查看: 7586|回復(fù): 0
定時器的問題
ID:4834 發(fā)表于 2008-9-9 20:23 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
要求定時器可以實現(xiàn)三個時間的顯示,而且每個時間的初始值可以改變,完成硬件電路設(shè)計和軟件程序設(shè)計,需要完成硬件仿真。(依據(jù)見習(xí)時間來決定,實物可以暫時不做)
設(shè)計指標(biāo)參數(shù):
(1)    定時時間1。1s-99s,可調(diào)。
(2)    定時時間2。1s-99s,可調(diào)。
(3)    定時時間3。1min-99min,可調(diào)。
(4)    所有時間數(shù)字均可調(diào)。
(5)    用數(shù)碼管顯示剩余時間。
#include<reg52.h>
sbit p1=P2^3;
void keyscan(uchar z);
void delay(uchar k);
void display(uchar i);
void shezhi();
void playon();
uchar nummiaoge,nummiaoshi,numfenge,numfenshi,numshige,numshishi,tt,num;
uchar code table1[]={0x3f,
0x06,0x5b,0x4f,0x66,0x6d,
0x7d,0x07,0x7f,0x6f,0x77};
ding1h=keyscan(0);
ding1l=keyscan(1);
ding2h=keyscan(2);
ding2l=keyscan(3);
ding3h=keyscan(4);
ding3l=keyscan(5);
ding4h=keyscan(6);
ding4l=keyscan(7);
ding5h=keyscan(8);
ding5l=keyscan(9);
ding6h=keyscan(10);
ding6l=keyscan(11);
play=keyscan(12);
zanting=keyscan(13);
close=keyscan(14);
res=keyscan(15);
nummiaoge=P2^0;
nummiaoshi=P2^1;
numfenge=P2^2;
numfenshi=P2^3;
numshige=P2^4;
numshishi=P2^5;
 tt=0;
 TMOD=0x01;
 TH0=(65536-50000)/256;
 TL0=(65536-50000)%256;
 EA=1;
 ET0=1;
 TR0=1;
  shezhi();
  playon();
 uchar n;
 P1=0xfe;
 n=P1;
 n&=0xf0;
 if(n!=0xf0)
  delay();
  P1=0xfe;
  n=P1;
  n&=0xf0;
  if(n!=0xf0)
     switch(n)
        case(0xe0):display(0);break;
        case(0xd0):display(1);break;
        case(0xb0):display(2);break;
        case(0x70):display(3);break;
 P1=0xfd;
 n=P1;
 n&=0xf0;
 if(n!=0xf0)
  delay();
  P1=0xfd;
  n=P1;
  n&=0xf0;
  if(n!=0xf0)
      switch(n)
        case(0xe0):display(4);break;
        case(0xd0):display(5);break;
        case(0xb0):display(6);break;
        case(0x70):display(7);break;
 P1=0xfb;
 n=P1;
 n&=0xf0;
 if(n!=0xf0)
   delay();
   P1=0xfb;
   n=P1;
   n&=0xf0;
   if(n!=0xf0)
       switch(n)
         case(0xe0):display(8);break;
         case(0xd0):display(9);break;
         case(0xb0):display(10);break;
         case(0x70):display(11);break;
 P1=0xf7;
 n=P1;
 n&=0xf0;
 if(n!=0xf0)
   delay();
   P1=0xf7;
   n=P1;
   n&=0xf0;
   if(n!=0xf0)
       switch(n)
         case(0xe0):display(12);break;
         case(0xd0):display(13);break;
         case(0xb0):display(14);break;
         case(0x70):display(15);break;
 uchar table2[]={
 0xC0,0xF9,0xA4,0xB0,
 0x99,0x92,0x82,0xF8,
 0x80,0x90,0x88,0x83,
 0xC6,0xA1,0x86,0x8E};
 P2=0xfe;
 P0=table;
void delay(uchar k)
 uint x,y;
 for(x=100;x>0;x--)
  for(y=k;y>0;y--);
void shezhi()
 if(ding1h==0)
   nummiaoge++;
   if(nummiaoge==10)
    nummaioge=0;
 if(ding1l==0)
   nummiaoge--;
   if(nummiaoshi==-1)
    nummaioshi=9;
 if(ding2h==0)
   nummiaoshi++;
   if(nummiaoshi==10)
    nummiaoshi=0;
 if(ding2l==0)
   nummiaoshi--;
   if(nummiaoshi==-1)
    nummiaoshi=9;
 if(ding3h==0)
   numfensge++;
   if(numfenge==10)
    numfenge=0;
 if(ding3l==0)
   numfenge--;
   if(numfenge==-1)
    numfenge=9;
 if(ding4h==0)
   numfenshi++;
   if(numfenshi==10)
    numfenshi=0;
 if(ding4l==0)
   numfenshi--;
   if(numfenshi==-1)
    numfenshi=9;
 if(ding5h==0)
   numshige++;
   if(numshige==10)
    numshige=0;
 if(ding5l==0)
   numshige--;
   if(numshige=-1)
    numshige=9;
 if(ding6h==0)
   numshishi++;
   if(numshishi==10)
    numshishi=0;
 if(ding6l==0)
   numshishi--;
   if(numshishi==-1)
    numshishi=9;
void playon()
  nummiaoge--;
  if(nummiaoge==0)
    nummiaoshi=nummiaoshi-1;
    nummiaoge=9;
    if(nummiaoshi==0)
     numfenge=numfenge-1;
     nummiaoshi=9;
     if(numfenge==0)
      numfenshi=numfenshi-1;
      numfenge=9;
      if(numfenshi==0)
       numshige=numshige-1;
       numfenshi=9;
       if(numshige=0)
        numshishi=numshishi-1;
        numshige=9;
  if(numshishi,numshige,numfenshi,numfenge,nummiaoshi,nummiaoge==0)
   p1=1;
void exter0() interrupt 1
 tt++;
我有些東西還是不大懂,我不知道怎么樣去把鍵盤的16個鍵如何去控制6歌數(shù)碼管的加減!
