查看: 1990|回復(fù): 0
1602 ds18b20溫度測(cè)量
ID:156618 發(fā)表于 2016-12-21 17:46 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
#include<reg52.h>
sbit DQ=P3^7;
sbit RS=P1^6;
sbit EN=P1^7;
unsigned char code str1[]={"T:"};
unsigned char code str2[]={" "};
uchar data disdata[5];
uint tvalue;
uchar tflag,num;
uint s,g,fs,fg,ss,sg,num0;
unsigned char num1,num2,num3;
void delay1ms(unsigned int ms)
                        unsigned int i,j;
                        for(i=0;i<ms;i++)
                        for(j=0;j<100;j++);
void wr_com(unsigned char com)
                        delay1ms(1);
                        RS=0;
                        EN=0;
                        P0=com;
                        delay1ms(1);
                        EN=1;
                        delay1ms(1);
                        EN=0;
void wr_dat(unsigned char dat)
                        delay1ms(1);;
                        RS=1;
                        EN=0;
                        P0=dat;
                        delay1ms(1);
                        EN=1;
                        delay1ms(1);
                        EN=0;
void lcd_init()
                        delay1ms(15);
                        wr_com(0x38);
                        delay1ms(5);
                        wr_com(0x08);
                        delay1ms(5);
                        wr_com(0x01);
                        delay1ms(5);
                        wr_com(0x06);
                    delay1ms(5);
                        wr_com(0x0c);
                        delay1ms(5);
void display(unsigned char *p)
                        while(*p!='\0')
                        wr_dat(*p);
                        p++;
                        delay1ms(1);
init_play()
                {         delay1ms(5);
                lcd_init();
                wr_com(0x80);
                display(str1);
                wr_com(0x82);
                display(str2);
void delay_18B20(unsigned int i)
    while(i--);
void ds1820rst()
                unsigned char x=0;
                DQ = 1;
                delay_18B20(4);
                DQ = 0;
                delay_18B20(100);
                DQ = 1;
                delay_18B20(40);
uchar ds1820rd()
                         unsigned char i=0;
                        unsigned char dat = 0;
                        for (i=8;i>0;i--)
                        DQ = 0;
                        dat>>=1;
                        DQ = 1;
                        if(DQ)
                        dat|=0x80;
                        delay_18B20(10);
                        return(dat);
void ds1820wr(uchar wdata)
                        unsigned char i=0;
                        for (i=8; i>0; i--)
                        DQ = 0;
                        DQ = wdata&0x01;
                        delay_18B20(10);
                        DQ = 1;
                        wdata>>=1;
read_temp()
                                uchar a,b;
                                ds1820rst();
                                ds1820wr(0xcc);
                                ds1820wr(0x44);
                                ds1820rst();
                                ds1820wr(0xcc);
                                ds1820wr(0xbe);
                                a=ds1820rd();
                                b=ds1820rd();
                                tvalue=b;
                                tvalue<<=8;
                                tvalue=tvalue|a;
                                if(tvalue<0x0fff)
                                tflag=0;
                                tvalue=~tvalue+1;
                                tflag=1;
                                tvalue=tvalue*(0.625);
                                return( tvalue);
void ds1820disp()
                                        uchar flagdat;
                                        disdata[0]=tvalue/1000+0x30;
                                        disdata[1]=tvalue%1000/100+0x30;
                                        disdata[2]=tvalue%100/10+0x30;
                                        disdata[3]=tvalue%10+0x30;
                                        if
                                        (tflag==0)
                                        flagdat=0x20;
                                        flagdat=0x2d;
                                        if(disdata[0]==0x30)
                                        disdata[0]=0x20;
                                        if
                                        (disdata[1]==0x30)
                                        {disdata[1]=0x20;
                                        wr_com(0x83);
                                        wr_dat(flagdat);          delay_18B20(4);
                                        wr_com(0x84);
                                        wr_dat(disdata[0]);         delay_18B20(4);
                                        wr_com(0x85);
                                        wr_dat(disdata[1]);                 delay_18B20(4);
                                        wr_com(0x86);
                                        wr_dat(disdata[2]);            delay_18B20(4);
                                        wr_com(0x87);
                                        wr_dat(0x2e);                                delay_18B20(4);
                                        wr_com(0x88);
                                        wr_dat(disdata[3]);                        delay_18B20(4);
        init_play();
       read_temp();
       ds1820disp();
            delay1ms(5);
相關(guān)帖子
