查看: 1856|回復: 0
大神們我這樣計算AD轉(zhuǎn)化值在處理延時有錯誤嗎?
回帖獎勵 60 黑幣 回復本帖可獲得 3 黑幣獎勵! 每人限 1 次
ID:156852 發(fā)表于 2016-12-30 15:08 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<intrins.h>
#include<stdio.h>
uint temp;
uchar i;
uint a;
float v;
uint v1,v2;
uchar qian,bai,shi,ge;
void display();
void delay(uint z);
void time0_init();
void time1_init();
void AD_0809();
uchar code table1[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar code table2[]={0xbf,0x86,0xdb,0xcf,0xe6,0xed,0xfd,0x87,0xff,0xef,0xf7,0xfc,0xb9,0xde,0xf9,0xf1};
sbit ST=P2^6;
sbit OE=P2^5;
sbit EOC=P2^4;
sbit CLK=P2^3;
sbit ALE=P2^6;
sbit OUT=P3^6;
uint gatedate;
uchar flag;
float t;
flag=0;                           //標志位0
time1_init();
time0_init();
  AD_0809(); //AD轉(zhuǎn)換程序
      if(v>1&&v<4)
          display();
          t=(float)(14060.0/(v*v));
           TR1=1;
           display();//數(shù)碼管顯示程序
        while(a>=t)
                 flag=1;         //標記位改為1;數(shù)碼管停止計數(shù)
void time0_init()
TMOD=0x12;
TH0=6;
TL0=6;//  TL0=(65536-20)%256;
EA=1;
ET0=1;
TR0=1;
void timer0()interrupt 1
CLK=~CLK;
void display()
P3=0xbe;
P0=table1[qian];
delay(2);
P3=0xbd;
P0=table2[bai];
delay(2);
P3=0xbb;
P0=table1[shi];
delay(2);
P3=0xb7;
P0=table1[ge];
delay(2);
void delay(uint z)
uint x,y;
for(x=z;x>0;x--)
for(y=110;y>0;y--); //110
void timer1()interrupt 3
TH1=(65536-10000)/256;
TL1=(65536-10000)%256;
a++;
i++;
if(i==10)
           i=0;
           if(flag==0)temp++;
                if(temp==9999)
                        temp=0;
                        if(flag==0)
                        qian=temp/1000;
                        bai=temp%1000/100;
                        shi=temp%100/10;
                        ge=temp%10;
void time1_init()
TMOD=0x12;
EA=1;
ET1=1;
TR1=0;
void AD_0809()
  ST=0;
_nop_();
OE=0;
_nop_();
ST=1;
_nop_();
ST=0;
while(EOC==0);
  OE=1;
  gatedate=P1;
  _nop_();
  OE=0;
  v1=gatedate*5/256;
  v2=(gatedate*500/256)%100;
  v=v1+(float)v2/100;
