查看: 5653|回復(fù): 9
求大神看看,各種錯誤,搞得我都絕望了
ID:152530 發(fā)表于 2017-1-5 19:04 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
這是源程序
#include <REGX52.H>
#define  uint unsigned int
#define  uchar unsigned char
sbit dula=P2^6;
sbit wela=P2^7;
uchar num;
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
void delay(uint z)
        num=0;
        tt=0;
        TMOD=0x01;
        TH0=(65535-50000)/256;
        TL0=(65535-50000)%256;
        EA=1;
        ET0=1;
        TR0=1;
        wela=1;
        P0=0xea;
        wela=0;
                if(tt==20)
                        tt=0;
                        P1^0=1;
                        if(num==16)
                        num=0;
                        num++;
                        dula=1;
                        P0=table[num];
                        dula=0;
                        delay(1000);
void delay(uint z)
                unit x,y;
                for(x=z;x>0;x--)
                        for(y=110;y>0,=;y--);
void exter0() interrupt 1
        t++;
這是錯誤
learn3.c(14): error C132: 'main': not in formal parameter list
learn3.c(14): error C141: syntax error near '{'
learn3.c(15): error C136: 'num': 'void' on variable
learn3.c(15): error C244: 'num': can't initialize, bad type or class
learn3.c(15): error C132: 'num': not in formal parameter list
learn3.c(16): error C244: 'tt': can't initialize, bad type or class
learn3.c(16): error C132: 'tt': not in formal parameter list
learn3.c(17): error C244: 'TMOD': can't initialize, bad type or class
learn3.c(17): error C132: 'TMOD': not in formal parameter list
learn3.c(18): error C244: 'TH0': can't initialize, bad type or class
learn3.c(18): error C132: 'TH0': not in formal parameter list
learn3.c(19): error C244: 'TL0': can't initialize, bad type or class
learn3.c(19): error C132: 'TL0': not in formal parameter list
learn3.c(20): error C244: 'EA': can't initialize, bad type or class
learn3.c(20): error C132: 'EA': not in formal parameter list
learn3.c(21): error C244: 'ET0': can't initialize, bad type or class
learn3.c(21): error C132: 'ET0': not in formal parameter list
learn3.c(22): error C244: 'TR0': can't initialize, bad type or class
learn3.c(22): error C132: 'TR0': not in formal parameter list
learn3.c(23): error C244: 'wela': can't initialize, bad type or class
learn3.c(23): error C132: 'wela': not in formal parameter list
learn3.c(24): error C244: 'P0': can't initialize, bad type or class
learn3.c(24): error C132: 'P0': not in formal parameter list
learn3.c(25): error C244: 'wela': can't initialize, bad type or class
learn3.c(25): error C132: 'wela': not in formal parameter list
learn3.c(26): error C141: syntax error near 'while'
learn3.c(26): error C141: syntax error near '1'
learn3.c(28): error C141: syntax error near '==', expected ')'
learn3.c(30): error C231: 'tt': redefinition
learn3.c(31): error C129: missing ';' before '^'
我死了算了
ID:155507 發(fā)表于 2017-1-5 22:56 | 只看該作者
  1. #include <REG52.H>   // #include <regx52.H>和#include <reg52.H> 不一樣
  2. #define  uint unsigned int
  3. #define  uchar unsigned char
  4. sbit dula=P2^6;
  5. sbit wela=P2^7;
  6. sbit PP10 = P1^0;
  7. uchar num, tt;
  8. uchar code table[]={
  9.         0x3f,0x06,0x5b,0x4f,
  10.         0x66,0x6d,0x7d,0x07,
  11.         0x7f,0x6f,0x77,0x7c,
  12.         0x39,0x5e,0x79,0x71};
  13. void delay(uint z);
  14. void main()
  15. {
  16.         num=0;
  17.         tt=0;
  18.         TMOD=0x01;
  19.         TH0=(65535-50000)/256;
  20.         TL0=(65535-50000)%256;
  21.         EA=1;
  22.         ET0=1;
  23.         TR0=1;
  24.         wela=1;
  25.         P0=0xea;
  26.         wela=0;
  27.         while(1)
  28.         {
  29.                 if(tt==20)
  30.                 {
  31.                         tt=0;
  32.                         PP10=1;
  33.                         if(num==16)
  34.                          num=0;
  35.                         num++;
  36.                         dula=1;
  37.                         P0=table[num];
  38.                         dula=0;
  39.                         delay(1000);
  40.                 }
  41.         }
  42.
