向向右,直接跳過*/
- m_MoveState = MOVE_LEFT; /*刷新蛇頭運(yùn)動方向(向左)*/
- if(!KEY_RIGHT_MOVE) /*響應(yīng)向右運(yùn)動事件*/
- Delay_10ms();
- while(!KEY_RIGHT_MOVE);
- if (m_MoveState != MOVE_LEFT) /*如果蛇頭運(yùn)動方向向左,直接跳過*/
- m_MoveState = MOVE_RIGHT; /*刷新蛇頭運(yùn)動方向(向右)*/
- if(!KEY_UP_MOVE) /*響應(yīng)向上運(yùn)動事件*/
- Delay_10ms();
- if(!KEY_UP_MOVE)
- while(!KEY_UP_MOVE);
- if (m_MoveState != MOVE_DOWN) /*如果蛇頭運(yùn)動方向向下,直接跳過*/
- m_MoveState = MOVE_UP; /*刷新蛇頭運(yùn)動方向(向上)*/
- if (!KEY_DOWN_MOVE) /*響應(yīng)向下運(yùn)動事件*/
- Delay_10ms();
- while (!KEY_DOWN_MOVE);
- if (m_MoveState != MOVE_UP) /*如果蛇頭運(yùn)動方向向上,直接跳過*/
- m_MoveState = MOVE_DOWN; /*刷新蛇頭運(yùn)動方向(向下)*/
- if(!KEY_CUSTOMS) /*響應(yīng)選關(guān)事件*/
- Delay_10ms();
- if(!KEY_CUSTOMS)
- while(!KEY_CUSTOMS);
- TR0 = 0;
- m_IsChoose = 1;
- Choice_Customs();
- /*******************為選關(guān)服務(wù)*********************/
- /**/ if(!KEY_OK && m_IsChoose) /**/
- /**/ Delay_10ms(); /**/
- /**/ if(!KEY_OK) /**/
- /**/ while(!KEY_OK); /**/
- /**/ m_IsChoose = 0; /**/
- /**/ TR0 = 1; /**/
- /**/ }//只有選關(guān)后確定鍵才有效 /**/
- if(!KEY_RESTORAL) /*響應(yīng)復(fù)位事件*/
- Delay_10ms();
- if(!KEY_RESTORAL)
- while(!KEY_RESTORAL);
- Restoral(); /*游戲復(fù)位處理*/
- if(!KEY_SPEED_MOVE) /*響應(yīng)加速事件*/
- Delay_10ms();
- TR0 = 0;
- while(!KEY_SPEED_MOVE)
- MoveProcess(); /*一直調(diào)用移動處理*/
- Delay_100ms(); /*延時100毫秒,也就是加速速度*/
- TR0 = 1;
- if (m_Flag) /*響應(yīng)正常的移動事件*/
- m_Flag = 0;
- MoveProcess(); /*移動處理*/
- if (m_TimeFlag) /*刷新時間顯示*/
- m_TimeFlag = 0;
- TimeDisplay();
- Terminal(); /*響應(yīng)鍵盤消息*/
- /*---------------------------主程序結(jié)束-----------------------------------*/
- //定時器0控制方塊下移速度及時間程序
- void Time_0_Int() interrupt 1 using 1
- static unsigned char Speed = 0;
- static unsigned char Time = 0;
- TH0 = 0x4C; TL0 = 0x00;
- Speed++;
- Time++;
- if (Time >= 40)
- Time = 0;
- m_Time++;
- m_TimeFlag = 1;
- if (Speed >= m_Speed)
- Speed = 0;
- m_Flag = 1;
