查看: 3621|回復(fù): 10
求AD7705與89C51的使用代碼
ID:155543 發(fā)表于 2016-12-18 08:37 | 顯示全部樓層 |閱讀模式
  AD7705到手感覺很復(fù)雜啊,不會用,有沒有哪位大佬有驅(qū)動代碼的,感覺這真有難度啊...
ID:1 發(fā)表于 2017-1-3 22:28 | 顯示全部樓層
下載:
AD7705_驅(qū)動_51單片機.rar (9.08 KB, 下載次數(shù): 58)
  1. /***************  AD7705 測試程序   000001 ****************/
  2. #include<reg52.h>
  3. #include <intrins.h>
  5. #define uint  unsigned int
  6.
  7. sbit lcden=P1^1;    //lcd使能
  8. sbit lcdrs=P1^0;    //lcd讀寫控制
  9. uint temp;
  10. /**********    1602   顯示      程序******/
  11. void delay(uint z)
  12. {
  13.      uint x,y;
  14.          for(x=z;x>0;x--)
  15.                  for(y=110;y>0;y--);
  16. }
  17. uchar code table[]="the resistance "; //15
  18. uchar code table1[]=" 00000   ohm";         //12
  19. void hc_595(uchar date)
  20. {
  21.     uint j;
  22.     for(j=0;j<8;j++)
  23.    {
  24.           SH=0;
  25.           date=date<<1;
  26.           DS=CY;
  27.       SH=1;
  28.           SH=0;     //上升沿發(fā)生移位
  29.     }
  30.         ST=0;
  31.     ST=1;           //上升沿將數(shù)據(jù)送到輸出鎖存器
  32.     ST=0;
  33. }
  34. void write_com1602(uchar com)      /* 寫命令*/
  35. {
  36.         lcdrs=0;
  37.     lcden=0;
  38.         hc_595(com);
  39.         delay(5);
  40.         lcden=1;
  41.         delay(5);
  42.         lcden=0;
  43. }
  44. void write_date1602(uchar date)       /* 寫數(shù)據(jù)*/
  45. {
  46.         lcdrs=1;
  47.         lcden=0;
  48.     hc_595(date);
  49.         delay(5);
  50.         lcden= 1;
  51.         delay(5);
  52.         lcden=0;
  53. }
  54. void write_dt1602(uint data2)       /* 顯示四位數(shù)*/
  55. {
  56.         uint wei_1,wei_2,wei_3,wei_4,wei_5;
  57.         wei_1=data2/10000;
  58.         wei_2=data2/1000%10;
  59.         wei_3=data2/100%10;
  60.         wei_4=data2/10%10;
  61.         wei_5=data2%10;
  62.         write_com1602(0x80+0x40+2);
  63.         write_date1602(0x30+wei_1);
  64.         write_date1602(0x30+wei_2);
  65.         write_date1602(0x30+wei_3);
  66.         write_date1602(0x30+wei_4);
  67.         write_date1602(0x30+wei_5);
  68. }
  69. void init1602()
  70. {
  71.     uint num;
  72.          lcden=0;
  73.          write_com1602(0x38);
  74.      write_com1602(0x0c);
  75.      write_com1602(0x06);
  76.          write_com1602(0x01);
  77.          write_com1602(0x80);
  78.          for(num=0;num<15;num++)
  79.           {
  80.                            write_date1602(table[num]);
  81.                          delay(5);
  82.           }
  83.           write_com1602(0x80+0x40);
  84.           for(num=0;num<12;num++)
  85.           {
  86.                            write_date1602(table1[num]);
  87.                          delay(5);
  88.           }
  89. }
  90. /****************************************************************/
  91.
  92. void main()
  93. {
  94.     Init7705();
  95.         init1602();
  96.         while(1)
  97.
  98.    {
  99.                    while(!drty)
  100.            {
  101.                 temp=GetData7705();
  102.             write_dt1602(temp);
  103.             }
  104.    }
  105. }
ID:161157 發(fā)表于 2017-4-25 15:36 | 顯示全部樓層
謝謝分享。。。。!
ID:222195 發(fā)表于 2017-8-3 17:46 | 顯示全部樓層
我想要一個 7705用15單片機的程序
ID:222195 發(fā)表于 2017-8-3 17:49 | 顯示全部樓層
額..這是1602的程序吧,7705的讀寫好像沒有
ID:157057 發(fā)表于 2017-8-3 17:53 | 顯示全部樓層
謝謝分享。。。。。
ID:193703 發(fā)表于 2017-8-5 16:07 | 顯示全部樓層
只是ldc 差7705
ID:335743 發(fā)表于 2018-8-30 09:14 | 顯示全部樓層
16位ad.....很煩  在比賽了
ID:335743 發(fā)表于 2018-8-30 09:16 | 顯示全部樓層
ID:46469 發(fā)表于 2018-12-23 21:24 | 顯示全部樓層
怎么嗎,沒有7705的程序
ID:518059 發(fā)表于 2019-7-28 20:11 | 顯示全部樓層
呃,7705引腳都沒定義啊