  43. }
  44. void delay(uint z)
  45. {
  46.         uint x,y;
  47.         for(x=z;x>0;x--)
  48.         for(y=110;y>0;y--);
  49. }
  50. void exter0() interrupt 1
  51. {
  52.         TH0=(65535-50000)/256;
  53.         TL0=(65535-50000)%256;
  54.         tt++;
  55. }
試試看。
ID:137239 發(fā)表于 2017-1-6 08:58 | 只看該作者
樓上正解!
ID:150865 發(fā)表于 2017-1-6 11:51 | 只看該作者
你的代碼敲錯太多了 延時函數(shù)里面uint你寫錯了 ,第二個for循環(huán)也有問題,你用的tt沒有定義,肯定錯誤很多啊
ID:149988 發(fā)表于 2017-1-6 13:53 | 只看該作者
RE: 求大神看看,各種錯誤,搞得我都絕望了
給你修改了一下,仔細對照一下,會有幫助的。
#include <reg51.h>
#include <intrins.h>
sbit dula=P2^6;
sbit wela=P2^7;
sbit aa=P1^0;  //P1^0在這里定義一下
uchar num;
uchar tt=0;  //tt應(yīng)定義為全局變量,所以應(yīng)在這里定義
void delay(uint z);
//void delay(uint z) //缺少“;”號
  num=0;
//  tt=0;
  TMOD=0x01;
  EA=1;
  ET0=1;
  TR0=1;
  wela=1;
  P0=0xea;
  wela=0;
    if(tt==20)
      tt=0;
//      P1^0;  //P1^0不能直接用,在前面定義一下
      aa=1;    //在前面定義了aa=P1^0;
      if(num==16)
      num=0;
      num++;
      dula=1;
      P0=table[num];
      dula=0;
      delay(1000);
void delay(uint z)
//  unit x,y; //unit是錯誤的
  uint x,y;   //unit應(yīng)為uint
  for(x=z;x>0;x--)
//  for(y=110;y>0,=;y--);  //多了,和=兩個符號
  for(y=110;y>0;y--);      //應(yīng)是這樣的
//  t++;   //雙t寫成了一個t
  tt++;    //應(yīng)是雙t
ID:160316 發(fā)表于 2017-1-6 16:18 | 只看該作者
ID:150865 發(fā)表于 2017-1-6 23:07 | 只看該作者
18815796398 發(fā)表于 2017-1-6 16:18
你的代碼敲錯太多了 延時函數(shù)里面uint你寫錯了 ,第二個for循環(huán)也有問題,你用的tt沒有定義,肯定錯誤很 ...
兄弟 干嘛要賦值粘貼啊
ID:149988 發(fā)表于 2017-1-7 08:33 | 只看該作者
這個問題我昨天回答過。
#include <REGX52.H>
sbit dula=P2^6;
sbit wela=P2^7;
sbit aa=P1^0;  /**********增加一組sbit aa=P1^0;************/
//uchar num;
uchar num,tt;  /**********增加一組tt************/
void delay(uint z); /**********增加一組void delay(uint z);************/
//void delay(uint z)/**********應(yīng)該有";"號************/
        num=0;
        tt=0;/*********tt沒有定義*************/
        TMOD=0x01;
        EA=1;
        ET0=1;
        TR0=1;
        wela=1;
        P0=0xea;
        wela=0;
                if(tt==20)
                        tt=0;
                        aa=1;/***********P1^0不能直接用,增加一組aa=1;************/
                       // P1^0=1;/***********P1^0不能直接用************/
                        if(num==16)
                        num=0;
                        num++;
                        dula=1;
                        P0=table[num];
                        dula=0;
                        delay(1000);
void delay(uint z)
                uint x,y;/***********增加一組uint x,y;************/
               // unit x,y;/**************unit書寫錯誤,應(yīng)該是uint****************/
                for(x=z;x>0;x--)
                   for(y=110;y>0;y--);
                      //  for(y=110;y>0,=;y--);/**************unit書寫錯誤,多寫了",="****************/
        tt++; /***********增加一組tt++;************/
      //  t++;  /***********少了一個t***************/
ID:100391 發(fā)表于 2017-1-8 18:34 | 只看該作者
你的頭文件是不是寫錯了?#include <REGX52.H>??應(yīng)該是#include <REG52.H>吧,開頭處的void delay(uint z)  這句后面應(yīng)該有 ; 才對(后面的那個 函數(shù)可以不用;)。
ID:152530 發(fā)表于 2017-1-15 18:11 | 只看該作者
謝謝各位了,當(dāng)時腦子短路了,半夜里打的
