串口應(yīng)該都很熟悉了,具體通信原理我就不提了,這個百度上都很多講的,然后就直接看函數(shù)了。
- void Uart_SendByte(int data)//這個函數(shù)是發(fā)送整型數(shù)據(jù),參數(shù)為data
- if(whichUart==0)//這個是選中串口0
- if(data=='')//然后判斷數(shù)據(jù)不為空
- /*寄存器的原始宏定義,
- #define rUTRSTAT0 (*(volatile unsigned *)0x50000010) //UART 0 Tx/Rx status*/
- while(!(rUTRSTAT0 & 0x2));/*這個就是查詢串口0的狀態(tài)寄存器,第1位是發(fā)送緩沖器是否為空
- 第二位是Transmit buffer empty
- 0 = The buffer register is not empty
- 1 = Empty 這里檢查為0的話就是還沒發(fā)送完全,當(dāng)置1的時候表示發(fā)完了,程序繼續(xù)執(zhí)行*/
- Delay(10); //because the slow response of hyper_terminal
- WrUTXH0('');
- while(!(rUTRSTAT0 & 0x2)); //Wait until THR is empty.
- Delay(10);
- WrUTXH0(data);
- else if(whichUart==1)
- if(data=='')
- while(!(rUTRSTAT1 & 0x2));
- rUTXH1 = '';
- while(!(rUTRSTAT1 & 0x2)); //Wait until THR is empty.
- Delay(10);
- rUTXH1 = data;
- else if(whichUart==2)
- if(data=='')
- while(!(rUTRSTAT2 & 0x2));
- rUTXH2 = '';
- while(!(rUTRSTAT2 & 0x2)); //Wait until THR is empty.
- Delay(10);
- rUTXH2 = data;
搞了這么久我還不知道如何確定ARM的大端或是小端格式,這個是在啟動代碼里設(shè)置的,現(xiàn)在還沒看,mini2440的串口代碼和華恒2410的串口發(fā)送代碼一樣的。注釋如上。
主函數(shù)中的關(guān)鍵代碼:
- * Function Name : Main()
- * Create Date : 2011/12/10
- * Author/Corporation : 濤行天下
- * Description : Find a proper thread in thread array
- * Param : ThreadNo : someParam description
- ThreadStaus : someParam description
- * Global Variable : DISP_wuiSegmentAppID
- * File Static Variable : naucThreadNo
- * Function Static Variable : None
- * Revision History
- * No. Date Revised by Item Description
- * V0.0 2011/12/10 濤行天下 ... ....
- void Main(void)
- U8 count_num = 0;
- char *mode;
- int i;
- U8 key;
- U32 mpll_val = 0 ;
- //U32 divn_upll = 0 ;
- #if ADS10
- // __rt_lib_init(); //for ADS 1.0
- #endif
- Port_Init();//端口初始化
- Isr_Init();//中斷初始化
- i = 2 ; //don't use 100M!
- //boot_params.cpu_clk.val = 3;
- //確定頻率
- switch ( i )
- case 0: //200
- key = 12;
- mpll_val = (92<<12)|(4<<4)|(1);
- break;
- case 1: //300
- key = 13;
- mpll_val = (67<<12)|(1<<4)|(1);
- break;
- case 2: //400
- key = 14;
- mpll_val = (92<<12)|(1<<4)|(1);
- break;
- case 3: //440!!!
- key = 14;
- mpll_val = (102<<12)|(1<<4)|(1);
- break;
- default:
- key = 14;
- break;
- //init FCLK=400M, so change MPLL first
- ChangeMPllValue((mpll_val>>12)&0xff, (mpll_val>>4)&0x3f, mpll_val&3);
- ChangeClockDivider(key, 12);
- cal_cpu_bus_clk();
- consoleNum = 0; // Uart 1 select for debug.選擇串口號
- Uart_Init( 0,115200 );//初始化串口參數(shù)以及時鐘源
- Uart_Select( consoleNum );//選擇串口號
- Beep(2000, 100);//蜂鳴器
- Uart_SendByte('');//打印信息
- Uart_SendByte('H');
- while(1)
- Uart_SendByte(count_num);
- Uart_SendByte(' ');
- count_num ++;
- Delay(500);
從而讓ARM一直向PC機發(fā)送從0-255數(shù)據(jù),在PC機中顯示結(jié)果如下:
2017-3-7 01:36 上傳
這個看不了十六進(jìn)制的數(shù),我搞了個串口助手來顯示:
2017-3-7 01:36 上傳
上面那個是用mini2440實現(xiàn)的,那個通過UBOOT可以直接燒寫程序,不過到了華恒的板子我就不知道為啥了,這個苦悶了我好久,今天在進(jìn)入PPCBOOT中利用erase命令把那個linux系統(tǒng)檫除了,然后進(jìn)入ppcboot命令行形式才可以jtag調(diào)試,不知道為啥,這次終于進(jìn)了一次調(diào)試結(jié)果出來了。
2017-3-7 01:36 上傳
2017-3-7 01:36 上傳
下面出一張計數(shù)的圖,感覺下成就感吧,雖然底層函數(shù)還沒完全弄懂!
