2017-2-13 21:39 上傳
所有資料下載(源碼 PCB 仿真):
ATMEGA8數(shù)控電源制作資料.rar
(202.04 KB, 下載次數(shù): 163)
2017-2-13 19:21 上傳
點(diǎn)擊文件名下載附件
rar 下載積分: 黑幣 -5
下面是數(shù)控電壓的仿真原理圖:
2017-2-13 21:37 上傳
2017-2-13 21:37 上傳
源程序:
- * vim: set sw=8 ts=8 si :
- * Author: Guido Socher, Copyright: GPL
- * This is the main program for the digital dc power supply
- * Chip type : ATMEGA8
- * Clock frequency : Internal clock 4 Mhz
- #include <avr/io.h>
- #include <inttypes.h>
- #include <avr/interrupt.h>
- #define F_CPU 4000000UL // 4 MHz
- #include <util/delay.h>
- #include "lcd.h"
- #include "dac.h"
- #include "kbd.h"
- #include "analog.h"
- #include "avr_compat.h"
- #include "hardware_settings.h"
- #include "i2c_avr.h"
- #include <stdlib.h> // atoi
- #include <string.h>
- #include <avr/eeprom.h>
- #define SWVERSION "ver: ddcp-0.5.0"
- static int set_val[2];
- static int measured_val[2];
- static char i2c_buf[MAX_BUF_LEN+1];
- // the set values but converted to ADC steps
- static int set_val_adcUnits[2];
- static unsigned char bpress=0;
- void delay_ms(unsigned int ms)
- /* delay for a minimum of <ms> */
- // we use a calibrated macro. This is more
- // accurate and not so much compiler dependent
- // as self made code.
- while(ms){
- _delay_ms(0.96);
- ms--;
- // Convert a integer which is representing a float into a string.
- // decimalpoint_pos sets the decimal point after 2 pos: e.g 74 becomes "0.74"
- // The integer may not be larger than 10000.
- // The integer must be a positive number.
- // spacepadd can be used to add a leading speace if number is less than 10
- static void int_to_ascii(int inum,char *outbuf,signed char decimalpoint_pos,signed char spacepadd){
- signed char i,j;
- char chbuf[8];
- j=0;
- while(inum>9 && j<7){
- // zero is ascii 48:
- chbuf[j]=(char)48+ inum-((inum/10)*10);
- inum=inum/10;
- j++;
- if(decimalpoint_pos==j){
- chbuf[j]='.';
- j++;
- chbuf[j]=(char)48+inum; // most significant digit
- decimalpoint_pos--;
- while(j<decimalpoint_pos){
- j++;
- chbuf[j]='0';
- if (spacepadd && j > (decimalpoint_pos+2)){
- // no leading space padding needed
- spacepadd=0;
- j++;
- chbuf[j]='.';
- j++;
- chbuf[j]='0'; // leading zero
- if (spacepadd){
- j++;
- chbuf[j]=' '; // leading space padding: "9.50" becomes " 9.50"
- // now reverse the order
- i=0;
- while(j>=0){
- outbuf[i]=chbuf[j];
- j--;
- i++;
- outbuf[i]='\0';
- // convert voltage values to adc values, disp=10 is 1.0V
- static int disp_u_to_adc(int disp){
- return((int)(disp * 102.3) / (ADC_REF * U_DIVIDER));
- // calculate the needed adc offset for voltage drop on the
- // current measurement shunt (the shunt has about 0.5 Ohm =1/2 Ohm)
- static int disp_i_to_u_adc_offset(int disp){
- return(disp_u_to_adc(disp/20));
- // convert adc values to voltage values, disp=10 is 1.0V
- // disp_i_val is needed to calculate the offset for the voltage drop over
- // the current measurement shunt
- static int adc_u_to_disp(int adcunits,int disp_i_val){
- int adcdrop;
- adcdrop=disp_i_to_u_adc_offset(disp_i_val);
- if (adcunits < adcdrop){
- return(0);
- adcunits=adcunits-adcdrop;
- return((int)(((adcunits /102.3)* ADC_REF * U_DIVIDER)+0.6));
- // convert adc values to current values, disp=10 needed to be printed
- // by the printing function as 0.10 A
- static int disp_i_to_adc(int disp){
- return((int) (((disp * 10.23)* I_RESISTOR) / ADC_REF));
- static int adc_i_to_disp(int adcunits){
- return((int) (((adcunits* ADC_REF)/(10.23 * I_RESISTOR))+0.6));
- static void store_permanent(void){
