2017-1-7 12:41 上傳
2017-1-7 12:41 上傳
void OSStartTask() 函數(shù)中RETI執(zhí)行后PC本該是0x01A1,可怎么變?yōu)?x0101啊
下面是“建立一個(gè)屬于自己的 AVR 的 RTOS.pdf”中的程序
#include <avr/io.h>
#include <avr/Interrupt.h>
#include <avr/signal.h>
unsigned char Stack[400];
register unsigned char OSRdyTbl asm("r2"); //任務(wù)運(yùn)行就緒表
register unsigned char OSTaskRunningPrio asm("r3"); //正在運(yùn)行的任務(wù)
#define OS_TASKS 3 //設(shè)定運(yùn)行任務(wù)的數(shù)量
struct TaskCtrBlock
unsigned int OSTaskStackTop; //保存任務(wù)的堆棧頂
unsigned int OSWaitTick; //任務(wù)延時(shí)時(shí)鐘
} TCB[OS_TASKS+1];
//防止被編譯器占用
register unsigned char tempR4 asm("r4");
register unsigned char tempR5 asm("r5");
register unsigned char tempR6 asm("r6");
register unsigned char tempR7 asm("r7");
register unsigned char tempR8 asm("r8");
register unsigned char tempR9 asm("r9");
register unsigned char tempR10 asm("r10");
register unsigned char tempR11 asm("r11");
register unsigned char tempR12 asm("r12");
register unsigned char tempR13 asm("r13");
register unsigned char tempR14 asm("r14");
register unsigned char tempR15 asm("r15");
register unsigned char tempR16 asm("r16");
register unsigned char tempR16 asm("r17");
//建立任務(wù)
void OSTaskCreate(void (*Task)(void),unsigned char *Stack,unsigned char TaskID)
unsigned char i;
*Stack--=(unsigned int)Task>>8; //將任務(wù)的地址高位壓入堆棧,
*Stack--=(unsigned int)Task; //將任務(wù)的地址低位壓入堆棧,
*Stack--=0x00; //R1 __zero_reg__
*Stack--=0x00; //R0 __tmp_reg__
*Stack--=0x80;
//SREG 在任務(wù)中,開啟全局中斷
for(i=0;i<14;i++) //在 avr-libc 中的 FAQ 中的 What registers are used by the C compiler?
*Stack--=i; //描述了寄存器的作用
TCB[TaskID].OSTaskStackTop=(unsigned int)Stack; //將人工堆棧的棧頂,保存到堆棧的數(shù)組中
OSRdyTbl|=0x01<<TaskID; //任務(wù)就緒表已經(jīng)準(zhǔn)備好
//開始任務(wù)調(diào)度,從最低優(yōu)先級(jí)的任務(wù)的開始
void OSStartTask()
OSTaskRunningPrio=OS_TASKS;
SP=TCB[OS_TASKS].OSTaskStackTop+17;
__asm__ __volatile__( "reti" " \t" );
//進(jìn)行任務(wù)調(diào)度
void OSSched(void)
// 根據(jù)中斷時(shí)保存寄存器的次序入棧,模擬一次中斷后,入棧的情況
__asm__ __volatile__("PUSH __zero_reg__ \t"); //R1
__asm__ __volatile__("PUSH __tmp_reg__\t"); //R0
__asm__ __volatile__("IN __tmp_reg__,__SREG__\t"); //保存狀態(tài)寄存器 SREG
__asm__ __volatile__("CLR __zero_reg__ \t"); //R0重新清零
__asm__ __volatile__("PUSH R18\t");
__asm__ __volatile__("PUSH R19\t");
__asm__ __volatile__("PUSH R20\t");
__asm__ __volatile__("PUSH R21\t");
__asm__ __volatile__("PUSH R22\t");
__asm__ __volatile__("PUSH R23\t");
__asm__ __volatile__("PUSH R24\t");
__asm__ __volatile__("PUSH R25\t");
__asm__ __volatile__("PUSH R26\t");
__asm__ __volatile__("PUSH R27\t");
__asm__ __volatile__("PUSH R30\t");
__asm__ __volatile__("PUSH R31\t");
__asm__ __volatile__("Int_OSSched: \t"); //當(dāng)中斷要求調(diào)度,直接進(jìn)入這里
__asm__ __volatile__("PUSH R28\t"); //R28與R29用于建立在堆棧上的指針
__asm__ __volatile__("PUSH R29\t"); //入棧完成
TCB[OSTaskRunningPrio].OSTaskStackTop=SP; //將正在運(yùn)行的任務(wù)的堆棧底保存
if(++OSTaskRunningPrio>=OS_TASKS) //輪流運(yùn)行各個(gè)任務(wù),沒有優(yōu)先級(jí)
OSTaskRunningPrio=0;
//cli(); //保護(hù)堆棧轉(zhuǎn)換
SP=TCB[OSTaskRunningPrio].OSTaskStackTop;
//sei();
//根據(jù)中斷時(shí)的出棧次序
__asm__ __volatile__("POP R29\t");
__asm__ __volatile__("POP R28\t");
__asm__ __volatile__("POP R31\t");
__asm__ __volatile__("POP R30\t");
__asm__ __volatile__("POP R27\t");
__asm__ __volatile__("POP R26\t");
__asm__ __volatile__("POP R25\t");
__asm__ __volatile__("POP R24\t");
__asm__ __volatile__("POP R23\t");
__asm__ __volatile__("POP R22\t");
__asm__ __volatile__("POP R21\t");
__asm__ __volatile__("POP R20\t");
__asm__ __volatile__("POP R19\t");
__asm__ __volatile__("POP R18\t");
__asm__ __volatile__("POP __tmp_reg__\t"); //SERG 出棧并恢復(fù)
__asm__ __volatile__("OUT __SREG__,__tmp_reg__ \t"); //
__asm__ __volatile__("POP __tmp_reg__ \t"); //R0 出棧
__asm__ __volatile__("POP __zero_reg__ \t"); //R1 出棧
__asm__ __volatile__("RETI\t"); //返回并開中斷
//中斷時(shí)出棧完成
void IntSwitch(void)
__asm__ __volatile__("POP R31\t"); //去除因調(diào)用子程序而入棧的 PC
__asm__ __volatile__("RJMP Int_OSSched\t"); //重新調(diào)度
void TCN0Init(void) // 計(jì)時(shí)器 0
TCCR0 = 0;
TCCR0 |= (1<<CS02); // 256預(yù)分頻
TIMSK |= (1<<TOIE0); // T0溢出中斷允許
TCNT0 = 100; // 置計(jì)數(shù)起始值
SIGNAL(SIG_OVERFLOW0)
TCNT0=100;
IntSwitch(); //任務(wù)調(diào)度
void Task0()
unsigned int j=0;
PORTB=j++;
//OSTimeDly(50);
void Task1()
unsigned int j=0;
PORTC=j++;
//OSTimeDly(5);
void Task2()
unsigned int j=0;
PORTD=j++;
//OSTimeDly(5);
void TaskScheduler()
OSSched(); //反復(fù)進(jìn)行調(diào)度
int main(void)
TCN0Init();
OSRdyTbl=0;
OSTaskCreate(Task0,&Stack[99],0);
OSTaskCreate(Task1,&Stack[199],1);
OSTaskCreate(Task2,&Stack[299],2);
OSTaskCreate(TaskScheduler,&Stack[399],OS_TASKS);
OSStartTask();