2017-3-7 01:36 上傳
現(xiàn)在總結(jié)這些步驟吧,最開始在上電的時候不要立馬啟動系統(tǒng),先要進(jìn)入PPCBOOT模式命令行,然后再啟動AXD調(diào)試器。
2017-3-7 01:36 上傳
通過H-JATG軟件可以看到是小端格式的,但是具體怎么設(shè)置暫時還不清楚,
#define WrUTXH0(ch) (*(volatile unsigned char *)0x50000020)=(unsigned char)(ch)
WrUTXH0即是寫UTXH0的意思,UTXH0是第一個串口的發(fā)送緩沖寄存器!
2011/12/13日
還是阿南的程序給力啊,華恒板子帶的程序沒啥用
2011/12/21日
感慨日子過的飛快!可是我卻沒啥長進(jìn),先上程序吧:
- ;//呼叫主應(yīng)用程序
- b UART
- UART
- ldr r0, =GPHCON ;//設(shè)置RxD0,TxD0引腳
- ldr r1, =0x2afaaa
- str r1, [r0]
- ldr r0, =GPHUP
- ldr r1, =0x7ff
- str r1, [r0] ; // The pull up function is disabled GPH[10:0]
- ldr r0, =UFCON0 ;//禁用FIFO
- ldr r1, =0x0
- str r1, [r0]
- ldr r0, =UMCON0 ;//禁用AFC
- ldr r1, =0x0
- str r1, [r0]
- ldr r0, =ULCON0 ;//設(shè)置線寄存器
- ldr r1, =0x3 ; //UART LINE CONFIG 正常模式,無奇偶校驗,一個停止位,8個數(shù)據(jù)位
- str r1, [r0]
- ldr r0, =UCON0 ;//設(shè)置Uart0控制器
- ldr r1, =0x245;//RX邊沿觸發(fā),TX電平觸發(fā),禁用延時中斷,使用RX 錯誤中斷,正常操作模式,中斷請求或表決模式
- str r1, [r0]
- ldr r0, =UBRDIV0 ;//設(shè)置波特率為115200
- ldr r1, =0x1a ;//int(50700000 / 16 / 115200) - 1 = 26
- str r1, [r0]
- mov r1, #100
- Delay
- sub r1, r1, #0x1
- bne Delay
- ;//開中斷
- ldr r0, =INTMSK
- ldr r1, [r0]
- and r1, r1, #0xefffffff
- str r1, [r0]
- MOV R5 , #127 ;//設(shè)置要打印的字符的個數(shù)
- MOV R1 , #0x0 ;//設(shè)置要打印的字符
- LOOP
- LDR R3 , =UTRSTAT0
- LDR R2 , [R3]
- TST R2 ,#0x04 ;//判斷發(fā)送緩沖區(qū)是否為空
- BEQ LOOP ;//為空則執(zhí)行下邊的語句,不為空則跳轉(zhuǎn)到LOOP
- LDR R0 , =UTXH0
- STR R1 ,[R0] ;//向數(shù)據(jù)緩沖區(qū)放置要發(fā)送的數(shù)據(jù)
- ADD R1, R1, #1
- SUB R5 ,R5, #0x01 ;//計數(shù)器減一
- CMP R5 ,#0x0
- BNE LOOP
- LOOP2 B LOOP2
這個緊跟隨這啟動代碼后面的一部分用匯編編的串口發(fā)送程序,設(shè)置相關(guān)寄存器,然后往PC端發(fā)送數(shù)據(jù)。
2017-3-7 01:36 上傳
