查看: 4517|回復: 1
基于RS485的Modbus通信示例
ID:164629 發(fā)表于 2017-2-18 16:33 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit BUZZ = P1^6;
bit flagBuzzOn = 0;   //蜂鳴器啟動標志
unsigned char T0RH = 0;  //T0重載值的高字節(jié)
unsigned char T0RL = 0;  //T0重載值的低字節(jié)
unsigned char regGroup[5];  //Modbus寄存器組,地址為0x00~0x04
void ConfigTimer0(unsigned int ms);
extern void UartDriver();
extern void ConfigUART(unsigned int baud);
extern void UartRxMonitor(unsigned char ms);
extern void UartWrite(unsigned char *buf, unsigned char len);
extern unsigned int GetCRC16(unsigned char *ptr,  unsigned char len);
extern void InitLcd1602();
extern void LcdShowStr(unsigned char x, unsigned char y, unsigned char *str);
    EA = 1;            //開總中斷
    ConfigTimer0(1);   //配置T0定時1ms
    ConfigUART(9600);  //配置波特率為9600
    InitLcd1602();     //初始化液晶
    while (1)
        UartDriver();  //調(diào)用串口驅(qū)動
/* 串口動作函數(shù),根據(jù)接收到的命令幀執(zhí)行響應的動作
   buf-接收到的命令幀指針,len-命令幀長度 */
void UartAction(unsigned char *buf, unsigned char len)
    unsigned char i;
    unsigned char cnt;
    unsigned char str[4];
    unsigned int  crc;
    unsigned char crch, crcl;
    if (buf[0] != 0x01) //本例中的本機地址設定為0x01,
    {                   //如數(shù)據(jù)幀中的地址字節(jié)與本機地址不符,
        return;         //則直接退出,即丟棄本幀數(shù)據(jù)不做任何處理
    //地址相符時,再對本幀數(shù)據(jù)進行校驗
    crc = GetCRC16(buf, len-2);  //計算CRC校驗值
    crch = crc >> 8;
    crcl = crc & 0xFF;
    if ((buf[len-2]!=crch) || (buf[len-1]!=crcl))
        return;   //如CRC校驗不符時直接退出
    //地址和校驗字均相符后,解析功能碼,執(zhí)行相關(guān)操作
    switch (buf[1])
        case 0x03:  //讀取一個或連續(xù)的寄存器
            if ((buf[2]==0x00) && (buf[3]<=0x05)) //只支持0x0000~0x0005
                if (buf[3] <= 0x04)
                    i = buf[3];      //提取寄存器地址
                    cnt = buf[5];    //提取待讀取的寄存器數(shù)量
                    buf[2] = cnt*2;  //讀取數(shù)據(jù)的字節(jié)數(shù),為寄存器數(shù)*2
                    len = 3;         //幀前部已有地址、功能碼、字節(jié)數(shù)共3個字節(jié)
                    while (cnt--)
                        buf[len++] = 0x00;          //寄存器高字節(jié)補0
                        buf[len++] = regGroup[i++]; //寄存器低字節(jié)
                else  //地址0x05為蜂鳴器狀態(tài)
                    buf[2] = 2;  //讀取數(shù)據(jù)的字節(jié)數(shù)
                    buf[3] = 0x00;
                    buf[4] = flagBuzzOn;
                    len = 5;
                break;
            else  //寄存器地址不被支持時,返回錯誤碼
                buf[1] = 0x83;  //功能碼最高位置1
                buf[2] = 0x02;  //設置異常碼為02-無效地址
                len = 3;
                break;
        case 0x06:  //寫入單個寄存器
                if (buf[3] <= 0x04)
                    regGroup[i] = buf[5];   //保存寄存器數(shù)據(jù)
                    cnt = regGroup[i] >> 4; //顯示到液晶上
                    if (cnt >= 0xA)
                        str[0] = cnt - 0xA + 'A';
                        str[0] = cnt + '0';
                    cnt = regGroup[i] & 0x0F;
                    if (cnt >= 0xA)
                        str[1] = cnt - 0xA + 'A';
                        str[1] = cnt + '0';
                    str[2] = '\0';
                    LcdShowStr(i*3, 0, str);
                    flagBuzzOn = (bit)buf[5]; //寄存器值轉(zhuǎn)為蜂鳴器的開關(guān)
                len -= 2; //長度-2以重新計算CRC并返回原幀
                break;
                buf[1] = 0x86;  //功能碼最高位置1
                len = 3;
                break;
        default:  //其它不支持的功能碼
            buf[1] |= 0x80;  //功能碼最高位置1
            buf[2] = 0x01;   //設置異常碼為01-無效功能
            len = 3;
            break;
    crc = GetCRC16(buf, len); //計算返回幀的CRC校驗值
    buf[len++] = crc >> 8;    //CRC高字節(jié)
    buf[len++] = crc & 0xFF;  //CRC低字節(jié)
    UartWrite(buf, len);      //發(fā)送返回幀
/* 配置并啟動T0,ms-T0定時時間 */
    unsigned long tmp;  //臨時變量
    tmp = 11059200 / 12;      //定時器計數(shù)頻率
    tmp = (tmp * ms) / 1000;  //計算所需的計數(shù)值
    tmp = 65536 - tmp;        //計算定時器重載值
    tmp = tmp + 33;           //補償中斷響應延時造成的誤差
    T0RH = (unsigned char)(tmp>>8);  //定時器重載值拆分為高低字節(jié)
    T0RL = (unsigned char)tmp;
    TMOD &= 0xF0;   //清零T0的控制位
    TMOD |= 0x01;   //配置T0為模式1
    TH0 = T0RH;     //加載T0重載值
    TL0 = T0RL;
    ET0 = 1;        //使能T0中斷
    TR0 = 1;        //啟動T0
/* T0中斷服務函數(shù),執(zhí)行串口接收監(jiān)控和蜂鳴器驅(qū)動 */
void InterruptTimer0() interrupt 1
    TH0 = T0RH;  //重新加載重載值
    TL0 = T0RL;
    if (flagBuzzOn)  //執(zhí)行蜂鳴器鳴叫或關(guān)閉
        BUZZ = ~BUZZ;
        BUZZ = 1;
    UartRxMonitor(1);  //串口接收監(jiān)控
admin + 50 共享資料的黑幣獎勵!
收藏收藏4 分享淘帖 頂 踩
ID:366088 發(fā)表于 2018-7-6 16:24 | 只看該作者
程序有殘缺吧,有些函數(shù)被寫出來了但是沒有調(diào)用