- int tmp;
- signed char changeflag=1;
- lcd_clrscr();
- if (eeprom_read_byte((uint8_t *)0x0) == 19){
- changeflag=0;
- // ok magic number matches accept values
- tmp=eeprom_read_word((uint16_t *)0x04);
- if (tmp != set_val[1]){
- changeflag=1;
- tmp=eeprom_read_word((uint16_t *)0x02);
- if (tmp != set_val[0]){
- changeflag=1;
- if (changeflag){
- lcd_puts_P("setting stored");
- eeprom_write_byte((uint8_t *)0x0,19); // magic number
- eeprom_write_word((uint16_t *)0x02,set_val[0]);
- eeprom_write_word((uint16_t *)0x04,set_val[1]);
- }else{
- if (bpress> 5){
- // display software version after long press
- lcd_puts_P(SWVERSION);
- lcd_gotoxy(0,1);
- lcd_puts_P("tuxgraphics.org");
- }else{
- lcd_puts_P("already stored");
- delay_ms(200);
- // check the keyboard
- static unsigned char check_buttons(void){
- if (check_u_button(&(set_val[1]))){
- if(set_val[1]>U_MAX){
- set_val[1]=U_MAX;
- return(1);
- if (check_i_button(&(set_val[0]))){
- if(set_val[0]>I_MAX){
- set_val[0]=I_MAX;
- return(1);
- if (check_store_button()){
- store_permanent();
- return(2);
- return(0);
- void check_i2c_interface(void){
- if (i2c_get_received_data(i2c_buf)){
- if (i2c_buf[0]=='i'){
- if (i2c_buf[1]=='=' && i2c_buf[2]!='\0'){
- set_val[0]=atoi(&i2c_buf[2]);
- set_val[0]=I_MAX;
- if(set_val[0]<0){
- set_val[0]=0;
- i2c_send_data("ok");
- }else{
- int_to_ascii(measured_val[0],i2c_buf,2,0);
- strcat(i2c_buf,"A");
- i2c_send_data(i2c_buf);
- }else if (i2c_buf[0]=='s'){
- }else if (i2c_buf[0]=='u'){
- set_val[1]=atoi(&i2c_buf[2]);
- set_val[1]=U_MAX;
- if(set_val[1]<0){
- set_val[1]=0;
- }else{
- int_to_ascii(measured_val[1],i2c_buf,1,0);
- strcat(i2c_buf,"V");
- }else{
- i2c_send_data("err");
- int main(void)
- char out_buf[20+1];
- measured_val[0]=0;
- measured_val[1]=0;
- init_dac();
- lcd_init(LCD_DISP_ON);
- init_kbd();
- set_val[0]=15;set_val[1]=50; // 150mA and 5V
- set_val[1]=eeprom_read_word((uint16_t *)0x04);
- set_val[0]=eeprom_read_word((uint16_t *)0x02);
- // I2C also called TWI, slave address=3
- i2c_init(3,1,0);
- sei();
- i2c_send_data("on");
- init_analog();
- while (1) {
- // current
- measured_val[0]=adc_i_to_disp(getanalogresult(0));
- set_val_adcUnits[0]=disp_i_to_adc(set_val[0]);
- set_target_adc_val(0,set_val_adcUnits[0]);
- // voltage
- measured_val[1]=adc_u_to_disp(getanalogresult(1),measured_val[0]);
- set_val_adcUnits[1]=disp_u_to_adc(set_val[1])+disp_i_to_u_adc_offset(measured_val[0]);
- set_target_adc_val(1,set_val_adcUnits[1]);
- // voltage
- lcd_clrscr();
- int_to_ascii(measured_val[1],out_buf,1,1);
- lcd_puts(out_buf);
- lcd_puts("V ");
- int_to_ascii(set_val[1],out_buf,1,1);
- lcd_putc('[');
- lcd_putc(']');
- if (!is_current_limit()){
- // put a marker to show which value is currenlty limiting
- lcd_puts("<-");
- check_i2c_interface();
- // current
- lcd_gotoxy(0,1);
- int_to_ascii(measured_val[0],out_buf,2,0);
- lcd_puts("A ");
- int_to_ascii(set_val[0],out_buf,2,0);
- lcd_putc('[');
- lcd_putc(']');
- if (is_current_limit()){
- lcd_puts("<-");
- //dbg
- //int_to_ascii(is_dacval(),out_buf,0,0);
- //lcd_puts(out_buf);
- // the buttons must be responsive but they must not
- // scroll too fast if pressed permanently
- if (check_buttons()==0){
- // no buttons pressed
- delay_ms(100);
- bpress=0;
- check_buttons();
- delay_ms(150);
- }else{
- // button press
- if (bpress > 11){
- // somebody pressed permanetly the button=>scroll fast
- delay_ms(10);
- delay_ms(40);
- }else{
- bpress++;
- delay_ms(100);
- delay_ms(150);
- return(0);
